  3. ECHO problems when sending with no payload
20 Posts 3 Posters 2.5k Views 3 Watching
  • karlheinz2000K
    karlheinz2000K
    karlheinz2000
    wrote on last edited by karlheinz2000
    I have this LED matrix to display time and text https://forum.mysensors.org/post/102819.
    Text is sent from controller (fhem), time is only requested once from node and the runs only on node.
    To switch from text to time, controller sends "" (no text). Node checks received data for NULL.
    strcpy(tempMessage, message.getString());        // copy it in
          if (tempMessage[0] == NULL) {                    //time
    I didn't use the text option for a long time. Now it does not work anymore.
    If controller sends "", node receives "]" and this does not work with NULL.
    Did anything change in MySensors?
    How can I debug what raw data is received? Maybe some changes on controller side...
    • fritsF
      fritsF
      frits
      Hi, can you provide the node's debug output? It should show what data was received.
      • karlheinz2000K
        karlheinz2000K
        karlheinz2000
        Debug does not help. According to debug payload is empty "" (or space). When I get the payload in receive() it reads "]".
        • fritsF
          fritsF
          frits
          I don't use FHEM but tested with MySController.
          Check message.getString() for NULL!
            char tempMessage[32];
            char * ret = message.getString ( );
            if ( NULL == ret )
              MY_SERIALDEVICE.println ( "ret is <null>" );
            else
              strcpy(tempMessage, ret );        // copy it in
              MY_SERIALDEVICE.println ( tempMessage[0] );
          Now if you send in an empty string, you will receive:
          27148 TSF:MSG:READ,0-0-124,s=36,c=1,t=47,pt=1,l=1,sg=1:0
          length: 1, type: 47
          ret is <null>
          (Note: payload length is 1 even if message is empty)
          Also check your data type, if it's not P_STRING, you'll get NULL!. See MyMessage.cpp:
          const char* MyMessage::getString(void) const
          	if (this->getPayloadType() == P_STRING) {
          		return this->data;
          	} else {
          		return NULL;
          • karlheinz2000K
            karlheinz2000K
            karlheinz2000
            @frits thanks for supporting. This works.
            • karlheinz2000K
              karlheinz2000K
              karlheinz2000
              @frits, can you please check, if MySController reads correct ECHO from a no payload message? I have some ECHO problems, when sending with no payload. But maybe FHEM related...
              • fritsF
                fritsF
                frits
                sending an empty V_TEXT with "ACK" = "YES":
                MySensors Ethernet Gateway
                1896935 GWT:RFC:MSG=123;1;1;1;47;
                1896941 TSF:MSG:SEND,0-0-123-123,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                1897074 TSF:MSG:READ,123-123-0,s=255,c=3,t=17,pt=6,l=25,sg=1:<NONCE>
                1897195 TSF:MSG:SEND,0-0-123-123,s=1,c=1,t=47,pt=1,l=1,sg=1,ft=0,st=OK:0
                1897365 TSF:MSG:READ,123-123-0,s=1,c=1,t=47,pt=1,l=1,sg=0:0
                1897371 TSF:MSG:ECHO
                MySensors Node
                812210 TSF:MSG:READ,0-0-123,s=1,c=3,t=16,pt=0,l=0,sg=1:
                812216 SGN:SKP:MSG CMD=3,TYPE=16
                812292 SGN:SKP:MSG CMD=3,TYPE=17
                812300 TSF:MSG:SEND,123-123-0-0,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:<NONCE>
                812308 SGN:NCE:XMT,TO=123
                812445 TSF:MSG:READ,0-0-123,s=1,c=1,t=47,pt=1,l=1,sg=1:0
                812451 SGN:BND:NONCE=xxxxxx
                812566 SGN:BND:HMAC=xxxxx
                812574 SGN:VER:OK
                812576 TSF:MSG:ECHO REQ
                812580 SGN:SKP:ECHO CMD=1,TYPE=47
                812584 TSF:MSG:SEND,123-123-0-0,s=1,c=1,t=47,pt=1,l=1,sg=0,ft=0,st=OK:0
                • karlheinz2000K
                  karlheinz2000K
                  karlheinz2000
                  Is 2.3.2 running on your GW?
                  I see different behaviour between 2.3.2 and old 2.2.0.
                  With 2.3.2 on GW I see ECHO problems, with 2.0.0 everything is fine.
                  First running a 2.3.2 GW, then switch to a 2.2.0 GW.
                  The 2.3.2 version is adding a "0", which causes problems.
                  12.11.2020 22:24:11	TX	70;0;1;1;47;
                  12.11.2020 22:24:11	RX	0;255;3;0;9;41152 TSF:MSG:SEND,0-0-70-70,s=0,c=1,t=47,pt=1,l=1,sg=0,ft=0,st=OK:0
                  12.11.2020 22:24:11	RX	0;255;3;0;9;41174 TSF:MSG:READ,70-70-0,s=0,c=1,t=47,pt=1,l=1,sg=0:0
                  12.11.2020 22:24:11	RX	0;255;3;0;9;41192 TSF:MSG:ECHO
                  12.11.2020 22:24:11	RX	70;0;1;1;47;0
                  12.11.2020 22:25:10	INFO	Disconnected
                  12.11.2020 22:25:24	INFO	Flushing FIFO
                  12.11.2020 22:25:24	INFO	Connected to COM4
                  12.11.2020 22:25:29	TX	70;0;1;1;47;
                  12.11.2020 22:25:29	RX	0;255;3;0;9;192065 TSF:MSG:SEND,0-0-70-70,s=0,c=1,t=47,pt=0,l=0,sg=0,ft=0,st=OK:
                  12.11.2020 22:25:29	RX	0;255;3;0;9;192088 TSF:MSG:READ,70-70-0,s=0,c=1,t=47,pt=0,l=0,sg=0:
                  12.11.2020 22:25:29	RX	0;255;3;0;9;192106 TSF:MSG:ACK
                  12.11.2020 22:25:29	RX	70;0;1;1;47;
                  • fritsF
                    fritsF
                    frits
                    yes, it's 2.3.2:
                    0 MCO:BGN:INIT GW,CP=RNNGAA--,FQ=8,REL=255,VER=2.3.2
                    38 TSM:INIT
                    40 TSF:WUR:MS=0
                    47 TSM:INIT:TSP OK
                    49 TSM:INIT:GW MODE
                    51 TSM:READY:ID=0,PAR=0,DIS=0
                    55 MCO:REG:NOT NEEDED
                    618 GWT:TIN:IP=192.168.99.13
                    1622 MCO:BGN:STP
                    Version 0.1
                    own mac address: DE:AD:BA:BE:99:13
                    own network address: 192.168.99.13
                    Gateway type: MysGW
                    network port: 5003
                    Radio type: NRF24
                    signing: yes
                    2140 MCO:BGN:INIT OK,TSP=1
                    2148 TSM:READY:NWD REQ
                    2154 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                    • fritsF
                      fritsF
                      frits
                      here's the requests with 2.2.0.
                      Gateway:
                      0 MCO:BGN:INIT GW,CP=RNNGA---,VER=2.2.0
                      4 TSM:INIT
                      4 TSF:WUR:MS=0
                      12 TSM:INIT:TSP OK
                      14 TSM:INIT:GW MODE
                      16 TSM:READY:ID=0,PAR=0,DIS=0
                      18 MCO:REG:NOT NEEDED
                      583 GWT:TIN:IP=192.168.99.13
                      1587 MCO:BGN:STP
                      Version 0.1
                      Gateway type: MysGW
                      network port: 5003
                      Radio type: NRF24
                      signing: no
                      2105 MCO:BGN:INIT OK,TSP=1
                      36448 TSF:MSG:READ,123-123-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                      36454 TSF:MSG:BC
                      36456 TSF:MSG:FPAR REQ,ID=123
                      36460 TSF:PNG:SEND,TO=0
                      36462 TSF:CKU:OK
                      36464 TSF:MSG:GWL OK
                      37095 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                      38502 TSF:MSG:READ,123-123-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                      38510 TSF:MSG:PINGED,ID=123,HP=1
                      38514 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                      38531 TSF:MSG:READ,123-123-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                      38539 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                      38549 TSF:MSG:READ,123-123-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.2.0
                      38557 TSF:MSG:READ,123-123-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                      38567 GWT:TSA:ETH OK
                      38576 GWT:RFC:MSG=123;255;3;0;6;M
                      38582 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=OK:M
                      38590 TSF:MSG:READ,123-123-0,s=255,c=3,t=11,pt=0,l=20,sg=0:Hello MySensors 328P
                      38602 TSF:MSG:READ,123-123-0,s=255,c=3,t=12,pt=0,l=3,sg=0:1.3
                      38612 TSF:MSG:READ,123-123-0,s=0,c=0,t=36,pt=0,l=6,sg=0:system
                      38623 TSF:MSG:READ,123-123-0,s=1,c=0,t=36,pt=0,l=9,sg=0:timestamp
                      38633 TSF:MSG:READ,123-123-0,s=2,c=0,t=3,pt=0,l=3,sg=0:led
                      38645 TSF:MSG:READ,123-123-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                      38653 TSF:MSG:SEND,0-0-123-123,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                      85934 GWT:RFC:MSG=123;1;1;1;47;hello
                      85940 TSF:MSG:SEND,0-0-123-123,s=1,c=1,t=47,pt=0,l=5,sg=0,ft=0,st=OK:hello
                      85950 TSF:MSG:READ,123-123-0,s=1,c=1,t=47,pt=0,l=5,sg=0:hello
                      85958 TSF:MSG:ACK
                      93378 GWT:RFC:MSG=123;1;1;1;47;next message empty
                      93386 TSF:MSG:SEND,0-0-123-123,s=1,c=1,t=47,pt=0,l=18,sg=0,ft=0,st=OK:next messa
                      ge empty
                      93399 TSF:MSG:READ,123-123-0,s=1,c=1,t=47,pt=0,l=18,sg=0:next message empty
                      93407 TSF:MSG:ACK
                      96987 GWT:RFC:MSG=123;1;1;1;47;
                      96993 TSF:MSG:SEND,0-0-123-123,s=1,c=1,t=47,pt=0,l=0,sg=0,ft=0,st=OK:
                      97001 TSF:MSG:READ,123-123-0,s=1,c=1,t=47,pt=0,l=0,sg=0:
                      97007 TSF:MSG:ACK
                      Node:
                      4 TSM:INIT
                      4 TSF:WUR:MS=0
                      12 TSM:INIT:TSP OK
                      14 TSM:INIT:GW MODE
                      1587 MCO:BGN:STP
                      Version 0.1
                      Gateway type: MysGW
                      network port: 5003
                      Radio type: NRF24
                      signing: no
                      36454 TSF:MSG:BC
                      36462 TSF:CKU:OK
                      85958 TSF:MSG:ACK
                      ge empty
                      93407 TSF:MSG:ACK
                      97007 TSF:MSG:ACK
                      • fritsF
                        fritsF
                        frits
                        sorry, ctr-c didn't work
                        Node:
                         __  __       ____
                                |___/                      2.2.0
                        16 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.2.0
                        26 MCO:BGN:BFR
                        Version 1.3
                        Radio type: NRF24
                        signing: no
                        32 TSM:INIT
                        40 TSF:WUR:MS=0
                        47 TSM:INIT:TSP OK
                        49 TSM:INIT:STATID=123
                        51 TSF:SID:OK,ID=123
                        53 TSM:FPAR
                        90 TSF:MSG:SEND,123-123-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        700 TSF:MSG:READ,0-0-123,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                        706 TSF:MSG:FPAR OK,ID=0,D=1
                        2099 TSM:FPAR:OK
                        2099 TSM:ID
                        2101 TSM:ID:OK
                        2103 TSM:UPL
                        2107 TSF:MSG:SEND,123-123-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                        2117 TSF:MSG:READ,0-0-123,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                        2123 TSF:MSG:PONG RECV,HP=1
                        2127 TSM:UPL:OK
                        2129 TSM:READY:ID=123,PAR=0,DIS=1
                        2134 TSF:MSG:SEND,123-123-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                        2142 TSF:MSG:READ,0-0-123,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                        2152 TSF:MSG:SEND,123-123-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.2.0
                        2160 TSF:MSG:SEND,123-123-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                        2185 TSF:MSG:READ,0-0-123,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                        2193 TSF:MSG:SEND,123-123-0-0,s=255,c=3,t=11,pt=0,l=20,sg=0,ft=0,st=OK:Hello MySensors 328P
                        2205 TSF:MSG:SEND,123-123-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.3
                        2215 TSF:MSG:SEND,123-123-0-0,s=0,c=0,t=36,pt=0,l=6,sg=0,ft=0,st=OK:system
                        2226 TSF:MSG:SEND,123-123-0-0,s=1,c=0,t=36,pt=0,l=9,sg=0,ft=0,st=OK:timestamp
                        2236 TSF:MSG:SEND,123-123-0-0,s=2,c=0,t=3,pt=0,l=3,sg=0,ft=0,st=OK:led
                        2244 MCO:REG:REQ
                        2248 TSF:MSG:SEND,123-123-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                        2256 TSF:MSG:READ,0-0-123,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                        2263 MCO:PIM:NODE REG=1
                        2265 MCO:BGN:STP
                        2267 MCO:BGN:INIT OK,TSP=1
                        49412 TSF:MSG:READ,0-0-123,s=1,c=1,t=47,pt=0,l=5,sg=0:hello
                        49420 TSF:MSG:ACK REQ
                        49424 TSF:MSG:SEND,123-123-0-0,s=1,c=1,t=47,pt=0,l=5,sg=0,ft=0,st=OK:hello
                        h
                        received message for sensor 1, type 47, value hello
                        56838 TSF:MSG:READ,0-0-123,s=1,c=1,t=47,pt=0,l=18,sg=0:next message empty
                        56846 TSF:MSG:ACK REQ
                        56850 TSF:MSG:SEND,123-123-0-0,s=1,c=1,t=47,pt=0,l=18,sg=0,ft=0,st=OK:next message empty
                        n
                        received message for sensor 1, type 47, value next message empty
                        60434 TSF:MSG:READ,0-0-123,s=1,c=1,t=47,pt=0,l=0,sg=0:
                        60440 TSF:MSG:ACK REQ
                        60444 TSF:MSG:SEND,123-123-0-0,s=1,c=1,t=47,pt=0,l=0,sg=0,ft=0,st=OK:
                        • karlheinz2000K
                          karlheinz2000K
                          karlheinz2000
                          I again checked with latest 2.3.2 development lib. Same, ECHO does not work.
                          You use ethernet gateway, my is serial. This might be the difference...
                          13.11.2020 09:17:20	TX	70;0;1;1;47;
                          13.11.2020 09:17:20	RX	0;255;3;0;9;10969 TSF:MSG:SEND,0-0-70-70,s=0,c=1,t=47,pt=1,l=1,sg=0,ft=0,st=OK:0
                          13.11.2020 09:17:20	RX	0;255;3;0;9;10989 TSF:MSG:READ,70-70-0,s=0,c=1,t=47,pt=1,l=1,sg=0:0
                          13.11.2020 09:17:20	RX	0;255;3;0;9;11008 TSF:MSG:ECHO
                          13.11.2020 09:17:20	RX	70;0;1;1;47;0
                          I now try to setup an ethernet gateway just for test.
                          • karlheinz2000K
                            karlheinz2000K
                            karlheinz2000
                            Same with ethernet gateway (UNO, W5100)
                            gateway 2.2.0
                            10:25:06.047 -> 73634 GWT:RFC:MSG=70;0;1;1;47;
                            10:25:06.047 -> 73639 TSF:MSG:SEND,0-0-70-70,s=0,c=1,t=47,pt=0,l=0,sg=0,ft=0,st=OK:
                            10:25:06.088 -> 73652 TSF:MSG:READ,70-70-0,s=0,c=1,t=47,pt=0,l=0,sg=0:
                            10:25:06.088 -> 73657 TSF:MSG:ACK
                            MYSController
                            13.11.2020 10:25:06	TX	70;0;1;1;47;
                            13.11.2020 10:25:06	RX	70;0;1;1;47;
                            gateway 2.3.2
                            10:30:45.718 -> 22546 GWT:RFC:MSG=70;0;1;1;47;
                            10:30:45.718 -> 22550 TSF:MSG:SEND,0-0-70-70,s=0,c=1,t=47,pt=1,l=1,sg=0,ft=0,st=OK:0
                            10:30:45.718 -> 22561 TSF:MSG:READ,70-70-0,s=0,c=1,t=47,pt=1,l=1,sg=0:0
                            10:30:45.718 -> 22566 TSF:MSG:ECHO
                            MYSController
                            13.11.2020 10:30:45	TX	70;0;1;1;47;
                            13.11.2020 10:30:45	RX	70;0;1;1;47;0
                            Now I have to look for some ESP board...
                            rejoe2R 1 Reply Last reply
                            • karlheinz2000K karlheinz2000
                              gateway 2.2.0
                              MYSController
                              gateway 2.3.2
                              MYSController
                              rejoe2R
                              rejoe2R
                              rejoe2
                              @karlheinz2000
                              Which type of radio you are using? There might be a difference between nRF24 and other (RFM-based?) transceivers. So if possible, also make a test with 2.3.2 and nRF24.
                              Problem may be related to the change from soft ACK to ECHO (https://github.com/mysensors/MySensors/releases).
                              • karlheinz2000K
                                karlheinz2000K
                                karlheinz2000
                                All tests are done with nRF24 radio only.
                                • rejoe2R
                                  rejoe2R
                                  rejoe2
                                  Thx, so this seems not to be the reason behind that.
                                  Sth. else: If possible, it could be a good idea to add some more content to the thread title (ECHO in 2.3.2 changes message content)?
                                  • fritsF
                                    fritsF
                                    frits
                                    the library differs the way it sends empty V_TEXT messages between 2.2.0 and 2.3.2.
                                    2.2.0
                                    note: length = 0, payload type = 0
                                    2.3.2
                                    note: length = 1, payload type = 1
                                    • fritsF
                                      fritsF
                                      frits
                                      I think the issue found it's way into the library here:
                                      https://github.com/mysensors/MySensors/commit/74e566f5602261ba58e9a7fb06357810ae793b0b#diff-75e571c3ad1b2847e816b36b077fb7306d69ac8386b59d600a265f12bee1f8ba
                                      old code:
                                      	// payload
                                      	if (command == C_STREAM) {
                                      		uint8_t bvalue[MAX_PAYLOAD_SIZE];
                                      		uint8_t blen = 0;
                                      new code:
                                      	// payload
                                      	if (str == NULL) {
                                      		// no payload, set default value
                                      		message.set((uint8_t)0);
                                      	} else if (command == C_STREAM) {
                                      		// stream payload
                                      if there's no payload, the library assumes uint8_t with value 0
                                      • rejoe2R
                                        rejoe2R
                                        rejoe2
                                        @frits: Thx for analyzing this issue. Atm I honestly don't have no clue how to deal with this change in the FHEM module code. When analyzing ECHO, there's a check weather send info is identical to what's been sent.
                                        So the only way out seems to be less exact and also let be 0 the same as "nothing" (Perl doesn't use NULL).
                                        @karlheinz2000 Perhaps, we could ad a small if statement at the end of line 760 to treat 0 as "nothing" or undef?
                                        or $_->{payload} ne $msg->{payload} if $msg->{payload}
                                        Deleting the entire line might cause problems...
                                        • karlheinz2000K
                                          karlheinz2000K
                                          karlheinz2000
                                          I've opened an issue for that.
                                          https://github.com/mysensors/MySensors/issues/1452
                                          According to API payload is same on ECHO message.
                                          I feel this should be handled/fixed in lib, but I have no idea how to do...
                                          If it is not possible to fix in lib, it shall not be allowed to send message with no payload anymore, which controller has to make sure then.
                                          @rejoe2
                                          Regarding FHEM, at the moment we should keep it as it is. No payload is not the normal use case.
                                          I flashed gateway with 2.2.0 and this fixed the problem for me.
