  3. Home Assistant
  4. Temp Humidity sensor only showing humidity in HA
4 Posts 4 Posters 760 Views 4 Watching
    Matt McAllister
    Good day,
    I've created a temperature/humidity sensor using a DHT22. My gateway is a nESP8266 MQTT. I have HA installed in a docker container on my OpenMediaVault server. I'm seeing the sensor populate automatically in the 'Entities' section of HA, unfortunately I'm only seeing the humidity node and not the temp node.
    Below is my sensor sketch, it's mostly stock. I've tried manually defining the node id but that didn't seem to change anything, other than the 'child id' in HA. I also renamed it to 'Greenhouse' just to see if it would update HA. I've tried with persistance on and off, but maybe there is still some bogus data in a pickle file? I'm not really sure how those work.
    Can anyone spot anything in the sketch that would prevent HA from publishing the temperature node? I don't get any errors in the HA logs, and I can see both values being published through MQTT:
     * Version 1.0: Henrik EKblad
    // Enable debug prints
    #define MY_RADIO_RF24
    //#define MY_RS485
    #include <DHT.h>
    #define DHT_DATA_PIN 3
    // Set this offset if the sensor has a permanent small offset to the real temperatures.
    // In Celsius degrees (as measured by the device)
    #define SENSOR_TEMP_OFFSET 0
    // Set node id for MQTT
    #define MY_NODE_ID 2
    #define CHILD_ID_HUM 2
    #define CHILD_ID_TEMP 1
    float lastTemp;
    float lastHum;
    uint8_t nNoUpdatesTemp;
    uint8_t nNoUpdatesHum;
    bool metric = true;
    DHT dht;
      sendSketchInfo("Greenhouse", "1.1");
      present(CHILD_ID_HUM, S_HUM);
      dht.readSensor(true);
      if (isnan(temperature)) {
        lastTemp = temperature;
        // apply the offset before converting to something different than Celsius degrees
        if (!metric) {
        // Reset no updates counter
        nNoUpdatesTemp = 0;
        #ifdef MY_DEBUG
        Serial.print("T: ");
        Serial.println(temperature);
      } else {
        nNoUpdatesTemp++;
      if (isnan(humidity)) {
        Serial.println("Failed reading humidity from sDHT");
        lastHum = humidity;
        nNoUpdatesHum = 0;
        #ifdef MY_DEBUG
        Serial.print("H: ");
        Serial.println(humidity);
      } else {
        nNoUpdatesHum++;
      sleep(UPDATE_INTERVAL);
    Thanks very much!
    K 1 Reply Last reply
    • BearWithBeardB
      BearWithBeardB
      BearWithBeard
      The IDs for humidity and temperature shown on the HA screenshot and written in the sketch don't match up.
      It looks like you have already presented the sensor node with different child IDs before and HA is still expecting the previous configuration. If you reassign an existing ID to a different type (say, S_HUM to S_TEMP), HA won't update automatically.
      I would suggest doing the following:
      • Power down your sensor node and shutdown the HA docker
      • Delete the existing .pickle persistance file, which may still contain the previous node configuration
      • Edit configuration.yaml and change the file type of the persistance file from .pickle to .json, because it's human readable (and editable).
      • You may also enable debug logging temporarily to get more info about what's happening when a node sends data
      • Restart HA and once the MySensors integration has finished initialization, power up the sensor node again
      If you don't change the current sketch, temperature should show up with the ID 1 and humidity with the ID 2 in HA. I can't spot anything wrong with it.
      If it still doesn't work, have a look at the HA log, e.g. with journalctl -u your-ha.service -f -n 100 | grep mysensors
      You should see that messages are incoming from the sensor node (ID 2) including the sketch name and values for every sensor, that HA subscribes to a MQTT topic for every sensor ID and that HA has saved changes to the persistante.json file.
      • M Matt McAllister
        Good day,
        //#define MY_RS485
        #include <DHT.h>
        float lastTemp;
        float lastHum;
        bool metric = true;
        DHT dht;
            if (!metric) {
            nNoUpdatesTemp = 0;
            #ifdef MY_DEBUG
          } else {
            nNoUpdatesTemp++;
            lastHum = humidity;
            nNoUpdatesHum = 0;
            #ifdef MY_DEBUG
          } else {
            nNoUpdatesHum++;
        Thanks very much!
        K
        K
        keithellis
        @Matt-McAllister Hi there, I know this is an old topic, but I've been experiencing the same issue. the way I got around it is by putting a:
        delay(500);
        between the two presentation statements.
        • J
          J
          JeeLet
          wait (5);
          c'est mieux ( pas d’interruption du pgm)
