  3. Raspberry Gateway
Raspberry Gateway
6 Posts 4 Posters 1.4k Views 4 Watching
  • A
    A
    alru
    I plan to set up a Raspberry Gateway (as standard ethernet version).
    Since I do use different Gateways, on different frequencies, I like to know, if there is a way to configure the channel on the Gateway.
    I use the NRF24 Radio.
    • skywatchS
      skywatchS
      skywatch
      #define MY_RF24_CHANNEL (put your channel number here).
      That's all there is to it!
      It should look like #define MY_RF24_CHANNEL (107)
      • alowhumA
        alowhumA
        alowhum
        @skywatch He mentioned using the 'standard ethernet version', so he's not using a serial device as the gateway. This means it's a bit more complicated.
        skywatchS 1 Reply Last reply
        • alowhumA alowhum
          skywatchS
          skywatchS
          skywatch
          @alowhum Sorry, I didn't realise that. I thought it was pi connecting to controller via ethernet and some rf GW's attached - I'll get my coat and go and watch the footie instead!
          • A alru
            @alru use
            --my-rf24-channel=<0-125>   RF channel for the sensor net. [76]
            See https://www.mysensors.org/build/raspberry#configure and https://www.mysensors.org/apidocs/group__RaspberryPiGateway.html for detailed documentation.
            A 1 Reply Last reply
              @alru use
              A
              A
              alru
              @mfalkvidd Thank you, this should be the solution I'm locking for.
              Meanwhile I found the config-description...
