  3. sendTxPowerLevel and sendSignalStrength
7 Posts 3 Posters 1.6k Views 5 Watching
    manutremo
    Hi, I'm interested on using the functions in the post title. I'm running Mysensors 2.2.0., and I have
    #define MY_SIGNAL_REPORT_ENABLED
    in my sketch.
    If I add something like
    sendSignalStrength (6);
    or
    sendTxPowerLevel (6);
    to my sketch, the Arduino compiler complains about undefined references.
    What do I need to do to get them working?
    Thanks.
    • berkseoB
      berkseoB
      berkseo
      With pleasure, too, I want comments from the founding fathers. How to use? Linker error.
      • scalzS
        scalzS
        wrote on last edited by scalz
        • when you enable MY_SIGNAL_REPORT_ENABLED, it should automatically send signal quality to the controller. Ideally controller could handle this message type. It is an internal message type I_
        • I think these two functions doesn't work because they aren't implemented yet, maybe simply an oversight or an artefact :)
        To directly get the signal value, you can use transportGetSignalReport() .
        • https://www.mysensors.org/apidocs/group__MyTransportgrp.html#ga45f0081116ad5985b8fc60c66689b871
        • https://github.com/mysensors/MySensors/blob/master/hal/transport/MyTransportHAL.h#L48
        If report is not available for a particular mcu, or a radio module (because of not provided by the hardware itself or not implemented yet), then it should return INVALID_RSSI, INVALID_SNR, INVALID_PERCENT, or INVALID_LEVEL
        • berkseoB
          berkseoB
          berkseo
          @scalz said in sendTxPowerLevel and sendSignalStrength:
          this is the most important..
          • berkseoB
            berkseoB
            berkseo
            wrote on last edited by berkseo
            int16_t RSSIQuality;
            typedef enum {
              I_SIGNAL_REPORT_QUALITY  = 35, //!< Device signal quality
            } custom_mysensors_internal_t;
            #define MY_RADIO_NRF5_ESB
            #define MY_NODE_ID 200
            #define MY_PARENT_NODE_ID 0
            #define MY_TRANSPORT_UPLINK_CHECK_DISABLED
            #define CHILD_ID 0
            MyMessage msg(CHILD_ID, V_TEMP);
              send(msg.set(25.0 + random(0, 30) / 10.0, 2),1);
              RSSIQuality = calculationRssiRxQuality();
              sendSignalStrength(RSSIQuality, 1);
              wait(3000, C_INTERNAL, I_SIGNAL_REPORT_QUALITY);
              CORE_DEBUG(PSTR("MyS: TEST WAIT\n"));
              wait(5000);
            //****************************** very experimental *******************************
            bool sendSignalStrength(const int16_t level, const bool ack)
              return _sendRoute(build(_msgTmp, GATEWAY_ADDRESS, NODE_SENSOR_ID, C_INTERNAL, I_SIGNAL_REPORT_QUALITY,
                                      ack).set(level));
            int16_t calculationRssiRxQuality() {
              int16_t nRFRSSI_temp = transportGetReceivingRSSI();
              int16_t nRFRSSI = map(nRFRSSI_temp, -85, -40, 0, 100);
              if (nRFRSSI < 0) {
                nRFRSSI = 0;
              if (nRFRSSI > 100) {
                nRFRSSI = 100;
              return nRFRSSI;
            • berkseoB
              berkseoB
              berkseo
              71539 TSF:MSG:SEND,200-200-0-0,s=255,c=3,t=35,pt=2,l=2,sg=0,ft=0,st=OK:42
              71546 TSF:MSG:READ,0-0-200,s=255,c=3,t=35,pt=2,l=2,sg=0:42
              • scalzS
                scalzS
                @berkseo
                yes, until now it has been implemented for rfm radios only, as nrf24 doesn't provide true rssi value. As usual, features appears along interests.
                So if you want it for nrf5, maybe post/PR your snippet on github ;)
                On my side no time for testing this, my mysensors HA isn't 2.4ghz based as I need longer range, and keep 2.4ghz bandwidth in case for others protocol (wifi, ble, zigbee) for limiting issues.
