  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 659.8k Views 35 Watching
  • F
    F
    Fabien
    I try to make OTA update for sensebender using 1.5 branch sketch on the sensebender (sensebender github sketch from 1.5 branch) and MYSController but it doesn't work. Any idea ?
    tbowmoT tekkaT 2 Replies Last reply
    • F Fabien
      tbowmoT
      tbowmoT
      tbowmo
      @Fabien
      Have you enabled spi flash, and Ota functions in the constructors for mysensors?
      • F Fabien
        tekkaT
        tekkaT
        tekka
        @Fabien MYSController is currently not supporting Sensebender board OTA - however, WIP and beta will be released soon. stay tuned :)
          @tekka
          Have you had the chance to get a sensebender board? As I still haven't verified the library code it probably could contain unverified features (== bug). Send me a ping on hangout if you need a board to test on. We should probably combine our effort.
          My last days of vacation has been filled with (family) activities. On my shortlist is the thermostat/HVAC device support (still a bit messy but I hope to get the devices from dev-branch into master together with the hvac thingies). Ping @pjr, @stephenmhall .
          http://forum.mysensors.org/topic/1337/request-new-sensor-type-thermostatically-controlled-switch/7
            Yes, it works in UI7. Are you using the correct Vera-branch?
            https://github.com/mysensors/Vera/tree/UI7
            K
            K
            Kurtsejr
            @hek
            I have used the one mentioned here: http://www.mysensors.org/controller/vera
            Still cant include, but I have had these problems before with e.g. a relay or motion sensor - but after several tries it include a appear in the user interface.
            But perhaps the software installed on the board does not use the same frequency as default Sensornet lib's are using?
            /Kurt
            • F
              F
              Fabien
              Thank you @tekka and @tbowmo. I don't change the constructors and if MYS doesn't support OTA, it can't work. I will upload a modified version tonight to be ready when MYSConrtoller will support sensebender.
              I have to upload new sketch with 1.5 branch on gateway too ?
              • G
                G
                gloob
                Today I received a new batch of radio modules and all problems with transmission fails is gone.
                • G gloob
                  Moshe LivneM
                  Moshe LivneM
                  Moshe Livne
                  @gloob can you share where you got the good nrf from?
                  G 1 Reply Last reply
                  • Moshe LivneM Moshe Livne
                    G
                    G
                    gloob
                    @Moshe-Livne This time I ordered the modules from a german eBay seller:
                    http://www.ebay.de/itm/201279950473?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                      mvader
                      @Moshe-Livne just FYI - i ordered all my NRF's from the same place i ordered the sensebender boards from.
                      and they were all legit NRF's came in their own boxes and have worked great.
                      http://imall.itead.cc/wireless/im120606002.html
                        wrote on last edited by hek
                        #231
                        My Sensebender has been running for a month now with 2xAA with the default sketch (which have improved a bit since then). Battery level has dropped 5%.
                        We've had a few hot days (inside the house) during the summer (Deg C).
                        • M mvader
                          NeverDieN
                          NeverDieN
                          Thanks for the tip! I just ordered some.
                          • 5546dug5
                            5546dug5
                            5546dug
                            @hek interesting my 2aa alkaline batteries are down 15% in a month with sketch supplied on board.
                            I will keep track. But to grAph I need the Ethernet gw am building it next.
                            • M mvader
                              NeverDieN
                              NeverDieN
                              Do they "just work out of the box" or do they benefit from the 10uF capacitor that some boards allegedly seem to need?
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                @NeverDie
                                I'm not using an extra capacitor on the 3 sensebenders (from itead) that I have in operation at the moment. and they are working without problems.
                                • rvendrameR
                                  rvendrameR
                                  rvendrame
                                  Batteries usually provide a 'clean' power supply. The capacitor is more useful when there is ripple from the AC adapter.
                                  ESP8266 GW + mySensors 2.3.2
                                  Alexa / Google Home
                                  • NeverDieN NeverDie
                                    mvader
                                    no cap needed.. just straight to the board.
                                    • G
                                      G
                                      gloob
                                      wrote on last edited by gloob
                                      #238
                                      I have just a question about the default sketch.
                                      Doesn't the following code influence the sleep time?
                                        // check if we can lower the speed
                                        if ((measureCount == 5) && highfreq)
                                          clock_prescale_set(clock_div_8); // Switch to 1Mhz for the reminder of the sketch, save power.
                                          highfreq = false;
                                      If i lower the clock speed I would expect a lower processing time.
                                      Also, the threshold for temperature and humidity is set to 0.5 and the humidity is read in percent as an integer. Doesn't this mean that even when the humidity changes by less than 1 percent I get an update of the values. I would expect that the noise of the humidity sensor is around 1%.
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        It's the watchdog that is used for calculating the sleeptime, which is running independently from the CPU oscliator (which is lowered here).
                                        Humidity is using a running average, it starts with taking average of the previous two measurements, put in the current measurement, and takes a new average (meaning this measurement, and the previous measurement). Then it takes the difference between those two averages, and this needs to be above 0.5.
                                        In theory it should lower the number of transmissions, if the humidity fluctuates, like: 50%, 51%, 50%.. without the running average, this would trigger 3 transmissions.
                                        You are welcome to suggest another method of limiting "spurious" transmissions :)
                                        • tbowmoT tbowmo
                                          Moshe LivneM
                                          Moshe LivneM
                                          Moshe Livne
                                          @tbowmo hmmm haven't looked at the details in the sketch but suppose we have 50, 50 , 51, 50, 51, 51, 51 wouldn't the results be:
                                          50, 50 = 50
                                          50, 50, 51 = 50.3
                                          50, 51 = 50.50
                                          50, 51, 50 = 50.50
                                          51, 50 = 50.50
                                          51, 50, 51 = 50.6
                                          50, 51 = 50.50
                                          50, 51, 51 = 50.6
                                          51, 51 = 51
                                          51, 51, 51 = 51
                                          so no over 0.5 fluctuation?
                                          I think a threshold would work better. can be by running average but from a fixed, last reported temp.
