  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 659.9k Views 35 Watching
  • D
    D
    Dean
    Hope this isn't too silly a question.... The temp/humidity sensing, that works 'out of the box' without requiring me actually connecting these sensors, right?
    And another question, would it be possible to turn the temp/hum function off and just have a motion sensor connected which would never do anything unless it sensed movement and then send a message to the gateway?
    I've been flat out at work for a couple months so I've been away from this for a while... :-)
    • tbowmoT
      tbowmoT
      tbowmo
      @Dean
      It will be programmed by the factory, with the "Sensebender micro" sketch, https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/examples/SensebenderMicro/SensebenderMicro.ino
      So it's plug'n'play as a sensor with temperature and humidity. You could always dump another sketch to the unit, if you want to use it for something else.
      • G
        G
        gol
        I have also ordered a couple of boards to be able to evaulate them as soon as possible.
        Just a question:
        • What is the expected lifetime of the batteries if you use 2 AA batteries, the default preloaded sketch and reports the temp and humidity values once per minute?
        • jeylitesJ
          jeylitesJ
          jeylites
          wrote on last edited by jeylites
          #24
          Out of curiosity, can over the air updates be implemented on Arduino Nano? I'm going to get 3 to put Sense to the test. :smiley:
            @gol
            It was measured by @blacey to 0.05 mA while sleeping and 0.95 mA during transmit. @tbowmo got some higher figures but they were most probably related to running a NRF24L01+ clone.
            @jeylites
            Yes, have a look at the bootloader here:
            https://github.com/mysensors/Arduino/tree/master/MYSBootloader
            You can test OTA updates using the MYSController. It overwrites program memory in-place during boot. If communication goes down or fails during this process the node won't boot up again (you have to upload a new sketch while connected to you computer).
            The sensbender has a external flash which means we can safely store the OTA firmware while normal sketch is running. When everything has been downloaded the DualOptiboot moves new firmware from flash to program memory during bootup. The code for this has been written (in development branch) but has not been tested yet (I failed handsoldering them :() .
            tekkaT D 2 Replies Last reply
            • D
              D
              Dean
              Thankyou @tbowmo
                @gol
                @jeylites
                tekkaT
                tekkaT
                tekka
                wrote on last edited by tekka
                #27
                @hek said:
                @jeylites
                If the communication fails, the bootloader will remain "bootloading", i.e. will try to fetch a new firmware from the controller until the CRC matches - no need to upload a sketch via computer.
                MYSBootloader 2.0 will have SHA signing implemented: for those nodes without ATSHA204 which need signed OTA updates :)
                jeylitesJ 1 Reply Last reply
                • tekkaT tekka
                  @hek said:
                  @jeylites
                  jeylitesJ
                  jeylitesJ
                  jeylites
                  Do I have to include those files into my sketch or just install MYS on windows and it will auto detect? In other words, do I have to make any changes to the sketch?
                  Is there any tutorial on MYS implementation?
                  hekH 1 Reply Last reply
                  • jeylitesJ jeylites
                    @jeylites
                    You should read up on what a bootloader is and how to install it.
                    http://www.arduino.cc/en/Hacking/Bootloader?from=Tutorial.Bootloader
                    Might be good to start another thread if you have more MYSController/bootloader questions,
                      @jeylites
                      marceltrapmanM
                      marceltrapmanM
                      marceltrapman
                      Nicely put :)
                      I would say 'please start another thread because this will never be found again and will help other as well'...
                      Just my 2 cents.
                      Fulltime Servoy Developer
                      • rvendrameR
                        rvendrameR
                        rvendrame
                        is 3V the absolute maximum or 3.3V is acceptable to power it? For non-battery operated sensors, it may be easier to find a 3.3V regulators instead 3V (at least in my country).
                        ESP8266 GW + mySensors 2.3.2
                        Alexa / Google Home
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          @rvendrame
                          absolute maximum voltage is 3.6V, above that you'll let the magic smoke out of the following components:
                          • Si7021
                          • external flash
                          • radio module.
                          Only the atmega328 and atsha204 will survive.
                          korttomaK 1 Reply Last reply
                          • rvendrameR
                            rvendrameR
                            rvendrame
                            But will all components work properly on 3.3V?
                            Alexa / Google Home
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              @rvendrame
                              Yes they would
                              • rvendrameR
                                rvendrameR
                                rvendrame
                                @tbowmo thx a lot!
                                Alexa / Google Home
                                • D
                                  D
                                  doblanch
                                  I didn't find mention of it. What is the expected battery life ?
                                  I was going to replace AA by CR123 to gain in space.
                                  thkx
                                    I posted some measurements above. Hard to say a definite battery life expectation. Depends on many factors such as battery quality, send frequency and what external sensors you attach.
                                    D 1 Reply Last reply
                                      @gol
                                      @jeylites
                                      D
                                      D
                                      doblanch
                                      wrote on last edited by doblanch
                                      #38
                                      @hek I computed that sending a value every minute with a 10 seconds of communication every minute (wakeup), the autonomy for a single 3V 1500mA CR123 lithium battery is around 1 year (312 Days). Around 2 year for a dual Lithium AA, I guess.
                                      If there is 5 second of wakeup every minute, it's 500 days for a single cell CR123.
                                      Purely theorical... but it gives an order of magnetude.
                                        D
                                        D
                                        doblanch
                                        @hek Of course it's difficult to predict, it's just to have an order of magnitude, specially if I want to use a CRV123 3V battery. I don't want to change it every 2 months. One year should be good.
                                        • H
                                          H
                                          Hausner
                                          wrote on last edited by Hausner
                                          #40
                                          Would this work with a 3,7V Li-Ion 18650 cell? Because I've got a S... load from old laptops
