  3. Air Quality Sensor
Air Quality Sensor
calibrationaqigas sensorhchoair quality
270 Posts 46 Posters 450.5k Views 35 Watching
  • korttomaK
    korttomaK
    korttoma
    #41
    Where can I find AirQuality1.xml?? (or all files related to this device if there are others then the .xml)
    01 09/03/14 13:46:53.685 ctrl_chr[31;1mDevice_LuaUPnP::LoadDeviceDoc can't load /etc/cmh-lu//D_AirQuality1.xmlctrl_chr[0m <0x2acc9000>
    02 09/03/14 13:46:53.686 ctrl_chr[33;1mJobHandler_LuaUPnP::m_sMissingFile_set /etc/cmh-lu//D_AirQuality1.xmlctrl_chr[0m <0x2acc9000>
    Seems like if this file is missing it brakes the whole MySensors plugin.
    All devices related to MySensors plugin are blank and nothing seems to update.
    Deleting the device that use AirQuality.xml will make the rest work again.
    Help!!
    • Tomas
    hekH 1 Reply Last reply
    • korttomaK korttoma
      Help!!
      @korttoma
      Unfortunately no one has created it :(
      korttomaK 1 Reply Last reply
        @korttoma
        korttomaK
        korttomaK
        korttoma
        @hek
        ahh, that's why I cant find it... no pressure from my side to get one done but maybe we should mention this little detail on the MySensors building page just as a heads up for others since there is a sketch published and all...
        • Tomas
        epierreE 1 Reply Last reply
        • epierreE
          epierreE
          epierre
          I made a template but I'm unable to test it...
          z-wave - Vera -> Domoticz
          • epierreE epierre
            @hek Here is a first list from the most commons:
            • Carbon Monoxide – CO
            • Carbon Dioxide – CO2
            • Oxygen – O2
            • Methane – CH4
            • Hydrogen – H2
            • Ammonia – NH3
            • Isobutane – C4H10
            • Ethanol – CH3CH2OH (aka C2H5OH or C2H60)
            • Toluene – C6H5CH3
            • Hydrogen Sulfide – H2S
            • Nitrogen Dioxide – NO2
            • Ozone – O3
            • Hydrocarbons – VOC
            • Chlorine CL2
            • Ammonium NH4
            • Ethanol CO2H50H
            • Methyl CH3
            • Acetone CH3_2CO
            • LPG (both C3H8 C4H10)
            epierreE
            epierreE
            epierre
            @hek here is an updated list from the Wunder Weather list of reportable gases:
            Oxygen – O2
            Methane – CH4
            Hydrogen – H2
            Ammonia – NH3
            Isobutane – C4H10
            Toluene – C6H5CH3
            Ozone – O3
            Hydrocarbons – VOC
            Chlorine CL2
            Ammonium NH4
            Ethanol CO2H50H
            Methyl CH3
            Acetone CH3_2CO
            • NO - nitric oxide
            • NOX - nitrogen oxides
            • NO3 ion (nitrate, not adjusted for ammonium ion) UG/M3
            • SO4 ion, sulfate, not adjusted for ammonium ion, UG/M3
            • SO2 sulfur dioxide, ppb
            • EC (elemental carbon) – PM2.5 UG/M3
            • OC (organic carbon, not adjusted for oxygen and hydrogen) – PM2.5 UG/M3
            • BC (black carbon at 880 nm) UG/M3
            • UV-AETH (second channel of Aethalometer at 370 nm) UG/M3
            • PM2.5 mass - UG/M3
            • PM10 mass - PM10 mass
            • epierreE epierre
              Oxygen – O2
              Methane – CH4
              Hydrogen – H2
              Ammonia – NH3
              Isobutane – C4H10
              Toluene – C6H5CH3
              Ozone – O3
              Hydrocarbons – VOC
              Chlorine CL2
              Ammonium NH4
              Ethanol CO2H50H
              Methyl CH3
              Acetone CH3_2CO
              • NO - nitric oxide
              Thanks!
              Still thinking about you gas_type suggestion. It would introduce another level of device types. Hmm..
                @hek
                epierreE
                epierreE
                epierre
                @korttoma look above to S_CO2Sensor.json D_CO2Sensor.xml D_CO2Sensor.json, if you can test it...
                • epierreE
                  epierreE
                  epierre
                  wrote on last edited by epierre
                  #48
                  @Yveaux I know you are strong at finding datasheet... can you find one for me ? I can't find the 2SH12 sensor altgough I've asked for it to all suppliers on aliexpress...
                  Same for theWSP1110
                  YveauxY 1 Reply Last reply
                  • epierreE epierre
                    Same for theWSP1110
                    YveauxY
                    YveauxY
                    @epierre Couldn't find it either, sorry...
                    I wouldn't buy a $52,- component without a datasheet, if I were you...
                    epierreE 2 Replies Last reply
                    • YveauxY Yveaux
                      epierreE
                      epierreE
                      epierre
                      #50
                      @Yveaux When I asked for the WSP110 they sent me only this (not the same for this one is HCHO and well documented...) :
                      • epierreE epierre
                        @epierre
                        I wonder what the green curve represents :confused:
                          @epierre
                          epierreE
                          epierreE
                          epierre
                          @hek that should be the more sensitive, and since it is given mostly for CHCO I guess this is it... (Formaldehyde)
                            @epierre
                            epierreE
                            epierreE
                            epierre
                            @hek 甲醛 is formaldehyde, given by google translate so I'm right !
                            • epierreE epierre
                              @epierre
                              Haha :thumbsup:
                              • epierreE
                                epierreE
                                epierre
                                Davide answered me, lot of things to read but a warning:
                                Anyway, for consistent CO2 investigaion, you HAVE to chose a NDIR sensor, those chemical sensor can not be used. They decay in a few year, and they differs a little one from each other.
                                I've asked him back for precision if he speaks of the organic sensor or the ceramic ones (like MQ...).
                                For the CO2, it is MH-Z14 which is $66+ priced.
                                • epierreE epierre
                                  @epierre said:
                                  MH-Z14
                                  Like this little puppy?
                                    @epierre said:
                                    MH-Z14
                                    epierreE
                                    epierreE
                                    epierre
                                    @hek exact !
                                    • epierreE epierre
                                      korttomaK
                                      korttomaK
                                      korttoma
                                      Thanks, found the device files and got the device included again.
                                      Seems like my MQ-2 is always reporting 0 or nothing at all. I guess I need to try to calibrate it again.
                                      It will do the calibration every time the sensor is restarted right?
                                      How can I calibrate the sensor if I put it somewhere where the air is not clean enough? (bring clean air in a jar? ;) )
                                      Maybe it would be an idea to add a calibration button to the mix and when run using the button it would save the calibration related data in the RAM so it can then always use this calibrated value and then it would not re-calibrate every time it loses power.
                                      I have the 10k resistor between GND and A0, is this really necessary?
                                      Does the potentiometer on the sensor board affect the analog out at all or is it only for sensitivity on the digital out?
                                      Sorry for all the questions ;)
                                      • Tomas
                                        epierreE
                                        epierreE
                                        epierre
                                        So you confirm they can be used as is ?
                                        How can I calibrate the sensor if I put it somewhere where the air is not clean enough? (bring clean air in a jar? wink )
                                        this is the ongoing work, except CO2 which is known to be 399ppm (co2now.org) that should report this in clean air, for the other that should be little, and for deadly gases a full warning if this is high.
                                        That is an option, but EEPROM has a 100k write cycle only... this is what citizensensors says about it:
                                        1) Metal oxide gas sensors have intrinsic drift over time i.e. it is necessary to perform calibration on a regular basis.
                                        2) Because of spread in baseline resistance, sensitivity, cross-sensitivity, temperature dependency it is not possible to apply same calibration parameters to all the sensors.
                                        3) This type of sensor is efficient to detect change in concentration but not well adapted to absolute readings because of multiple dependency (T, RH, cross-contaminants).
                                        4) Using smart algorithm allows indicating useful information like the correlation with CO2 in confined space like offices or buildings (see VZ-87 in attachment).
                                        For absolute readings with high accuracy and repeatability I agree with you that you should use another technology.
                                        From this we have the calibration issue... in another post, since they only report resistance, they say they will rebuild all their platform to address callibration issue... but since calibration depends only from a reference gas concentration... only the pre-calibrated sensors remains viable for the low cost MQ/MICS/TGS will never be really calibrated...
                                        no you can remove it, I have observed a different behavior when moving it, it looks like it is shared by both digital and analogic for the same reason. What I'd like to find is where to measure the resistance for there are often some more on the board.
                                        good questions are always useful, especially when they meet my current subject of interrest ;-)
                                        • epierreE epierre
                                          korttomaK
                                          korttomaK
                                          korttoma
                                          well, for the device in Vera I had to change the parameter "device_file" from "D_AirQuality1.xml" to "D_CO2Sensor.xml".
                                          I don't get any errors but I also do not get any values but I guess this is because my node is not sending any values.
                                          I'll try to look in to why my node is not reporting any value and try to remove the 10kR and see if I can measure the load resistance of my MQ-2 sensor board and maybe even remove some unnecessary components from it...
                                          • Tomas
