  3. Home Assistant
  4. Request the status of a Home Assistant entity that is not defined in the MySensors integration?
3 Posts 2 Posters 559 Views 2 Watching
  • G
    G
    Gibber
    I am trying to use a battery powered node to control a window blind. The sleep function does not cooperate well with a control entity due to the sleep delay interfering with the acknowledgement timing.
    I saw in another post that there is no "optimistic" mode available with the MySensor integration.
    Does anyone know if it is possible for a node to request the status of home assistant entity that is not defined as part of the MySensor integration?
    • electrikE
      electrikE
      electrik
      With some logic in home assistant like in an automation or node red, this is possible. Use a helper function to set the state, and request that status from the node
      • G
        G
        Gibber
        Thanks for the response. Can you be more specific about how to request the status from the node?
        My understanding is the request format is:
        request (Child_ID, VariableType);
        But if the Home Assistant entity that I want to request the status of is not a MySensors entity it will not have a Child_ID. So how do I format the request statement?
