  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 657.0k Views 35 Watching
  • alexsh1A alexsh1
    @Anticimex I tried the sensebender with soft singing - still the same st=fail
    @alexsh1 just a hunch: do both nodes have identical CPU's & clock frequency?
    alexsh1A 1 Reply Last reply
    • YveauxY Yveaux
      alexsh1A
      alexsh1A
      alexsh1
      @Yveaux Correct - I have used Pro Mini 3.3V 8Mhz which corresponds to the sensebender
      ximinezX 1 Reply Last reply
      • alexsh1A alexsh1
        ximinezX
        ximinezX
        ximinez
        Is there a "pre setup" available yet? The failed transmits are before sensor values are transmitted, so they aren't in the actual sketch but somewhere in the library. I'd like to try just sleeping the sensor 5-10 seconds before the initial data is transmitted and see if that makes a difference.
        AnticimexA alexsh1A hekH 3 Replies Last reply
        • AnticimexA Anticimex
          @alexsh1 Ok. I guess that is "good news for me" as it rules out signing related hardware as well. I guess so far, the only conclusion is that rf performance is to some extent degraded on the sensebender.
          alexsh1A
          alexsh1A
          alexsh1
          @Anticimex Yeah it seems like a combination of things but not a signing problem
          • ximinezX ximinez
            AnticimexA
            AnticimexA
            Anticimex
            @ximinez not sure. I know it has been discussed. But you can always patch the library to test.
            • ximinezX ximinez
              alexsh1A
              alexsh1A
              alexsh1
              #494
              @ximinez I do not think so. Either to patch the library or you do it in the sketch. Unless I do not know some other secret place.
              • ximinezX ximinez
                @ximinez
                You can add a before()-method.
                  @ximinez
                  ximinezX
                  ximinezX
                  ximinez
                  @hek said:
                  @ximinez
                  It's that easy? I'll give it a try when I get around to it, unless @alexsh1 feels like trying it first :)
                  • HaakonH
                    HaakonH
                    Haakon
                    Hi! I have just gotten four Sensebenders and was hoping to connect PIRs to them and powering them with AA batteries. I understand from the forums that people do this. But is there a working Arduino sketch example implementing a PIR for wake-up out there? (And perhaps there is a more detailed description for such a hardware setup for us newbies?)
                    • T
                      tomkxy
                      I have bought another couple of sensebenders.
                      I am not able to upload sketches to one of them.
                      When I connect the programmer the status led goes to solid red. From another one, I realized that it is not solid red.
                      What is the meaning of a solid red status LED?
                        What does the log say when you upload?
                        • HaakonH Haakon
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @Haakon Have a look here - https://forum.mysensors.org/topic/2478/slim-cr123a-2aa-battery-node
                          Just change your board for sensebender.
                          • T
                            tomkxy
                            @hek
                            D -Uflash:w:/var/folders/3s/rjbksrj96nv0hqfqjlpfw8bm0000gn/T/build8699526819198040594.tmp/SecurityPersonalizer.cpp.hex:i
                                     User configuration file is "/Users/tom/.avrduderc"
                                     Using Port                    : /dev/cu.usbserial-DA01IGTO
                                     Overriding Baud Rate          : 57600
                            avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
                            avrdude: ser_recv(): read error: Device not configured
                            Probleme beim Hochladen auf die Platine. Hilfestellung dazu unter http://www.arduino.cc/en/Guide/Troubleshooting#upload
                            I have Sensebender selected as board.
                            Btw, where is the hardware folder? It is not present anymore in the development branch?
                              You can use the build in board manager nowadays.
                              https://github.com/mysensors/ArduinoBoards
                              Check board for solder bridges or anything suspicious.
                              • J
                                J
                                johnr
                                I wonder if anyone modified the original sensebender sketch to include a door sensor?
                                Do you need a pullup? If you have a sketch somewhere I would be happy if you could send/post it, as I have problem finding time to code right now.
                                martinhjelmareM alexsh1A 2 Replies Last reply
                                • J johnr
                                  martinhjelmareM
                                  martinhjelmareM
                                  martinhjelmare
                                  @johnr
                                  Here's one for a button, but shouldn't matter:
                                  https://forum.mysensors.org/topic/2887/sensebender-micro-button/2
                                  • J johnr
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @johnr This is easy.
                                    // PIN = 2 or 3 only
                                    void setup {
                                      pinMode(PIN,INPUT);
                                      digitalWrite(PIN,HIGH);
                                    This activates internal pull-up.
                                    The sensebender has got pinout of Pro Mini
                                    • T
                                      timropp
                                      Well that didn't go well... assembling my first micro. Soldered on some pins for the FTDI connection, added power (2xAA holder), and soldered on the radio with cap. Then I put in batteries and brought up my domoticz page to see if it showed up. Started to smell something, looked down, and there's smoke coming from the battery holder. Grabbed the whole thing and yanked the wire free then dropped it in the sink. Not sure where I screwed up, but I sure shorted something!
                                      VeraEdge UI7 with Mysensors ethernet gateway
                                        :scream: Did you find the problem?
                                        • T timropp
                                          alexsh1A
                                          alexsh1A
                                          alexsh1
                                          @timropp sounds like you shorted batteries somewhere
