  3. Gateway device
Gateway device
151 Posts 19 Posters 155.6k Views 21 Watching
  • RJ_MakeR
    RJ_MakeR
    RJ_Make
    That right there is a work of art!
    RJ_Make
      You may be interested in this Arduino shield:
      http://www.ebay.com/itm/WireLess-Gate-Shield-DIY-Maker-Seeed-BOOOLE-/171713943896?hash=item27faf2d958
      It has both NRF24L01+ and RFM69HW radios.
      • 5546dug5
        5546dug5
        5546dug
        @tbowmo this gw is looking good, hope the prototypes get to you soon!
        • tbowmoT
          tbowmoT
          tbowmo
          #108
          The first pcb's have arrived today.
          They came a bit faster from dirtypcbs.com, than I had expected. So haven't even sourced the components yet.
          So need to look into that the next couple of days.
          with W5100 / NRF module "mounted" :
          RJ_MakeR 1 Reply Last reply
          • tbowmoT tbowmo
            RJ_MakeR
            RJ_MakeR
            RJ_Make
            @tbowmo No mounting holes?
            RJ_Make
            • tbowmoT
              tbowmoT
              tbowmo
              @ServiceXp
              As we need to bring things to life on a new MCU core (Cortex M0), I decided to just make a "simple" dev board, without holes. They will probably be added on the next iteration of the board. (Besides that, 3 of the corners are a bit crammed with components, so no place for the holes anyway.)
                @tbowmo: very beautiful board. I can't wait to see how it will work. And your feedback about dirtypcb. I often use seeed for their price. But dirty seems good too regarding their shipping rates. I like osh sometimes for their beautiful boards.
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @scalz
                  Haven't tried any of the other "cheap" board houses. But I'm glad for the quality that dirtypcbs are delivering, and the price can't be argued about..
                    thx good to know.
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      things are beginning to take form..
                      First arduino sketch are running on the GW
                      Proof is here :)
                        great :clap:
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          Just learned a lesson the hard way, the last couple of days.. Discovered that I hadn't read the datasheet for the atsamd21 good enough, so I had connected all the PINS for the SPI / UARTs completely wrong. Which means 10-12 connections that was wrong (the board uses 3 SPI ports and 2 UARTs, one SPI doubles as UART, depending on the network interface connected)
                          So new boards are in the pipeline from dirtypcbs.com
                          This is btw improved on a couple of other points, compared to the previous board. Biggest is, that it now has 4 x 3mm mounting holes, (happy now @ServiceXp ? :)). It also got a couple of extra solder jumpers on the backside, that could be used for software configurations, or test points.
                            @tbowmo: what a bad luck! but it is so easy to miss something when you look at the datasheet size :wink:
                            I hope you will get it working like you want, I am sure :smiley:
                            I like your enlarged pads for 0402. Is it easier to solder like this? Do you handsolder it? Do you think using 0603/0805 with no enlarged pads would take same place???I am asking this for my future designs, in case. But 0402 is so small...
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              @scalz
                              I'm using 0603 components this time, as I'm not under that big a space constraint, as on the sensebender micro.
                              The biggest issue is the finepitched SAMD21, have to be extra careful not to make solder bridges between the pins..
                                @tbowmo: 0603, cool. I have some samd21 sample but have not tried to solder them. it looks tiny but I think I will be able but not without some :cold_sweat:
                                thank you for your precision :smile:
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @scalz
                                  atsamd21 comes in 3 variants, with 32, 48 og 64 pins (If I remember right). I'm using the 64 pin variant
                                  If things go well with this one, then I might make a sensebender micro 2, with an 32 pin atsamd20 (almost the same as d21, but without USB host/slave capabilities)
                                    @tbowmo: oh, i have the 48p variant. so I will try to use it in another project in the future. and will order other sample.
                                    sensebender micro2 atsam, wow, crazy thing! could be fun to see this :smile:
                                    • tbowmoT tbowmo
                                      RJ_MakeR
                                      RJ_MakeR
                                      RJ_Make
                                      @tbowmo Now that's what I'm talking about.. Those holes look so sexy.... wait, that doesn't sound right.... :bowtie:
                                      RJ_Make
                                      • tbowmoT tbowmo
                                        @scalz
                                        RJ_MakeR
                                        RJ_MakeR
                                        RJ_Make
                                        @tbowmo How is the testing going?
                                        RJ_Make
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @ServiceXp
                                          I just received the PCBs for the second prototype spin yesterday, the first spin had too many errors in the routing around SPI / UARTS so I decided to ditch it, and do a second spin. Dirtypcbs got some hickups processing my gerbers but finaly made the boards.
                                          I hope that I can get around to assemble one this weekend, but I can't promise anything, as I have been loaded more than 150% with work (both from my employer, and from the wife).
