  3. Problems with the Raspberry Pi gateway
16 Posts 4 Posters 2.9k Views 4 Watching
  • vladimirV Offline
    vladimirV Offline
    vladimir
    Hello! Please help to solve the problem.:man-gesturing-ok:
    Here's what is written at startup:
    mysgw: Starting gateway...
    mysgw: Protocol version - 2.2.0
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: failed to connect
    mysgw: GWT:TIN:ETH OK
    mysgw: GWT:TPS:ETH OK
    Here's what I wrote in the console:
    cd MySensors
    ./configure --my-transport=nrf24
    ./configure --my-gateway=ethernet --my-port=5003
    ./configure --my-gateway=ethernet --my-controller-ip-address=192.168.1.2
    make
    sudo ./bin/mysgw -d
    • vladimirV Offline
      vladimirV Offline
      vladimir
      wrote on last edited by vladimir
      Here, all that was written in the console:
      [00:24:15] openhabian@openHABianPi:~$ git clone https://github.com/mysensors/MySensors.git --branch master
      Cloning into 'MySensors'...
      remote: Counting objects: 15830, done.
      remote: Total 15830 (delta 0), reused 0 (delta 0), pack-reused 15830
      Receiving objects: 100% (15830/15830), 20.48 MiB | 3.49 MiB/s, done.
      Resolving deltas: 100% (9639/9639), done.
      [00:24:46] openhabian@openHABianPi:~$ cd MySensors
      [00:25:34] openhabian@openHABianPi:~/MySensors$ ./configure --my-transport=nrf24
        [OK] SPI driver detected:BCM.
      [OK] Finished.
      [00:26:09] openhabian@openHABianPi:~/MySensors$ ./configure --my-gateway=ethernet --my-port=5003
      [OK] Finished.
      [00:27:08] openhabian@openHABianPi:~/MySensors$ ./configure --my-gateway=ethernet --my-controller-ip-address=192.168.1.2
      [OK] Finished.
      [00:27:40] openhabian@openHABianPi:~/MySensors$ make
      gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_CONTROLLER_IP_ADDRESS=192,168,1,2  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/log.c -o build/drivers/Linux/log.o
      g++ -MT build/drivers/Linux/IPAddress.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_CONTROLLER_IP_ADDRESS=192,168,1,2  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/IPAddress.cpp -o build/drivers/Linux/IPAddress.o
      g++ -MT build/drivers/Linux/noniso.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_CONTROLLER_IP_ADDRESS=192,168,1,2  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/noniso.cpp -o build/drivers/Linux/noniso.o
      g++ -MT build/drivers/Linux/GPIO.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_CONTROLLER_IP_ADDRESS=192,168,1,2  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/GPIO.cpp -o build/drivers/Linux/GPIO.o
      g++ -MT build/drivers/Linux/SPIDEV.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_CONTROLLER_IP_ADDRESS=192,168,1,2  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SPIDEV.cpp -o build/drivers/Linux/SPIDEV.o
      g++ -MT build/drivers/Linux/Print.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_CONTROLLER_IP_ADDRESS=192,168,1,2  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/Print.cpp -o build/drivers/Linux/Print.o
      g++ -MT build/drivers/Linux/EthernetClient.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_CONTROLLER_IP_ADDRESS=192,168,1,2  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/EthernetClient.cpp -o build/drivers/Linux/EthernetClient.o
      g++ -MT build/drivers/Linux/compatibility.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_CONTROLLER_IP_ADDRESS=192,168,1,2  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/compatibility.cpp -o build/drivers/Linux/compatibility.o
      g++ -MT build/drivers/Linux/SerialPort.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_CONTROLLER_IP_ADDRESS=192,168,1,2  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SerialPort.cpp -o build/drivers/Linux/SerialPort.o
      g++ -MT build/drivers/Linux/Stream.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_CONTROLLER_IP_ADDRESS=192,168,1,2  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/Stream.cpp -o build/drivers/Linux/Stream.o
      g++ -MT build/drivers/Linux/interrupt.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_CONTROLLER_IP_ADDRESS=192,168,1,2  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/interrupt.cpp -o build/drivers/Linux/interrupt.o
      g++ -MT build/drivers/Linux/SerialSimulator.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_CONTROLLER_IP_ADDRESS=192,168,1,2  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SerialSimulator.cpp -o build/drivers/Linux/SerialSimulator.o
      g++ -MT build/drivers/Linux/SoftEeprom.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_CONTROLLER_IP_ADDRESS=192,168,1,2  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/SoftEeprom.cpp -o build/drivers/Linux/SoftEeprom.o
      g++ -MT build/drivers/Linux/EthernetServer.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_CONTROLLER_IP_ADDRESS=192,168,1,2  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/Linux/EthernetServer.cpp -o build/drivers/Linux/EthernetServer.o
      g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_CONTROLLER_IP_ADDRESS=192,168,1,2  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
      gcc -MT build/drivers/BCM/bcm2835.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_CONTROLLER_IP_ADDRESS=192,168,1,2  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/bcm2835.c -o build/drivers/BCM/bcm2835.o
      g++ -MT build/drivers/BCM/BCM.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_CONTROLLER_IP_ADDRESS=192,168,1,2  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/BCM.cpp -o build/drivers/BCM/BCM.o
      g++ -MT build/drivers/BCM/SPIBCM.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_CONTROLLER_IP_ADDRESS=192,168,1,2  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/SPIBCM.cpp -o build/drivers/BCM/SPIBCM.o
      g++ -MT build/drivers/BCM/Wire.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_CONTROLLER_IP_ADDRESS=192,168,1,2  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/Wire.cpp -o build/drivers/BCM/Wire.o
      g++ -MT build/drivers/BCM/RPi.o -MMD -MP -march=armv8-a+crc -mtune=cortex-a53 -mfpu=neon-fp-armv8 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DLINUX_SPI_BCM -DLINUX_ARCH_RASPBERRYPI -DMY_CONTROLLER_IP_ADDRESS=192,168,1,2  -Ofast -g -Wall -Wextra  -I. -I./core -I./drivers/Linux -I./drivers/BCM -c drivers/BCM/RPi.cpp -o build/drivers/BCM/RPi.o
      g++ -pthread  -o bin/mysgw build/drivers/Linux/log.o build/drivers/Linux/IPAddress.o build/drivers/Linux/noniso.o build/drivers/Linux/GPIO.o build/drivers/Linux/SPIDEV.o build/drivers/Linux/Print.o build/drivers/Linux/EthernetClient.o build/drivers/Linux/compatibility.o build/drivers/Linux/SerialPort.o build/drivers/Linux/Stream.o build/drivers/Linux/interrupt.o build/drivers/Linux/SerialSimulator.o build/drivers/Linux/SoftEeprom.o build/drivers/Linux/EthernetServer.o build/examples_linux/mysgw.o build/drivers/BCM/bcm2835.o build/drivers/BCM/BCM.o build/drivers/BCM/SPIBCM.o build/drivers/BCM/Wire.o build/drivers/BCM/RPi.o
      [00:30:01] openhabian@openHABianPi:~/MySensors$ sudo ./bin/mysgw -d
      mysgw: TSF:LRT:OK
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
        All configure parameters needs to be on the same line. In your case just use these
        ./configure --my-gateway=ethernet --my-port=5003 as the others are not needed
        vladimirV 1 Reply Last reply
          vladimirV Offline
          vladimirV Offline
          vladimir
          @gohan many thanks!:raised_hands:
          • gfinkG Offline
            gfinkG Offline
            gfink
            Hey @gohan I'm having a similiar issue, I've pasted my
            ./configure --my-transport=nrf24 --my-gateway=ethernet --my-port=5003 --my-gateway=ethernet --my-controller-ip-address=192.168.10.12 as a single line, then "make", and created the service, but I still get the same that Vladimir was getting.
            May 28 19:17:46 ERROR failed to connect
            May 28 19:17:46 DEBUG GWT:TPS:ETH OK
            May 28 19:17:46 ERROR connect: Connection refused
            ^CMay 28 19:17:46 NOTICE Received SIGINT
            I've tried the Master and development branch, and have triple checked the nrf24 wiring, made sure SPI was enabled on my pi, I'm at a loss of ideas, can anyone offer some suggestions?
            • gfinkG gfink
              @gfink port 5003 on 192.168.10.12 isn't open for oncoming connections. What controller are you using? Does that controller support incoming connections from MySensors ethernet gateways? Most controllers prefer to connect to the gateway instead of having the gatewayconect to them.
              gfinkG 1 Reply Last reply
              • gfinkG Offline
                gfinkG Offline
                gfink
                • gfinkG Offline
                  gfinkG Offline
                  gfink
                  @mfalkvidd Also, fyi, the drawing may need to be updated, as it's referencing pings 24/26 whereas the charts shows 22/24. If I'm reading it correctly: https://www.mysensors.org/build/raspberry
                    gfinkG Offline
                    gfinkG Offline
                    gfink
                    @mfalkvidd I'm using openhab2.4 on the same pi, I'd initially tried it w/o port 5003, similiar to below to no avail. So am I mistaken to even try to run openhab2, and try to run the mySensor's ethernet gateway on the same pi? I was trying to conserve resources.
                    ./configure --my-gateway=ethernet --my-controller-url-address=192.168.10.12 --my-transport=rf24 --my-rf24-irq-pin=15
                    • gfinkG gfink
                      @gfink I can't find a reference to 26 on that page. Could you explain what I'm missing?
                      • gfinkG gfink
                        @gfinkrunning on the same pi is ok.
                        I don't have any experience with OpenHab but according to https://github.com/tobof/openhab2-addons/wiki/Configuration OpenHab connects to the gateway, not the other way around. Remove my-controller-url-address from the gateway configuration and re-run make and install.
                          gfinkG Offline
                          gfinkG Offline
                          gfink
                          This image is referencing (SPI0 CS0 = pin 24) and (SPI0 CS1 = pin 26). and below that image on the same URL, references this chart. I'm assuming that this is for the RPI (2-3)'s. So should the pic be updated to reference 22/24 and not 24/26 or the chart? Just asking to try to help others as I'd tripped over this for a short while. :)
                          Raspberry NRF24L01+ Color
                          GND GND Black
                          3.3V(*) VCC Red
                          22 CE Orange
                          24 CSN/CS Yellow
                          23 SCK Green
                          19 MOSI Blue
                          21 MISO Violet
                          15(**) IRQ Gray
                          • gfinkG gfink
                            GND GND Black
                            3.3V(*) VCC Red
                            22 CE Orange
                            24 CSN/CS Yellow
                            23 SCK Green
                            19 MOSI Blue
                            21 MISO Violet
                            15(**) IRQ Gray
                            @gfink sorry, I don't see how it is referencing pin 26. Yes, pin 26 is present in the picture but so are pins 36, 39 and lots of other pins that are not used.
                              gfinkG Offline
                              gfinkG Offline
                              gfink
                              @mfalkvidd I guess I was under the impression that the purple labels signified the CE / CSN-CS pins for the nrf. That was a little confusing for a slow learner like myself. :)
                                gfinkG Offline
                                gfinkG Offline
                                gfink
                                @mfalkvidd You're correct again sir. I ran "./configure --my-gateway=ethernet --my-transport=rf24 --my-rf24-irq-pin=15" and then make/install. and it now works. Thanks for all of your time, wisdom, and helping us along this journey.
                                • gfinkG gfink
                                  @gfink great work, thanks for reporting back
                                  12.1k
