  3. Sensor for Vallox DigitSE RS485 ventilation system with integration into FHEM.
rs485valloxfhem
36 Posts 12 Posters 27.5k Views 12 Watching
  • HeinzH Heinz
    For those who want to have the FHEM files here they are:
    _MYSENSOR_Vallox.cfg
    simply place the file in FHEM's subfolder FHEM and include it your fhem.cfg:
    include ./FHEM/_MYSENSOR_Vallox.cfg
    And here are the plot files which have to be placed in the subfolder www\gplot
    SVG_FileLog_Vallox_6.gplot
    SVG_FileLog_Vallox_5.gplot
    SVG_FileLog_Vallox_4.gplot
    SVG_FileLog_Vallox_3.gplot
    SVG_FileLog_Vallox_2.gplot
    SVG_FileLog_Vallox_1.gplot
    You will likely have to adapt the room and group names, and of course the german names, sorry for that.
    m26872M
    m26872M
    m26872
    @Heinz
    Nice! Now I really want to buy a Vallox ... (and a house...)
    • SkjallS
      SkjallS
      Skjall
      Moin @Heinz,
      is it possible to use a RS485 USB-Stick (http://shop.in-circuit.de/product_info.php?cPath=38&products_id=81) instead of this construction? I've tried it with your .net Sniffer on my Windows PC and it worked well.
      Skjall
      • HeinzH
        HeinzH
        Heinz
        You can use this rs485 to usb adapter to control the vallox device, no problem there. But do you intend to use your windows pc as controller then? Or do you want to use the stick directly with fhem? this would require some software which takes the serial telegrams and imports the values into fhem... or any other homeautomation controller.
        • SkjallS
          SkjallS
          Skjall
          wrote on last edited by Skjall
          #21
          No, the Windows PC was only for testing and verifying that the RS485 Connection workes well.
          My preferred solution would be this stick at the Raspberry Pi which is running the FHEM. Therefor I'd need a module to read the stream and interpret it in the FHEM format. Problem: I've never written a module. It would be possible somehow.. in some month. ;)
          The alternate solution would be your mysensor system. Especially because its running and tested. Problem: The Hardware. I have no experience in arduino and absolutly no idea how to build such a board. Thats why I thought I could plug the stick to an arduino and make it magicly work. ;)
          EDIT: Ok. It is easier than I thought to write this module. I'm working on it and the main functions should be finished this week. I'll publish it, if it is ready for testing.
          HeinzH 1 Reply Last reply
          • SkjallS Skjall
            HeinzH
            HeinzH
            Heinz
            Ah ok I see. Probably you can get some help in the fhem forum. I also thought about doing this using a raspi... you could use the library to write a standalone exe which reads the serial stuff from usb and sets the values in fhem using the webinterface.
            • B
              B
              boehrian
              Hello, Thank you for this Tool. I have rebuild it but I get no Data in Fhem and the serial Monitor from Arduino. Can every one help me?
              0_1488198457149_upload-35f8091f-da2a-4c43-ab73-7574f41a77b4
              This is the output from serial Monitor.
              • HeinzH
                HeinzH
                Heinz
                here is my output:
                Opening port
                Port open
                Starting repeater (RNNRA-, 2.0.0)
                TSM:INIT
                TSM:RADIO:OK
                TSP:ASSIGNID:OK (ID=100)
                TSM:FPAR
                TSP:MSG:SEND 100-100-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                TSP:MSG:READ 1-1-100 s=255,c=3,t=8,pt=1,l=1,sg=0:1
                TSP:MSG:FPAR RES (ID=1, dist=1)
                TSP:MSG:PAR OK (ID=1, dist=2)
                TSP:MSG:READ 0-0-100 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                TSP:MSG:PAR OK (ID=0, dist=1)
                TSP:MSG:READ 104-104-100 s=255,c=3,t=8,pt=1,l=1,sg=0:1
                TSP:MSG:FPAR RES (ID=104, dist=1)
                TSM:FPAR:OK
                TSM:ID
                TSM:CHKID:OK (ID=100)
                TSM:UPL
                TSP:PING:SEND (dest=0)
                TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                TSP:MSG:READ 0-0-100 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                TSP:MSG:PONG RECV (hops=1)
                TSP:CHKUPL:OK
                TSM:UPL:OK
                TSM:READY
                TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                !TSP:MSG:SEND 100-100-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,ft=0,st=fail:2.0.0
                TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=ok:0
                TSP:MSG:READ 0-0-100 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=11,pt=0,l=15,sg=0,ft=0,st=ok:Vallox Digit SE
                TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:2.5
                TSP:MSG:SEND 100-100-0-0 s=0,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=2,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=3,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=4,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=5,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=6,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=7,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=8,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=9,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=10,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=11,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=12,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=13,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=14,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=15,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=24,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=25,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=26,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=27,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=28,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=29,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=30,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=31,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=32,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=33,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=34,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=35,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=36,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=37,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=38,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=39,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=40,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=41,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=42,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=43,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=44,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=45,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=46,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=47,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=48,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
                TSP:MSG:SEND 100-100-0-0 s=49,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
                Started cyclic update timer.
                Request registration...
                TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                TSP:MSG:READ 0-0-100 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                Node registration=1
                Init complete, id=100, parent=0, distance=1, registration=1
                Dropped 0
                Received telegram from 21->11 command=0 arg=A3
                Received telegram from 11->21 command=A3 arg=29
                Property 200 changed 41
                Power state 1
                TSP:MSG:SEND 100-100-0-0 s=8,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:1
                CO2 adjust state 0
                TSP:MSG:SEND 100-100-0-0 s=9,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:0
                Humidity adjust state 0
                TSP:MSG:SEND 100-100-0-0 s=10,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:0
                Heating state 1
                TSP:MSG:SEND 100-100-0-0 s=11,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:1
                Filter guard indicator 0
                TSP:MSG:SEND 100-100-0-0 s=12,c=1,t=24,pt=2,l=2,sg=0,ft=0,st=ok:0
                Heating indicator 1
                TSP:MSG:SEND 100-100-0-0 s=13,c=1,t=24,pt=2,l=2,sg=0,ft=0,st=ok:1
                Fault indicator 0
                TSP:MSG:SEND 100-100-0-0 s=14,c=1,t=24,pt=2,l=2,sg=0,ft=0,st=ok:0
                Serivce reminder indicator 0
                TSP:MSG:SEND 100-100-0-0 s=15,c=1,t=24,pt=2,l=2,sg=0,ft=0,st=ok:0
                Received telegram from 21->11 command=0 arg=29
                Received telegram from 11->21 command=29 arg=1
                Received telegram from 21->11 command=0 arg=35
                Received telegram from 11->21 command=35 arg=9D
                Temp incomming 19
                TSP:MSG:SEND 100-100-0-0 s=4,c=1,t=0,pt=2,l=2,sg=0,ft=0,st=ok:19
                Received telegram from 21->11 command=0 arg=71
                Received telegram from 11->21 command=71 arg=0
                This is the output of the mysensors 2.0 version which can be downloaded from
                https://github.com/windkh/mysensors/tree/master/ValloxSensor
                I wonder why your node has id=0.
                • B
                  B
                  boehrian
                  Hi, my output ist now:
                  0 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.1.1
                  3 TSM:INIT
                  4 TSF:WUR:MS=0
                  12 TSM:INIT:TSP OK
                  13 TSF:SID:OK,ID=42
                  15 TSM:FPAR
                  52 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  2059 !TSM:FPAR:NO REPLY
                  2061 TSM:FPAR
                  2098 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  4105 !TSM:FPAR:NO REPLY
                  4107 TSM:FPAR
                  4143 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  6151 !TSM:FPAR:NO REPLY
                  6153 TSM:FPAR
                  6189 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  8197 !TSM:FPAR:FAIL
                  8198 TSM:FAIL:CNT=1
                  8200 TSM:FAIL:PDT
                  18203 TSM:FAIL:RE-INIT
                  18205 TSM:INIT
                  18212 TSM:INIT:TSP OK
                  18214 TSF:SID:OK,ID=42
                  18216 TSM:FPAR
                  18253 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  20261 !TSM:FPAR:NO REPLY
                  20263 TSM:FPAR
                  20300 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  22307 !TSM:FPAR:NO REPLY
                  22309 TSM:FPAR
                  22346 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  24353 !TSM:FPAR:NO REPLY
                  24355 TSM:FPAR
                  24392 TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                  I get no reply from the Vallox.
                  Is your original Vallox controller online
                  • HeinzH
                    HeinzH
                    Heinz
                    wrote on last edited by Heinz
                    #26
                    The "no reply" message is from the mysensors library, but I don't know what it means.
                    The line "started cyclic update timer" indicates that the sensor initialized successfully, but it is missing in your output.
                    My latest code is online at
                    https://github.com/windkh/valloxserial/blob/master/examples/mysensors/ValloxSensor.ino
                      Use the log parser to help you interpret the log.
                      • HeinzH Heinz
                        ausbremenA
                        ausbremenA
                        ausbremen
                        @heinz
                        Hi Heinz, the SVG_FileLog_Vallox_#.gplot files are empty ...probably the link is dead...could you reup them? Or could you send them tio me?
                        Thanks, Holger
                        • HeinzH Heinz
                          ausbremenA
                          ausbremenA
                          ausbremen
                          @heinz
                          Sorry...everything is fine with the gplot files...it was my fault trying to look at them with the crimpson editor...instead of FHEM gplot
                          • C
                            C
                            captaindork
                            Hello Heinz, all,
                            first of all thank you for sharing your work in this thread!
                            I have not to much skills around programming and arduino, but was however able to build this and integrate my Vallox 90 SE into ioBroker. Absolutely Great!
                            You mentioned the bypass damper above and I see you have visualized it in fhem. I found the Value to set the Threshold temp for this (31), however I wonder where you got the actual bypass position from. Which Value shows if its open or closed?
                            I do not want to control it, i just would like to log the Position Status to see when it happens.
                            Thanks a lot i feel blind :)
                            • C captaindork
                              Hello Heinz, all,
                              HeinzH
                              HeinzH
                              Heinz
                              Hi @captaindork
                              sorry for delay,.... the position of the damper (which is the bypass) is indicated through a single bit of the multi purpose IO-Port 2. The library defines that as property 38 DamperMotorPositionProperty.
                              In the mysensors example it is published as
                              const uint8_t DAMPER_MOTOR_POSITION = 42;
                              The value is either 1 or 0.
                              I mapped it in FHEM as follows
                              attr MYSENSOR_Vallox mapReading_DamperMotorPosition 42 value1
                              define MYSENSOR_Vallox_DamperMotorPosition dummy
                              attr MYSENSOR_Vallox_DamperMotorPosition alias WRG-Bypass
                              attr MYSENSOR_Vallox_DamperMotorPosition devStateIcon 1:rc_GREEN 0:rc_BLANK
                              attr MYSENSOR_Vallox_DamperMotorPosition event-on-update-reading state
                              attr MYSENSOR_Vallox_DamperMotorPosition group Status
                              attr MYSENSOR_Vallox_DamperMotorPosition icon vent_bypass
                              attr MYSENSOR_Vallox_DamperMotorPosition room Lüftung
                              attr MYSENSOR_Vallox_DamperMotorPosition sortby 3
                              define MYSENSOR_Vallox_DamperMotorPosition_Notify notify MYSENSOR_Vallox:DamperMotorPosition:.* { my $d = sprintf ("%.0f", ReadingsVal("MYSENSOR_Vallox","DamperMotorPosition", 0));; fhem("set MYSENSOR_Vallox_DamperMotorPosition $d");;}
                              define MYSENSOR_Vallox_DamperMotorPosition_Notify2 at +*00:01:00 { my $d = sprintf "%.0f", ReadingsVal("MYSENSOR_Vallox","DamperMotorPosition", 0);; fhem("set MYSENSOR_Vallox_DamperMotorPosition $d");;}
                              • R
                                R
                                RHead
                                Hi.
                                Can you make exact parts list for this setup.
                                • HeinzH
                                  HeinzH
                                  Heinz
                                  Ok ... after my holidays.
                                  • HeinzH
                                    HeinzH
                                    Heinz
                                    Well basically the part list is very simple
                                    1x Arduino Mega 2560
                                    1x NRF24L01+
                                    1x Pushbutton
                                    2x MAX485 Module TTL Switch Module (one for sender, one for receiver)
                                    (e.g. https://protosupplies.com/product/max485-ttl-to-rs-485-interface-module/)
                                    The 1x Resistor 120Ohms is only neccessary if not already mounted on the MAX485 Module. It depends on what module
                                    you bought. So have a look at the layout and check if there is a 120Ohms resistor mounted between pins A and B.
                                    The module (https://protosupplies.com/product/max485-ttl-to-rs-485-interface-module/) already contains that resistor.
                                    Optionally you can add a capacitor between + and - to stabilize the voltage level if your power supply is a weak one.
                                    Anyone will do like 10uF, 100uF...
                                    • HeinzH
                                      HeinzH
                                      Heinz
                                      Note that you can make use of any MAX485 module that is suitable for the arduino (5V). Basically they are all the same except for a few minor tweaks like LEDs or other non relevant stuff.
                                      • MasMatM
                                        MasMatM
                                        MasMat
                                        I found this old thread and since I have a Vallox machine it's interesting. RS485 is new to me but MySensors isn't.
                                        Can I have a node like this described by Heinz parallel with the "mickey mouse"-display? Using the display's connector? Or is it one or the other?
                                        I'd feel better having both (manual display&buttons and connection to MySensors=>Domoticz, in my case).
