  3. [Solved] How to adjust MySBootloader files to compile other EN & CSN pins different channel and external 8MHz crystal
26 Posts 2 Posters 3.1k Views 2 Watching
  • JoeridemanJ
    JoeridemanJ
    Joerideman
    wrote on last edited by tekka
    It took some time to learn how to use the make program. But I figured this out. But, with every version of bootloader that I create, I can not upload a sketch using the Serial programming via the Arduino IDE. This is possible with the 8MHz internal osc bootloader in the MySbootloader folders.
    I used this repository https://github.com/mysensors/MySensorsBootloaderRF24
    I have made a few changes/additions in different files:
    mysbootloader.c --> #define RF24_CHANNEL (122)
    makefile -->CLK = 8000000L
    BAUDRATE = 57600
    ISP_HFUSE = D2 //DA and
    ISP_LFUSE = FF //F7 and
    ISP_EFUSE = 06 //was 06 /FE
    HW.h --> #elif defined(SPI_PINS_CE8_CSN9)
    	#define CSN_PORT	PORTB	// port for CSN
    	#define CSN_DDR		DDRB	// DDR for CSN
    	#define	CSN_PIN		PB1		// Arduino Pin 9 <-> Bit 1 of port B
    	#define CE_PORT		PORTB	// port for CE
    	#define CE_DDR		DDRB	// DDR for CE
    	#define	CE_PIN		PB0		// Arduino Pin  8 <-> Bit 0 of port B
    		// set pin mode: MOSI,SCLK,CE,CSN = OUTPUT, MISO = INPUT (=> all on same port)
    		SPI_DDR = _BV(SPI_MOSI) | _BV(SPI_SCLK) | _BV(CE_PIN) | _BV(CSN_PIN) | ~_BV(SPI_MISO);
    I was not sure what this part is used for, so I experimented giving it the same fusesettings as I use in the boards.txt
    So I want to use:
    8 MHz external oscillator. (alltough I start to wonder now how important an oscillator is)
    PB0 or pin 8 for CE
    PB1 or pin 9 for CSN
    RFChannel 122
    tekkaT 1 Reply Last reply
    • JoeridemanJ Joerideman
      BAUDRATE = 57600
      So I want to use:
      PB0 or pin 8 for CE
      RFChannel 122
      tekkaT
      tekkaT
      tekka
      @Joerideman What board are you using? Also, please post the entire SPI communication section from HW.h for full reference.
      • JoeridemanJ
        JoeridemanJ
        Joerideman
        wrote on last edited by Joerideman
        I am using my own board. ATmega328P-AU with 8MHz external crystal osc. Shown on this page:
        https://forum.mysensors.org/topic/11158/please-check-my-pcb-design-for-24v-led-dimmer
        hw.h:
         * MYSBootloader 1.3.0-rc.1
         * OTA RF24 bootloader for MySensors: https://www.mysensors.org
         * Based on MySensors library 2.2
         * Developed and maintained by tekka 2018
        #ifndef HW_H
        #define HW_H
        // hardware
        # define UART_SRA UCSR0A
        # define UART_SRB UCSR0B
        # define UART_SRC UCSR0C
        # define UART_SRL UBRR0L
        # define UART_UDR UDR0
        /* set the UART baud rate defaults */
        #ifndef BAUD_RATE
        	#if F_CPU >= 16000000L
        		#define BAUD_RATE   115200L
        	#elif F_CPU >= 8000000L
        		#define BAUD_RATE   57600L
        	#elif F_CPU >= 1000000L
        		#define BAUD_RATE   9600L   // 19200 also supported, but with significant error
        	#elif F_CPU >= 128000L
        		#define BAUD_RATE   4800L   // Good for 128kHz internal RC
        	#else
        		#define BAUD_RATE 1200L     // Good even at 32768Hz
        #ifndef UART
        	#define UART 0
        #define BAUD_SETTING (( (F_CPU + BAUD_RATE * 4L) / ((BAUD_RATE * 8L))) - 1 )
        #define BAUD_ACTUAL (F_CPU/(8 * ((BAUD_SETTING)+1)))
        #if BAUD_ACTUAL <= BAUD_RATE
        	#define BAUD_ERROR (( 100*(BAUD_RATE - BAUD_ACTUAL) ) / BAUD_RATE)
        	#if BAUD_ERROR >= 5
        		#error BAUD_RATE error greater than -5%
        	#elif BAUD_ERROR >= 2
        		#warning BAUD_RATE error greater than -2%
        #else
        	#define BAUD_ERROR (( 100*(BAUD_ACTUAL - BAUD_RATE) ) / BAUD_RATE)
        	#if BAUD_ERROR >= 5
        		#error BAUD_RATE error greater than 5%
        		#warning BAUD_RATE error greater than 2%
        #if (F_CPU + BAUD_RATE * 4L) / (BAUD_RATE * 8L) - 1 > 250
        	#error Unachievable baud rate (too slow) BAUD_RATE
        #endif // baud rate slow check
        #if (F_CPU + BAUD_RATE * 4L) / (BAUD_RATE * 8L) - 1 < 3
        	#if BAUD_ERROR != 0 // permit high bitrates (ie 1Mbps@16MHz) if error is zero
        		#error Unachievable baud rate (too fast) BAUD_RATE
        // Watchdog definitions and functions
        #define WATCHDOG_OFF    (0)
        #define WATCHDOG_16MS   (_BV(WDE))
        #define WATCHDOG_32MS   (_BV(WDP0) | _BV(WDE))
        #define WATCHDOG_64MS   (_BV(WDP1) | _BV(WDE))
        #define WATCHDOG_125MS  (_BV(WDP1) | _BV(WDP0) | _BV(WDE))
        #define WATCHDOG_250MS  (_BV(WDP2) | _BV(WDE))
        #define WATCHDOG_500MS  (_BV(WDP2) | _BV(WDP0) | _BV(WDE))
        #define WATCHDOG_1S     (_BV(WDP2) | _BV(WDP1) | _BV(WDE))
        #define WATCHDOG_2S     (_BV(WDP2) | _BV(WDP1) | _BV(WDP0) | _BV(WDE))
        #define WATCHDOG_4S     (_BV(WDP3) | _BV(WDE))
        #define WATCHDOG_8S     (_BV(WDP3) | _BV(WDP0) | _BV(WDE))
        static inline void watchdogReset(void) {
        	__asm__ __volatile__ ("wdr\n");
        static void watchdogConfig(const uint8_t wdtConfig) {
        	WDTCSR = _BV(WDCE) | _BV(WDE);
        	WDTCSR = wdtConfig;
        // SPI communication
        #define SPI_PORT	PORTB	//
        #define SPI_DDR		DDRB	//
        #define	SPI_SCLK	PB5		// Arduino Pin 13 <-> Bit 5 of port B
        #define	SPI_MISO	PB4		// Arduino Pin 12 <-> Bit 4 of port B
        #define	SPI_MOSI	PB3		// Arduino Pin 11 <-> Bit 3 of port B
        #if defined(SPI_PINS_CE9_CSN10)
        	#define	CSN_PIN		PB2		// Arduino Pin 10 <-> Bit 2 of port B
        	#define	CE_PIN		PB1		// Arduino Pin  9 <-> Bit 1 of port B
        #elif defined(SPI_PINS_CSN7_CE8)
        	#define CSN_PORT	PORTD	// port for CSN
        	#define CSN_DDR		DDRD	// DDR for CSN
        	#define	CSN_PIN		PD7		// Arduino Pin 7 <-> Bit 7 of port D
        #elif defined(SPI_PINS_CE4_CSN10)
        	#define CE_PORT		PORTD	// port for CE
        	#define CE_DDR		DDRD	// DDR for CE
        	#define	CE_PIN		PD4		// Arduino Pin  4 <-> Bit 4 of port D
        #elif defined(SPI_PINS_CE7_CSN10)
        	// NRF24Duino Configuration
        	#define	CE_PIN		PD7		// Arduino Pin 7 <-> Bit 7 of port D
        	// NRF24Duino has LED on Pin 9 set the LED_PIN in MYSBootloader.c to PB1
        #define CSN_LOW()	CSN_PORT &= ~_BV(CSN_PIN)
        #define CSN_HIGH()	CSN_PORT |= _BV(CSN_PIN)
        #define CE_LOW()	CE_PORT &= ~_BV(CE_PIN)
        #define CE_HIGH()	CE_PORT |= _BV(CE_PIN)
        static void initSPI(void) {
        	// Initialize the SPI pins: SCK, MOSI, CE, CSN as outputs, MISO as input
        		// CSN_PIN (=PB2) is SS pin and set as output
        		SPI_DDR = _BV(SPI_MOSI) | _BV(SPI_SCLK) | _BV(CE_PIN) | _BV(CSN_PIN);
        		// PB2 is SS pin has to be defined as OUTPUT, else SPI goes to slave mode
        		SPI_DDR = _BV(SPI_MOSI) | _BV(SPI_SCLK) | _BV(CE_PIN) | _BV(PB2);
        		CSN_DDR = _BV(CSN_PIN);
        		SPI_DDR = _BV(SPI_MOSI) | _BV(SPI_SCLK) | _BV(PB2) | _BV(CSN_PIN);
        		CE_DDR = _BV(CE_PIN);
        	// SPE	=	SPI enable
        	// SPIE	=	SPI interrupt enable
        	// DORD	=	data order (0:MSB first, 1:LSB first)
        	// MSTR	=	Master/Slave select
        	// SPR1	=	SPI clock rate bit 1
        	// SPR0	=	SPI clock rate bit 0; 0,0=osc/4, 0,1=osc/16, 1,0=osc/64, 1,1=osc/128
        	// CPOL	=	clock polarity idle (0:low, 1:high)
        	// CPHA	=	clock phase edge sampling (0:leading, 1:trailing)
        	// SPI speed setting, nRF24L01P max. 10Mhz
        	#if (F_CPU >= 16000000)
        		// DIV 16 = 1 Mhz
        		SPCR = _BV(SPE) | _BV(MSTR) | _BV(SPR0);
        	#elif (F_CPU >= 8000000)
        		// DIV 8 = 1 Mhz
        		SPSR = _BV(SPI2X);
        	#elif (F_CPU >= 4000000)
        		// DIV 4 = 1Mhz
        		SPCR = _BV(SPE) | _BV(MSTR);
        	#elif (F_CPU >= 2000000)
        		// DIV 2 = 1 Mhz
        		SPSR = _BV(SPI2X);
        	#else
        		// DIV 2 <= 0.5 Mhz
        		SPSR = _BV(SPI2X);
        static uint8_t SPItransfer(const uint8_t value) {
        	SPDR = value;
        	while(!(SPSR & _BV(SPIF)));		// wait until transmitted
        	return SPDR;
        static inline void SPIclose(void) {
        	// disable hardware SPI
        	SPCR = 0;
        // UART
        static void initUART(void) {
        	UART_SRA = _BV(U2X0); //Double speed mode USART0
        	UART_SRB = _BV(RXEN0) | _BV(TXEN0);
        	UART_SRC = _BV(UCSZ00) | _BV(UCSZ01);
        	UART_SRL = (uint8_t)( (F_CPU + BAUD_RATE * 4L) / (BAUD_RATE * 8L) - 1 );
        void putch(const uint8_t ch) {
        	while (!(UART_SRA & _BV(UDRE0)));
        	UART_UDR = ch;
        static uint8_t getch(void) {
        	// wait until char received
        	while(!(UART_SRA & _BV(RXC0)));
        	// 10 bytes
        	// framing error?
        	if (!(UART_SRA & _BV(FE0))) {
        		watchdogReset();
        	return UART_UDR;
        static inline void writeTemporaryBuffer(const uint16_t address, const uint16_t data) {
        	// fill temporary page buffer
        	__boot_page_fill_short(address, data);
        static void programPage(const uint16_t page){
        	__boot_page_erase_short(page);	// erase page
        	boot_spm_busy_wait();
        	__boot_page_write_short(page);	// program page
        	__boot_rww_enable_short();		// re-enable RWW
        static uint16_t crc16_update(uint16_t crc, const uint8_t data) {
        	crc ^= data;
        	for (uint8_t i = 0; i < 8; ++i) {
        		crc = (crc >> 1) ^ (-(int16_t)(crc & 1) & 0xA001);
        	return crc;
        static uint16_t calcCRCrom (const uint16_t len) {
        	// init CRC
        	uint16_t _internal_crc = 0xFFFF;
        	// start address for CRC calculation
        	uint16_t address = 0x0000;
        	// calc and prevent overflow
        	while (address < len && address < BOOTLOADER_START_ADDRESS) {
        		uint8_t _rom_byte;
        		// read a flash byte and increment the address
        		__asm__ ("lpm %0,Z+\n" : "=r" (_rom_byte), "=z" (address): "1" (address));
        		_internal_crc = crc16_update(_internal_crc,_rom_byte);
        	return _internal_crc;
        static void blinkLed(void) {
        	LED_DDR |= _BV(LED_PIN);
        	//300ms total
        	for (uint8_t i = 0; i < 6; i++) {
        		LED_PORT ^= _BV(LED_PIN);
        		_delay_ms(50);
        #endif // HW_H
          hw.h:
          #ifndef HW_H
          #define HW_H
          // hardware
          #ifndef BAUD_RATE
          	#else
          #ifndef UART
          	#define UART 0
          	#if BAUD_ERROR >= 5
          #else
          	#if BAUD_ERROR >= 5
          	WDTCSR = wdtConfig;
          	// SPE	=	SPI enable
          		// DIV 16 = 1 Mhz
          		// DIV 8 = 1 Mhz
          		SPSR = _BV(SPI2X);
          		// DIV 4 = 1Mhz
          		// DIV 2 = 1 Mhz
          		SPSR = _BV(SPI2X);
          	#else
          		// DIV 2 <= 0.5 Mhz
          		SPSR = _BV(SPI2X);
          	SPDR = value;
          	return SPDR;
          	SPCR = 0;
          // UART
          	UART_UDR = ch;
          	// 10 bytes
          	// framing error?
          		watchdogReset();
          	return UART_UDR;
          	crc ^= data;
          	return crc;
          	// init CRC
          		uint8_t _rom_byte;
          	//300ms total
          		_delay_ms(50);
          #endif // HW_H
          tekkaT
          tekkaT
          tekka
          @Joerideman I noticed that you didn't set PB2 as output (see comments) => SPI operates in slave mode. Do you see radio activity on channel 122 after fixing that?
          • JoeridemanJ
            JoeridemanJ
            Joerideman
            Allright one step further.
            		SPI_DDR = _BV(SPI_MOSI) | _BV(SPI_SCLK) | _BV(CE_PIN) | _BV(PB2) | ~_BV(SPI_MISO);
            And now I can use the serial upload :).
            No luck seeing any chatter though. To be sure, I just watch commando's that come in in MySController ?
              tekkaT
              tekkaT
              tekka
              @Joerideman I'm not quite sure how setting the master SPI mode should fix the serial upload issue...What exactly are you referring to? Serial upload via FTDI adapter or FOTA (=firmware over the air) update via RF24?
              • JoeridemanJ
                JoeridemanJ
                Joerideman
                @tekka I can use an FTDI device now for standard uploading of the sketch. The non OTA way.
                What do you mean with the master SPI mode? Is that because of the fuses that I tried to change?
                I have watch the MyScontroller Debug window and the messages. But I only see a presentation at some point, and than it is started.
                  tekkaT
                  tekkaT
                  tekka
                  @Joerideman Setting PB2 as output ensures that the SPI runs in master mode which is essential for a correct communication between the ATmega328 and the RF24 radio.
                  However, after setting PB2 you report:
                  which is not related to SPI (serial upload uses the UART interface).
                  Please provide debug logs / screenshots / whatever you have for further troubleshooting...
                  • JoeridemanJ
                    JoeridemanJ
                    Joerideman
                    @tekka But that setting somehow made a difference.
                    Nevermind here is the debug info from the gateway.
                    When I restart the node, it takes a few seconds before information starts rolling in.
                    10:15:48.219 -> 312137 TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                    10:15:48.252 -> 312197 TSF:MSG:BC
                    10:15:48.287 -> 312216 TSF:MSG:FPAR REQ,ID=1
                    10:15:48.321 -> 312246 TSF:PNG:SEND,TO=0
                    10:15:48.355 -> 312272 TSF:CKU:OK
                    10:15:48.355 -> 312291 TSF:MSG:GWL OK
                    10:15:49.434 -> 313336 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                    10:15:50.208 -> 314109 TSF:MSG:READ,1-1-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                    10:15:50.242 -> 314169 TSF:MSG:PINGED,ID=1,HP=1
                    10:15:50.309 -> 314212 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                    10:15:50.376 -> 314285 TSF:MSG:READ,1-1-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                    10:15:50.443 -> 314352 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                    10:15:50.510 -> 314428 TSF:MSG:READ,1-1-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.2
                    10:15:50.576 -> 314493 TSF:MSG:READ,1-1-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                    10:15:50.712 -> 314642 GWT:RFC:C=0,MSG=1;255;3;0;6;M
                    10:15:50.780 -> 314683 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=OK:M
                    10:15:50.847 -> 314755 TSF:MSG:READ,1-1-0,s=255,c=3,t=11,pt=0,l=19,sg=0:4channel 24V dimmer
                    10:15:50.914 -> 314836 TSF:MSG:READ,1-1-0,s=255,c=3,t=12,pt=0,l=4,sg=0:2.00
                    10:15:50.982 -> 314900 TSF:MSG:READ,1-1-0,s=1,c=0,t=4,pt=0,l=0,sg=0:
                    10:15:51.083 -> 315013 TSF:MSG:READ,1-1-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                    10:15:51.152 -> 315080 TSF:MSG:SEND,0-0-1-1,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                    10:15:51.220 -> 315153 TSF:MSG:READ,1-1-0,s=1,c=1,t=2,pt=2,l=2,sg=0:0
                    10:15:51.287 -> 315211 TSF:MSG:READ,1-1-0,s=1,c=2,t=3,pt=0,l=0,sg=0:
                    Here is the serial output from the node at the same time.
                    10:15:48.154 ->
                    10:15:48.154 ->  __  __       ____
                    10:15:48.154 -> |  \/  |_   _/ ___|  ___ _ __  ___  ___  _ __ ___
                    10:15:48.221 -> | |\/| | | | \___ \ / _ \ `_ \/ __|/ _ \| `__/ __|
                    10:15:48.221 -> | |  | | |_| |___| |  __/ | | \__ \  _  | |  \__ \
                    10:15:48.221 -> |_|  |_|\__, |____/ \___|_| |_|___/\___/|_|  |___/
                    10:15:48.221 ->         |___/                      2.3.2
                    10:15:48.221 ->
                    10:15:48.221 -> 16 MCO:BGN:INIT NODE,CP=RNNNA---,FQ=8,REL=255,VER=2.3.2
                    10:15:48.221 -> 28 TSM:INIT
                    10:15:48.221 -> 28 TSF:WUR:MS=0
                    10:15:48.221 -> 36 TSM:INIT:TSP OK
                    10:15:48.221 -> 38 TSM:INIT:STATID=1
                    10:15:48.221 -> 40 TSF:SID:OK,ID=1
                    10:15:48.221 -> 43 TSM:FPAR
                    10:15:48.221 -> 47 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                    10:15:49.404 -> 1271 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                    10:15:49.404 -> 1277 TSF:MSG:FPAR OK,ID=0,D=1
                    10:15:50.144 -> 2056 TSM:FPAR:OK
                    10:15:50.144 -> 2056 TSM:ID
                    10:15:50.144 -> 2058 TSM:ID:OK
                    10:15:50.144 -> 2060 TSM:UPL
                    10:15:50.179 -> 2068 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                    10:15:50.246 -> 2170 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                    10:15:50.314 -> 2177 TSF:MSG:PONG RECV,HP=1
                    10:15:50.314 -> 2179 TSM:UPL:OK
                    10:15:50.314 -> 2181 TSM:READY:ID=1,PAR=0,DIS=1
                    10:15:50.314 -> 2187 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                    10:15:50.449 -> 2314 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                    10:15:50.449 -> 2322 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.2
                    10:15:50.449 -> 2332 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                    10:15:50.754 -> 2656 TSF:MSG:READ,0-0-1,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                    10:15:50.754 -> 2664 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=0,st=OK:4channel 24V dimmer
                    10:15:50.788 -> 2676 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=4,sg=0,ft=0,st=OK:2.00
                    10:15:50.788 -> 2686 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=OK:
                    10:15:51.093 -> 2994 MCO:REG:REQ
                    10:15:51.093 -> 2996 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                    10:15:51.126 -> 3063 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                    10:15:51.160 -> 3069 MCO:PIM:NODE REG=1
                    10:15:51.160 -> 3074 MCO:BGN:STP
                    10:15:51.160 -> 3080 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:0
                    10:15:51.260 -> 3186 TSF:MSG:SEND,1-1-0-0,s=1,c=2,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                    10:15:51.593 -> 3520 MCO:BGN:INIT OK,TSP=1
                      10:15:48.154 ->
                      10:15:48.221 ->
                      tekkaT
                      tekkaT
                      tekka
                      @Joerideman There is no sign of the bootloader here - can you confirm that your GW is listening on channel 122?
                      • JoeridemanJ
                        JoeridemanJ
                        Joerideman
                        @tekka how? They are talking with each other ones everything has started. Does that not mean the gateway is on the same channel?
                        This is the code of my node: I set the channel to 122 right?
                          combinatie van mysensors en adafruits pwm library
                         versie 2. basis werking
                         versie2.1 Betere response op de controller. Requests voor de
                        //########## mysensors instellingen
                        #define MY_NODE_ID 1
                        #define MY_RF24_CHANNEL (122)
                        #define MY_RF24_CE_PIN 8
                        #define MY_RF24_CS_PIN 9
                        #define MY_RADIO_RF24
                        //#define MY_RADIO_NRF5_ESB
                        //#define MY_RADIO_RFM95
                        #define SN "4channel 24V dimmer"
                        #define SV "2.00"
                        //#define LED_PIN 3      // Arduino pin attached to MOSFET Gate pin // niet relevant. Dimmen gaat via i2c
                        #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
                        #define LED_TYPE S_DIMMER
                        #define AMOUNT_OF_LED 1
                        byte LED_CURRENTLEVEL[] = {0, 0, 0, 0, 0};
                        byte LedCurrentStep[] = {0, 0, 0, 0, 0};
                        byte LedTempCurrentStep[] = {0, 0, 0, 0, 0};
                        byte LED_TOLEVEL[] = {0, 0, 0, 0, 0};
                        byte LedToStep[] = {0, 0, 0, 0, 0};
                        byte LED_Status[] = {0, 0, 0, 0, 0}; //all off
                        byte ledUpdate[] = {0, 0, 0, 0, 0};
                        bool updateLED = false;
                        byte sensorId = 1;
                        MyMessage dimmerMsg(sensorId, V_PERCENTAGE); // was ooit V_Dimmer
                        MyMessage lightMsg(sensorId, V_STATUS); //on or off was ooit V_LIGHT
                        #include <Wire.h>
                        #include <Adafruit_PWMServoDriver.h>
                        // called this way, it uses the default address 0x40
                        //Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
                        // you can also call it with a different address you want
                        Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x40);
                        // you can also call it with a different address and I2C interface
                        //Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x40, &Wire);
                        int lichtwaarde[141] = {0, 1, 1, 1, 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2, 2, 2, 3, 3, 3, 3, 3, 4, 4, 4, 4, 5, 5, 5, 5, 6, 6, 7, 7, 7, 8, 8, 9, 9, 10, 11, 11, 12, 13, 14, 14, 15, 16, 17, 18, 20, 21, 22, 23, 25, 26, 28, 30, 32, 34, 36, 38, 40, 43, 46, 48, 51, 55, 58, 62, 66, 70, 74, 79, 84, 89, 94, 100, 106, 113, 120, 128, 136, 144, 153, 163, 173, 184, 195, 207, 220, 234, 249, 264, 281, 298, 317, 337, 358, 380, 404, 429, 456, 485, 515, 547, 581, 618, 656, 697, 741, 787, 837, 889, 944, 1003, 1066, 1133, 1204, 1279, 1359, 1444, 1534, 1630, 1732, 1840, 1955, 2077, 2207, 2345, 2491, 2647, 2812, 2988, 3175, 3373, 3584, 3808, 4046, 4096};
                           Dimmable LED initialization method
                          sendSketchInfo(SN, SV);
                          //Present nodes
                          for (sensorId = 1; sensorId < (AMOUNT_OF_LED + 1) ; sensorId++) { //
                            present(sensorId, LED_TYPE);
                            wait(300);
                          //###### Mysensors Setup
                          // Pull the gateway's current dim level - restore light level upon node power-up
                          for (sensorId = 1; sensorId < (AMOUNT_OF_LED + 1); sensorId++) {
                            send(lightMsg.set(0));
                                wait(100);
                            request( sensorId, V_PERCENTAGE );
                            wait(300);
                          //###### PWM setup
                          pwm.begin();
                          pwm.setPWMFreq(1600);  //
                          // if you want to really speed stuff up, you can go into 'fast 400khz I2C' mode
                          // some i2c devices dont like this so much so if you're sharing the bus, watch
                          // out for this!
                          Wire.setClock(400000);
                          for (int i = 0; i < 4; i++) { //zet alles uit
                            pwm.setPin((i), lichtwaarde[0]);
                        void loop() {// de eerste 4 aansluitingen
                          if ((ledUpdate[1] + ledUpdate[2] + ledUpdate[3] + ledUpdate[4]) > 0) {
                            fade();
                            wait(15);
                            int tempStatus = ( 1 <= atoi (message.data)) ? 1 : 0;
                            //Serial.print("V type Message data = ");
                            //Serial.println(tempStatus);
                            if (tempStatus > LED_Status[message.sensor]) {
                              ledUpdate[message.sensor] = true;
                              if (LED_CURRENTLEVEL[message.sensor] == 0) {
                                LED_CURRENTLEVEL[message.sensor] = 70;
                                LedToStep[message.sensor] = map(LED_CURRENTLEVEL[message.sensor], 0, 100, 0, 140);
                                Serial.print("ledtostep = ");
                                Serial.println(LedToStep[message.sensor] );
                              else if (LED_CURRENTLEVEL[message.sensor] > 0) {
                                LedCurrentStep[message.sensor] = 0;
                                Serial.print("ledtostep2 = ");
                            else if (tempStatus < LED_Status[message.sensor]) {
                              //Led gaat uit
                              LedToStep[message.sensor] = 0;
                              LedTempCurrentStep[message.sensor] = LedCurrentStep[message.sensor];
                            sensorId = message.sensor;
                            LED_Status[message.sensor] = tempStatus; //de status
                            send(lightMsg.set(LED_Status[message.sensor]));
                          else if (message.type == V_PERCENTAGE) {
                            Serial.print("v percentage Message data = ");
                            Serial.println(atoi( message.data ));
                            if (LED_CURRENTLEVEL[message.sensor] != atoi(message.data)) {
                              LED_CURRENTLEVEL[message.sensor] = (100 <= atoi( message.data )) ? 100 : atoi( message.data ); //de level
                              if (LedToStep[message.sensor] != 0) {
                              //LED_Status[message.sensor] = 1;
                               // sensorId = message.sensor;
                                //send(lightMsg.set(LED_Status[message.sensor]));
                              request( sensorId, V_STATUS );
                                         send(dimmerMsg.set(LED_CURRENTLEVEL[message.sensor]));
                        void fade() {
                          //als de status van een led == true. Dan de fade.
                          for (int ledNumber = 1; ledNumber <= AMOUNT_OF_LED; ledNumber++) {
                            if (ledUpdate[ledNumber] == true) {
                              if (LedTempCurrentStep[ledNumber] == 0 && LED_Status[ledNumber] == 0) {
                                //Serial.println("fade0");
                                //do nothing
                              else if (LedCurrentStep[ledNumber] < LedToStep[ledNumber] && LED_Status[ledNumber] == 1) {
                                //Serial.println("fade1");
                                //increase light
                                LedCurrentStep[ledNumber]++;
                                pwm.setPin((ledNumber - 1), lichtwaarde[LedCurrentStep[ledNumber]]);
                              else if (LedTempCurrentStep[ledNumber] > LedToStep[ledNumber] && LED_Status[ledNumber] == 0) {
                                //turn off  but remember the last lightlevel
                                //Serial.println("fade2");
                                LedTempCurrentStep[ledNumber]--;
                                pwm.setPin((ledNumber - 1), lichtwaarde[LedTempCurrentStep[ledNumber]]);
                              else if (LedCurrentStep[ledNumber] > LedToStep[ledNumber] && LED_Status[ledNumber] == 1) {
                                //decrease light
                                //Serial.println("fade3");
                                LedCurrentStep[ledNumber]--;
                              if (LedCurrentStep[ledNumber] == LedToStep[ledNumber]) {
                                ledUpdate[ledNumber] = false;
                                //Serial.println("fade4");
                                //Serial.println("fade5");
                                //Serial.println("fade6");
                          #define SV "2.00"
                          byte sensorId = 1;
                          #include <Wire.h>
                            //Present nodes
                              wait(300);
                                  wait(100);
                              wait(300);
                            //###### PWM setup
                            pwm.begin();
                            // out for this!
                              fade();
                              wait(15);
                                //Led gaat uit
                          void fade() {
                                  //do nothing
                                  //increase light
                                  //decrease light
                          tekkaT
                          tekkaT
                          tekka
                          @Joerideman That looks alright! Just out of curiosity, if you use the bootloader with the default settings (channel, ce/csn assignment), do you see a difference in the debug log?
                          • JoeridemanJ
                            JoeridemanJ
                            Joerideman
                            I used the 8MHZ int RC one
                            log node:
                            12:09:50.469 -> ⸮& ⸮⸮⸮⸮⸮AGC`⸮48⸮C⸮⸮⸮⸮⸮{}
                            12:09:50.469 -> 2058 TSM:FPAR
                            12:09:50.469 -> 2062 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            12:09:50.469 ->
                            12:09:50.469 ->  __  __       ____
                            12:09:50.469 -> |  \/  |_   _/ ___|  ___ _ __  ___  ___  _ __ ___
                            12:09:50.469 -> | |\/| | | | \___ \ / _ \ `_ \/ __|/ _ \| `__/ __|
                            12:09:50.469 -> | |  | | |_| |___| |  __/ | | \__ \  _  | |  \__ \
                            12:09:50.469 -> |_|  |_|\__, |____/ \___|_| |_|___/\___/|_|  |___/
                            12:09:50.469 ->         |___/                      2.3.2
                            12:09:50.469 ->
                            12:09:50.469 -> 16 MCO:BGN:INIT NODE,CP=RNNNA---,FQ=8,REL=255,VER=2.3.2
                            12:09:50.469 -> 28 TSM:INIT
                            12:09:50.469 -> 28 TSF:WUR:MS=0
                            12:09:50.469 -> 36 TSM:INIT:TSP OK
                            12:09:50.469 -> 38 TSM:INIT:STATID=1
                            12:09:50.469 -> 40 TSF:SID:OK,ID=1
                            12:09:50.469 -> 43 TSM:FPAR
                            12:09:50.469 -> 47 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            12:09:52.420 -> 2056 !TSM:FPAR:NO REPLY
                            12:09:52.420 -> 2058 TSM:FPAR
                            12:09:52.420 -> 2062 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            12:09:54.367 -> 4071 !TSM:FPAR:NO REPLY
                            12:09:54.367 -> 4073 TSM:FPAR
                            12:09:54.367 -> 4077 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            12:09:56.349 -> 6086 !TSM:FPAR:NO REPLY
                            12:09:56.349 -> 6088 TSM:FPAR
                            12:09:56.383 -> 6092 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            12:09:58.338 -> 8101 !TSM:FPAR:FAIL
                            12:09:58.338 -> 8103 TSM:FAIL:CNT=1
                            12:09:58.338 -> 8105 TSM:FAIL:DIS
                            12:09:58.338 -> 8108 TSF:TDI:TSL
                            12:10:08.065 -> 18112 TSM:FAIL:RE-INIT
                            12:10:08.065 -> 18114 TSM:INIT
                            12:10:08.098 -> 18120 TSM:INIT:TSP OK
                            12:10:08.098 -> 18122 TSM:INIT:STATID=1
                            12:10:08.098 -> 18126 TSF:SID:OK,ID=1
                            12:10:08.098 -> 18128 TSM:FPAR
                            12:10:08.098 -> 18132 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            12:10:10.054 -> 20142 !TSM:FPAR:NO REPLY
                            12:10:10.054 -> 20144 TSM:FPAR
                            12:10:10.088 -> 20148 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            12:10:12.042 -> 22157 !TSM:FPAR:NO REPLY
                            12:10:12.042 -> 22159 TSM:FPAR
                            12:10:12.075 -> 22163 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            12:10:14.024 -> 24172 !TSM:FPAR:NO REPLY
                            12:10:14.024 -> 24174 TSM:FPAR
                            12:10:14.024 -> 24178 ?TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                            12:10:14.290 -> 24473 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                            12:10:14.323 -> 24479 TSF:MSG:FPAR OK,ID=0,D=1
                            12:10:16.012 -> 26187 TSM:FPAR:OK
                            12:10:16.012 -> 26189 TSM:ID
                            12:10:16.012 -> 26189 TSM:ID:OK
                            12:10:16.012 -> 26191 TSM:UPL
                            12:10:16.012 -> 26200 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                            12:10:16.111 -> 26302 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                            12:10:16.146 -> 26308 TSF:MSG:PONG RECV,HP=1
                            12:10:16.146 -> 26312 TSM:UPL:OK
                            12:10:16.146 -> 26314 TSM:READY:ID=1,PAR=0,DIS=1
                            12:10:16.146 -> 26320 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                            12:10:16.247 -> 26447 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                            12:10:16.282 -> 26456 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.2
                            12:10:16.282 -> 26466 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                            12:10:16.521 -> 26703 TSF:MSG:READ,0-0-1,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                            12:10:16.554 -> 26716 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=11,pt=0,l=19,sg=0,ft=0,st=OK:4channel 24V dimmer
                            12:10:16.554 -> 26730 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=12,pt=0,l=4,sg=0,ft=0,st=OK:2.00
                            12:10:16.554 -> 26742 TSF:MSG:SEND,1-1-0-0,s=1,c=0,t=4,pt=0,l=0,sg=0,ft=0,st=OK:
                            12:10:16.858 -> 27049 MCO:REG:REQ
                            12:10:16.858 -> 27052 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                            12:10:16.926 -> 27121 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                            12:10:16.926 -> 27127 MCO:PIM:NODE REG=1
                            12:10:16.926 -> 27129 MCO:BGN:STP
                            12:10:16.926 -> 27136 TSF:MSG:SEND,1-1-0-0,s=1,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:0
                            12:10:17.029 -> 27246 TSF:MSG:SEND,1-1-0-0,s=1,c=2,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
                            12:10:17.368 -> 27580 MCO:BGN:INIT OK,TSP=1
                            12:10:38.436 -> 49125 TSF:MSG:READ,0-0-255,s=255,c=3,t=20,pt=0,l=0,sg=0:
                            12:10:38.436 -> 49131 TSF:MSG:BC
                            12:10:39.446 -> 50141 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=OK:0
                              log node:
                              12:09:50.469 ->
                              12:09:50.469 ->
                              tekkaT
                              tekkaT
                              tekka
                              @Joerideman The bootloader doesn't generate serial debug output, would be helpful to see the GW debug log
                              • JoeridemanJ
                                JoeridemanJ
                                Joerideman
                                @tekka Allright I am home again :-).
                                Here is the sketch I use for the gateway. It comes out of the examples folder from mysensors. I think Debug is enabled. But for 5-6 seconds after resetting the node, I get nothing out of the gateway.
                                 * Version 1.0 - Henrik Ekblad
                                 * Contribution by tekka,
                                 * Contribution by Ivo Pullens (ESP8266 support)
                                 * The EthernetGateway sends data received from sensors to the WiFi link.
                                 * VERA CONFIGURATION:
                                 * Enter "ip-number:port" in the ip-field of the Arduino GW device. This will temporarily override any serial configuration for the Vera plugin.
                                 * E.g. If you want to use the default values in this sketch enter: 192.168.178.66:5003
                                 * LED purposes:
                                 * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
                                 * - ERR (red) - fast blink on error during transmission error or receive crc error
                                 * See https://www.mysensors.org/build/connect_radio for wiring instructions.
                                 * If you are using a "barebone" ESP8266, see
                                 * https://www.mysensors.org/build/esp8266_gateway#wiring-for-barebone-esp8266
                                 * Inclusion mode button:
                                #define MY_BAUD_RATE 57600
                                #define MY_GATEWAY_ESP8266
                                #define MY_WIFI_SSID "-------"
                                #define MY_WIFI_PASSWORD "---------"
                                // passed to the DHCP server if not static.
                                #define MY_HOSTNAME "Mysensors_GW"
                                // Enable UDP communication
                                //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS below
                                #define MY_PORT 5003
                                // Enable inclusion mode
                                // Set blinking period
                                // #define MY_DEFAULT_LED_BLINK_PERIOD 300
                                // Flash leds on rx/tx/err
                                // Led pins used if blinking feature is enabled above
                                #include <ArduinoOTA.h>
                                	ArduinoOTA.onStart([]() {
                                		Serial.println("ArduinoOTA start");
                                	ArduinoOTA.onEnd([]() {
                                		Serial.println("\nArduinoOTA end");
                                	ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
                                		Serial.printf("OTA Progress: %u%%\r", (progress / (total / 100)));
                                	ArduinoOTA.onError([](ota_error_t error) {
                                		Serial.printf("Error[%u]: ", error);
                                		if (error == OTA_AUTH_ERROR) {
                                			Serial.println("Auth Failed");
                                		} else if (error == OTA_BEGIN_ERROR) {
                                			Serial.println("Begin Failed");
                                		} else if (error == OTA_CONNECT_ERROR) {
                                			Serial.println("Connect Failed");
                                		} else if (error == OTA_RECEIVE_ERROR) {
                                			Serial.println("Receive Failed");
                                		} else if (error == OTA_END_ERROR) {
                                			Serial.println("End Failed");
                                	ArduinoOTA.begin();
                                	ArduinoOTA.handle();
                                • JoeridemanJ
                                  JoeridemanJ
                                  Joerideman
                                  @tekka I used an rf24 sniffer. I tested if it received signals on channel 122 when I just upload my sketch. This works.
                                  No signal in over 5 minutes time after resetting the node. only signal came from the gateway itself.
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @Joerideman Yeah, I assume something is wrong with the bootloader configuration. Can you zip and upload all bootloader files (or the entire folder) you are using with all the settings and modifications you did?
                                    • JoeridemanJ
                                      JoeridemanJ
                                      Joerideman
                                      @tekka Here is a link to my onedrive: https://1drv.ms/u/s!ArHxoBCXZ0wDiKRLceoqlgchv1r_GQ?e=RvboMa
                                      It holds a zip archive.
                                        tekkaT
                                        tekkaT
                                        tekka
                                        @Joerideman Thanks, I again had a quick look at your HW.h file and found the issue:
                                        SPI_DDR and CSN_DDR are both pointing at DDRB:
                                        and
                                        Thus, setting CSN_DDR = _BV(CSN_PIN) you overwrite SPI_DDR. Comment out the second line and add _BV(CSN_PIN) to SPI_DDR:
                                        SPI_DDR = _BV(SPI_MOSI) | _BV(SPI_SCLK) | _BV(CE_PIN) | _BV(PB2) |  _BV(CSN_PIN);
                                        //CSN_DDR = _BV(CSN_PIN);
                                        • JoeridemanJ
                                          JoeridemanJ
                                          Joerideman
                                          @tekka
                                          Is this the only adjustment that I needed to make?
                                          at this point there is no fota and somewhere in the past days Serial update using the uart has also been destroyed again. I think I should restart with a clean download and start again. I am afraid I changed things I should not have,
                                          The log from running make. I notice now that some parts are failed. But I do not know what that means. I do not remember if this was alway the case. This might be a clue that something went wrong.
                                          G:\OneDrive\Arduino\mysensors\MySensorsBootloaderRF24-development>make
                                          rm *.o
                                          process_begin: CreateProcess(NULL, rm *.o, ...) failed.
                                          make (e=2): Het systeem kan het opgegeven bestand niet vinden.
                                          make: [clean] Fout 2 (genegeerd)
                                          rm *.elf
                                          process_begin: CreateProcess(NULL, rm *.elf, ...) failed.
                                          rm *.hex
                                          process_begin: CreateProcess(NULL, rm *.hex, ...) failed.
                                          "C:/Program Files (x86)/Atmel/Studio/7.0/toolchain/avr8/avr8-gnu-toolchain/bin/avr-objcopy" -O ihex -R .eeprom MYSBootloader.elf MYSBootloader.hex
                                          "C:/Program Files (x86)/Atmel/Studio/7.0/toolchain/avr8/avr8-gnu-toolchain/bin/avr-size" MYSBootloader.elf
                                             text    data     bss     dec     hex filename
                                             2032       6      71    2109     83d MYSBootloader.elf
                                          With a fresh download of all the files without any changes to the make file I get this:
                                          It says in dutch "make (e=2) the system can not find the file specified"
                                          rm *.o
                                          rm *.elf
                                          rm *.hex
                                          "C:/Program Files (x86)/Atmel/Studio/7.0/toolchain/avr8/avr8-gnu-toolchain/bin/avr-gcc" -I"C:/Program Files (x86)/Atmel/Studio/7.0/toolchain/avr8/avr8-gnu-toolchain/avr/include/avr          " -funsigned-char -funsigned-bitfields -DF_CPU=16000000L -DBAUD_RATE=115200 -Os -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -mrelax -Wall -Wextra -Wundef -pedantic -mmcu=atmega328p -c -std=gnu99 -MD -MP -MF "MYSBootloader.d" -MT"MYSBootloader.d" -MT"MYSBootloader.o"  MYSBootloader.c -o MYSBootloader.o
                                          In file included from Core.h:40:0,
                                                           from MYSBootloader.c:81:
                                          HW.h:51:4: warning: #warning is a GCC extension
                                          HW.h:51:4: warning: #warning BAUD_RATE error greater than 2% [-Wcpp]
                                          "C:/Program Files (x86)/Atmel/Studio/7.0/toolchain/avr8/avr8-gnu-toolchain/bin/avr-gcc" -nostartfiles -Wl,-s -Wl,-static -Wl,-Map=".map" -Wl,--start-group -Wl,--end-group -Wl,--gc-sections -mrelax -Wl,-section-start=.text=0x7800 -mmcu=atmega328p   -o MYSBootloader.elf MYSBootloader.o -lm
