  3. About DS18B20 onewire.
dallasone wireonewireds18b20
48 Posts 5 Posters 19.2k Views 10 Watching
  • pepsonP pepson
    @flopp
    Hi
    Tell me... is any chance to add in sketch position to write description for sensor and to send this description to Home Assistant....? It is ok write in other sketch for relay and it works perfect:
    https://github.com/lkankowski/arduino-multi-relay/blob/master/arduino-multi-relay.ino
    It show in Home Assisnatn this information in description example: Ł2 - kinkiet [C10]
    @pepson yes. Just change the present call, just like in your sketch.
    Example: change
    present(i, S_HEATER);
    to
    present(i, S_HEATER, "Description goes here");
    pepsonP 2 Replies Last reply
      Example: change
      to
      pepsonP
      pepsonP
      pepson
      @mfalkvidd
      OK but also must add defined description to all address. But how add also description?
      rejoe2R 1 Reply Last reply
      • pepsonP pepson
        @mfalkvidd
        rejoe2R
        rejoe2R
        rejoe2
        @pepson said in About DS18B20 onewire.:
        @mfalkvidd
        Don't know, if that really works, because I never tested it since my controller sw supports comments: https://github.com/rejoe2/MySensors-Dallas-Address-ChildID-Consistency/blob/master/DallasTemperatureSimple/DallasTemperatureSimple.ino
        pepsonP 1 Reply Last reply
        • rejoe2R rejoe2
          @mfalkvidd
          pepsonP
          pepsonP
          pepson
          @rejoe2
          But where in sketch you define address and description ?
          • pepsonP pepson
            @rejoe2
            rejoe2R
            rejoe2R
            rejoe2
            @pepson That's not necessary: The sketch reads the bus to get all the necessary info and will just send whatever is found.
            If you want a "hardcoded version", you'd have to addopt the sketch for something in between these variants: if you use an array for the 1-wire addresses like https://github.com/rejoe2/MySensors-Dallas-Address-ChildID-Consistency/blob/master/Dallas_Addresses_Array_Solution/Dallas_Addresses_Array_Solution.ino does, just built the comment char-array based on that info.
            • rejoe2R rejoe2
              pepsonP
              pepsonP
              pepson
              @rejoe2 said in About DS18B20 onewire.:
              Ok i know how add to present description , but still dont know how add description to each sensors.... as in sketch for relay as i show as example.
              • pepsonP pepson
                rejoe2R
                rejoe2R
                rejoe2
                @pepson I'd suggest you make a test with the "simple" variant of the sketches. Then we could lateron discuss how to deal with an array containing the hardcoded addresses.
                Pls. make also a test with the hardcoded version. Afai remember, it will print the needed array to serial, as long as #define PRINT_ARRAY isn't commented.
                  Example: change
                  to
                  pepsonP
                  pepsonP
                  pepson
                  @mfalkvidd Can you help me... or change it ?
                  • F flopp
                     * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
                     * http://www.mysensors.org/build/temp
                    #define MY_NODE_ID 14
                    #define COMPARE_TEMP 0 // Send temperature only if changed? 1 = Yes 0 = No
                    #define ATTACHED_DS18B20 40
                    unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
                    byte D[ATTACHED_DS18B20][8] = {
                    { 0x10, 0x04, 0xB8, 0x3F, 0x02, 0x08, 0x00, 0xBD }, //KökTbx
                    { 0x10, 0xF4, 0xD7, 0x3F, 0x02, 0x08, 0x00, 0xB1 }, //UppTbx
                    { 0x10, 0x92, 0x9F, 0x3E, 0x02, 0x08, 0x00, 0x98 }, //KökUt
                    { 0x10, 0x4E, 0xE4, 0x3E, 0x02, 0x08, 0x00, 0x3C }, //ToaUt
                    { 0x10, 0x1E, 0xE8, 0x3E, 0x02, 0x08, 0x00, 0x33 }, //EfterPump
                    { 0x10, 0x09, 0xA1, 0x3E, 0x02, 0x08, 0x00, 0xF7 }, //HallTbx
                    { 0x10, 0x59, 0xCB, 0x3F, 0x02, 0x08, 0x00, 0xFA }, //UppUt
                    { 0x10, 0x07, 0x1B, 0x3F, 0x02, 0x08, 0x00, 0x99 }, //ToaTbx
                    { 0x28, 0xFF, 0xB1, 0xAA, 0x63, 0x15, 0x03, 0xC8 }, //Kök
                    { 0x10, 0x80, 0xB6, 0x3F, 0x02, 0x08, 0x00, 0x29 }, //Panna komp
                    { 0x10, 0x3C, 0x9C, 0x3E, 0x02, 0x08, 0x00, 0x99 }, //Hall ut
                    { 0x10, 0x42, 0xE0, 0x3F, 0x02, 0x08, 0x00, 0xD1 }, //Tvätt
                    { 0x10, 0xCE, 0xE9, 0x3E, 0x02, 0x08, 0x00, 0x3A }, //T12
                    { 0x10, 0x99, 0xAC, 0x3F, 0x02, 0x08, 0x00, 0x25 }, //V mellan
                    { 0x10, 0x15, 0xDB, 0x3E, 0x02, 0x08, 0x00, 0x01 }, //Hallen
                    { 0x10, 0xF3, 0xD7, 0x3F, 0x02, 0x08, 0x00, 0x34 }, //Panna El
                    { 0x10, 0xFB, 0xCB, 0x3F, 0x02, 0x08, 0x00, 0xC8 }, //Toa Nere
                    { 0x10, 0x97, 0x23, 0x3F, 0x02, 0x08, 0x00, 0x92 }, //Varmvatten
                    { 0x10, 0x0F, 0xE6, 0x3E, 0x02, 0x08, 0x00, 0xFD }, //Carport
                    { 0x10, 0xF3, 0xC6, 0x3F, 0x02, 0x08, 0x00, 0x85 }, //Förrådet
                    { 0x10, 0x9C, 0x3B, 0x52, 0x02, 0x08, 0x00, 0x25 }, //Mark 60
                    { 0x10, 0xF2, 0x24, 0x3F, 0x02, 0x08, 0x00, 0xEB }, //Vrum V
                    { 0x10, 0x6A, 0x5E, 0x52, 0x02, 0x08, 0x00, 0x26 }, //Mark 30
                    { 0x10, 0x76, 0xCE, 0x3F, 0x02, 0x08, 0x00, 0xBA }, //Plattan
                    { 0x10, 0x0E, 0x7B, 0x13, 0x02, 0x08, 0x00, 0x7C }, //Utetemp
                    { 0x10, 0xEE, 0xEB, 0x3E, 0x02, 0x08, 0x00, 0x0F }, //Uterum
                    { 0x28, 0x8C, 0x2D, 0xB4, 0x04, 0x00, 0x00, 0x9C }, //Kyl uppe
                    { 0x28, 0xFF, 0xB2, 0x74, 0x63, 0x15, 0x02, 0xCC }, //Kyl mitten
                    { 0x28, 0xFF, 0x08, 0x07, 0x52, 0x04, 0x00, 0xFF }, //Kyl nere
                    { 0x28, 0xFF, 0xE6, 0x06, 0x52, 0x04, 0x00, 0x08 }, //Frys uppe
                    { 0x28, 0xFF, 0xB4, 0x07, 0x55, 0x04, 0x00, 0xEB }, //Kyl bakom
                    { 0x10, 0x1C, 0xA8, 0x3F, 0x02, 0x08, 0x00, 0x3B }, //Lucas
                    { 0x10, 0x83, 0x3C, 0x3F, 0x02, 0x08, 0x00, 0x06 }, //Allrum
                    { 0x10, 0xA3, 0xE8, 0x3E, 0x02, 0x08, 0x00, 0x7E }, //Theo
                    { 0x10, 0x33, 0x3C, 0x3F, 0x02, 0x08, 0x00, 0x01 }, //Sovrum
                    { 0x28, 0xFF, 0xFB, 0x3D, 0xC3, 0x16, 0x03, 0x58 }, //Panna luft in(varm)
                    { 0x28, 0xFF, 0xD4, 0x1C, 0x00, 0x17, 0x03, 0x43 }, //Dränering
                    { 0x28, 0xFF, 0x97, 0x11, 0x01, 0x15, 0x04, 0xC0 } // Poolvatten
                    float lastTemperature[ATTACHED_DS18B20];
                    MyMessage msg(0,V_TEMP);
                    MyMessage heat(0,V_STATUS);
                      sensors.begin();
                      sendSketchInfo("OneWire Temp+Heating LED", "20180709");
                      //numSensors = sensors.getDeviceCount();
                      for (int i=0; i<ATTACHED_DS18B20; i++) {
                         present(i, S_TEMP);
                      for (int i=ATTACHED_DS18B20; i<ATTACHED_DS18B20+5; i++) {
                      sleep(conversionTime);
                      //Serial.println(sensors.getResolution(D[i]), DEC);
                     //   float temperature = static_cast<float>(static_cast<int>((sensors.requestTemperaturesByAddress(D[i])) * 10.)) / 10.;
                          float temperature = sensors.getTempC(D[i]);
                        #if COMPARE_TEMP == 1
                        if (temperature != -127.00 && temperature <= 85.00) {
                       for (int i=0; i<5;i++){
                        int value = analogRead(i);
                        /*Serial.print("Pin");
                        Serial.print(i);
                        Serial.print("=");
                        Serial.println(value);
                        int j=i+ATTACHED_DS18B20;
                        if (value>150) {
                          send(heat.setSensor(j).set(1));
                        else {
                          send(heat.setSensor(j).set(0));
                      sleep(SLEEP_TIME);
                    pepsonP
                    pepsonP
                    pepson
                    @flopp said in About DS18B20 onewire.:
                      sensors.begin();
                         present(i, S_TEMP);
                        Serial.print(i);
                        Serial.print("=");
                        if (value>150) {
                        else {
                      sleep(SLEEP_TIME);
                    When i try compile this sketch it get me error:
                    C:\Users\Piotrek\Desktop\Temp dallas\Arduino_dallas_18B20_with_desc\Arduino_dallas_18B20_with_desc.ino: In function 'void presentation()':
                    Arduino_dallas_18B20_with_desc:117:3: error: expected initializer before 'sensors'
                    exit status 1
                    • pepsonP pepson
                        sensors.begin();
                           present(i, S_TEMP);
                          Serial.print(i);
                          Serial.print("=");
                          if (value>150) {
                          else {
                        sleep(SLEEP_TIME);
                      exit status 1
                      #43
                      @pepson you have a stray } after setWaitForConversion
                      Tip: use ctrl+t in the editor to easier see this type of mistake
                        pepsonP
                        pepsonP
                        pepson
                        @mfalkvidd
                        Still is problem after use CTRL+T
                           DESCRIPTION
                        #define MY_GATEWAY_SERIAL
                        MyMessage msg(0, V_TEMP);
                        MyMessage heat(0, V_STATUS);
                          sensors.begin();
                          for (int i = 0; i < ATTACHED_DS18B20; i++) {
                            present(i, S_TEMP);
                          for (int i = ATTACHED_DS18B20; i < ATTACHED_DS18B20 + 5; i++) {
                              send(msg.setSensor(i).set(temperature, 1));
                              lastTemperature[i] = temperature;
                          for (int i = 0; i < 5; i++) {
                              Serial.print(i);
                              Serial.print("=");
                            int j = i + ATTACHED_DS18B20;
                            if (value > 150) {
                            else {
                          sleep(SLEEP_TIME);
                        exit status 1
                        • pepsonP pepson
                          @mfalkvidd
                             DESCRIPTION
                            sensors.begin();
                              present(i, S_TEMP);
                                Serial.print(i);
                                Serial.print("=");
                              if (value > 150) {
                              else {
                            sleep(SLEEP_TIME);
                          exit status 1
                          @pepson you’re missing a } before start of loop.
                            pepsonP
                            pepsonP
                            pepson
                            @mfalkvidd
                            Where ? please show me more.... :( i am beginner
                            • pepsonP pepson
                              @mfalkvidd
                              pepsonP
                              pepsonP
                              pepson
                              @pepson ok fixed it :)
                              • pepsonP
                                pepsonP
                                pepson
                                But.... Can you also help me to add to this sketch option to send to example to Home Assistant also DESCRIPTION to each sensors ? And description will be get from sketch from name about address sensor ?
                                As in this sketch which i have for relay:
                                #define USE_EXPANDER
                                #ifdef USE_EXPANDER
                                  #include <Wire.h>    // Required for I2C communication
                                  #include "PCF8574.h"
                                  uint8_t expanderAddresses[] = {0x20};
                                  const int numberOfExpanders = sizeof(expanderAddresses);
                                  PCF8574 expander[numberOfExpanders];
                                  #define E(expanderNo, ExpanderPin) (((expanderNo+1)<<8) | (ExpanderPin))
                                // No Button Constant
                                #define NOB -1
                                #define MULTI_RELAY_VERSION 9
                                #define RELAY_STATE_STORAGE 1
                                const uint8_t RELAY_TRIGGER_LOW  = 0;
                                const uint8_t RELAY_TRIGGER_HIGH = 1;
                                const uint8_t RELAY_STARTUP_ON   = 2;
                                const uint8_t RELAY_STARTUP_OFF  = 4;
                                const uint8_t RELAY_STARTUP_MASK = RELAY_STARTUP_ON | RELAY_STARTUP_OFF;
                                enum ButtonType {
                                  MONO_STABLE = 0,
                                  BI_STABLE = 1,
                                  DING_DONG = 2 // HIGH state immediatly after push, LOW state after release
                                typedef struct {
                                  int sensorId;
                                  int relay;
                                  int button;
                                  uint8_t relayOptions;
                                  ButtonType buttonType;
                                  const char * relayDescription;
                                } RelayButton;
                                // CONFIGURE ONLY THIS ARRAY!
                                // Row params: sensor ID - sensor ID reported on MySensor Gateway
                                //             relay pin - Expander supported
                                //             button pin - <0 for virtual buttons (only available in MySensor Gateway); no support for Expander
                                //             relay options - [RELAY_TRIGGER_LOW|RELAY_TRIGGER_HIGH] {RELAY_STARTUP_ON|RELAY_STARTUP_OFF}
                                //             button type - [MONO_STABLE|BI_STABLE|DING_DONG]
                                //             relay description - reported on MySensor Gateway, can help identify device on initial configuration in Home Automation App, can be empty ("")
                                RelayButton myRelayButtons[] = {
                                  {0, 2, A0, RELAY_TRIGGER_LOW, MONO_STABLE, "Ł2 - kinkiet [C10]"},  // WŁ: Ł2
                                  {1, 16, A1, RELAY_TRIGGER_LOW, BI_STABLE, "Salon 2 [A9]"},  // WŁ: Salon 2
                                  {2, 15, A2, RELAY_TRIGGER_LOW, BI_STABLE, "Salon 1 [A10]"},  // WŁ: Salon 1
                                  {3, E(0,1), A3, RELAY_TRIGGER_LOW | RELAY_STARTUP_OFF, BI_STABLE, "Halogen - Taras [B8]"},  // WŁ: Taras
                                  {4, 22, A4, RELAY_TRIGGER_LOW, BI_STABLE, "Kuchnia [B2]"},  // WŁ: Kuchnia 1
                                  {5, 23, A5, RELAY_TRIGGER_LOW, BI_STABLE, "Kuchnia - Kinkiet [B3]"},  // WŁ: Kuchnia 2
                                  {6, 28, A6, RELAY_TRIGGER_LOW, BI_STABLE, "Jadalnia 2 [A4]"},  // WŁ: Hall I/Jadalnia prawy
                                  {17, 17, A7, RELAY_TRIGGER_LOW, BI_STABLE, "Ł1 - Kinkiet [A11]"},  // WŁ: Hall I/Ł1 prawy
                                  {8, 31, A8, RELAY_TRIGGER_LOW, MONO_STABLE, "Garaż [A7]"},  // WŁ: Kotłownia/Garaż
                                  {8, 31, A9, RELAY_TRIGGER_LOW, MONO_STABLE, "Garaż [A7]"},  // WŁ: Garaż
                                  {10, 14, A10, RELAY_TRIGGER_LOW | RELAY_STARTUP_ON, BI_STABLE, "Halogen - wejście [B4]"},  // WŁ: Drzwi wejściowe
                                  {11, E(0,7), A11, RELAY_TRIGGER_LOW, DING_DONG, "Dzwonek [?]"},  // WŁ: Dzwonek
                                  {12, 29, A12, RELAY_TRIGGER_LOW, BI_STABLE, "Hall 1 [A5]"},  // WŁ: Hall I/Jadalnia lewy
                                  {12, 29, A13, RELAY_TRIGGER_LOW, BI_STABLE, "Hall 1 [A5]"},  // WŁ: Hall I/Wiatrołap
                                  {14, 32, A14, RELAY_TRIGGER_LOW, BI_STABLE, "Wiatrołap [A8]"},  // WŁ: Wiatrołap/Hall I
                                  {15, 19, A15, RELAY_TRIGGER_LOW, MONO_STABLE, "Kotłownia [B1]"},  // WŁ: Kotłownia/Hall I
                                  {16, 24, 53, RELAY_TRIGGER_LOW, BI_STABLE, "Ł1 - Taśma LED [C1]"},  // WŁ: Hall I/Ł1 środek
                                  {17, 17, 52, RELAY_TRIGGER_LOW, MONO_STABLE, "Ł1 - Kinkiet [A11]"},  // WŁ: Ł1
                                  {18, 18, 51, RELAY_TRIGGER_LOW, BI_STABLE, "Ł1 [A12]"},  // WŁ: Hall I/Ł1 lewy
                                  {19, 6, 50, RELAY_TRIGGER_LOW, BI_STABLE, "Klatka Schodowa [B7]"},  // WŁ: Hall I/Schody 1
                                  {12, 29, 49, RELAY_TRIGGER_LOW, BI_STABLE, "Hall 1 [A5]"},  // WŁ: Hall I/Schody 2
                                  {21, 26, 48, RELAY_TRIGGER_LOW, BI_STABLE, "Gabinet [A2]"},  // WŁ: Gabinet
                                  {22, 7, 47, RELAY_TRIGGER_LOW, BI_STABLE, "Hall 2 [B5]"},  // WŁ: Hall II/Schody 1
                                  {19, 6, 46, RELAY_TRIGGER_LOW, BI_STABLE, "Klatka Schodowa [B7]"},  // WŁ: Hall II/Schody 2
                                  {24, 10, 45, RELAY_TRIGGER_LOW, BI_STABLE, "Garderoba [C12]"},  // WŁ: Garderoba
                                  {25, 4, 44, RELAY_TRIGGER_LOW, MONO_STABLE, "Pok. nad kuchnią 2 [B10]"},  // WŁ: Pok. nad kuchnią 2
                                  {26, 5, 43, RELAY_TRIGGER_LOW, BI_STABLE, "Pok. nad kuchnią 1 [B9]"},  // WŁ: Pok. nad kuchnią 1
                                  {27, 8, 42, RELAY_TRIGGER_LOW, BI_STABLE, "Pok. nad salonem 2 [B12]"},  // WŁ: Pok. nad salonem 2
                                  {28, 9, 41, RELAY_TRIGGER_LOW, MONO_STABLE, "Pok. nad salonem 1 [B11]"},  // WŁ: Pok. nad salonem 1
                                  {29, 3, 40, RELAY_TRIGGER_LOW, BI_STABLE, "Ł2 [C7]"},  // WŁ: Hall II/Ł2 1
                                  {30, E(0,3), 39, RELAY_TRIGGER_LOW, BI_STABLE, "Ł2 - Taśma LED [?]"},  // WŁ: Hall II/Ł2 2
                                  {22, 7, 38, RELAY_TRIGGER_LOW, BI_STABLE, "Hall 2 [B5]"},  // WŁ: Hall II/Sypialnia
                                  {32, 11, 37, RELAY_TRIGGER_LOW, BI_STABLE, "Sypialnia 2 [C9]"},  // WŁ: Sypialnia 2
                                  {33, 12, 36, RELAY_TRIGGER_LOW, BI_STABLE, "Sypialnia 1 [C8]"},  // WŁ: Sypialnia 1
                                  {34, 25, -1, RELAY_TRIGGER_LOW | RELAY_STARTUP_ON, MONO_STABLE, "Halogen - Garaż [A1]"},  // WŁ: Virtual Button 1
                                  {35, 30, -2, RELAY_TRIGGER_LOW | RELAY_STARTUP_OFF, MONO_STABLE, "Ł1 - Wentylator [A3]"},  // WŁ: Virtual Button 2
                                  {36, E(0,2), -3, RELAY_TRIGGER_LOW | RELAY_STARTUP_OFF, MONO_STABLE, "Halogen - wschód [B6]"},  // WŁ: Virtual Button 3
                                  {37, E(0,4), -4, RELAY_TRIGGER_LOW, MONO_STABLE, "Lampki schodowe [C6]"},  // WŁ: Virtual Button 4
                                  {38, E(0,5), -5, RELAY_TRIGGER_LOW, MONO_STABLE, "Lampki podłogowe I [C4]"},  // WŁ: Virtual Button 5
                                  {39, E(0,6), -6, RELAY_TRIGGER_LOW, MONO_STABLE, "Lampki podłogowe II [C2]"},  // WŁ: Virtual Button 6
                                  {40, E(0,0), -7, RELAY_TRIGGER_LOW | RELAY_STARTUP_OFF, MONO_STABLE, "Ł2 - wentylator [C11]"},  // WŁ: Virtual Button 7
                                const int numberOfRelayButtons = sizeof(myRelayButtons) / sizeof(RelayButton);
                                typedef struct {
                                  int firstButton;
                                  int nextButton;
                                } RelayMultiButtons;
                                RelayMultiButtons relayMultiButtons[numberOfRelayButtons];
                                uint8_t myRelayState[numberOfRelayButtons];
                                // MySensors - Sending Data
                                // To send data you have to create a MyMessage container to hold the information.
                                MyMessage msgs[numberOfRelayButtons];
                                Bounce myButtonDebouncer[numberOfRelayButtons];
                                //Function Declaration
                                uint8_t loadRelayState(int relayNum, uint8_t forceEeprom = 0);
                                void saveRelayState(int relayNum, uint8_t state, uint8_t useEeprom);
                                void saveRelayState(int relayNum, uint8_t state);
                                void changeRelayState(int relayNum, uint8_t relayState);
                                // MySensors - This will execute before MySensors starts up
                                void before() {
                                  #ifdef USE_EXPANDER
                                    /* Start I2C bus and PCF8574 instance */
                                    for(int i = 0; i < numberOfExpanders; i++) {
                                      expander[i].begin(expanderAddresses[i]);
                                  // initialize multiple buttons list structure
                                  for (int i = 0; i < numberOfRelayButtons; i++) {
                                    relayMultiButtons[i].firstButton = -1;
                                    relayMultiButtons[i].nextButton = -1;
                                  // find multiple buttons for the same relay (uni-directional list)
                                  for (int i = 0; i < numberOfRelayButtons-1; i++) {
                                    if (relayMultiButtons[i].firstButton == -1) {
                                      int prevRelayButton = i;
                                      for (int j = i+1; j < numberOfRelayButtons; j++) {
                                        if (myRelayButtons[i].relay == myRelayButtons[j].relay) {
                                          relayMultiButtons[prevRelayButton].firstButton = i;
                                          relayMultiButtons[prevRelayButton].nextButton = j;
                                          relayMultiButtons[j].firstButton = i;
                                          prevRelayButton = j;
                                  // if version has changed, reset state of all relays
                                  int versionChangeResetState = (MULTI_RELAY_VERSION == loadState(0) ) ? 0 : 1;
                                    // if this relay has multiple buttons, load only first
                                    if (relayMultiButtons[i].firstButton == -1 || relayMultiButtons[i].firstButton == i) {
                                      #ifdef USE_EXPANDER
                                        if ( myRelayButtons[i].relay & 0xff00 ) {
                                          // EXPANDER
                                          int expanderNo = (myRelayButtons[i].relay >> 8) - 1;
                                          int expanderPin = myRelayButtons[i].relay & 0xff;
                                          expander[expanderNo].pinMode(expanderPin, OUTPUT);
                                          pinMode(myRelayButtons[i].relay, OUTPUT);
                                      #ifdef USE_EXPANDER
                                      uint8_t isTurnedOn = 0;
                                      if (myRelayButtons[i].relayOptions & RELAY_STARTUP_ON) {
                                        isTurnedOn = 1;
                                      } else if (myRelayButtons[i].relayOptions & RELAY_STARTUP_OFF) {
                                        isTurnedOn = loadRelayState(i, 1); // 1 - true, 0 - false
                                        if (versionChangeResetState && isTurnedOn) {
                                          saveRelayState(i, 0, 1);
                                          isTurnedOn = 0;
                                      changeRelayState(i, isTurnedOn);
                                      myRelayState[i] = isTurnedOn;
                                  if (versionChangeResetState) {
                                    // version has changed, so store new version in eeporom
                                    saveState(0, MULTI_RELAY_VERSION);
                                // executed AFTER mysensors has been initialised
                                  for(int i = 0; i < numberOfRelayButtons; i++) {
                                    if (myRelayButtons[i].button >= 0) {
                                      // No Expander support for buttons (de-bouncing)
                                      pinMode(myRelayButtons[i].button, INPUT_PULLUP); // HIGH state when button is not pushed
                                  delay(5000);
                                  // Send state to MySensor Gateway
                                    // if this relay has multiple buttons, send only first
                                      msgs[i] = MyMessage(myRelayButtons[i].sensorId, V_LIGHT);
                                      uint8_t relayState;
                                        relayState = 1;
                                        relayState = 0;
                                        relayState = loadRelayState(i);
                                      send(msgs[i].set(relayState)); // send current state
                                  // Setup buttons
                                      // setup debouncer
                                      myButtonDebouncer[i] = Bounce();
                                      myButtonDebouncer[i].attach(myRelayButtons[i].button);
                                      myButtonDebouncer[i].interval(50);
                                    if (myRelayButtons[i].button >= 0 && myButtonDebouncer[i].update()) {
                                      int buttonState = myButtonDebouncer[i].read();
                                      #ifdef MY_DEBUG
                                        Serial.print("# Button ");
                                        Serial.print(i);
                                        Serial.print(" changed to: ");
                                        Serial.println(buttonState);
                                      int relayNum = (relayMultiButtons[i].firstButton == -1) ? i : relayMultiButtons[i].firstButton;
                                      if (myRelayButtons[i].buttonType == DING_DONG) {
                                        if (buttonState == LOW) { // button pressed
                                          changeRelayState(relayNum, 1);
                                          send(msgs[relayNum].set(1));
                                        } else { // button released
                                          changeRelayState(relayNum, 0);
                                          send(msgs[relayNum].set(0));
                                      } else if (myRelayButtons[i].buttonType == BI_STABLE || buttonState == HIGH) {
                                        // If button type is BI_STABLE, any change will toggle relay state
                                        // For MONO_STABLE, button must be pushed and released (HIGH)
                                        uint8_t isTurnedOn = ! loadRelayState(relayNum); // 1 - true, 0 - false
                                        changeRelayState(relayNum, isTurnedOn);
                                        send(msgs[relayNum].set(isTurnedOn));
                                        saveRelayState(relayNum, isTurnedOn);
                                // MySensors - Presentation
                                // Your sensor must first present itself to the controller.
                                // The presentation is a hint to allow controller prepare for the sensor data that eventually will come.
                                // Executed after "before()" and before "setup()" in: _begin (MySensorsCore.cpp) > gatewayTransportInit() > presentNode()
                                  sendSketchInfo("Multi Relay", "1.2");
                                  // Register every relay as separate sensor
                                    // if this relay has multiple buttons, register only first
                                      // void present(uint8_t childSensorId, uint8_t sensorType, const char *description, bool ack);
                                      //   childSensorId - The unique child id you want to choose for the sensor connected to this Arduino. Range 0-254.
                                      //   sensorType - The sensor type you want to create.
                                      //   description An optional textual description of the attached sensor.
                                      //   ack - Set this to true if you want destination node to send ack back to this node. Default is not to request any ack.
                                      present(myRelayButtons[i].sensorId, S_BINARY, myRelayButtons[i].relayDescription);
                                // MySensors - Handling incoming messages
                                // Nodes that expects incoming data, such as an actuator or repeating nodes,
                                // must implement the receive() - function to handle the incoming messages.
                                // Do not sleep a node where you expect incoming data or you will lose messages.
                                    uint8_t isTurnedOn = message.getBool(); // 1 - true, 0 - false
                                    changeRelayState(message.sensor, isTurnedOn);
                                    // Store state in eeprom if changed
                                    if (loadRelayState(message.sensor) != isTurnedOn) {
                                      saveRelayState(message.sensor, isTurnedOn);
                                    send(msgs[message.sensor].set(isTurnedOn)); // support for OPTIMISTIC=FALSE (Home Asistant)
                                    #ifdef MY_DEBUG
                                      Serial.print("# Incoming change for sensor: " + message.sensor);
                                      Serial.println(", New status: " + isTurnedOn);
                                uint8_t loadRelayState(int relayNum, uint8_t forceEeprom) {
                                  uint8_t relayState;
                                  if (forceEeprom) {
                                    relayState = loadState(RELAY_STATE_STORAGE + relayNum);
                                    relayState = myRelayState[relayNum];
                                  #ifdef MY_DEBUG
                                    Serial.print("# loadRelayState: ");
                                    Serial.print(relayNum);
                                    if (forceEeprom) {
                                      Serial.print("(byte ");
                                      Serial.print(RELAY_STATE_STORAGE + relayNum);
                                      Serial.print(")");
                                    Serial.print(" = ");
                                    Serial.println(relayState);
                                  return(relayState);
                                void saveRelayState(int relayNum, uint8_t state, uint8_t useEeprom) {
                                  int mainRelayNum = (relayMultiButtons[relayNum].firstButton == -1) ? relayNum : relayMultiButtons[relayNum].firstButton;
                                  myRelayState[mainRelayNum] = state;
                                  if (useEeprom && (relayNum == mainRelayNum)) {
                                    saveState(RELAY_STATE_STORAGE + mainRelayNum, state);
                                  int nextButton = mainRelayNum;
                                  // update all buttons
                                  while ((nextButton = relayMultiButtons[nextButton].nextButton) != -1) {
                                    myRelayState[nextButton] = state;
                                void saveRelayState(int relayNum, uint8_t state) {
                                  uint8_t useEeprom = ((myRelayButtons[relayNum].relayOptions & RELAY_STARTUP_MASK) == 0);
                                  saveRelayState(relayNum, state, useEeprom);
                                void changeRelayState(int relayNum, uint8_t relayState) {
                                  uint8_t relayTrigger = myRelayButtons[relayNum].relayOptions & RELAY_TRIGGER_HIGH;
                                  uint8_t digitalOutState = relayState ? relayTrigger : ! relayTrigger;
                                  #ifdef USE_EXPANDER
                                    if ( myRelayButtons[relayNum].relay & 0xff00 ) {
                                      int expanderNo = (myRelayButtons[relayNum].relay >> 8) - 1;
                                      int expanderPin = myRelayButtons[relayNum].relay & 0xff;
                                      expander[expanderNo].digitalWrite(expanderPin, digitalOutState);
                                    digitalWrite(myRelayButtons[relayNum].relay, digitalOutState);
                                  #ifdef USE_EXPANDER
                                And in Home assistant show example decription: Ł2 - kinkiet [C10] or for second Salon 2 [A9] etc.
                                Please help me... because it will be good to identify sensors when add to Controller.
                                12.5k
