  3. ds18b20 on 2xAAA battery
34 Posts 10 Posters 6.2k Views 8 Watching
  • pihomeP Offline
    pihomeP Offline
    pihome
    Hi All,
    i have nodes running on 18650 battery on Arduino mini pro 8mhz (3.3v) without much modification or any low power bootloader but now i want to switch to AAA battery to keep everything tidy and need but one issue ds18b20 requires 3.3v whereas 2xAAA can supply 3v, now million dollar question is what you guys doing to supply 3.3v to ds18b20? boost converter consume power as well and all on ebay/aliexpress ones are seems very power hungry (Quiescent current 13uA).
    https://www.aliexpress.com/item/32800430445.html?spm=2114.search0104.3.219.5b3d1a25h7pRRv&ws_ab_test=searchweb0_0%2Csearchweb201602_2_10065_10068_319_10059_10884_317_10887_10696_321_322_10084_453_10083_454_10103_10618_10304_10307_10820_10821_537_10302_536%2Csearchweb201603_51%2CppcSwitch_0&algo_expid=e6ec65d0-b780-4c66-b06a-52134fa6c454-31&algo_pvid=e6ec65d0-b780-4c66-b06a-52134fa6c454&transAbTest=ae803_3
    i m thinking to find alternate to ds18b20 that can run reliably on 2v,
    any thoughts or suggestions?
    PiHome - Smart Heating Control
    mfalkviddM zboblamontZ K T 4 Replies Last reply
    • pihomeP pihome
      Hi All,
      @pihome https://forum.mysensors.org/topic/3801/witch-temp-hum-sensor-is-best-to-use-for-battery-powered-sensors/ and the linked study is a good source.
      • pihomeP pihome
        Hi All,
        zboblamontZ Offline
        zboblamontZ Offline
        zboblamont
        @pihome
        The advantage of the ds18b20 is the one-wire topology, 12 of them here on cat5e to a single node (PSU with 2AA backup), short of installing 12 nodes I found no better option, but your install is undoubtedly different.
        Would it not be worth re-examining the power options or other methods of extending battery life or is reduced volume such a big issue?
        AAA v AA is not a massive difference in size, but a BIG difference in mAh...
        Your Pro-mini will need modified for lower voltage unless it and a booster is powered on/off externally (timer?) but this adds to bulk.
        If the Pro-mini is running purely on battery power, why not switch on/off the booster the dsb20 and a level converter? The power draw should be minimal for such short duration.
        • pihomeP pihome
          Hi All,
          K Offline
          K Offline
          kimot
          @pihome
          very power hungry (Quiescent current 13uA) ?
          And do you know, that with AAA (1000 mAh) it is 8 years in standby?
          Maybe self discharge is greater.
          Alternetively use 3xAAA with low quiescent current 3.3V LDO.
          • pihomeP Offline
            pihomeP Offline
            pihome
            i have done some testing for power consumption, these enamourments are taken using cheap chines multimeter.
            Power consumption when powered by 18650 battery with onboard regulator and power and pin 13 led removed without any further modification:
            18.11 mA startup
            66.9 uA during sleeping
            3.01 mA during Transmission
            Pro mini with 1mhz bootloader and on board regulator/LED removed:
            14.42 mA startup
            7.50 uA during sleeping
            1.40 mA during Transmission
            @zboblamont, i was thinking the same to power on/off boost converter to save some battery. but need to test this and may be integrate boost converter into my pcb.
            @kimot, sorry haven't checked self discharge of any battery also i m trying to fit this temperature sensors in
            small box
            i would prefer to use ds18b20 sensors but also if battery works for 1 to 1.5 years i m happy with that. any suggestion on boost converter?
            • pihomeP pihome
              18.11 mA startup
              14.42 mA startup
              small box
              zboblamontZ Offline
              zboblamontZ Offline
              zboblamont
              @pihome I have such an arrangement using a small 3v latching dpdt relay to battery feed a 5v booster/ultrasonic/level-converter arrangement, but in my case the pro-mini's onboard booster provides a solid 3.3v and the external crystal runs it at 16MHz, not sure how in your case you could reliably fire a 3v relay with a declining voltage. The trade-offs of detuning a pro-mini to run on low voltage are not necessarily applicable now compared to when Arduino projects were in their infancy. Yes, it works, but it is no longer the only way.
              I selected this product as it preserved full 16MHz 3.3v capabilities in preference to DIY detuning and modifying a cheap pro-mini, no regrets or magic smoke with hobby skills from the valve-era, and thumbs like mallets :stuck_out_tongue_winking_eye: . Aged eyesight is not a problem with 4xc250b's.
              At 6 months in the 2xAA alkalines are on 2.93v, and should nosedive around the 1.7v mark, so well over a year is probable.
              There is nothing exotic about the board's booster circuit component-wise to my limited knowledge, so it is likely available somewhere, just not necessarily cheap from China.
              By way of contrast - the node monitoring the gas meter (no external power demand - reed activated) is running over a year now with the 2xAA batteries still reading 2.95v. I will be interested but not surprised to see it run another year.. - PS They all have onboard RFM69s...
              My point is that there must be equally efficient boosters out there to buy in or DIY, you don't have to change the car because the ash-tray's full.. ;
              • pihomeP Offline
                pihomeP Offline
                pihome
                @zboblamont, i love your analogy about ash-try in car.
                i just feed arduino with 1mhz bootloader through raw pin with 2xAAA batteries (i know it was very long shot) and it didnt work onboard regulator can not supply enough voltage to ds18b20, but sure i need to look into boost converter.
                before i dive into boost convert i wanted to ask what others are doing and how they are managing voltage for voltage hungry sensors. i have found few examples on openhardware.io all of them are by @NeverDie
                mfalkviddM K 2 Replies Last reply
                • pihomeP pihome
                  @pihome a "low-tech" solution is to use 2xAA to power the mcu and another AA to power the temperature sensor as described by yveaux here. Maybe even use 2xAA and another AAA.
                  • pihomeP Offline
                    pihomeP Offline
                    pihome
                    @mfalkvidd having multiple batteries in confined space isn't option.
                    i m leaning towards this Boost Converter
                    • nagelcN Offline
                      nagelcN Offline
                      nagelc
                      Do you even need to boost? I have several ds18b20 nodes running on 2 AA batteries with a ProMini 8Mhz and basic low power mods. Wired like here: https://www.mysensors.org/build/temp
                      I get nearly 2 years on a set of batteries. The ds18b20 seem to work fine at the lower voltages, but I have not tested them rigorously. The output just seems about right.
                      • pihomeP Offline
                        pihomeP Offline
                        pihome
                        @nagelc,
                        you AA batteries must be 1.6 or above voltage, as mine had same voltage, in other words when new batteries were supplying 1.6v/AAA it was working fine as soon as voltage dropped to 3.0 temperature sensors stoped, node is sending battery voltage which mean node and radio working fine but ds18b20 stopped.
                        • pihomeP pihome
                          K Offline
                          K Offline
                          kimot
                          @pihome
                          said in ds18b20 on 2xAAA battery:
                          One useful "switch" you have got on your PRO MINI.
                          My from ebay has got LDO marked LG33, which is MIC5219 LDO with shutdown pin capability.
                          So remove one from arduino hacked for ultra low consumption and use it for switch power hungry sensors.
                          Or only unsolder and bend up from pcb output and shutdown pin of LDO.
                          Then you can use 3AAA to power directly VCC ( 4.5V ). Connect this to RAW pin ( input LDO ) too.
                          Your sensors connect to unsoldered LDO output pin and shutdown pin connect with some output IO to drive your sensors ON/OFF.
                          Problem can be, that sensors run on 3.3V and your Arduino runs on 4.5V.
                          So you can put some diodes in series between battery and Vcc pin. Each diode ( not LED ) drops about 0.6V ( try different diodes ).
                          Another interesting idea with this LDO can be seen here:
                          https://forum.arduino.cc/index.php?topic=360996.15
                          • pihomeP Offline
                            pihomeP Offline
                            pihome
                            so far i have temperature sensors running on 18650 battery by feeding to raw pin on arduino and it works fine now i'm switching to 2xAAA battery and at this stage i think i have no option but to go for boost converter to power sensor on the node, i wish i had space in sensor box i m using for 3xAAA batteries.
                            MIC5219-3.3BM5 is good option but it has minimum Input Voltage 2.5v, with good Quiescent 8µA but i think i m leaning toward TPS613221A boost convert chip i know it does not have shutdown option but very low quiescent current of 6.5uA, here is unfinished prototype pcb design.
                            • pihomeP pihome
                              zboblamontZ Offline
                              zboblamontZ Offline
                              zboblamont
                              @pihome Surely VR shutdown is irrelevant for a live device, or am I completely misunderstanding this function?
                              Presumably you will deploy one of these for each zone instead instead of running a cable.
                              Passing thought - Have you considered a plastic type battery holder on back of the circuitry, halving the current board area but making it slightly thicker?
                              • pihomeP Offline
                                pihomeP Offline
                                pihome
                                @zboblamont
                                you are right one battery powered sensor for each zone and reading once every minute and no cables to sensors. but during sleep time VR will consume power, i had thought about 3x AAA battery on the back of pcb but i n using tht nrf or perhaps i have to rethink the whole design.
                                • pihomeP pihome
                                  @zboblamont
                                  zboblamontZ Offline
                                  zboblamontZ Offline
                                  zboblamont
                                  @pihome Perhaps re-evaluate what you are trying to achieve and how?
                                  The array in my place reads every 5 minutes over a cable array, even for outside temperatures half-hourly samples would probably be fine, this is my screen-shot.
                                  Frankly your goal of 1 minute granularity makes no sense with real world temperature variations, even in interior spaces. If the objective is heating control, room effects are slow.
                                  If necessay you could up the sample rate when heat is circulating, thence minimise wasted yet finite energy?
                                  Even the choice of radio may be inappropriate to your energy efficiency goals, I explained previously how this end works, @nagelc has outlined he is getting super performance with 2+ years battery life, this perhaps merits review...
                                  • pihomeP Offline
                                    pihomeP Offline
                                    pihome
                                    @kimot said in ds18b20 on 2xAAA battery:
                                    MIC5219
                                    you are right i think i have to go back to drawing board and re-evaluate my design. thanks for reply.
                                    • pihomeP pihome
                                      Hi All,
                                      T Offline
                                      T Offline
                                      tommies
                                      @pihome i use ds18b20 on 2xAA with an atmega328p without any problem ans without any regulator
                                      • B Offline
                                        B Offline
                                        buxtronix
                                        Confirming also, I have about a dozen nodes around the place, all running off 2xAA batteries and all of the DS18B20 devices have no problems with this supply voltage, even when they are down to 2.8V they're still reporting reliably.
                                        • pihomeP Offline
                                          pihomeP Offline
                                          pihome
                                          i must admit you are lucky or your sensors dont care about voltage but at this stage after reading your comments i have tried 3 different sensors and all the same result
                                          may be something is in my sketch ?
                                          //  _____    _   _    _
                                          // |  __ \  (_) | |  | |
                                          // | |__) |  _  | |__| |   ___    _ __ ___     ___
                                          // |  ___/  | | |  __  |  / _ \  | |_  \_ \   / _ \
                                          // | |      | | | |  | | | (_) | | | | | | | |  __/
                                          // |_|      |_| |_|  |_|  \___/  |_| |_| |_|  \___|
                                          //    S M A R T   H E A T I N G   C O N T R O L
                                          // *       Battery Powered OneWire DS18B20 Temperature Sensor      *
                                          // *           Version 0.31 Build Date 06/11/2017                  *
                                          // *            Last Modification Date 09/05/2019                  *
                                          // *                                          Have Fun - PiHome.eu *
                                          #define MY_RADIO_RF24
                                          //#define MY_RADIO_NRF5_ESB
                                          //#define MY_RADIO_RFM95
                                          // #define MY_RF24_PA_LEVEL RF24_PA_LOW
                                          // RF24_PA_MIN RF24_PA_LOW RF24_PA_HIGH RF24_PA_MAX RF24_PA_ERROR
                                          #define MY_RF24_PA_LEVEL RF24_PA_MIN
                                          // RF channel for the sensor net, 0-127 Default is 76
                                          #define MY_RF24_CHANNEL	76
                                          //PiHome - Make Sure you change Node ID, for each temperature sensor. 21 for Ground Floor, 20 for First Floor, 30 for Domastic Hot Water.
                                          #define MY_NODE_ID 33
                                          // Set baud rate to same as optibot
                                          //#define MY_BAUD_RATE 9600
                                          //set how long to wait for transport ready in milliseconds
                                          //#define MY_TRANSPORT_WAIT_READY_MS 3000
                                          //#include <SPI.h>
                                          #include <OneWire.h>
                                          #define ledpin 4 // LED for one Blink Power On, Solid LED for No sensors, 5 Blinks for no Radio (this settings is in MySensors.cpp) and three blinks for low battery
                                          // Define sensor node childs
                                          #define CHILD_ID_BATT 1
                                          #define CHILD_ID_TEMP 0
                                          #define COMPARE_BVOLT 1 // Send battery voltage only if changed? 1 = Yes 0 = No
                                          #define MAX_ATTACHED_DS18B20 2
                                          unsigned long SLEEP_TIME = 56000; // Sleep time between reads (in milliseconds)
                                          // Battery related init
                                          float oldBatteryV = 0;
                                          MyMessage msgBatt(CHILD_ID_BATT, V_VOLTAGE);
                                          // Dallas Temperature related init
                                          int numSensors=0;
                                          bool receivedConfig = false;
                                          bool metric = true;
                                          MyMessage msg(CHILD_ID_TEMP, V_TEMP);
                                          void before(){
                                            sensors.begin();
                                          void setup(){
                                          	//This is LED pin set to output and turn it on for short while
                                          	pinMode(ledpin, OUTPUT);
                                          	digitalWrite(ledpin, HIGH);
                                          	delay(60);
                                          	digitalWrite(ledpin, LOW);
                                            // needed for battery soc
                                                analogReference(INTERNAL1V1);
                                                analogReference(INTERNAL);
                                              // disable ADC
                                            //ADCSRA = 0;
                                            //power_usart0_disable();// Serial (USART)
                                            //power_adc_disable(); // ADC converter
                                            //power_twi_enable(); // TWI (I2C)
                                          	sendSketchInfo("Temperature Sensor", "0.31");
                                          	//Blink LED as number of sensors attached
                                          	blink_led(numSensors, ledpin);
                                          	//check if attached sensors number is grater then 0 if no then put led on solid
                                          	#if numSensors > 0
                                               present(i, S_TEMP);
                                          void loop(){
                                          	// get the battery Voltage
                                          	//ref http://www.ohmslawcalculator.com/voltage-divider-calculator
                                          	// 1M, 100K divider across battery and using internal ADC ref of 1.1V
                                          	// ((1e6+100e3)/100e3)*1.1 = Vmax = 12.1 Volts
                                          	// 12.1/1023 = Volts per bit = 0.011828
                                          	//R1 820k, R2 220k
                                          	//((820e3+220e3)/220e3)*1.1 = Vmax = 5.2 Volts
                                          	//5.2/1023 = Volts per bit = 0.005083089
                                          	int battSensorValue = analogRead(BATTERY_SENSE_PIN);
                                          	//float batteryV  = battSensorValue * 0.005083089; //R1 820k, R2 220k divider across battery and using internal ADC ref of 1.1v
                                          	float batteryV  = battSensorValue * 0.011828;    //R1 1M, R2 100K divider across battery and using internal ADC ref of 1.1v
                                          	//int batteryPcnt = ( ( batteryV - 2.9 ) / ( ( 4.2 - 2.9 ) / 100 ) ); // for 18650 Battery Powred
                                          	int batteryPcnt = ( ( batteryV - 2.1 ) / ( ( 3.0 - 2.1 ) / 100 ) ); // for AAA Battery Powered
                                          	#ifdef MY_DEBUG
                                          		Serial.print("Pin Reading: ");
                                          		Serial.println(battSensorValue);
                                          		Serial.print(batteryV);
                                          		Serial.println(" v");
                                          		//Print Battery Percentage
                                          		Serial.print(batteryPcnt);
                                          		Serial.println(" %");
                                          	#if COMPARE_BVOLT == 1
                                          		if (oldBatteryV != batteryV) {
                                          			send(msgBatt.set(batteryV, 2));
                                          			oldBatteryV = batteryV;
                                          	//sleep() call can be replaced by wait() call if node need to process incoming messages (or if node is repeater)
                                          	sleep(conversionTime);
                                          		#if COMPARE_TEMP == 1
                                          		//Condition to check battery levell is lower then minimum then blink led 3 times
                                          		//if (batteryV < 2.9) { //for 18650 Battery Powered Sensor
                                          		if (batteryV < 2.0) { //for AAA Battery Powered Sensor
                                          			blink_led(3, ledpin);
                                          			//Serial.print("Low Voltage");
                                          	//go to sleep for while
                                          	//smartSleep(SLEEP_TIME);
                                          	sleep(SLEEP_TIME);
                                          //Blink LED function, pass ping number and number of blinks usage: blink_led(variable or number of time blink, ledpin);
                                          void blink_led(int count, int pin){
                                          	for(int i=0;i<count;i++){
                                          		digitalWrite(pin, HIGH);
                                          		delay(700);
                                          		digitalWrite(pin, LOW);
                                          		delay(700);
                                          12.2k
