  3. Array in send message command
3 Posts 2 Posters 1.1k Views 2 Watching
  • Y
    Y
    yourry
    Hi there,
    I am currently working on a node with openEnergy Monitor.
    I'm measuring a total of 6 SCT013 current transformer and wondering how in the mySensor code to include everything in a for loop.
    For example, to send the message, I hope to do:
    MyMessage msgInA0(CHILD_ID_V_A0, V_WATT);
    MyMessage msgInA1(CHILD_ID_V_A1, V_WATT);
    MyMessage msgInA2(CHILD_ID_V_A2, V_WATT);
    MyMessage msgInA3(CHILD_ID_V_A3, V_WATT);
    MyMessage msgInA4(CHILD_ID_V_A4, V_WATT);
    MyMessage msgInA5(CHILD_ID_V_A5, V_WATT);
    #define NSENSORS
    //Read values and send to gateway
    for (int i=0; i<NSENSORS; i++)
    	watt[i] = (emon[i].calcIrms(1480))*230*0.9;
    	send(msgInA[i].set(watt[i], 1)); //Error: not working
    But it doesn't work.
    Do you have a trick to avoid writing the same code X times?
    Thank you,
    H 1 Reply Last reply
    • Y yourry
      Hi there,
      #define NSENSORS
      Thank you,
      H
      H
      hard-shovel
      @yourry for an example of array usage see Temperature Sensors build page.
      MyMessage msgInA(0, V_WATT);     // only one message required
      #define NSENSORS   6
      	send(msgInA.setSensor(i).set(watt[i], 1));        //setSensor(i) is the magic
      • Y
        Y
        yourry
        Great, thanks for your reply and help.
        I was able to do what I wanted, I give you some code snippets to make several messages via a for loop,
        I'm not a code proffesional but this works:
        // Initialize messages
        MyMessage msgInA(0,V_CURRENT);
        MyMessage msgWhA(0,V_WATT);
        #define NSENSORS              6				//used current sensors
        	//initialize energy monitor CurrentSensor
        		wh[i]        = { 0.0 };  //initialize wh
        		lwhtime[i]   = {0};	//initialize time
        		present(i, S_MULTIMETER);
        		present(i, S_POWER);
        		send(msgInA.setSensor(i).set(Irms[i], 1));
        		send(msgWhA.setSensor(i).set(wh[i], 1));
