  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 658.9k Views 35 Watching
  • ximinezX
    ximinezX
    ximinez
    I just ignore the first fails. It works after that, and has done so for close to a month.
    • AnticimexA
      AnticimexA
      Anticimex
      #482
      Well, if you think the signing implementation cause initial radio transmissions to fail I am afraid I will need your help in explaining how. Because I fail to see any connection between signing and radio behaviour. st=fail is a transmission problem, and signing implementation require flawless transmissions. I also suspect you both use nrf24 and I also suspect you will not see this if you use rfm69 although I use nrf24 myself for testing and I have not seen what you report. But I am sure you really experience this strange behaviour. But I maintain that it is due to some startup problems of the radio. I am afraid I cannot find anything I can change in the signing codebase to have an influence on st=ok or st=fail. But I am all ears to suggestions of course if you see something suspicious.
      alexsh1A 1 Reply Last reply
      • AnticimexA Anticimex
        alexsh1A
        alexsh1A
        alexsh1
        @Anticimex Interesting observation - another node with the same rf24l01+ radio from the sensebender with the same GW and signing works without st=fail. This is now clear that this is not a rf24l01+ hardware issue.
        AnticimexA 1 Reply Last reply
        • alexsh1A alexsh1
          AnticimexA
          AnticimexA
          Anticimex
          @alexsh1 Indeed. And also that it is not a signing issue since I take it you use the same FW?
          I still think it is a HW issue. You have a new node, right? So the radio has a new power source?
            alexsh1A
            alexsh1A
            alexsh1
            Yes, I tried to compare apples with apples:
            1. it is the same distance / FW
            2. the code is different to the expend that the sensebender has got Si7021/ATSHA204a and the other sensor did not. I may try to upload a simplified code to the sensebender just to test it to make it a more equal comparison.
            3. the power source is the same - 5V 500mA via AMS1117 + cap
            • alexsh1A alexsh1
              AnticimexA
              AnticimexA
              Anticimex
              @alexsh1 You could also try soft signing on the sensebender and see if that makes a difference. Perhaps the atsha device interferes with the radio (this depends on routing and such things). I have no sensebender myself and I have not noticed the behavior you describe with nrf24 and atsha204a.
                alexsh1A
                alexsh1A
                alexsh1
                @Anticimex I tried the sensebender with soft singing - still the same st=fail
                AnticimexA YveauxY 2 Replies Last reply
                • alexsh1A alexsh1
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @alexsh1 Ok. I guess that is "good news for me" as it rules out signing related hardware as well. I guess so far, the only conclusion is that rf performance is to some extent degraded on the sensebender.
                  • alexsh1A alexsh1
                    YveauxY
                    YveauxY
                    @alexsh1 just a hunch: do both nodes have identical CPU's & clock frequency?
                    • YveauxY Yveaux
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @Yveaux Correct - I have used Pro Mini 3.3V 8Mhz which corresponds to the sensebender
                      ximinezX 1 Reply Last reply
                      • alexsh1A alexsh1
                        ximinezX
                        ximinezX
                        ximinez
                        Is there a "pre setup" available yet? The failed transmits are before sensor values are transmitted, so they aren't in the actual sketch but somewhere in the library. I'd like to try just sleeping the sensor 5-10 seconds before the initial data is transmitted and see if that makes a difference.
                        AnticimexA alexsh1A hekH 3 Replies Last reply
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @Anticimex Yeah it seems like a combination of things but not a signing problem
                          • ximinezX ximinez
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @ximinez not sure. I know it has been discussed. But you can always patch the library to test.
                            • ximinezX ximinez
                              alexsh1A
                              alexsh1A
                              alexsh1
                              #494
                              @ximinez I do not think so. Either to patch the library or you do it in the sketch. Unless I do not know some other secret place.
                              • ximinezX ximinez
                                @ximinez
                                You can add a before()-method.
                                  @ximinez
                                  ximinezX
                                  ximinezX
                                  ximinez
                                  @hek said:
                                  @ximinez
                                  It's that easy? I'll give it a try when I get around to it, unless @alexsh1 feels like trying it first :)
                                  • HaakonH
                                    HaakonH
                                    Haakon
                                    Hi! I have just gotten four Sensebenders and was hoping to connect PIRs to them and powering them with AA batteries. I understand from the forums that people do this. But is there a working Arduino sketch example implementing a PIR for wake-up out there? (And perhaps there is a more detailed description for such a hardware setup for us newbies?)
                                    • T
                                      tomkxy
                                      I have bought another couple of sensebenders.
                                      I am not able to upload sketches to one of them.
                                      When I connect the programmer the status led goes to solid red. From another one, I realized that it is not solid red.
                                      What is the meaning of a solid red status LED?
                                        What does the log say when you upload?
                                        • HaakonH Haakon
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @Haakon Have a look here - https://forum.mysensors.org/topic/2478/slim-cr123a-2aa-battery-node
                                          Just change your board for sensebender.
