Sensebender Micro
@alexsh1 Indeed. And also that it is not a signing issue since I take it you use the same FW?
I still think it is a HW issue. You have a new node, right? So the radio has a new power source?@Anticimex said:
I still think it is a HW issue. You have a new node, right? So the radio has a new power source?Yes, I tried to compare apples with apples:
- it is the same distance / FW
- the code is different to the expend that the sensebender has got Si7021/ATSHA204a and the other sensor did not. I may try to upload a simplified code to the sensebender just to test it to make it a more equal comparison.
- the power source is the same - 5V 500mA via AMS1117 + cap
@alexsh1 You could also try soft signing on the sensebender and see if that makes a difference. Perhaps the atsha device interferes with the radio (this depends on routing and such things). I have no sensebender myself and I have not noticed the behavior you describe with nrf24 and atsha204a.
@Anticimex I tried the sensebender with soft singing - still the same st=fail
Is there a "pre setup" available yet? The failed transmits are before sensor values are transmitted, so they aren't in the actual sketch but somewhere in the library. I'd like to try just sleeping the sensor 5-10 seconds before the initial data is transmitted and see if that makes a difference.
@alexsh1 Ok. I guess that is "good news for me" as it rules out signing related hardware as well. I guess so far, the only conclusion is that rf performance is to some extent degraded on the sensebender.
@Anticimex Yeah it seems like a combination of things but not a signing problem
Hi! I have just gotten four Sensebenders and was hoping to connect PIRs to them and powering them with AA batteries. I understand from the forums that people do this. But is there a working Arduino sketch example implementing a PIR for wake-up out there? (And perhaps there is a more detailed description for such a hardware setup for us newbies?)
D -Uflash:w:/var/folders/3s/rjbksrj96nv0hqfqjlpfw8bm0000gn/T/build8699526819198040594.tmp/SecurityPersonalizer.cpp.hex:i avrdude: Version 6.0.1, compiled on Apr 14 2015 at 16:30:25 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2009 Joerg Wunsch System wide configuration file is "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf" User configuration file is "/Users/tom/.avrduderc" User configuration file does not exist or is not a regular file, skipping Using Port : /dev/cu.usbserial-DA01IGTO Using Programmer : arduino Overriding Baud Rate : 57600 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00 avrdude: ser_recv(): read error: Device not configured Probleme beim Hochladen auf die Platine. Hilfestellung dazu unter http://www.arduino.cc/en/Guide/Troubleshooting#uploadI have Sensebender selected as board.
Btw, where is the hardware folder? It is not present anymore in the development branch?
I wonder if anyone modified the original sensebender sketch to include a door sensor?
Do you need a pullup? If you have a sketch somewhere I would be happy if you could send/post it, as I have problem finding time to code right now.Here's one for a button, but shouldn't matter:
https://forum.mysensors.org/topic/2887/sensebender-micro-button/2
