  3. DHT and DOOR sensor
DHT and DOOR sensor
20 Posts 6 Posters 4.1k Views 6 Watching
  • T Offline
    T Offline
    Terence Faul
    Hi
    Please assist, I am trying to combine the default straight from the examples, but the DHT give an error on compile
     * Version 1.0: Henrik EKblad
    // Enable debug prints
    #define MY_RADIO_RF24
    //#define MY_RS485
    #include <DHT.h>
    #include <Bounce2.h>
    #define DHT_DATA_PIN 3
    #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
    // Set this offset if the sensor has a permanent small offset to the real temperatures.
    // In Celsius degrees (as measured by the device)
    #define SENSOR_TEMP_OFFSET 0
    #define CHILD_ID 3
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
    Bounce debouncer = Bounce();
    int oldValue=-1;
      sendSketchInfo("TemperatureAndHumidity", "1.1");
      present(CHILD_ID_HUM, S_HUM);
      present(CHILD_ID, S_DOOR);
    	// Setup the button
    pinMode(BUTTON_PIN,INPUT);
    // Activate internal pull-up
    debouncer.attach(BUTTON_PIN);
    debouncer.interval(5);
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        // apply the offset before converting to something different than Celsius degrees
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        Serial.println(temperature);
      } else {
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
      } else {
        nNoUpdatesHum++;
    		debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
         // Send in the new value
         send(msg.set(value==HIGH ? 1 : 0));
         oldValue = value;
      sleep(UPDATE_INTERVAL);
    The error is below
    /Users/terencefaul/Documents/PlatformIO/Projects/Mysensors DHT and Door/src/BinarySwitchSleepSensor.ino.ino: In function 'void loop()':
    /Users/terencefaul/Documents/PlatformIO/Projects/Mysensors DHT and Door/src/BinarySwitchSleepSensor.ino.ino:129:22: error: no matching function for call to
    'DHT::readSensor(bool)'
    dht.readSensor(true);```
    HomerH S 2 Replies Last reply
    • T Terence Faul
      Hi
      //#define MY_RS485
      #include <DHT.h>
      #define CHILD_ID 3
      float lastTemp;
      float lastHum;
      bool metric = true;
      DHT dht;
      int oldValue=-1;
      	// Setup the button
          if (!metric) {
          nNoUpdatesTemp = 0;
          #ifdef MY_DEBUG
        } else {
          nNoUpdatesTemp++;
          lastHum = humidity;
          nNoUpdatesHum = 0;
          #ifdef MY_DEBUG
        } else {
          nNoUpdatesHum++;
      		debouncer.update();
           oldValue = value;
      The error is below
      HomerH Offline
      HomerH Offline
      Homer
      @terence-faul I'm probably wrong, but it looks to me like the sensor and the button are on the same pin.
      I'm only learning, so it's probably wise to wait for someone else to chime in.
      mfalkviddM 2 Replies Last reply
      • HomerH Homer
        mfalkviddM Online
        mfalkviddM Online
        @homer you'll need to install the modified DHT library as described on https://www.mysensors.org/build/humidity#example
        HomerH 1 Reply Last reply
          HomerH Offline
          HomerH Offline
          Homer
          @mfalkvidd said in DHT and DOOR sensor:
          Thanks, but did I spot the issue with the pins correctly?
          • HomerH Homer
            mfalkviddM Online
            mfalkviddM Online
            @homer yes, they are using the same pin. Move one of them (doesn't matter which) to pin 2. On atmega328, only pins 2 and 3 have full interrupt functionality.
            • T Offline
              T Offline
              Terence Faul
              Hi
              I have sorted the pins and library problems, but now I get failed to read errors
              Updated Sketch
              #define MY_RX_MESSAGE_BUFFER_FEATURE
              #define MY_RF24_IRQ_PIN 2
              //#define MY_RS485
              #include <DHT.h>
              #define DHT_DATA_PIN 4
              #define CHILD_ID 3
              float lastTemp;
              float lastHum;
              bool metric = true;
              DHT dht;
              int oldValue=-1;
                sendSketchInfo("Door/DHT", "1.1");
              	// Setup the button
                  if (!metric) {
                  nNoUpdatesTemp = 0;
                  #ifdef MY_DEBUG
                } else {
                  nNoUpdatesTemp++;
                  lastHum = humidity;
                  nNoUpdatesHum = 0;
                  #ifdef MY_DEBUG
                } else {
                  nNoUpdatesHum++;
              		debouncer.update();
                   oldValue = value;
              and error snippet
              3534 TSF:MSG:SEND,1-1-0-0,s=2,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
              3545 MCO:SLP:MS=60000,SMS=0,I1=1,M1=1,I2=255,M2=255
              3553 TSF:TDI:TSL
              3555 MCO:SLP:WUP=1
              3557 TSF:TRI:TSB
              3584 TSF:MSG:SEND,1-1-0-0,s=2,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
              3592 MCO:SLP:MS=60000,SMS=0,I1=1,M1=1,I2=255,M2=255
              3602 TSF:TDI:TSL
              3604 MCO:SLP:WUP=1
              3606 TSF:TRI:TSB
              • T Terence Faul
                Hi
                Updated Sketch
                //#define MY_RS485
                #include <DHT.h>
                #define CHILD_ID 3
                float lastTemp;
                float lastHum;
                bool metric = true;
                DHT dht;
                int oldValue=-1;
                	// Setup the button
                    if (!metric) {
                    nNoUpdatesTemp = 0;
                    #ifdef MY_DEBUG
                  } else {
                    nNoUpdatesTemp++;
                    lastHum = humidity;
                    nNoUpdatesHum = 0;
                    #ifdef MY_DEBUG
                  } else {
                    nNoUpdatesHum++;
                		debouncer.update();
                     oldValue = value;
                and error snippet
                3553 TSF:TDI:TSL
                3555 MCO:SLP:WUP=1
                3557 TSF:TRI:TSB
                3602 TSF:TDI:TSL
                3604 MCO:SLP:WUP=1
                3606 TSF:TRI:TSB
                mfalkviddM Online
                mfalkviddM Online
                @terence-faul said in DHT and DOOR sensor:
                This means the DHT library is unable to read from the DHT sensor. Double-check that the DHT gets sufficient power and that it is wired correctly. If you have another DHT sensor, switch sensors and see if that helps.
                • T Offline
                  T Offline
                  Terence Faul
                  Will give that a go. But if I load the DHT only sketch on the same node it reads fine.
                  Could you check my sketch I’m a bit of a noob with code
                  • T Terence Faul
                    mfalkviddM Online
                    mfalkviddM Online
                    @terence-faul the sketch looks good to me. Could you post your "dht only" sketch?
                    • HomerH Offline
                      HomerH Offline
                      Homer
                      I can't believe I spotted am error in the code! I guess I'm starting to get a bit better at this! 😁😁
                      • T Offline
                        T Offline
                        Terence Faul
                        //#define MY_RS485
                        #include <DHT.h>
                        float lastTemp;
                        float lastHum;
                        bool metric = true;
                        DHT dht;
                            if (!metric) {
                            nNoUpdatesTemp = 0;
                            #ifdef MY_DEBUG
                          } else {
                            nNoUpdatesTemp++;
                            lastHum = humidity;
                            nNoUpdatesHum = 0;
                            #ifdef MY_DEBUG
                          } else {
                            nNoUpdatesHum++;
                        • T Terence Faul
                          //#define MY_RS485
                          #include <DHT.h>
                          float lastTemp;
                          float lastHum;
                          bool metric = true;
                          DHT dht;
                              if (!metric) {
                              nNoUpdatesTemp = 0;
                              #ifdef MY_DEBUG
                            } else {
                              nNoUpdatesTemp++;
                              lastHum = humidity;
                              nNoUpdatesHum = 0;
                              #ifdef MY_DEBUG
                            } else {
                              nNoUpdatesHum++;
                          mfalkviddM Online
                          mfalkviddM Online
                          Thanks @terence-faul
                          I can't see any problem with the sketches.
                          • skywatchS Offline
                            skywatchS Offline
                            skywatch
                            @Terence-Faul The only thing I can say is that it is generally good practice to put all #include statements at the start of the code, then all the #define statements and finally all other items. At the moment you #define things before you #include the library and maybe that is an issue for the compiler?
                            • skywatchS skywatch
                              mfalkviddM Online
                              mfalkviddM Online
                              @skywatch while your recommendation is good in general, all MySensors defines (MY_*) must be defined before including MySensors.h. Otherwise the defines won't be available to the library, so the library will need to fall back on the default settings.
                              skywatchS 1 Reply Last reply
                              • T Offline
                                T Offline
                                Terence Faul
                                Thanks so much for the help, what is the next step then? create two sensors?
                                K 1 Reply Last reply
                                • T Terence Faul
                                  K Offline
                                  K Offline
                                  kimot
                                  wrote on last edited by kimot
                                  @terence-faul
                                  comment step by step blocks of code for DOOR switch and try when it start to work.
                                    skywatchS Offline
                                    skywatchS Offline
                                    skywatch
                                    @mfalkvidd Ah yes, I forgot that bit!
                                    • skywatchS Offline
                                      skywatchS Offline
                                      skywatch
                                      This post is deleted!
                                      • T Terence Faul
                                        Hi
                                        //#define MY_RS485
                                        #include <DHT.h>
                                        #define CHILD_ID 3
                                        float lastTemp;
                                        float lastHum;
                                        bool metric = true;
                                        DHT dht;
                                        int oldValue=-1;
                                        	// Setup the button
                                            if (!metric) {
                                            nNoUpdatesTemp = 0;
                                            #ifdef MY_DEBUG
                                          } else {
                                            nNoUpdatesTemp++;
                                            lastHum = humidity;
                                            nNoUpdatesHum = 0;
                                            #ifdef MY_DEBUG
                                          } else {
                                            nNoUpdatesHum++;
                                        		debouncer.update();
                                             oldValue = value;
                                        The error is below
                                        sharpy
                                        Hi @terence-faul did you fix this?
                                        i'm also trying too merge a door & dht sketch but have not got a clue where too start
                                        if you have solved this can you post the working sketch
                                        • HomerH Offline
                                          HomerH Offline
                                          Homer
                                          How much power are you feeding the sensor? I've had issues when I've fed too little power and it's resolved once I use more power.
