  3. Multi Binary Switches
13 Posts 6 Posters 8.1k Views 2 Watching
  • jeylitesJ Offline
    jeylitesJ Offline
    jeylites
    wrote on last edited by jeylites
    Hi, I'm trying to create an array of binary switches based on the 8Ch relay script, but I'm having issues setting it up. I don't have much knowledge in programming and I was wondering if anyone here could guide me. This is what I have done...
    // Simple binary switch example
    // Connect button or door/window reed switch between
    // digitial I/O pin 3 (BUTTON_PIN below) and GND.
    #include <Bounce2.h>
    const int BUTTON[] = {3, 4, 5};
    #define NUMBER_OF_BUTTONS 3
    //#define CHILD_ID 3
    //#define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
    Bounce debouncer = Bounce();
    int oldValue=-1;
    MyMessage msg(V_TRIPPED);
      gw.begin();
    // Fetch relay status
      for (int sensor=1, pin=0; sensor<=NUMBER_OF_BUTTONS;sensor++, pin++) {
     // Setup the button
      pinMode(BUTTON[pin],INPUT);
      // Activate internal pull-up
      digitalWrite(BUTTON[pin],HIGH);
      debouncer.attach(BUTTON[pin]);
      debouncer.interval(5);
      gw.present(sensor, S_DOOR);
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue) {
         // Send in the new value
         gw.send(msg.set(value==HIGH ? 1 : 0));
         oldValue = value;
    • M Offline
      M Offline
      maltimus
      What is the issues you are having?
      jeylitesJ 1 Reply Last reply
      • M maltimus
        jeylitesJ Offline
        jeylitesJ Offline
        jeylites
        @maltimus
        I can't seem to get binary to work in an Array.
        • R Offline
          R Offline
          raditv
          you have to make an array also for debouncer
          • B Offline
            B Offline
            BulldogLowell
            wrote on last edited by BulldogLowell
            @jeylites
            have you checked this thread?
            http://forum.mysensors.org/topic/994/multi-button-relay-switch/24
            • B BulldogLowell
              @jeylites
              jeylitesJ Offline
              jeylitesJ Offline
              jeylites
              @BulldogLowell
              I'm trying to do Multi Binary switches without the relays. I tried using the Multi Button Relay sketch, but I'm afraid that if remove the relay function, it would affect the button setup.
              @Rachmat-Aditiya How do I go about doing that an array for debouncer?
              B 1 Reply Last reply
              • jeylitesJ jeylites
                @BulldogLowell
                B Offline
                B Offline
                BulldogLowell
                the example of debouncing an array of sensors was in the code in the examples... was my point.
                • M Offline
                  M Offline
                  mikeones
                  Here is one example with a few extras.
                  #include <Time.h>        //http://playground.arduino.cc/Code/Time
                  #include <TimeAlarms.h>  //http://playground.arduino.cc/Code/Time
                  #define RADIO_ID 12
                  #define noReeds 5
                  const int BUTTON_PIN[] = {14, 15, 16, 17, 18};            // Arduino Digital I/O pin for button/reed switch, A0 - A4
                  boolean reedState[] = {HIGH, HIGH, HIGH, HIGH, HIGH};
                  Bounce debouncer[noReeds];
                  MyMessage msg[noReeds];
                  void setup(){
                    Serial.println("Starting setup" );
                    gw.begin(NULL, RADIO_ID, true);  //stattc RADIO_ID an enable repeater
                    Alarm.delay(250);
                    gw.sendSketchInfo("Alarm Pannel", "1.0");
                    Alarm.delay(250);
                    gw.requestTime(receiveTime);
                    // initialize Relays with corresponding buttons
                    for (int i = 0; i < noReeds; i++){
                      msg[i].sensor = i;			// initialize messages
                      msg[i].type = V_TRIPPED;
                      debouncer[i] = Bounce();		// initialize debouncer
                      debouncer[i].attach(BUTTON_PIN[i]);
                      debouncer[i].interval(5);
                      // Setup the button
                      pinMode(BUTTON_PIN[i],INPUT);
                      digitalWrite(BUTTON_PIN[i],HIGH);
                      gw.present(i, S_DOOR);		// present sensor to gateway
                      Serial.print("setup for switch: ");
                      Serial.print(BUTTON_PIN[i]);
                      Serial.println(" complete" );
                      Alarm.timerRepeat(720, updateState); // update relay status every 2 hrs
                      Alarm.delay(250);
                    Serial.println("Setup complete" );
                    gw.process();
                      debouncer[i].update();
                      int value = debouncer[i].read();
                      if (value != reedState[i]) {
                         gw.send(msg[i].set(value==HIGH ? 1 : 0), false);
                         reedState[i] = value;
                         Serial.print("updating state for swicth: ");
                         Serial.print(" state: ");
                         Serial.println(reedState[i]);
                  void updateState(){
                    Serial.println("Start state info");
                        Serial.print("sending update for switch: ");
                        Serial.println(BUTTON_PIN[i]);
                        Alarm.delay(250);
                        //MyMessage msg(relayPin[pin],V_LIGHT);
                        gw.send(msg[i].set(reedState[i]), false); // Send last state from eprom to GW
                        Alarm.delay(250);
                  // This is called when a new time value was received
                  void receiveTime(unsigned long time) {
                    setTime(time);
                  • M mikeones
                    #define RADIO_ID 12
                    #define noReeds 5
                    void setup(){
                      Alarm.delay(250);
                      Alarm.delay(250);
                        // Setup the button
                        Alarm.delay(250);
                      gw.process();
                    void updateState(){
                          Alarm.delay(250);
                          Alarm.delay(250);
                      setTime(time);
                    jeylitesJ Offline
                    jeylitesJ Offline
                    jeylites
                    @mikeones Thank you, The sketch is very helpful and it works. Just out of curiosity, what is the function of Time & TimeAlarm ?
                    • M Offline
                      M Offline
                      mikeones
                      It forces a status update at a predefined interval.
                      • M mikeones
                        jeylitesJ Offline
                        jeylitesJ Offline
                        jeylites
                        @mikeones Got it.
                        • C Offline
                          C Offline
                          Cowboy1980
                          Much appreciated for the script but Ive been trying to get more reed switches running off the one nano, I added the extra pins to Button_Pin and changed noReeds and boonlean readstate to represent how many pins I was using. I have 12 showing up in vera and serial shows correctly the change in state of all 12 pins but in the Vera all 12 show but dont trip/show the state change. What am I missing? When I run the code youve written as is everything works fine but as soon as I even add 1 more pin Mios wont show the state change. Plz help!
                          • C Cowboy1980
                            jeylitesJ Offline
                            jeylitesJ Offline
                            jeylites
                            @Cowboy1980 Can you post your script...
                            12.2k
