  3. Domoticz
  4. Ethernet gateway doesn't work with Domoticz.
ethernetdomoticz
11 Posts 7 Posters 8.6k Views 2 Watching
  • K
    K
    kunall
    I wanted to report my or some other members issues with Ethernet Gw and Domoticz. It seems that Ethernet gateway only works one way and not other with Domoticz.
    I was able to get status updates on Domoticz via Ethernet gateway but I couldn't send any command to any nodes.
    Ex. I could see all the sensor data, relay's physical button status update but I could not send a on/off command to the relay. There's just no response from Ethernet Gw if issues a command from Domoticz UI.
    I tested serial gateway, it worked without any issue.
    Thanks!
      You might get luckier by reporting this over at the Domoticz forum/issue tracker.
      K 1 Reply Last reply
        K
        K
        kunall
        @hek You mean this isn't an issue with the ethernet gateway but Domoticz itself? I will open a support ticket with domoticz. Thanks!
          You ether got one way communication (which should be visible in serial monitor) or Domoticz somehow have problems sending out commands over ethernet.
          • S
            Striffster
            @kunall Please post a note here if you will get any solution from Domoticz.
              K
              K
              kunall
              @hek Thats right, I only get one way communication. Domoticz doesn't send cmd via Ethernet for some reason.
              • S Striffster
                K
                K
                kunall
                @Striffster I surly will.
                • sundberg84S
                  I have a ethernet gw with domoticz. Im having problem with incoming battery level is added to the wrong node. I will try to re-compile with some new log commands. If there is any you want me to add let me know and i can try to debug.
                  A 1 Reply Last reply
                  • sundberg84S sundberg84
                    A
                    A
                    andriej
                    @sundberg84 I've seen it should be fixed lately - check domoticz's commits at: http://sourceforge.net/p/domoticz/code/commit_browser
                    • H
                      H
                      HenkeP
                      @sundberg84 @andriej, I'm running MySensors using serial gateway on Domoticz and saw the same issue but it got fixed just recently and it seems to work on the latest Beta which I'm running.
                      • S
                        sve
                        I have created a topic in the forum before, with tcpdump examples.
                        http://www.domoticz.com/forum/viewtopic.php?f=6&t=6112
                        But the problem is still there, hopefully soon fix.
