  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 659.8k Views 35 Watching
    @gbfromhb
    D3 is available on the side-pins. D2 is routed to the radio but can be used with some hacking.
    M 1 Reply Last reply
    • G gbfromhb
      I hope this question has not been answered already and I did not miss the answer. I was thinking about connecting a motion sensor to this and was hoping that one of the digital pins supports an interrupt. Is there an interrupt available?
      mvader
      I'm planning to do the same thing.
      i ordered my 5v step up regulators to support the PIR sensor.
      although I hope adding the motion isnt going to kill the batteries.
      • G
        G
        gbfromhb
        wrote on last edited by gbfromhb
        #163
        @mvader
        I have so far had no problems running my PIR sensors at 3.3v with the following hack.
        http://techgurka.blogspot.com/2013/05/cheap-pyroelectric-infrared-pir-motion.html
        You can not do this with all PIR Sensors from what I understand, but one of the ones listed in the MySensors store is what I've been using. Go down to the bottom of the article.
        M 2 Replies Last reply
        • G
          G
          gbfromhb
          @Hek
          Thanks, I saw the D3, but I'm new enough to this adventure that I was not sure if I should have assumed that it also had an interrupt like all the other boards.
          • tbowmoT
            tbowmoT
            tbowmo
            @gbfromhb
            I tried to keep the naming, and pins on the atmega, the same as an ordinary arduino :)
            • G gbfromhb
              @mvader
              mvader
              @gbfromhb said:
              @mvader
              wow.. nice.. thanks for the info! I will give this a go asap.
              • G
                G
                gloob
                I have one more question. Is it possible to power the micro from the ftdi pins? I would like to use jumper wires.
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @gloob
                  Yes it's possible to power it from the FTDI pins, if you want to..
                  • G
                    G
                    gloob
                    Are there any recommendations for a low power temperature, humidity sensor regarding the update cycle.
                    Currently I plan to wake up the sensor each 10 minutes instead of each 1 minute to update the values. This should increase the duration of the battery. A complete update of all values if performed each 30 minutes as usual.
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      I would probably choose 5 minutes interval instead.. I have updated the sensebendermicro sketch tonight (just waiting for @hek to approve it). so it holds of on the transmissions a bit. Now the temperature needs to change more than 0.5 degrees from the previous transmitted value. OR
                      humidity needs to change more than 0.5, measured with a moving average. OR
                      30 minutes since last transmission.
                      • G
                        G
                        gloob
                        wrote on last edited by gloob
                        #171
                        I found that when I power the micro from 2 batteries I get the following error:
                        T: 23.21
                        H: 50
                        send: 104-104-0-0 s=1,c=1,t=0,pt=7,l=5,st=fail:23.2
                        send: 104-104-0-0 s=2,c=1,t=1,pt=2,l=2,st=fail:50
                        This does not happen when I power it from the FTDI programmer.
                        Does anybody have any ideas?
                        The batteries have a voltage of 3.25V
                        I did not have this issues with my arduino nano sensors. and i did use the same radio modules.
                        When I check the modules they seem to be real nrf24l01+ modules:
                        STATUS		 = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
                        RX_ADDR_P0-1	x00 = 0xe7e7e7e7e7 0xf0f0f0f0d2
                        RX_ADDR_P2-5	x00 = 0xc3 0xc4 0xc5 0xc6
                        TX_ADDR		 = 0xe7e7e7e7e7
                        RX_PW_P0-6	x00 = 0x00 0x20 0x00 0x00 0x00 0x00
                        EN_AA		 = 0x3f
                        EN_RXADDR	x00 = 0x03
                        RF_CH		 = 0x4c
                        RF_SETUP	x00 = 0x07
                        CONFIG		 = 0x0f
                        DYNPD/FEATURE	x00 = 0x00 0x00
                        Data Rate	 = 1MBPS
                        Model		 = nRF24L01+
                        CRC Length	 = 16 bits
                        PA Power	 = PA_HIGH
                        • F
                          F
                          Fabien
                          I have a batch of 5 sensebender and actually I build 3 and one of them doesn't work properly. Lot of st:fail when I put my finger on the board it works better so I try to make all solder one more time but it's not ok. I try with few radios and same radios work well on the others sensbender.
                          Any idea or way to exchange with Itead ?
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @Fabien
                            Where exactly do you put your finger on it, in order to get it working?
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              @gloob
                              It's the same power rail (FTDI, and the battery connector). What do you supply the board with, thru the FTDI header?
                              • F
                                F
                                Fabien
                                @tbowmo difficult to answer this question. It seems to be on Atmega but after trying to resold it's not better. I resol capacitors, resistors ... I don't know what to do now ...
                                • tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @Fabien
                                  Did you also resolder the atmega itself?
                                  Could you try and measure supply current it uses?
                                  • F
                                    F
                                    Fabien
                                    current when powering on : 20 mA and during sleeping about 20uA (not very accurate).
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @Fabien
                                      Have you tried to add an extra capacitor to the NRF module, on the one that's bad? (Could be your finger adds a bit more capacitance, I know it's a wild guess but just trying to think out loud)
                                      • F
                                        F
                                        Fabien
                                        Ok but wich value ? I just finish to solder my 4th sensebender and ok too.
                                          wrote on last edited by hek
                                          #180
                                          Does the failed messages reach their destination (gateway in your case)? As you might know it is the ack that never reaches the sensbender node which could be a result of power issues on the gateway side.
