  3. Vera
  4. Vera Edge pi v1 ethernet gateway
10 Posts 2 Posters 2.2k Views 2 Watching
  • urbanusU
    urbanusU
    urbanus
    Hi. Anybody have the above configuration working? I have compiled as per the build instructions and run the test and all seems well, no error messages etc. Vera however doesn't seem to communicate with the gateway. I can ping the Vera.
    Regards
    David
    urbanusU 1 Reply Last reply
    • urbanusU urbanus
      Regards
      David
      urbanusU
      urbanusU
      urbanus
      @urbanus I also note that the wiring diagram for the LED's seems to be incorrect 9or I'm not reading it correctly. Doesnt the pi switch the outputs HIGH when a GPIO pin is called? The diagram seems to feed the LED's from 3.3v and then on through the limiting resistor back to the GPIO which will be at 3.3v when high.
      • urbanusU urbanus
        urbanusU
        urbanusU
        urbanus
        @urbanus this is the output from the test:
        Dec 07 14:56:12 INFO Starting gateway...
        Dec 07 14:56:12 INFO Protocol version - 2.3.1
        Dec 07 14:56:12 DEBUG MCO:BGN:INIT GW,CP=RNNGL---,REL=255,VER=2.3.1
        Dec 07 14:56:12 DEBUG TSF:LRT:OK
        Dec 07 14:56:12 DEBUG TSM:INIT
        Dec 07 14:56:12 DEBUG TSF:WUR:MS=0
        Dec 07 14:56:12 DEBUG TSM:INIT:TSP OK
        Dec 07 14:56:12 DEBUG TSM:INIT:GW MODE
        Dec 07 14:56:12 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
        Dec 07 14:56:12 DEBUG MCO:REG:NOT NEEDED
        Dec 07 14:56:12 DEBUG Listening for connections on 0.0.0.0:5003
        Dec 07 14:56:12 DEBUG MCO:BGN:STP
        Dec 07 14:56:12 DEBUG MCO:BGN:INIT OK,TSP=1
        Dec 07 14:56:12 DEBUG TSM:READY:NWD REQ
        Dec 07 14:56:12 DEBUG TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
        Dec 07 15:02:59 DEBUG TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        Dec 07 15:02:59 DEBUG TSF:MSG:BC
        Dec 07 15:02:59 DEBUG TSF:MSG:FPAR REQ,ID=1
        Dec 07 15:02:59 DEBUG TSF:PNG:SEND,TO=0
        Dec 07 15:02:59 DEBUG TSF:CKU:OK
        Dec 07 15:02:59 DEBUG TSF:MSG:GWL OK
        Dec 07 15:03:00 DEBUG TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        • urbanusU urbanus
          urbanusU
          urbanusU
          urbanus
          @urbanus Just looking at the config.h file - do I have to set my SSID and password in this file before I "make" ? If do is this my VERA ssid etc. or my wifi ssid?
          • urbanusU
            urbanusU
            urbanus
            Just in case anybody visits this post with the same problems - It's now sorted and working. Basic issues were:
            1 - I did not set the parameters in the MyConfig.h files correctly, especially I needed to uncomment the inclusion feature!
            2 - The fritz diagram for the LED 's is incorrect, if you build the gateway with the LED's you need to switch the GPIO pins to ground not to vcc as shown.
            Regards
            David
            • urbanusU urbanus
              Regards
              David
              Thanks for reporting back @urbanus
              Could you share where the fritzing diagram is? Would be good if we could correct it.
              Did you use MY_WITH_LEDS_BLINKING_INVERSE ?
              • urbanusU
                urbanusU
                urbanus
                Hi. Hope this link is okay, I'm not really sure how to do this.
                https://www.mysensors.org/uploads/57c1a876f40891c215911e40/image/RPi3_status_led.jpg
                It shows the GPIO pins routed to pin 1 on the pi - pin 1 is 3.3v. I followed the diagram withoit thinking the first tie and it was only when I had problems I started to think "how does this work"? taking it to ground sorted it.
                David
                • urbanusU
                  urbanusU
                  urbanus
                  Hi again, I did not select the inverse feature as I was under the impression this just changes their behaviour ( i.e normally illuminated and turned off/on during tx/rx/error or normally not illuminated and turns on/off during tx/rx/error).
                  Thanks,
                  David
                    Thanks for explaining. I have not used the status leds myself, and from what I see the wiring in the picture is correct but maybe the code behavior has changed. I'll try to dig through the code some day sson.
                    • urbanusU urbanus
                      Thanks,
                      David
                      @urbanus in your wiring, did you flip around the leds? (i.e. did you connect the longer pin to the gpio pins instead of to vcc?
                      With your wiring, are the leds on when there is no traffic?
                      My guess is that you have reversed the connections. Which is fine, but by default the leds will be on.
