  3. NRF24l01 Sensor_id aleatory
11 Posts 2 Posters 1.6k Views 2 Watching
    maos
    wrote on last edited by maos
    Hello, i need help
    I have a gateway with nrf24l01 with the mysensor lib and a client with the arduino mini pro.
    However when I get in the gatway the topic of the sensor_id is random.
    I tested with an arduino nano and it worked well.
    Something that is escaping me?
    63551 GWT:TPS:TOPIC=mygateway1-out/255/174/3/0/3,MSG SENT
    64551 TSF:MSG:READ,255-255-0,s=139,c=3,t=3,pt=0,l=0,sg=0:
    64557 GWT:TPS:TOPIC=mygateway1-out/255/139/3/0/3,MSG SENT
    65557 TSF:MSG:READ,255-255-0,s=104,c=3,t=3,pt=0,l=0,sg=0:
    65562 GWT:TPS:TOPIC=mygateway1-out/255/104/3/0/3,MSG SENT
    66562 TSF:MSG:READ,255-255-0,s=69,c=3,t=3,pt=0,l=0,sg=0:
    66567 GWT:TPS:TOPIC=mygateway1-out/255/69/3/0/3,MSG SENT
    174,139,104,69
    in the client I only have two registered:
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    sendSketchInfo("TemperatureAndHumidity", "1.1");
    present(CHILD_ID_HUM, S_HUM);
    • M maos
      Hello, i need help
      174,139,104,69
      float lastTemp;
      float lastHum;
      bool metric = true;
      Strange problem.
      Could you post the full sketch and the log from the node? (preferably with gateway log for the same time)
        maos
        This??
        Basic gateway :
        #define MY_BAUD_RATE 115200
        #define MY_RADIO_RF24
        //#define MY_RADIO_RFM95
        #define MY_GATEWAY_ESP8266
        // Set MQTT client id
        // Enable these if your MQTT broker requires username/password
        // Set WIFI SSID and password
        #define MY_WIFI_SSID "xxx"
        #define MY_WIFI_PASSWORD "xxx"
        // #define MY_HOSTNAME "mqtt-sensor-gateway"
        // MQTT broker ip address.
        #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 211
        //MQTT broker if using URL instead of ip address.
        //#define MY_CONTROLLER_URL_ADDRESS "192.168.1.211"
        #define MY_PORT 1883
        // Enable inclusion mode
        //#define MY_INCLUSION_MODE_BUTTON_PIN D1
        // Set blinking period
        //#define MY_DEFAULT_LED_BLINK_PERIOD 300
        // Flash leds on rx/tx/err
        //#define MY_DEFAULT_ERR_LED_PIN 16 // Error led pin
        //#define MY_DEFAULT_RX_LED_PIN 16 // Receive led pin
        //#define MY_DEFAULT_TX_LED_PIN 16 // the PCB, on board LED
        #include <ESP8266WiFi.h>
        Client, simple sketch to send only simple values like temperature a humidity :
        // Enable debug prints
        //#define MY_RS485
        //#define SENSOR_TEMP_OFFSET 0
        static const uint64_t UPDATE_INTERVAL = 5000;
        //static const uint8_t FORCE_UPDATE_N_READS = 10;
        bool metric = true;
        send(msgTemp.set(12, 1));
        send(msgHum.set(66, 1));
        //sleep(UPDATE_INTERVAL);
        delay(UPDATE_INTERVAL);
          maos
          Forget, i use node-red, the message arrives, but of course empty, because i subscribe : mygateway1-out/#...
            maos
            I think that is a insufficient current. A mini is a 3.3v. Now a use a pro mini 5v, and work....
              maos
              NRF24 can work with wemos d1 mini as client? I try but the result is the sensor_id in topic, in gateway is aleatory .
              • M maos
                @maos the node is trying to request a node id.
                Add #define MY_NODE_ID 3 (or whatever number between 1 and 254 you want your node to have) in the node sketch, above #include MySensors.h
                  maos
                  @mfalkvidd said in NRF24l01 Sensor_id aleatory:
                  Yes, it does. This is the first time I work with this livrary. Thank you for taking the time to help me.
                  I have this scenario. Have a gateway with mqtt and others to send to this gateway. However I also need to send some information to the gateways. I have control receive (const MyMessage & message) {
                  However can I, send this information to all the clients that are sending to this gateway?
                  • M maos
                    @maos great that you got it working.
                    Sending to all clients can be done, but there are a few things to consider:
                    • nodes on battery will be sleeping and will therefore not be able to receive messages. To handle this case, look at smartsleep.
                    • when should the information be sent? Is it triggered by some message from something? Or by time? Something else?
                    • will you be sending the exact same information, or will the information be customized per node?
                    Some controllers support sending to multiple nodes. How to do this differs depending on which controller you are using. Sometimes it is better to let the nodes request information from the controller.
                      maos
                      Sorry, I guess I was not very clear. At this point would be to just send to another nearby node 3 or 4.
                      I do not want to send it to everyone at the same time.
                      From gateway to another node.
                        maos
                        Stupid.....
                        mygateway1-in / 3/0/1/0/1, to publish .....
                        I'm going to study the library gradually, so far I think top
