  3. Sensor for Vallox DigitSE RS485 ventilation system with integration into FHEM.
rs485valloxfhem
36 Posts 12 Posters 27.7k Views 12 Watching
  • B
    B
    boehrian
    Hello, Thank you for this Tool. I have rebuild it but I get no Data in Fhem and the serial Monitor from Arduino. Can every one help me?
    0_1488198457149_upload-35f8091f-da2a-4c43-ab73-7574f41a77b4
    This is the output from serial Monitor.
    • HeinzH
      HeinzH
      Heinz
      here is my output:
      Opening port
      Port open
      Starting repeater (RNNRA-, 2.0.0)
      TSM:INIT
      TSM:RADIO:OK
      TSP:ASSIGNID:OK (ID=100)
      TSM:FPAR
      TSP:MSG:SEND 100-100-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
      TSP:MSG:READ 1-1-100 s=255,c=3,t=8,pt=1,l=1,sg=0:1
      TSP:MSG:FPAR RES (ID=1, dist=1)
      TSP:MSG:PAR OK (ID=1, dist=2)
      TSP:MSG:READ 0-0-100 s=255,c=3,t=8,pt=1,l=1,sg=0:0
      TSP:MSG:PAR OK (ID=0, dist=1)
      TSP:MSG:READ 104-104-100 s=255,c=3,t=8,pt=1,l=1,sg=0:1
      TSP:MSG:FPAR RES (ID=104, dist=1)
      TSM:FPAR:OK
      TSM:ID
      TSM:CHKID:OK (ID=100)
      TSM:UPL
      TSP:PING:SEND (dest=0)
      TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
      TSP:MSG:READ 0-0-100 s=255,c=3,t=25,pt=1,l=1,sg=0:1
      TSP:MSG:PONG RECV (hops=1)
      TSP:CHKUPL:OK
      TSM:UPL:OK
      TSM:READY
      TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
      !TSP:MSG:SEND 100-100-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,ft=0,st=fail:2.0.0
      TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=ok:0
      TSP:MSG:READ 0-0-100 s=255,c=3,t=6,pt=0,l=1,sg=0:M
      TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=11,pt=0,l=15,sg=0,ft=0,st=ok:Vallox Digit SE
      TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:2.5
      TSP:MSG:SEND 100-100-0-0 s=0,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=2,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=3,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=4,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=5,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=6,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=7,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=8,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=9,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=10,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=11,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=12,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=13,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=14,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=15,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=24,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=25,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=26,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=27,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=28,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=29,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=30,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=31,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=32,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=33,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=34,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=35,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=36,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=37,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=38,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=39,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=40,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=41,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=42,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=43,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=44,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=45,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=46,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=47,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=48,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 100-100-0-0 s=49,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
      Started cyclic update timer.
      Request registration...
      TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
      TSP:MSG:READ 0-0-100 s=255,c=3,t=27,pt=1,l=1,sg=0:1
      Node registration=1
      Init complete, id=100, parent=0, distance=1, registration=1
      Dropped 0
      Received telegram from 21->11 command=0 arg=A3
      Received telegram from 11->21 command=A3 arg=29
      Property 200 changed 41
      Power state 1
      TSP:MSG:SEND 100-100-0-0 s=8,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:1
      CO2 adjust state 0
      TSP:MSG:SEND 100-100-0-0 s=9,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:0
      Humidity adjust state 0
      TSP:MSG:SEND 100-100-0-0 s=10,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:0
      Heating state 1
      TSP:MSG:SEND 100-100-0-0 s=11,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:1
      Filter guard indicator 0
      TSP:MSG:SEND 100-100-0-0 s=12,c=1,t=24,pt=2,l=2,sg=0,ft=0,st=ok:0
      Heating indicator 1
      TSP:MSG:SEND 100-100-0-0 s=13,c=1,t=24,pt=2,l=2,sg=0,ft=0,st=ok:1
      Fault indicator 0
      TSP:MSG:SEND 100-100-0-0 s=14,c=1,t=24,pt=2,l=2,sg=0,ft=0,st=ok:0
      Serivce reminder indicator 0
      TSP:MSG:SEND 100-100-0-0 s=15,c=1,t=24,pt=2,l=2,sg=0,ft=0,st=ok:0
      Received telegram from 21->11 command=0 arg=29
      Received telegram from 11->21 command=29 arg=1
      Received telegram from 21->11 command=0 arg=35
      Received telegram from 11->21 command=35 arg=9D
      Temp incomming 19
      TSP:MSG:SEND 100-100-0-0 s=4,c=1,t=0,pt=2,l=2,sg=0,ft=0,st=ok:19
      Received telegram from 21->11 command=0 arg=71
      Received telegram from 11->21 command=71 arg=0
      This is the output of the mysensors 2.0 version which can be downloaded from
      https://github.com/windkh/mysensors/tree/master/ValloxSensor
      I wonder why your node has id=0.
      • B
        B
        boehrian
        Hi, my output ist now:
        0 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.1.1
        3 TSM:INIT
        4 TSF:WUR:MS=0
        12 TSM:INIT:TSP OK
        13 TSF:SID:OK,ID=42
        15 TSM:FPAR
        52 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        2059 !TSM:FPAR:NO REPLY
        2061 TSM:FPAR
        2098 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        4105 !TSM:FPAR:NO REPLY
        4107 TSM:FPAR
        4143 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        6151 !TSM:FPAR:NO REPLY
        6153 TSM:FPAR
        6189 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        8197 !TSM:FPAR:FAIL
        8198 TSM:FAIL:CNT=1
        8200 TSM:FAIL:PDT
        18203 TSM:FAIL:RE-INIT
        18205 TSM:INIT
        18212 TSM:INIT:TSP OK
        18214 TSF:SID:OK,ID=42
        18216 TSM:FPAR
        18253 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        20261 !TSM:FPAR:NO REPLY
        20263 TSM:FPAR
        20300 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        22307 !TSM:FPAR:NO REPLY
        22309 TSM:FPAR
        22346 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        24353 !TSM:FPAR:NO REPLY
        24355 TSM:FPAR
        24392 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
        I get no reply from the Vallox.
        Is your original Vallox controller online
        • HeinzH
          HeinzH
          Heinz
          wrote on last edited by Heinz
          #26
          The "no reply" message is from the mysensors library, but I don't know what it means.
          The line "started cyclic update timer" indicates that the sensor initialized successfully, but it is missing in your output.
          My latest code is online at
          https://github.com/windkh/valloxserial/blob/master/examples/mysensors/ValloxSensor.ino
            Use the log parser to help you interpret the log.
            • HeinzH Heinz
              For those who want to have the FHEM files here they are:
              _MYSENSOR_Vallox.cfg
              simply place the file in FHEM's subfolder FHEM and include it your fhem.cfg:
              include ./FHEM/_MYSENSOR_Vallox.cfg
              And here are the plot files which have to be placed in the subfolder www\gplot
              SVG_FileLog_Vallox_6.gplot
              SVG_FileLog_Vallox_5.gplot
              SVG_FileLog_Vallox_4.gplot
              SVG_FileLog_Vallox_3.gplot
              SVG_FileLog_Vallox_2.gplot
              SVG_FileLog_Vallox_1.gplot
              You will likely have to adapt the room and group names, and of course the german names, sorry for that.
              ausbremenA
              ausbremenA
              ausbremen
              @heinz
              Hi Heinz, the SVG_FileLog_Vallox_#.gplot files are empty ...probably the link is dead...could you reup them? Or could you send them tio me?
              Thanks, Holger
              • HeinzH Heinz
                ausbremenA
                ausbremenA
                ausbremen
                @heinz
                Sorry...everything is fine with the gplot files...it was my fault trying to look at them with the crimpson editor...instead of FHEM gplot
                • C
                  C
                  captaindork
                  Hello Heinz, all,
                  first of all thank you for sharing your work in this thread!
                  I have not to much skills around programming and arduino, but was however able to build this and integrate my Vallox 90 SE into ioBroker. Absolutely Great!
                  You mentioned the bypass damper above and I see you have visualized it in fhem. I found the Value to set the Threshold temp for this (31), however I wonder where you got the actual bypass position from. Which Value shows if its open or closed?
                  I do not want to control it, i just would like to log the Position Status to see when it happens.
                  Thanks a lot i feel blind :)
                  HeinzH 1 Reply Last reply
                  • C captaindork
                    Hello Heinz, all,
                    HeinzH
                    HeinzH
                    Heinz
                    Hi @captaindork
                    sorry for delay,.... the position of the damper (which is the bypass) is indicated through a single bit of the multi purpose IO-Port 2. The library defines that as property 38 DamperMotorPositionProperty.
                    In the mysensors example it is published as
                    const uint8_t DAMPER_MOTOR_POSITION = 42;
                    The value is either 1 or 0.
                    I mapped it in FHEM as follows
                    attr MYSENSOR_Vallox mapReading_DamperMotorPosition 42 value1
                    define MYSENSOR_Vallox_DamperMotorPosition dummy
                    attr MYSENSOR_Vallox_DamperMotorPosition alias WRG-Bypass
                    attr MYSENSOR_Vallox_DamperMotorPosition devStateIcon 1:rc_GREEN 0:rc_BLANK
                    attr MYSENSOR_Vallox_DamperMotorPosition event-on-update-reading state
                    attr MYSENSOR_Vallox_DamperMotorPosition group Status
                    attr MYSENSOR_Vallox_DamperMotorPosition icon vent_bypass
                    attr MYSENSOR_Vallox_DamperMotorPosition room Lüftung
                    attr MYSENSOR_Vallox_DamperMotorPosition sortby 3
                    define MYSENSOR_Vallox_DamperMotorPosition_Notify notify MYSENSOR_Vallox:DamperMotorPosition:.* { my $d = sprintf ("%.0f", ReadingsVal("MYSENSOR_Vallox","DamperMotorPosition", 0));; fhem("set MYSENSOR_Vallox_DamperMotorPosition $d");;}
                    define MYSENSOR_Vallox_DamperMotorPosition_Notify2 at +*00:01:00 { my $d = sprintf "%.0f", ReadingsVal("MYSENSOR_Vallox","DamperMotorPosition", 0);; fhem("set MYSENSOR_Vallox_DamperMotorPosition $d");;}
                    • R
                      R
                      RHead
                      Hi.
                      Can you make exact parts list for this setup.
                      • HeinzH
                        HeinzH
                        Heinz
                        Ok ... after my holidays.
                        • HeinzH
                          HeinzH
                          Heinz
                          Well basically the part list is very simple
                          1x Arduino Mega 2560
                          1x NRF24L01+
                          1x Pushbutton
                          2x MAX485 Module TTL Switch Module (one for sender, one for receiver)
                          (e.g. https://protosupplies.com/product/max485-ttl-to-rs-485-interface-module/)
                          The 1x Resistor 120Ohms is only neccessary if not already mounted on the MAX485 Module. It depends on what module
                          you bought. So have a look at the layout and check if there is a 120Ohms resistor mounted between pins A and B.
                          The module (https://protosupplies.com/product/max485-ttl-to-rs-485-interface-module/) already contains that resistor.
                          Optionally you can add a capacitor between + and - to stabilize the voltage level if your power supply is a weak one.
                          Anyone will do like 10uF, 100uF...
                          • HeinzH
                            HeinzH
                            Heinz
                            Note that you can make use of any MAX485 module that is suitable for the arduino (5V). Basically they are all the same except for a few minor tweaks like LEDs or other non relevant stuff.
                            • MasMatM
                              MasMatM
                              MasMat
                              I found this old thread and since I have a Vallox machine it's interesting. RS485 is new to me but MySensors isn't.
                              Can I have a node like this described by Heinz parallel with the "mickey mouse"-display? Using the display's connector? Or is it one or the other?
                              I'd feel better having both (manual display&buttons and connection to MySensors=>Domoticz, in my case).
