  2. Feature Requests
  3. Domoticz full integration
79 Posts 26 Posters 76.7k Views 11 Watching
  • epierreE
    epierreE
    epierre
    Hi all,
    A hint of what is going on... with the vera gateway !
    http://forum.mysensors.org/topic/142/#1321
    z-wave - Vera -> Domoticz
    • L
      L
      larky
      +1 on domoticz integration!
      • R
        R
        roblom
        +1 for the full domoticz integration.
        And sorry for not being helpful because i'm no programmer..
        • D
          D
          Dylantje
          So please..
          Include this realy nice stuff to domoticz.
          +10
            maglo18
            I ask again what is the best way to use mysensor in domoticz software?
            hekH 1 Reply Last reply
            • M maglo18
              @maglo18
              Someone who knows Domoticz need to step up and help creating a plugin for the controller. Either by using the serial protocol or by utilizing MQTT.
              We can help someone get started but the actual work has to be done by someone actually using the controller.
              • epierreE
                epierreE
                epierre
                I would add someone developping in domoticz for there are (too) few and some new features should be added too...
                externally is possible and ongoing...
                • V
                  V
                  Vincent TODESCHINI
                  +1 to domoticz full integration plizzzz !!!!
                  • S
                    ShaK
                    +1 to Domoticz full integration :)
                      wrote on last edited by hek
                      #30
                      I've commented on the Domiticz feature request:
                      http://www.domoticz.com/forum/tracker.php?p=2&t=143
                      epierreE 1 Reply Last reply
                      • bjornhallbergB
                        bjornhallbergB
                        bjornhallberg
                        Also, if such a C++ ninja would appear, many would be very, very happy to also see native MQTT support for Domoticz.
                        http://www.domoticz.com/forum/viewtopic.php?f=5&t=838
                        YveauxY 1 Reply Last reply
                          YveauxY
                          YveauxY
                          @bjornhallberg did you call for a c++ ninja? ;-)
                            epierreE
                            epierreE
                            epierre
                            @hek I would say a demi dozen ninjas would be necessary, one for understanding, one for mapping, one for coding, one for testing one for answering people claims and one ... to support the integration of the code... did I miss one ? ;-)
                            the internal model is not unified, this is more types built uppon types in several classes, based on evolutions from rfxtrx and then zwave, some are duplications of others (hard coded, no attributes...)... a real headache just on the JSON interface and no testbed/test cases/testmaterial, just full debug with users reporting bugs... doing the Imperihome integration I can say I had a hard time just from outside the code...
                            • YveauxY Yveaux
                              bjornhallbergB
                              bjornhallbergB
                              bjornhallberg
                              @Yveaux Haha, yeah, but in all honestly I'm not expecting or suggesting anyone here do their work for them. If they had any sense they would have had support for MQTT and such years ago. And an infrastructure in place for user plugins. I'm such a sad sod that I actually subscribe to the RSS feed for Domoticz commits (for a few months now, as I do with many of these HA software) and I can't say I'm often surprised by anything they put into the code.
                              On the other hand Domoticz has a lot going for it, including pretty decent graphs that work out of the box. It has blockly. And it has native code. And its JSON API isn't half bad either. I mean, I did try the script by @epierre for a while and I could have settled for hard coding sensor input into Domoticz ... but now I've scrapped the serial gateway due to issues brought up in the other thread and I'm back to either the MQTT or Ethernet gateway so no more Domoticz input. Unless I get a new single-board computer or NUC or whatever to interface with.
                                epierreE
                                epierreE
                                epierre
                                @bjornhallberg What do you mean by :
                                Domoticz is perfect for 433Mhz users supported by the rfxtrx, which is its origin. Here you need to code, flash, wire, power, find a box... not for the faintest of heart... clearly not a plug and play philosophy of Domoticz. This is why I'm wopndering so many people ask for the integration but actually don't report questions on sketches or issues, are there are many...
                                • epierreE epierre
                                  bjornhallbergB
                                  bjornhallbergB
                                  bjornhallberg
                                  wrote on last edited by bjornhallberg
                                  #36
                                  @epierre I just meant that I used to have an Arduino Nano + NRF24 PA LNA connected to my Raspberry, but due to some issue or another (I'm not sure) it wouldn't work properly. Perhaps the power draw on the 3.3V. Perhaps the two extra walls between the Raspberry and where I currently have the MQTT gateway. Perhaps interference from some other piece of electronic inside the cramped camera housing. Who knows.
                                  Of course moving away from serial gateway means a world of trouble as most controllers and such have plugins made with that gateway in mind. IF I get a new computer to host a serial gateway, it would have to be many, many times faster than the Raspberry and preferably x86. With only slightly higher idle power consumption. Only the latest generation i3 and i5 NUCs match that description.
                                  Right now I'm looking into paho-mqtt for python and making a script much like yours that uses the JSON API to update virtual sensors inside Domoticz. I'm almost there I hope. It's not pretty but trying to get some of these other HA solutions to work is like banging your head against a brick wall. At least with Domoticz you have a great deal going for you out of the box. Like graphing which I mentioned above. Seeing all these new and fantastic JS graphing solutions, you sort of get a bit spoiled. Domoticz has some of the best graphs imo, even if that isn't saying much.
                                    epierreE
                                    epierreE
                                    epierre
                                    @bjornhallberg intel is not the only way... for $50 there is the banana-pi ... I've moved from raspi to a cubie 2 in urgency, latest domoticz updates made it impossible to live on a raspi... with only rfxtrx and JSON updates... the cubie 2 is a bi-core A20 and my cpuload is 10% at worse... in raspi it was 100%... for a better community support the odroid is way faster and better supported (quad core, the samsung S3 ekynos processor just to name it) but is twice the price.
                                    • AWIA
                                      AWIA
                                      AWI
                                      wrote on last edited by AWI
                                      #38
                                      In the quest for Domoticz full integration, I have been doing some prototyping in Python. Domoticz has very capable JSON support and virtual device types so we can do without "full integration" .
                                      My python script is built around a 'dictionary' based Database with a hardcoded MySensor-Domoticz translation. The script is running stable with 20+ sensor/actuators and limited cpu load on raspberry pi (15%).
                                      What is next:
                                      • dynamic sensor inclusion i.s.o. fixed nodes.
                                      • more sensor types and support for combined devices (e.g. Temp, Hum, Baro)
                                      • (sqlite i.s.o. python dictionary)
                                      dependencies: requests, json
                                      anybody interested?
                                      You can find the attempt at: Domoticz-MySensors
                                      all suggestions welcome..
                                      hekH A 2 Replies Last reply
                                      • AWIA AWI
                                        What is next:
                                        anybody interested?
                                        @AWI
                                        That would be awesome!
                                        AWIA 1 Reply Last reply
                                        • AWIA AWI
                                          What is next:
                                          anybody interested?
                                          A
                                          A
                                          andriej
                                          @AWI That would be pretty awesome!
                                          If I can help anyhow, just say so.
                                          Currently I'm running Domoticz with custom-built gateway on MEGA, but could probably start switching whole thing to MySensors as whole setup use nRF24L01 :-)
                                          How can I help? Or is it ready for tests?
