  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 657.0k Views 35 Watching
  • alexsh1A alexsh1
    @Yveaux Correct - I have used Pro Mini 3.3V 8Mhz which corresponds to the sensebender
    ximinezX
    ximinezX
    ximinez
    Is there a "pre setup" available yet? The failed transmits are before sensor values are transmitted, so they aren't in the actual sketch but somewhere in the library. I'd like to try just sleeping the sensor 5-10 seconds before the initial data is transmitted and see if that makes a difference.
    AnticimexA alexsh1A hekH 3 Replies Last reply
    • AnticimexA Anticimex
      @alexsh1 Ok. I guess that is "good news for me" as it rules out signing related hardware as well. I guess so far, the only conclusion is that rf performance is to some extent degraded on the sensebender.
      alexsh1A
      alexsh1A
      alexsh1
      @Anticimex Yeah it seems like a combination of things but not a signing problem
      • ximinezX ximinez
        AnticimexA
        AnticimexA
        Anticimex
        @ximinez not sure. I know it has been discussed. But you can always patch the library to test.
        • ximinezX ximinez
          alexsh1A
          alexsh1A
          alexsh1
          #494
          @ximinez I do not think so. Either to patch the library or you do it in the sketch. Unless I do not know some other secret place.
          • ximinezX ximinez
            @ximinez
            You can add a before()-method.
            ximinezX 1 Reply Last reply
              @ximinez
              ximinezX
              ximinezX
              ximinez
              @hek said:
              @ximinez
              It's that easy? I'll give it a try when I get around to it, unless @alexsh1 feels like trying it first :)
              • HaakonH
                HaakonH
                Haakon
                Hi! I have just gotten four Sensebenders and was hoping to connect PIRs to them and powering them with AA batteries. I understand from the forums that people do this. But is there a working Arduino sketch example implementing a PIR for wake-up out there? (And perhaps there is a more detailed description for such a hardware setup for us newbies?)
                alexsh1A 1 Reply Last reply
                • T
                  tomkxy
                  I have bought another couple of sensebenders.
                  I am not able to upload sketches to one of them.
                  When I connect the programmer the status led goes to solid red. From another one, I realized that it is not solid red.
                  What is the meaning of a solid red status LED?
                    What does the log say when you upload?
                    • HaakonH Haakon
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @Haakon Have a look here - https://forum.mysensors.org/topic/2478/slim-cr123a-2aa-battery-node
                      Just change your board for sensebender.
                      • T
                        tomkxy
                        @hek
                        D -Uflash:w:/var/folders/3s/rjbksrj96nv0hqfqjlpfw8bm0000gn/T/build8699526819198040594.tmp/SecurityPersonalizer.cpp.hex:i
                                 User configuration file is "/Users/tom/.avrduderc"
                                 Using Port                    : /dev/cu.usbserial-DA01IGTO
                                 Overriding Baud Rate          : 57600
                        avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
                        avrdude: ser_recv(): read error: Device not configured
                        Probleme beim Hochladen auf die Platine. Hilfestellung dazu unter http://www.arduino.cc/en/Guide/Troubleshooting#upload
                        I have Sensebender selected as board.
                        Btw, where is the hardware folder? It is not present anymore in the development branch?
                          You can use the build in board manager nowadays.
                          https://github.com/mysensors/ArduinoBoards
                          Check board for solder bridges or anything suspicious.
                          • J
                            J
                            johnr
                            I wonder if anyone modified the original sensebender sketch to include a door sensor?
                            Do you need a pullup? If you have a sketch somewhere I would be happy if you could send/post it, as I have problem finding time to code right now.
                            martinhjelmareM alexsh1A 2 Replies Last reply
                            • J johnr
                              martinhjelmareM
                              martinhjelmareM
                              martinhjelmare
                              @johnr
                              Here's one for a button, but shouldn't matter:
                              https://forum.mysensors.org/topic/2887/sensebender-micro-button/2
                              • J johnr
                                alexsh1A
                                alexsh1A
                                alexsh1
                                @johnr This is easy.
                                // PIN = 2 or 3 only
                                void setup {
                                  pinMode(PIN,INPUT);
                                  digitalWrite(PIN,HIGH);
                                This activates internal pull-up.
                                The sensebender has got pinout of Pro Mini
                                • T
                                  timropp
                                  Well that didn't go well... assembling my first micro. Soldered on some pins for the FTDI connection, added power (2xAA holder), and soldered on the radio with cap. Then I put in batteries and brought up my domoticz page to see if it showed up. Started to smell something, looked down, and there's smoke coming from the battery holder. Grabbed the whole thing and yanked the wire free then dropped it in the sink. Not sure where I screwed up, but I sure shorted something!
                                  VeraEdge UI7 with Mysensors ethernet gateway
                                    :scream: Did you find the problem?
                                    • T timropp
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      @timropp sounds like you shorted batteries somewhere
                                      • T
                                        timropp
                                        Nope, didn't find the problem. Must be some solder that shorted the batteries out but I don't see it. Oh well... main problem is that was my only 2AA holder on hand, and it melted right through the end of it, so now I have to wait on more before I can try again. Bummer :)
                                        • alexsh1A
                                          alexsh1A
                                          alexsh1
                                          You can feed it with just two wires connected to the USB FTDI TTL converter / programmer - have a look at this https://www.mysensors.org/hardware/micro
                                          Available Pins - GND, GND, VCC (on the right)
