  3. implementing multiple sensors
83 Posts 28 Posters 99.2k Views 15 Watching
  • AnticimexA
    AnticimexA
    Anticimex
    @waynehead99 you most likely need 1.4 Lib for the new sleep constructor. I have not used sleep on 1.3 so I do not remember what arguments you had available there.
    I have also extended sleep with an additional constructor which @hek has pulled into the release branch of 1.4 that permits you to use two external interrupts with independent triggers for sleep in addition to a timeout. Great for nodes with multiple sensors that still run on battery.
    • E
      E
      egbertje
      wrote on last edited by egbertje
      #53
      @Mountainman ;
      Im trying your code and its almost what im looking for.
      I have two questions about it:
      1 : Is it possible that the battery info has is own child id?
      2 : Why dont you implement a light sensor like an LDR?
      I think that including LDR/light then you have the ideal multisensor ; light + temp/hum + motion + batt monitoring !
      But for now im playing with your code and try to implement light.
      • mountainmanM mountainman
        Here is a version I'm currently using that makes use of interrupts so might be more suitable for a battery driven DHT/Motion multi sensor. It also includes the battery monitoring. Any feedback or improvements would be appreciated.
        #define CHILD_ID_HUM 0
        #define CHILD_ID_TEMP 1
        #define CHILD_ID_MOTION 2   // Id of the sensor child
        unsigned long SLEEP_TIME = F; // Sleep time between reports (in milliseconds)
        int oldValue=-1;
        DHT dht;
        float lastTemp;
        float lastHum;
        boolean metric = false;
        int oldBatteryPcnt = 0;
        int battLoop =0;
        // Initialize motion message
        MyMessage msg(CHILD_ID_MOTION, V_TRIPPED);
        boolean pinTriggered=0;//waitTime is number of seconds to hol in while loop
        long lastDebounceTime = 0;  // the last time the output pin was toggled
        long debounceDelay = 50;    // the debounce time; increase if the output flickers
          analogReference(INTERNAL);
          gw.begin();
          gw.sendSketchInfo("Motion Humidity w/ Batt", "1.0");
          gw.present(CHILD_ID_MOTION, S_MOTION);
          pinMode(DIGITAL_INPUT_SENSOR,INPUT);      // sets the motion sensor digital pin as input
          digitalWrite(DIGITAL_INPUT_SENSOR,HIGH);   // Activate internal pull-up
          check_batt();
          if (pinTriggered)
        	Serial.println(millis()-lastDebounceTime);
        	// Read digital motion value
        	boolean value = digitalRead(DIGITAL_INPUT_SENSOR);
        	// If the switch changed, due to noise or pressing
        	if (value != oldValue) {
        		lastDebounceTime = millis();
        		// Send in the new value
        		battLoop++;
        		oldValue = value;
        		Serial.print("Mot: ");
        		Serial.println(value);
        	pinTriggered=0;
        	if (isnan(temperature))
        	else if (temperature != lastTemp)
        	  lastTemp = temperature;
        	  if (!metric)
        	  battLoop++;
        	  Serial.print("T: ");
        	if (isnan(humidity))
        	else if (humidity != lastHum)
        	  lastHum = humidity;
        	  battLoop++;
        	  Serial.print("H: ");
        	  Serial.println(humidity);
        	if (battLoop > 10)
        	  check_batt();
        	  battLoop=0;
          pinTriggered = gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME);
        void check_batt()
          // get the battery Voltage
          Serial.println(sensorValue);
          Serial.print(batteryV);
          Serial.println(" V");
          Serial.print(batteryPcnt);
          Serial.println(" %");
        	// Power up radio after sleep
        	oldBatteryPcnt = batteryPcnt;
        C
        C
        codenea
        @mountainman Is there any instructions on how to wire/setup the hardware to work with your code?
        • mountainmanM
          mountainmanM
          mountainman
          @egbertje;
          The battery percentage is associated with the parent Arduino Node in the vera UI.
          I have some LDRs ordered from Ebay so that is the next step. I had previously used the BH1750 I2C sensor in a multi sensor with the 1.3 lib but I want to debug on its own as it seemed to be giving unexpected readings.
          @codenea The instructions are pretty much from the main page although if I get a chance I try to draw it up and post some pics. My setup not very pretty yet with perf board and jumper wires. A dedicated PCB would be nice.
          • epierreE
            epierreE
            epierre
            Here is my combo to make a Home Monitoring solution:
            https://github.com/empierre/arduino/blob/master/MQv01dgi_1_4.ino
            It includes (currently on a Mega):
            • Barometer : BMP085
            • Temperature + Humidity DHT11
            • Particle sensor
            • Gas sensors MQ2 MQ6 MQ131 MQ135 TGS2600 2SH12
            To be added when stabilized:
            • Sound level in DB
            Could be added:
            • Light sensor
            • Vibration sensor
            • PIR
            z-wave - Vera -> Domoticz
            • pgoP
              pgoP
              pgo
              wrote on last edited by pgo
              #57
              Hi guys,
              this is a one node with publishing DS temperatures and listening for relay commands I finished and tested yesterday>
              https://github.com/pgo-sk/mysensors/blob/master/arduino/DS_and_Relay.ino
              feel free to comment/use/publish...
              I combined the Dalas and Relay examples together - you have to deactivate the sleep for the relays to listen 100% of time.
              MQTT identification on openHAB:
              MyMQTT/20/0/V_TEMP - DS sensor(s)
              MyMQTT/20/1/V_LIGHT - relay 1
              MyMQTT/20/2/V_LIGHT - relay 2
              If somebody is interested I can post the maps/items files for openHAB
              Regards,
              Pego
              PS I am working on an home automation system with solar hot air panels control/solar hot water panels and all the common stuff like lights/temperatures/weather etc.. More here: https://github.com/pgo-sk/mysensors/wiki/Home-automation-using-mysensors-and-openHAB
              • I
                I
                integlikewhoa
                I'm also following along interested in the Temp, Humidity, and motion sensor.
                • I integlikewhoa
                  Tibus
                  @integlikewhoa check this :
                  http://forum.mysensors.org/topic/404/3-in-1-humidity-temp-and-motion
                  • pgoP
                    pgoP
                    pgo
                    #60
                    https://github.com/pgo-sk/mysensors/blob/master/arduino/DS_Light_Relay
                    • DS18B20 (up to 16 like in original temp sketch)
                    • TEMT6000 reporting LUX light values
                    • 2x Relays
                      running and tested
                      Sensor <-> MQTT gateway <-> openHAB/PC
                    When interested can post the openHAB items/sitemap(s) settings
                    Screenshots - over teamviewer, sorry for the quality.
                    Here the TEMT6000 output - in a quite dark room and changing weather today>
                    upload-42ac73c1-61cf-4b90-9ec5-14a994a3b50a
                    Here the temperature and relays:
                    upload-86825c33-2cc2-4018-9e08-2020007af3a9
                    Menu:
                    upload-adf5c382-2803-49b9-a461-eb25beb572c0
                    aquaproA 1 Reply Last reply
                    • D
                      Dany
                      Has anyone made ​​RGB LED strip node? I am looking for a working example program ...
                      N 1 Reply Last reply
                      • blaceyB
                        blaceyB
                        blacey
                        @Dany - yes. Checkout http://www.mysensors.org/build/dimmer
                        D 1 Reply Last reply
                        • korttomaK
                          korttomaK
                          korttoma
                          Or here is an example I'm using:
                          https://codebender.cc/sketch:44740
                          • Tomas
                          • pgoP pgo
                            • 2x Relays
                              running and tested
                            Menu:
                            aquaproA
                            aquaproA
                            aquapro
                            wrote on last edited by aquapro
                            #64
                            Hi, I'm interested. :-)
                            Or is this the latest version ?
                            pgoP 1 Reply Last reply
                            • aquaproA aquapro
                              pgoP
                              pgoP
                              pgo
                              #65
                              Yes :), for the sketches mentioned earlier.
                              <Comment to myself: Have to switch to some versioning as now I am already deeper in the project including cameras, weather forcasts etc.>
                              • aquaproA
                                aquaproA
                                aquapro
                                I could not decide yet on a platform. OpenHAB should be my next test.
                                • pgoP
                                  pgoP
                                  pgo
                                  #67
                                  test1.items
                                  test1.sitemap
                                  test1.rules
                                  webcam.png -icon for webcam - put in openhab/webapps/images
                                  My Current openHAB items/sitemap. 1 multisensor with Temp/Lux/Humidity sensor, 1 ethernet/MQTT gateway.
                                  Also weather forcast from yr.no and Samsung TV remote controls (Mute working, rest not so much)
                                  • openHAB v 1.5.1
                                  • Addons :
                                    \openhab\addons>
                                    org.openhab.binding.http-1.5.1.jar
                                    org.openhab.binding.mqtt-1.6.0-SNAPSHOT.jar
                                    org.openhab.binding.ntp-1.5.1.jar
                                    org.openhab.binding.samsungtv-1.6.0-SNAPSHOT.jar
                                    org.openhab.binding.zwave-1.6.0-SNAPSHOT.jar
                                    org.openhab.io.habmin-1.6.0-SNAPSHOT.jar
                                    org.openhab.persistence.exec-1.5.1.jar
                                    org.openhab.persistence.logging-1.5.1.jar
                                    org.openhab.persistence.mqtt-1.6.0-SNAPSHOT.jar
                                    org.openhab.persistence.rrd4j-1.5.1.jar
                                  HABmin conf with graphs:
                                  charts.xml -put in openhab/etc/habmin
                                  In habmin.cfg specify the IP of your MQTT arduino and port>
                                  '#'mqtt:<broker>.clientId=<clientId>
                                  mqtt:mysensor.url=tcp://192.168.1.234:1883
                                  mqtt:mysensor.clientId=MQTT
                                  mqtt:mysensor.qos=0
                                  mqtt:mysensor.retain=true
                                  mqtt:mysensor.async=true
                                  Here some screenshots:
                                  These (Direct channel/Channel/Volume) does not work yet... Mute is OK and Volume displays only the current TV volume.
                                  • aquaproA aquapro
                                    pgoP
                                    pgoP
                                    pgo
                                    It runs quit stable on my old WinXP64Pro Quadcore w/many virtual machines on it.
                                    Have still some problems with the syntax of the openHAB settings, but else nice controller ;)
                                    • blaceyB blacey
                                      Dany
                                      wrote on last edited by Dany
                                      #69
                                      @blacey I tried this already. This is a simple dimmer node, not RGB. It's work fine.
                                      But I would like to use a RGB colorpicker in openhab.
                                      • D Dany
                                        pgoP
                                        pgoP
                                        pgo
                                        #70
                                        @Dany said:
                                        I would like to use with a RGB colorpicker in openhab.
                                        I would do that soon too. Would you like to have a node only as rgbw dimmer or maybe with a lux sensor as I like to do to also adjust for constant light/lux in the room?
                                        In my menu you can see the setpoint for lux under the light sensor.
                                        • pgoP pgo
                                          Dany
                                          @pgo The RGB Colorpicker works already in openhab.
                                          I have some problem in arduino side...i tried update the sample DimmerActuator code, but didn't work. I tried korttoma's code, but it didn't works for me, too.
                                          (e.g. message.header.childId -didn't work)
