  3. implementing multiple sensors
83 Posts 28 Posters 96.6k Views 15 Watching
  • D Offline
    Dany
    Has anyone made ​​RGB LED strip node? I am looking for a working example program ...
    N 1 Reply Last reply
    • B Offline
      B Offline
      blacey
      @Dany - yes. Checkout http://www.mysensors.org/build/dimmer
      D 1 Reply Last reply
      • K Offline
        K Offline
        korttoma
        Or here is an example I'm using:
        https://codebender.cc/sketch:44740
        • Tomas
        • P pgo
          https://github.com/pgo-sk/mysensors/blob/master/arduino/DS_Light_Relay
          • DS18B20 (up to 16 like in original temp sketch)
          • TEMT6000 reporting LUX light values
          • 2x Relays
            running and tested
            Sensor <-> MQTT gateway <-> openHAB/PC
          When interested can post the openHAB items/sitemap(s) settings
          Screenshots - over teamviewer, sorry for the quality.
          Here the TEMT6000 output - in a quite dark room and changing weather today>
          upload-42ac73c1-61cf-4b90-9ec5-14a994a3b50a
          Here the temperature and relays:
          upload-86825c33-2cc2-4018-9e08-2020007af3a9
          Menu:
          upload-adf5c382-2803-49b9-a461-eb25beb572c0
          A Offline
          A Offline
          aquapro
          wrote on last edited by aquapro
          #64
          Hi, I'm interested. :-)
          Or is this the latest version ?
          P 1 Reply Last reply
          • A aquapro
            P Offline
            P Offline
            pgo
            wrote on last edited by pgo
            #65
            Yes :), for the sketches mentioned earlier.
            <Comment to myself: Have to switch to some versioning as now I am already deeper in the project including cameras, weather forcasts etc.>
            • A Offline
              A Offline
              aquapro
              I could not decide yet on a platform. OpenHAB should be my next test.
              • P Offline
                P Offline
                pgo
                #67
                test1.items
                test1.sitemap
                test1.rules
                webcam.png -icon for webcam - put in openhab/webapps/images
                My Current openHAB items/sitemap. 1 multisensor with Temp/Lux/Humidity sensor, 1 ethernet/MQTT gateway.
                Also weather forcast from yr.no and Samsung TV remote controls (Mute working, rest not so much)
                • openHAB v 1.5.1
                • Addons :
                  \openhab\addons>
                  org.openhab.binding.http-1.5.1.jar
                  org.openhab.binding.mqtt-1.6.0-SNAPSHOT.jar
                  org.openhab.binding.ntp-1.5.1.jar
                  org.openhab.binding.samsungtv-1.6.0-SNAPSHOT.jar
                  org.openhab.binding.zwave-1.6.0-SNAPSHOT.jar
                  org.openhab.io.habmin-1.6.0-SNAPSHOT.jar
                  org.openhab.persistence.exec-1.5.1.jar
                  org.openhab.persistence.logging-1.5.1.jar
                  org.openhab.persistence.mqtt-1.6.0-SNAPSHOT.jar
                  org.openhab.persistence.rrd4j-1.5.1.jar
                HABmin conf with graphs:
                charts.xml -put in openhab/etc/habmin
                In habmin.cfg specify the IP of your MQTT arduino and port>
                '#'mqtt:<broker>.clientId=<clientId>
                mqtt:mysensor.url=tcp://192.168.1.234:1883
                mqtt:mysensor.clientId=MQTT
                mqtt:mysensor.qos=0
                mqtt:mysensor.retain=true
                mqtt:mysensor.async=true
                Here some screenshots:
                These (Direct channel/Channel/Volume) does not work yet... Mute is OK and Volume displays only the current TV volume.
                • A aquapro
                  P Offline
                  P Offline
                  pgo
                  It runs quit stable on my old WinXP64Pro Quadcore w/many virtual machines on it.
                  Have still some problems with the syntax of the openHAB settings, but else nice controller ;)
                  • B blacey
                    Dany
                    wrote on last edited by Dany
                    #69
                    @blacey I tried this already. This is a simple dimmer node, not RGB. It's work fine.
                    But I would like to use a RGB colorpicker in openhab.
                    • D Dany
                      P Offline
                      P Offline
                      pgo
                      #70
                      @Dany said:
                      I would like to use with a RGB colorpicker in openhab.
                      I would do that soon too. Would you like to have a node only as rgbw dimmer or maybe with a lux sensor as I like to do to also adjust for constant light/lux in the room?
                      In my menu you can see the setpoint for lux under the light sensor.
                      • P pgo
                        Dany
                        @pgo The RGB Colorpicker works already in openhab.
                        I have some problem in arduino side...i tried update the sample DimmerActuator code, but didn't work. I tried korttoma's code, but it didn't works for me, too.
                        (e.g. message.header.childId -didn't work)
                        • D Dany
                          P Offline
                          P Offline
                          pgo
                          Can you post the HW connections you use on arduino and the items/sitemap of the dimmer in openHAB? I can then check on my install.
                          • D Dany
                            N Offline
                            N Offline
                            niccodemi
                            I combined Humidity and Lux code. Serial monitor works ok (see below) but for some reason when I try to add node to Vera I get only node, temp and lux (no humidity). I guess something is wrong in combined sketch?
                            serial monitor
                            sensor started, id 1
                            send: 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
                            send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                            read: 0-0-1 s=255,c=3,t=6,pt=0,l=1:M
                            send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=12,st=ok:Humidity/Lux
                            send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
                            send: 1-1-0-0 s=0,c=0,t=7,pt=0,l=5,st=ok:1.4.1
                            send: 1-1-0-0 s=1,c=0,t=6,pt=0,l=5,st=ok:1.4.1
                            send: 1-1-0-0 s=2,c=0,t=16,pt=0,l=5,st=ok:1.4.1
                            send: 1-1-0-0 s=1,c=1,t=0,pt=7,l=5,st=ok:28.6
                            T: 28.60
                            send: 1-1-0-0 s=0,c=1,t=1,pt=7,l=5,st=ok:61.8
                            H: 61.80
                            send: 1-1-0-0 s=2,c=1,t=23,pt=3,l=2,st=ok:2
                            sketch
                            #include <DHT.h>
                            #include <BH1750.h>
                            #include <Wire.h>
                            #define CHILD_ID_HUM 0
                            #define CHILD_ID_TEMP 1
                            #define CHILD_ID_LIGHT 2
                            #define LIGHT_SENSOR_ANALOG_PIN 0
                            BH1750 lightSensor;
                            DHT dht;
                            float lastTemp;
                            float lastHum;
                            boolean metric = true;
                            uint16_t lastlux;
                              gw.begin();
                              gw.sendSketchInfo("Humidity/Lux", "1.0");
                              gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);
                              lightSensor.begin();
                              if (isnan(temperature)) {
                                lastTemp = temperature;
                                if (!metric) {
                                Serial.print("T: ");
                                Serial.println(temperature);
                              if (isnan(humidity)) {
                                  lastHum = humidity;
                                  Serial.print("H: ");
                                  Serial.println(humidity);
                              uint16_t lux = lightSensor.readLightLevel();// Get Lux value
                              Serial.println(lux);
                              if (lux != lastlux) {
                                  gw.send(msg.set(lux));
                                  lastlux = lux;
                              gw.sleep(SLEEP_TIME); //sleep a bit
                            • N niccodemi
                              serial monitor
                              T: 28.60
                              H: 61.80
                              sketch
                              #include <DHT.h>
                              #include <BH1750.h>
                              #include <Wire.h>
                              BH1750 lightSensor;
                              DHT dht;
                              float lastTemp;
                              float lastHum;
                              uint16_t lastlux;
                                gw.begin();
                                  if (!metric) {
                                    lastHum = humidity;
                                    lastlux = lux;
                              P Offline
                              P Offline
                              pgo
                              @niccodemi Check:
                              gw.send(msg.set(lux)); I miss here ",1"
                              • P pgo
                                @niccodemi Check:
                                N Offline
                                N Offline
                                niccodemi
                                @pgo thanks, all sensors show up now.
                                • N Offline
                                  N Offline
                                  niccodemi
                                  One more combined sketch - UV / Light Lux. Everything seems to work ok except only 2 items show up in vera: node and lux sensor. UV sensor is missing.
                                  serial output
                                  sensor started, id 6
                                  send: 6-6-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
                                  send: 6-6-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
                                  read: 0-0-6 s=255,c=3,t=6,pt=0,l=1:M
                                  send: 6-6-0-0 s=255,c=3,t=11,pt=0,l=13,st=ok:UV/Lux Sensor
                                  send: 6-6-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
                                  send: 6-6-0-0 s=0,c=0,t=16,pt=0,l=5,st=ok:1.4.1
                                  send: 6-6-0-0 s=0,c=0,t=11,pt=0,l=5,st=ok:1.4.1
                                  Lux reading: 48
                                  send: 6-6-0-0 s=0,c=1,t=23,pt=7,l=5,st=ok:48.0
                                  Uv reading: 583
                                  Uv index: 5
                                  send: 6-6-0-0 s=0,c=1,t=11,pt=7,l=5,st=ok:5.0
                                  sketch code
                                    Vera Arduino BH1750FVI Light sensor
                                    communicate using I2C Protocol
                                    this library enable 2 slave device addresses
                                    Main address  0x23
                                    secondary address 0x5C
                                    connect the sensor as follows :
                                    Light sensor
                                    VCC  >>> 5V
                                    Gnd  >>> Gnd
                                    ADDR >>> NC or GND
                                    SCL  >>> A5
                                    SDA  >>> A4
                                    UV sensor
                                    VCC  >>> 5V
                                    Gnd  >>> Gnd
                                    OUT  >>> A3
                                    Contribution: idefix
                                  #include <BH1750.h>
                                  #include <Wire.h>
                                  #define CHILD_ID_LIGHT 0
                                  #define CHILD_ID_UV 0
                                  #define UV_SENSOR_ANALOG_PIN 3
                                  BH1750 lightSensor;
                                  MyMessage uvMsg(CHILD_ID_UV, V_UV);
                                  uint16_t lastlux;
                                  int lastUV = -1;
                                  int uvIndexValue [13] = { 50, 227, 318, 408, 503, 606, 696, 795, 881, 976, 1079, 1170, 3000};
                                  int uvIndex;
                                    gw.begin();
                                    gw.sendSketchInfo("UV/Lux Sensor", "1.0");
                                    gw.present(CHILD_ID_UV, S_UV);
                                    Serial.print("Lux reading: ");
                                        gw.send(msg.set(lux, 1));
                                        lastlux = lux;
                                    uint16_t uv = analogRead(0);// Get UV value
                                    Serial.print("Uv reading: ");
                                    Serial.println(uv);
                                    for (int i = 0; i < 13; i++)
                                      if (uv <= uvIndexValue[i])
                                        uvIndex = i;
                                        break;
                                    Serial.print("Uv index: ");
                                    Serial.println(uvIndex);
                                    if (uvIndex != lastUV) {
                                        gw.send(uvMsg.set(uvIndex, 1));
                                        lastUV = uvIndex;
                                  • H Offline
                                    H Offline
                                    There is a perfectly good explanation why UV sensor isn't showing up. MySensors does not distribute any device files for it. It might work with the rfx-plugin-device:
                                    http://code.mios.com/trac/mios_rfxcom/browser
                                    B 1 Reply Last reply
                                    • H hek
                                      B Offline
                                      B Offline
                                      BulldogLowell
                                      @hek
                                      I remember @epierre working on the sensor, I helped him with the little sort logic on the sensor readings to determine the index... I cannot recall what device he used to present the index within Vera...
                                      In china right now, the Great Firewall preventing a good search on the forum for that project...
                                      perhaps @epierre can recall for you
                                      • N Offline
                                        N Offline
                                        niccodemi
                                        wrote on last edited by niccodemi
                                        #79
                                        @hek @BulldogLowell UV sensor works fine as standalone sensor / node. After trying different things I noticed that if I switch order of
                                        these lines
                                        to these below
                                        then node and UV sensor show up in vera, but lux light is missing. It seems that sensor presented 1st gets recognized but second one omitted. Could it have to do anything with both devices using analog pins?
                                        • B Offline
                                          B Offline
                                          BulldogLowell
                                          CHILD_ID_LIGHT and CHILD_ID_UV are defined as two different nonzero numbers, right?
                                          Sorry I cannot read your sketch here in China!!
                                          12.1k
