  2. Enclosures / 3D Printing
  3. Best 3d printers
Best 3d printers
106 Posts 30 Posters 31.2k Views 28 Watching
  • HomerH Offline
    HomerH Offline
    Homer
    I'm thinking about buying the Creality CR-10 S5. Has anyone had any experience with this 3D printer or have heard any good or negative comments about it?
    • B bjacobse
      @skywatch @mbj
      I think you are experienced and - and would you really recommend for a fist time use/novice as the topic poster to suggest printing in more than 1 colour? as beginner you need advice to get started and get success, and build competence, then you can later on move to a higher level, modify your printer and print with several colours
      M Offline
      M Offline
      mbj
      @bjacobse With two extruders you load up each with your most common filaments and thus do a filament change less frequent. Then it is a "nice-to-have" but nothing cruicial at least not for me who rarely combine materials in same print.
      In more advanced use when people want to print for example support structures in one material and the item itself with another filament this is not practically possible with less than two extruders.
      Changing colors can be done with one extruder but frequent changes for same part are of course a pain.
      So depending on use the dual (or even more complex) extruders are everything from just nice to a must. For a beginner it is not needed (and for something "home built" it is most likely possible to change to a more complex extruder after some years).
      B 1 Reply Last reply
      • M mbj
        B Offline
        B Offline
        bjacobse
        @mbj
        And please share you experience using 2 extruders when available, (as I agree it is a nice enhancement) after a novice have become experienced using one filament/extruder
        • C Offline
          C Offline
          Crumpy10
          Well, I didnt think this post would get so popular! but thats great, have learnt a lot just by looking suggested things up.
          So, Software....
          I am thinking of using sketchup as I already use this quite a bit for different projects and can find my way around it well.
          Has anyone else used it and think there is better? Preferably free or open source...
          What's everyone's preference?
          mfalkviddM skywatchS B 3 Replies Last reply
          • C Crumpy10
            So, Software....
            I have used SolidWorks because that’s what I learned in school. I like it.
            Fusion360 is becoming very popular.
            Both are available for free for makers.
            Both these have a engineering focus, while Sketchup has a more aesthetic design focus I think.
            • C Crumpy10
              So, Software....
              skywatchS Offline
              skywatchS Offline
              skywatch
              @crumpy10 For starting out I'd suggest online sites like tinkercad. It's free, you can download stl files to print and it's a good way to learn.
              It's not as fully featured as some of the paid packages, but it will give you a taste of what you need and can go from there with whatever suits your need and budget.
              I believe that sktechup also can output stl files (maybe needs a plugin, I don't know I don't use it), so maybe an option if you are happy with that.
              • HomerH Offline
                HomerH Offline
                Homer
                I just purchased a Creality CR-10S Pro. It should arrive in a couple days. Anyone own one of these? This is my first step into the 3D making world :-)
                skywatchS 1 Reply Last reply
                • HomerH Homer
                  skywatchS Offline
                  skywatchS Offline
                  skywatch
                  #28
                  @homer I think you've made a good choice - good luck with with your new source of frustration and learning! :)
                  If it turns out you don't like it, feel free to send it to me (Heeeee) ;)
                  From experience though, test out your printer with something simple from thingiverse.com and see how it goes....
                  For me the following were the areas I had problems with at first.....
                  1. Bed leveling - this has to be right to get the first layer the same thickness.
                  2. Bed adhesion - I had 'lifting' problems that took a while to sort out.
                  3. Supports - You'll get a feel for where and when to use supports, it takes a little trail and error though....
                  HomerH 1 Reply Last reply
                  • C Crumpy10
                    So, Software....
                    B Offline
                    B Offline
                    bjacobse
                    @crumpy10
                    I use Freecad as it works on Linux/Ububntu
                    Why not use the CAD program that already are using and are familiar with
                    • C Offline
                      C Offline
                      Crumpy10
                      Thanks everyone, good advice. A bit of trial and error learning, with a vertical learning curve...
                      Looks like I may go for either the Creality CR10 or the Ender 3, then have a play printing some existing items to see whats possible before I do my own designs.
                      • skywatchS skywatch
                        HomerH Offline
                        HomerH Offline
                        Homer
                        @skywatch said in Best 3d printers:
                        Thanks mate! So far I'm liking it, so I'm sorry to say that I won't be sending it to you anytime soon haha
                        So far I've printed 3 things. The first was the cat that was on the SD card, and this came out perfect. I used the filament that came with the printer. My next two models were the same, a sign for two of my kids who play Fortnite. The object was quite flat but spread across the bed. Each was printer with different filament. The first lifted very badly but not bad enough to use. The good thing was that this print was nice and easy to remove from the bed haha. The third printed perfectly but wow it was extremely difficult to get off the bed!
                        I do have an issue with leveling. The bar that holds the printer head, no matter what I do in the way of adjustment, the right side is close to 3mm higher than the left. I'm in the process of having this addressed with who I bought it from, but at this stage all they are saying is to level the bed automatically, which seems to be working fine, but I don't know how it will go with taller prints.
                        I would like to start making my own boxes for my Mysensors, but don't know what program to use. I've never done this sort of thing before, so at the moment I'm a little concerned about the learning curve, so if you or anyone knows of a program that is simple to use for this purpose, please share what it is!
                        • HomerH Homer
                          skywatchS Offline
                          skywatchS Offline
                          skywatch
                          @homer said in Best 3d printers:
                          Thanks mate! So far I'm liking it, so I'm sorry to say that I won't be sending it to >you anytime soon haha
                          Awwwww.... :(
                          I would like to start making my own boxes for my Mysensors, but don't know >what program to use. I've never done this sort of thing before, so at the moment >I'm a little concerned about the learning curve, so if you or anyone knows of a >program that is simple to use for this purpose, please share what it is!
                          As I said, try tinkercad. It's a free online 3D design tool that will give you a good taste of 3D design and the features you may want/need in a full paid product.
                          You probably won't stop printing now for at least 6 months! ;)
                          • C Offline
                            C Offline
                            cyberchuckTX
                            I bought a PowerSpec Wanhao Duplicator Prusa i3 Plus and am quite happy with it (see https://www.microcenter.com/product/486543/wanhao-duplicator-i3-plus-3d-printer ).
                            Several things to consider:
                            • There are a LOT of great 3D communities for 3D printers; check out "Wanhao" on Thingiverse to see parts you can print to upgrade your printer(s) ( http://www.thingiverse.com/search?q=wanhao&dwh=995d35d8e0e03d1 ).
                            • Check with your local makerspaces (Houston has 13 Makerspaces, I'd check with the major ones like TXRX Labs ( https://www.txrxlabs.org/ ) who not only can advise you on printers but may actually sell kits made by members.
                            • C Offline
                              C Offline
                              Crumpy10
                              wrote on last edited by Crumpy10
                              #34
                              Ok, so I got my hands on an Ender3 printer. So far so good, very impressed for the price. But could someone tell me what causes this?0_1564479120229_96D400A1-4B43-462F-8160-F1A376C13888.jpeg
                              Y B N 4 Replies Last reply
                              • C Crumpy10
                                Y Offline
                                Y Offline
                                @crumpy10 bad adhesion to printer bed, mixed with inconsistent filament extrusion.
                                See this page for 3d printer troubleshooting : https://www.simplify3d.com/support/print-quality-troubleshooting/
                                • alowhumA Offline
                                  alowhumA Offline
                                  alowhum
                                  Woule the Mirobot in theory be capable of working like a 3D printer?
                                  https://www.kickstarter.com/projects/mirobot/mirobot-6-axis-mini-industrial-robot-arm/faqs
                                  • C Crumpy10
                                    B Offline
                                    B Offline
                                    bjacobse
                                    wrote on last edited by bjacobse
                                    #37
                                    @crumpy10
                                    Looks like your skirt are fine (The round first prints) but inside your print you get to little PLA through your nozzle
                                    is temperature correct?
                                    is is a good source from PLA? or is it that came along the 3D printer, then swap and use new PLA
                                    If you have Bowden extruder, is it extruding correctly? maybe the gear slips
                                    And then maybe is your bed 100% calibrated?
                                    I don't think your nozzle is clogged as the skirt looks ok
                                    • alowhumA alowhum
                                      B Offline
                                      B Offline
                                      bjacobse
                                      @alowhum
                                      NO it can't be used as 3D printer, it's not accurate enough
                                      QA from their homepage:
                                      Would it be possible to place circuit components on circuit boards using this arm or does it not have enough precision?
                                      Yes, the repeatability is 0.2mm, This is enough for PCB soldering.
                                      My 3D printer, zonestar 802 have this accuracy:
                                      XY-Axis Positioning Accuracy: 0.012mm
                                      • alowhumA Offline
                                        alowhumA Offline
                                        alowhum
                                        @bjacobse thanks!
                                        • C Crumpy10
                                          B Offline
                                          B Offline
                                          bjacobse
                                          @crumpy10
                                          Try FIRST to level your bed - PLA can't stick to air if you have too much distance between nozzlehead and bed.
