  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 325.2k Views 52 Watching
  • epierreE
    epierreE
    epierre
    looking at the project, I'm wondering why you propose 3.3V only, is this for the shift register and the screen ? Why not stay in 5V ?
    z-wave - Vera -> Domoticz
    petewillP 1 Reply Last reply
    • epierreE epierre
      petewillP
      petewillP
      petewill
      @epierre Where did you see that I don't remember? Perhaps for the NRF radio?
      • epierreE
        epierreE
        epierre
        @petewill it is here: http://www.mysensors.org/build/irrigation
        it is hard to know the BOM from the page, so I was wondering why you would neeed the powering adaptation if you input 5V
        • epierreE epierre
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @epierre
          If you watch the video, you can see he's using the voltage regulator to supply power to the radio.
          Are you getting ready to build?
          epierreE 1 Reply Last reply
            @epierre
            epierreE
            epierreE
            epierre
            @BulldogLowell said:
            @epierre
            I've ordered the 8 switch, I have soil moisture, leaf moisture, ground humidity, rain gauge and found some evapotranspiration algorithm so I have all inputs and now need to have outputs in parallel of my rainbird scheduler (too dumb...)
            So I'm ready to build as you say ;-)
              Added your project to the main site togeter with @petewill excellent new video.
              https://youtu.be/l4GPRTsuHkI
              C
              C
              charlybrown
              Excellent project.
              Can you help me with the android code, to send instrucctions from my cell phone to Arduino? like on-off light , bomb, etc.
              thanks for your time!
              best regards.
              • C
                C
                charlybrown
                Excellent work. I need help with android code. Anybody can help me with this?
                thanks
                • S
                  shemmozhipandian
                  I made the circuit, but later i realize it required vera controller to sync all the data. Is there other way or idea to send data to the built system.
                  • S shemmozhipandian
                    petewillP
                    petewillP
                    petewill
                    @shemmozhipandian Sorry for the delayed reply. It does require a controller (like Vera) but there are free ones out there. Take a look here: http://www.mysensors.org/controller/
                    I know Domoticz is free and seems to be fairly popular here. There are others as well. If you find one you like you may want to write a quick post to check compatibility. I personally use Vera so I'm not sure how the others work.
                      A Former User
                      Hello Pete, thanks for your hard work on this. Superb!
                      I want to build a irrigation controller like your project but can't figure out hows the wiring. On the wiki an image is shown but I can't see what the connections are in this "virtual proto board"
                      Is there something clearer or like a pinout to pin list?
                      I'm using an Arduino Nano, so things will be something different.
                      Thank you very much.
                      • ? A Former User
                        petewillP
                        petewillP
                        petewill
                        @Sergio Jim (@BulldogLowell) posted some more details above but here is my fritzing project as well. Hopefully you can zoom in where you need to see more.
                        Fritzing Irrigation Controller Wiring.fzz
                          A Former User
                          wrote on last edited by [[global:former-user]]
                          #112
                          Mmm... I finally assembled the device. But I'm having problems with it. It doesn't activate/deactivates the relays. I'm getting the power for the relay board from the nano itself. Could that be the problem?
                          Also, my domoticz doesn't receive the off signal from the controller. (doens't turn the light off) and sometimes throws some error telling that can't contact the node.
                          BTW I tried to contac Bulldogloweel without success :sob:
                          • ? A Former User
                            petewillP
                            petewillP
                            petewill
                            Yes, that is most likely the problem. Most of the relays I have used need more power than what the arduino can supply. Try feeding it more power (like from a phone charger).
                            Check the serial monitor with debug enabled. Does this happen every time? It could be radio issues. Do you have a 4.7uf cap on the radio? Is it close enough to your gateway?
                              @moffen666
                              I don't have Domoticz but I suspect that the callback isn't functioning.
                              try populating the array with the desired times for each sequence. replace this:
                              int allZoneTime [NUMBER_OF_VALVES + 1];
                              int valveSoloTime [NUMBER_OF_VALVES + 1];
                              with something like this:
                              int allZoneTime [NUMBER_OF_VALVES + 1] = {0, 10, 10, 10, 5,<... how many valves you have with zero in the first position>} ;
                              int valveSoloTime [NUMBER_OF_VALVES + 1] = {0, 5, 5, 5, 5,<... how many valves you have with zero in the first position>};
                              This will load in the times that the program uses as your 'default' values. Then, you can check with Domoticz experts on getting the V_VAR variables working.
                              fusion_manF
                              fusion_manF
                              fusion_man
                              @BulldogLowell
                              I need to add a relay for a master valve. This will open when any zone valves open. I think it could be mapped to All On 0(1) but I am not sure how to accomplish this. I don't know the code for that or electrical connection. I also noticed we are about maxed out of data (99%) using ProMini. Any ideas?
                              • BulldogLowellB
                                BulldogLowellB
                                BulldogLowell
                                wrote on last edited by BulldogLowell
                                #115
                                If you are worried about Program Space you can turn off Serial debug to rid yourself of a bunch of overhead in the sketch. I am not using String class so there is PLENTY of RAM and I've been using this for a while with no stack corruption issues:
                                #define DEBUG_ON   // comment out to surpress serial monitor output
                                if you propose to turn ON the master valve when each valve is cycled on, then I believe all you need to do is add that valve to the bitmask (logical OR) each time you updateRelays().
                                void updateRelays(int value)
                                  if(value)
                                    value |= 0b0000000010000000;  // master is the eighth relay, there are 7 controlled in this example (active HIGH in this example)
                                  digitalWrite(latchPin, LOW);
                                  shiftOut(dataPin, clockPin, MSBFIRST, highByte(value));
                                  shiftOut(dataPin, clockPin, MSBFIRST, lowByte(value));
                                  digitalWrite(latchPin, HIGH);
                                not tested
                                fusion_manF 2 Replies Last reply
                                    if(value)
                                  not tested
                                  fusion_manF
                                  fusion_manF
                                  fusion_man
                                  @BulldogLowell
                                  By commenting out the DEBUG, it went from 99% to 63% used memory.
                                  The modification to void updateRelays worked very nicely. I only wish the master control valve would remain ON during cycling through each valve (subjected to VALVE_RESET_TIME) as I am using it to control a chemical feed pump to prevent hydrogen proxide (30%) from entering my irrigation system.
                                  Awesome job and I am very pleased with your design.
                                  The only problem I had when building the controller was getting the LCD to communicate.
                                  I added this comment to my program under Instructions.
                                  • If your LCD is unresponsive, download sketch http://forum.arduino.cc/index.php?topic=128635.0 then check serial monitor for LCD address. Insert your address below.
                                      if(value)
                                    not tested
                                    fusion_manF
                                    fusion_manF
                                    fusion_man
                                    @BulldogLowell
                                    I ended up going a different approach. I modified the program so I could use Arduino digital pin6 as an output powering my master valve relay. I then added digitalWrite (masterValvePin, HIGH) where you have updateRelays(BITSHIFT_VALVE_NUMBER) to turn ON the valve. To turn off the valve I added a delay then digitalWrite (masterValvePin, LOW) to if (state == STAND_BY_ALL_OFF). This has tested perfectly for my situation.
                                    The only thing missing from the Controller is the ability to add the RainBird rain sensor to the board. I think the way of achieving this is an input to my Vera controller.
                                    • fusion_manF fusion_man
                                      @BulldogLowell
                                      BulldogLowellB
                                      BulldogLowellB
                                      BulldogLowell
                                      @fusion_man
                                      maybe we can add a rain sensor this season. It is a good idea to include it.
                                      fusion_manF 1 Reply Last reply
                                        @fusion_man
                                        fusion_manF
                                        fusion_manF
                                        fusion_man
                                        @BulldogLowell
                                        I already did and it is up and running. I used A0 as the input for the rain sensor. I can see the rain sensor in Vera as a motion sensor. I didn't post the code as I didn't want to offend the designer. Being a newbie, I didn't know how to handle this update.
                                          @BulldogLowell
                                          BulldogLowellB
                                          BulldogLowellB
                                          BulldogLowell
                                          @fusion_man
                                          why not just post your code? I'm sure the guy who wrote the original code won't mind, if you include his original notes and credits.
