  3. Is it possible to reduce SRAM usage of Arduino Nano ethernet MySensors gateway (based on ECN28J60) ?
3 Posts 2 Posters 675 Views 2 Watching
  • M Offline
    M Offline
    matkor
    I need only few binary sensors/switches (relays) controllable from HomeAssistant, so I hoped to add their simple logic to
    https://github.com/mysensors/MySensorsArduinoExamples/blob/master/examples/GatewayENC28J60/GatewayENC28J60.ino
    But building above already takes: Sketch uses 29276 bytes (...) Global variables use 1757 bytes
    I tried to reduce SRAM usage, but disabling MY_DEBUG, MY_RADIO_RF24, MY_INCLUSION_* , MY_DEFAULT_* reduces sizes to
    Sketch uses 22980 bytes (...) Global variables use 1626 bytes (79%)
    only :(
    Is there any way one can go down with SRAM usage further?
    • M matkor
      only :(
      @matkor yes. Use the W5100 module instead (if you need ethernet)
      If you don’t need ethernet, use usb or wifi since those options also use less ram.
      • M Offline
        M Offline
        matkor
        @mfalkvidd
        Good idea, thanks! Same code, but only W5100 based:
        Sketch uses 17190 bytes (...) Global variables use 853 bytes (41%)
        Using W5500 ( Ethernet2.h ) gives even better:
        Sketch uses 14712 bytes (...) Global variables use 809 bytes (39%)
        I need some kind of 25m wire so options are ethernet, RS-485 or PJON
