  3. Problems with the Raspberry Pi gateway
16 Posts 4 Posters 3.5k Views 4 Watching
    All configure parameters needs to be on the same line. In your case just use these
    ./configure --my-gateway=ethernet --my-port=5003 as the others are not needed
    vladimirV
    vladimirV
    vladimir
    @gohan many thanks!:raised_hands:
    • gfinkG
      gfinkG
      gfink
      Hey @gohan I'm having a similiar issue, I've pasted my
      ./configure --my-transport=nrf24 --my-gateway=ethernet --my-port=5003 --my-gateway=ethernet --my-controller-ip-address=192.168.10.12 as a single line, then "make", and created the service, but I still get the same that Vladimir was getting.
      May 28 19:17:46 ERROR failed to connect
      May 28 19:17:46 DEBUG GWT:TPS:ETH OK
      May 28 19:17:46 ERROR connect: Connection refused
      ^CMay 28 19:17:46 NOTICE Received SIGINT
      I've tried the Master and development branch, and have triple checked the nrf24 wiring, made sure SPI was enabled on my pi, I'm at a loss of ideas, can anyone offer some suggestions?
      • gfinkG gfink
        @gfink port 5003 on 192.168.10.12 isn't open for oncoming connections. What controller are you using? Does that controller support incoming connections from MySensors ethernet gateways? Most controllers prefer to connect to the gateway instead of having the gatewayconect to them.
        gfinkG 1 Reply Last reply
        • gfinkG
          gfinkG
          gfink
          • gfinkG
            gfinkG
            gfink
            @mfalkvidd Also, fyi, the drawing may need to be updated, as it's referencing pings 24/26 whereas the charts shows 22/24. If I'm reading it correctly: https://www.mysensors.org/build/raspberry
              gfinkG
              gfinkG
              gfink
              @mfalkvidd I'm using openhab2.4 on the same pi, I'd initially tried it w/o port 5003, similiar to below to no avail. So am I mistaken to even try to run openhab2, and try to run the mySensor's ethernet gateway on the same pi? I was trying to conserve resources.
              ./configure --my-gateway=ethernet --my-controller-url-address=192.168.10.12 --my-transport=rf24 --my-rf24-irq-pin=15
              • gfinkG gfink
                @gfink I can't find a reference to 26 on that page. Could you explain what I'm missing?
                • gfinkG gfink
                  @gfinkrunning on the same pi is ok.
                  I don't have any experience with OpenHab but according to https://github.com/tobof/openhab2-addons/wiki/Configuration OpenHab connects to the gateway, not the other way around. Remove my-controller-url-address from the gateway configuration and re-run make and install.
                    gfinkG
                    gfinkG
                    gfink
                    This image is referencing (SPI0 CS0 = pin 24) and (SPI0 CS1 = pin 26). and below that image on the same URL, references this chart. I'm assuming that this is for the RPI (2-3)'s. So should the pic be updated to reference 22/24 and not 24/26 or the chart? Just asking to try to help others as I'd tripped over this for a short while. :)
                    Raspberry NRF24L01+ Color
                    GND GND Black
                    3.3V(*) VCC Red
                    22 CE Orange
                    24 CSN/CS Yellow
                    23 SCK Green
                    19 MOSI Blue
                    21 MISO Violet
                    15(**) IRQ Gray
                    • gfinkG gfink
                      GND GND Black
                      3.3V(*) VCC Red
                      22 CE Orange
                      24 CSN/CS Yellow
                      23 SCK Green
                      19 MOSI Blue
                      21 MISO Violet
                      15(**) IRQ Gray
                      @gfink sorry, I don't see how it is referencing pin 26. Yes, pin 26 is present in the picture but so are pins 36, 39 and lots of other pins that are not used.
                        gfinkG
                        gfinkG
                        gfink
                        @mfalkvidd I guess I was under the impression that the purple labels signified the CE / CSN-CS pins for the nrf. That was a little confusing for a slow learner like myself. :)
                          gfinkG
                          gfinkG
                          gfink
                          @mfalkvidd You're correct again sir. I ran "./configure --my-gateway=ethernet --my-transport=rf24 --my-rf24-irq-pin=15" and then make/install. and it now works. Thanks for all of your time, wisdom, and helping us along this journey.
                          • gfinkG gfink
                            @gfink great work, thanks for reporting back
