  3. Gateway message GWT:TIN:CONNECTING.
5 Posts 3 Posters 798 Views 3 Watching
    mhkid
    What does the message, GWT:TIN:CONNECTING..., mean? Connecting to what? Sometimes mine will just repeat over and over and I have to reset it one or more times until it connects to whatever it is it's connecting to. Assuming it's my wifi it's trying to connect to? My gateway is a Node MCU ESP8266.
    • M mhkid
      Yes it means the esp8266 wifi is trying to connect to the configured access point.
      References in case you want to dig deeper:
      https://www.mysensors.org/apidocs/group__MyGatewayTransportgrp.html
      https://github.com/mysensors/MySensors/blob/98355b2d0b68190a87c3ac76698014adb58fc882/core/MyGatewayTransport.h#L45
      https://github.com/mysensors/MySensors/blob/dd91aeb9c30dbd658bd02c34445669a7cd996c0f/core/MyGatewayTransportEthernet.cpp#L187
      M 1 Reply Last reply
        mhkid
        @mfalkvidd Thank you
          mhkid
          I went to the last link you provided and looked where it makes the connection. I've tried to find the description of signature of the call when it makes the connection and I don't see a definition for the signature being used below. The signature I've used and seen is using the first two parameters, but what are the 3rd and 4th parameters?
          (void)WiFi.begin(MY_WIFI_SSID, MY_WIFI_PASSWORD, 0, MY_WIFI_BSSID);
          YveauxY 1 Reply Last reply
          • M mhkid
            YveauxY
            YveauxY
            @mhkid here you go : https://arduino-esp8266.readthedocs.io/en/latest/esp8266wifi/station-class.html
