  3. Home Assistant
  4. Relay device not showing up in HA but does in .json
6 Posts 4 Posters 834 Views 4 Watching
    mrhutchinsonmn
    I have the following relay device that shows up in the .json file of HA, but will not appear on the dashboard as an available device. Guessing it doesn't like something about the sketch, but not sure what that might be.
    Sketch:
     * Version 1.0 - Henrik Ekblad
    #define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    #define MY_REPEATER_FEATURE
    #define MY_NODE_ID 100
    #define RELAY_PIN 2  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    void before()
      for (int sensor=1, pin=RELAY_PIN; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
        pinMode(pin, OUTPUT);
        present(sensor, S_BINARY);
      if (message.getType()==V_STATUS) {
        // Change relay state
        digitalWrite(message.getSensor()-1+RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
        // Store state in eeprom
        saveState(message.getSensor(), message.getBool());
        // Write some debug info
        Serial.print(message.getSensor());
    .json file:
        "0": {
            "sensor_id": 0,
            "children": {},
            "type": 18,
            "sketch_name": null,
            "sketch_version": null,
            "battery_level": 0,
            "protocol_version": "2.3.2",
            "heartbeat": 0
        "100": {
            "sensor_id": 100,
            "children": {
                "1": {
                    "id": 1,
                    "type": 3,
                    "description": "",
                    "values": {}
            "type": 18,
            "sketch_name": "Relay",
            "sketch_version": "1.0",
            "battery_level": 0,
            "heartbeat": 0
    • C
      C
      cabat
      Hello, friend.
      Do you read this Presentation?
      M 1 Reply Last reply
      • C cabat
        Hello, friend.
        mrhutchinsonmn
        @cabat Thank you! Apparently, the MySensors sketch supplied in the Build section is not written to work with HA. I did take a stab at it and pop some code in the loop section, and the sensor now shows up but is not functional. I will have to dig more and determine what should be added to the sketch for it to work.
        Thanks much for the pointer.
        Y 1 Reply Last reply
        • M mrhutchinsonmn
          Y
          Y
          yoshida
          @mrhutchinsonmn have you managed to get your node working under HA? I would migrate from Domoticz to HA, but I have never saw any working sketch :D (I use relay switch, some temp+hum, light level measure)
          • C
            C
            cabat
            This post is deleted!
            • monteM
              monteM
              monte
              wrote on last edited by monte
              Please read carefully documentation for HA. https://www.home-assistant.io/integrations/mysensors/
              You need to send initial state of your sensors. There is example code for doing it. Basically you check in loop if the node just started and send some values to HA. After that your sensor will appear in HA.
