set Metric on gw?
Sorry, I am brand new to MySensors. I see in all the examples there is a gw.getConfig().isMetric
I know this is a new feature. Trying to figure out how to set this, before I update all my nodes with the metric part just commented out.
Can I push this setting out from openhab (via SerialGateway)?
TIA. -
Guess I should have posted this code initially. I already have that rule in place, and still no luck. (I couldnt get "gw.requestTime(receiveTime)" to work either)
This is in the setup portion in arduino sketch
metric = gw.getConfig().isMetric;Only posted relevant portions of the code. The rule itself works (for V_TEMP, etc), just none of the "internal commands I_*" do.
var int I_CONFIG = 6 //receiving msg from mysensors gateway rule "Arduino sends to Openhab" when Item Arduino received update then var String lineBuffer = Arduino.state.toString.split("\n") for (String line : lineBuffer) { var String[] message = line.split(";") var Integer nodeId = new Integer(message.get(0)) var Integer childId = new Integer(message.get(1)) var Integer msgType = new Integer(message.get(2)) var Integer ack = new Integer(message.get(3)) var Integer subType = new Integer(message.get(4)) var String msg = message.get(5) // Internal Command if(msgType == 3){ if(subType == I_CONFIG){ var String unit unit = "I" //unit = "M" sendCommand(Arduino, nodeId + ";255;3;0;6;" + unit + "\n") println("Updated Sensor Units to " + unit +) } } } endThis is what openhab is getting when the arduino is reset.
101;255;3;0;11;Humidity 0;0;3;0;9;read: 101-101-0 s=255,c=3,t=12,pt=0,l=3:1.0 101;255;3;0;12;1.0 0;0;3;0;9;read: 101-101-0 s=0,c=0,t=7,pt=0,l=5:1.4.1 101;0;0;0;7;1.4.1 0;0;3;0;9;read: 101-101-0 s=1,c=0,t=6,pt=0,l=5:1.4.1 101;1;0;0;6;1.4.1 0;0;3;0;9;read: 101-101-0 s=2,c=0,t=4,pt=0,l=5:1.4.1 101;2;0;0;4;1.4.1 0;0;3;0;9;read: 101-101-0 s=3,c=2,t=3,pt=0,l=0: 101;3;2;0;3; 0;0;3;0;9;read: 101-101-0 s=1,c=1,t=0,pt=7,l=5:26.0 101;1;1;0;0;26.0 0;0;3;0;9;read: 101-101-0 s=0,c=1,t=1,pt=7,l=5:34.0 101;0;1;0;1;34.0Shouldnt there be something like
101;255;3;0;6;? -
Ok, it just started working !!!! I created a separate rul for it. So either it doesnt like being mixed in with the other stuff or it doesnt like the == I_CONFIG
This rule below is working
rule "Arduino config" when Item Arduino received update then var String lineBuffer = Arduino.state.toString.split("\n") for (String line : lineBuffer) { var String[] message = line.split(";") var Integer nodeId = new Integer(message.get(0)) var Integer childId = new Integer(message.get(1)) var Integer msgType = new Integer(message.get(2)) var Integer ack = new Integer(message.get(3)) var Integer subType = new Integer(message.get(4)) var String msg = message.get(5) // Internal Command if(msgType == 3){ if(subType == 6){ var String unit unit = "I" //unit = "M" sendCommand(Arduino, nodeId + ";255;3;0;6;" + unit + "\n") println("Updated Sensor Units to " + unit +) } } } end -
Glad you got yours working. I tried changing the code on mine to see if it would respond, but it didn't. I may have hard coded the sensors to imperial though. I believe mine is catching the I_CONFIG variable, because I would get an output on the console when the sensor started up where I had a println command. Hopefully it was just my syntax that was wrong.
On another note, can you trigger a "sendCommand" with xxx;255;3;0;6;<I or M> at any time, or can it only be in response to the request from the sensor node?
@Tango2 I had been doing this a different way until I noticed the GW should be able to do it. BTW, It is only working on one node, not sure why :(.
Anyway, my alternate solution allows be to send "settings: to the nodes. For example, change the loop time or measurement unit.
This is not the complete code, just the relevant parts (hopefully).
void setup() { gw.begin(incomingMessage, nodeID); } void loop() { gw.process(); } void incomingMessage(const MyMessage &message) { if (message.type == 97) { Serial.print("Recvd Time"); Serial.println(time); timeReceived=true; } if (message.type == 98) { int reqsleep = atoi( message.data ); SLEEP_TIME = reqsleep*1000; Serial.print( "Changing sleep to: " ); Serial.println( String(reqsleep) ); } if (message.type == 99) { int requnit = atoi( message.data ); Serial.print( "Changing units to: " ); if(requnit == M){ metric = true; Serial.println( "metric" ); } else { metric = false; Serial.println( "imprerial" ); } } }Using this code, I can send things from openhab, or any serial command I suppose.
My openhab rules
Send Units:sendCommand(Arduino, "101;99;1;0;99;M\n")Send Time:
var Number time1 time1 = now().getMillis() / 1000 sendCommand(Arduino, "101;97;1;0;97;" + time1 + "\n")
