  3. Gateway device
Gateway device
151 Posts 19 Posters 155.2k Views 21 Watching
  • blaceyB
    blaceyB
    blacey
    wrote on last edited by blacey
    #96
    Sweet!!! :+1: :+1: :+1:
    Sign me up for 5! :)
    • FrancoisF
      FrancoisF
      Francois
      You put a work into this board and it looks great. Cannot wait for it to come available.
      • 5546dug5
        5546dug5
        5546dug
        @tbowmo My hat is off to you, for the major effort put forth along with @blacey ,@Anticimex , @axillent and @hek to name but a few.
        While following this thread at times lost (mostly?) with explanations and concepts I have been learning which is half the battle.
        It seems it never too late for a old dog to learn a little.
        However it seems there is a need for a better gw from some of the threads I have read.
        I for one will purchase a unit in what ever form it morphs into.
        Great work with all these boards.
        • tbowmoT
          tbowmoT
          tbowmo
          I'm still routing the board, it's more complicated than my previous boards, so will be a bit longer process to get all in place.
          • tbowmoT
            tbowmoT
            tbowmo
            #100
            A small update here, on an even larger update on the gateway device.
            After some considerations, I have decided to switch the MCU for the GW to an atmel SAM D21G, instead of atmega1284. While doing this I have reduced the BOM for the GW, and cut about 1/3 of the BOM price.
            The D21G is the same chip that's on the new arduino zero, and also on a kickstarter project called neutrino. @blacey is the one who pointed me in that direction :)
            While being a more powerful chip (256kb flash, 32kb ram, 48 MHz, loads of extra peripherals) it is actually cheaper than the atmega1284, and it has build in USB controler, so the ftdi chip could be removed, a couple of other glue components is also gone now.
            It will mean that we have to work a bit harder at getting mysensors running, but since the MCU is supported by arduino, we should be able to manage.
              very interesting! I didn't know neutrino, pretty nice board. Seems there will be some work on software part but it is doable like you said. And you will have more power, which is nice for the GW I think, and I like when chip is usb compatible (like pic18f4550 ...). Maybe one day, it will become HID, lol!
              • tbowmoT
                tbowmoT
                tbowmo
                #102
                @scalz
                I didn't know of the neutrino (or arduino zero) before @blacey mentioned it to me, and he finally got me convinced that I should swap the atmega1284. (I know that @axillent tried to convince me to use another chip, than the atmega, before.. But when you find this, and it can reduce board complexity..)
                  @tbowmo: it is likely same things for me. lots of 8/16bits chip collection (microchip). but never moved to 32bit even if i have a 32bit usb bit wacker (not time to test it). I was thinking that you can do lot of things with 8bit chips. So yesterday, I have read a little the datasheet atsamd21. Wow, 1077 pages! But there is lots lots of features! I think I will try to order one sample for my collection! Plus, these chips seems to be not expensive but there is some learning curve on it. I think Microchip have missed a big move with arduino platform!
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    A couple of late night shots, of the progress..
                    Getting ready for the first prototype spin of the board
                    • RJ_MakeR
                      RJ_MakeR
                      RJ_Make
                      That right there is a work of art!
                      RJ_Make
                        You may be interested in this Arduino shield:
                        http://www.ebay.com/itm/WireLess-Gate-Shield-DIY-Maker-Seeed-BOOOLE-/171713943896?hash=item27faf2d958
                        It has both NRF24L01+ and RFM69HW radios.
                        • 5546dug5
                          5546dug5
                          5546dug
                          @tbowmo this gw is looking good, hope the prototypes get to you soon!
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            #108
                            The first pcb's have arrived today.
                            They came a bit faster from dirtypcbs.com, than I had expected. So haven't even sourced the components yet.
                            So need to look into that the next couple of days.
                            with W5100 / NRF module "mounted" :
                            RJ_MakeR 1 Reply Last reply
                            • tbowmoT tbowmo
                              RJ_MakeR
                              RJ_MakeR
                              RJ_Make
                              @tbowmo No mounting holes?
                              RJ_Make
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                @ServiceXp
                                As we need to bring things to life on a new MCU core (Cortex M0), I decided to just make a "simple" dev board, without holes. They will probably be added on the next iteration of the board. (Besides that, 3 of the corners are a bit crammed with components, so no place for the holes anyway.)
                                  @tbowmo: very beautiful board. I can't wait to see how it will work. And your feedback about dirtypcb. I often use seeed for their price. But dirty seems good too regarding their shipping rates. I like osh sometimes for their beautiful boards.
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    @scalz
                                    Haven't tried any of the other "cheap" board houses. But I'm glad for the quality that dirtypcbs are delivering, and the price can't be argued about..
                                      thx good to know.
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        things are beginning to take form..
                                        First arduino sketch are running on the GW
                                        Proof is here :)
                                          great :clap:
