  2. Feature Requests
  3. Domoticz full integration
79 Posts 26 Posters 76.7k Views 11 Watching
  • A andriej
    @AWI That would be pretty awesome!
    If I can help anyhow, just say so.
    Currently I'm running Domoticz with custom-built gateway on MEGA, but could probably start switching whole thing to MySensors as whole setup use nRF24L01 :-)
    How can I help? Or is it ready for tests?
    AWIA
    AWIA
    AWI
    @andriej It is ready for test. Just edit the your setup in the header and adapt "Sensor_DB" to your setup. Nothing really fancy.
    A 1 Reply Last reply
    • AWIA AWI
      A
      A
      andriej
      @AWI I'm after first test and that's what I get just after running the code:
      # python mysensors-dom.py
      2015-01-17 02:59:41 Start
      ('Wrong/No input from MySensors gateway', ValueError('No JSON object could be decoded',))
      Are these desired messages?
      What I'm supposed to do later on?
      • A andriej
        A
        A
        andriej
        I've managed to get it to work.
        First issue - since always I've reported temperature and humidity altogether (from DHT sensors).
        Currently I can't specify one IDX for two values and I can't see in code where I could put two values to report in Domoticz at once.
        They use to be reported in one URL.
        AWIA 1 Reply Last reply
        • AWIA
          AWIA
          AWI
          Good to see you are taking the jump... What you see in the first test is are generic error messages which can be generated in many place. There is a "catch-all" exception handler on the main loop, I suggest you take out the word "ValueError". After that the script will come to a halt and indicate where it went wrong.
          I am 'almost' in the next major update. I hope to upload today .
          Good luck!
            @AWI
            That would be awesome!
            AWIA
            AWIA
            AWI
            @hek I am almost done with the python -Domoticz "full integration" but strugling with a few message types. The code for Vera is a good source for information but it is hard to determine the role of the controller in the construction/routing of the network. For now I assumed only node numbering and keeping track of the sensors. Is the controller supposed to do something with the relay nodes? what is the function of the I_CHILDREN message?
              Just skip it. It's deprecated and will be removed.
              tekkaT 1 Reply Last reply
              • A andriej
                AWIA
                AWIA
                AWI
                @andriej I will be posting a new version tomorrow which adds maximum functionality for Domoticz (from my view): combined sensors (trick), node numbering, inclusion and an external database in JSON. I will keep it running tonight to test the stability. ...
                • AWIA
                  AWIA
                  AWI
                  Major update (but still very beta...,) supports:
                  • dynamic sensor inclusion i.s.o. fixed nodes.
                  • more sensor types and support for combined domoticz devices (e.g. Temp, Hum, Baro)
                  • external JSON database
                  The python script is built around a 'dictionary' based Database with the MySensor-Domoticz translation. The script is running stable with 20+ sensor/actuators and limited cpu load on raspberry pi (15%).
                  Known issues:
                  • You need to edit the JSON database yourself if you need combined Domoticz devices eg. (Temp/Hum/Baro). Not difficult
                  • Need to create Switch types yourself in Domoticz , then assign these in the database
                  • Usage/power not supported yet (need a "multiple value" trick..)
                  You can find the attempt at: Domoticz-MySensors with a small instruction in the first few lines
                  all suggestions welcome..
                    @AWI, great work!
                    You should probably post something over at Domoticz forum as well.
                    • GizMoCuzG
                      GizMoCuzG
                      GizMoCuz
                      wrote on last edited by GizMoCuz
                      #50
                      Domoticz:
                      Starting with a native implementation, thanks to Ad for providing the RF interfaces.
                      Maybe best (for domoticz) to continue on the forum,
                      i need serial logs of all possible combinations and meaning
                      node-id;child-sensor-id;message-type;ack;sub-type;payload
                      we developers probably have to do some special tricks to get some nice sensors
                      for instance, it would be nice if there where subtypes for:
                      • Temp+Hum
                      • Temp+Hum+Baro
                      • Kwh+Watt
                      • Wind+Gust+Direction
                      I can not watch this forum, if you want to contribute, plz use the domoticz forum
                      hekH 1 Reply Last reply
                      • GizMoCuzG GizMoCuz
                        Domoticz:
                        • Temp+Hum
                        • Temp+Hum+Baro
                        • Kwh+Watt
                        @Rob-Peters
                        Hi, great to see you here! I'll send you my contact details if you have any specific questions.
                        @AWI seems to have implemented most of the logic necessary.
                        • A
                          A
                          andriej
                          In latest release of Domoticz I can see first implementations of MySensors!
                          Maybe it's worth a shot for someone to register on Domoticz forum and help their team out?
                          • A andriej
                            AWIA
                            AWIA
                            AWI
                            @andriej Hi, GizMoCuz is working on it (2 reply's before) asked for serial log of all possible combinations. I am trying to help out, but some help and priority setting is more than welcome.
                            • epierreE
                              epierreE
                              epierre
                              I've answered to Rob sending some of my logs and a link to my interface, I guess seeing a link between values and JSON will help a bit ;-).
                              @hek we've not settled about gas values, no ?
                              z-wave - Vera -> Domoticz
                                @epierre
                                Sort of... But I will probably not change anything in 1.4.
                                • GizMoCuzG
                                  GizMoCuzG
                                  GizMoCuz
                                  Posted a new beta of domoticz.
                                  Lots have been changed
                                  If anyone can supply me with serial log messages of:
                                  S_LIGHT_LEVEL
                                  S_WATT
                                  S_KWH
                                  That would be helpfull
                                  With regards,
                                  Rob
                                    S_LIGHT_LEVEL
                                    S_WATT
                                    S_KWH
                                    With regards,
                                    Rob
                                    @GizMoCuz
                                    Sent you an email...
                                      tekkaT
                                      tekkaT
                                      tekka
                                      wrote on last edited by tekka
                                      #58
                                      @hek:
                                      The I_CHILDREN+"C" message is useful during development/implementation/repositioning of nodes with repeater functionality (changing node location may alter routing).
                                      From my experience, this function is helpful and should even be expanded to clearing the parent_node_id: i.e. I faced the situation where the parent node (not gw) was out of range and the node could not communicate back to the gateway. The only resolution is to clear the eeprom or sending the I_CHILDREN + "C" command
                                      • jendrushJ
                                        jendrushJ
                                        jendrush
                                        I have a question. If someone is using pulse power meter with new version of Domoticz please tell me if Domoticz is able to send last know value of kwh to node?
                                        • A
                                          A
                                          andriej
                                          Has anyone tested the Domoticz's support of MySensors?
                                          Maybe it should be mentioned on the webpage somehow.
                                          It's still one of the most nice-looking systems out there...
