  3. Domoticz
  4. WebThings gateway and Domoticz
4 Posts 3 Posters 785 Views 3 Watching
  • R Offline
    R Offline
    rmalbers
    I entered another question/issue I have here also but I guess I'm wondering, can I run Domoticz and WebThings at the same time both connected to the same mysensors gateway? I currently am trying to do that and maybe that's my problem.
    • mfalkviddM Offline
      I don't have experience with webthings, but two controllers usually do not work together. But it depends a bit on how you use and configure the controllers.
      R 1 Reply Last reply
        R Offline
        R Offline
        rmalbers
        @mfalkvidd I did see some talk in the 'Vera' section about it and it 'sounds' like it would work if you have this set to more than one and I do have it set to six: #define MY_GATEWAY_MAX_CLIENTS 6 ---- After thinking about it and posting this I did shut down domoticz and tried it with the same results (as I have in my other post) so I guess that is not my issue.
        • alowhumA Offline
          alowhumA Offline
          alowhum
          If you are using a serial gateway, then no, you cannot. The serial messages can only go to one place, so one of the two controllers will win. It might get mixed up - some messages to one, some to the other.
          I don't know about the other two types of gateway.
          11.9k
          113.3k
