  3. Which are the *best* NRF24L01+ modules?
310 Posts 42 Posters 342.4k Views 37 Watching
  • YveauxY Yveaux
    @Moshe-Livne said:
    why don't you start a github sketch with simple regression results that will evolve with time?
    I'm thinking about a simple sketch, based of the nRF24 Sniffer's code, which connects two radios and checks on air how a radio communicates. This should allow detecting the inverted NO_ACK bit (see Jay Tyzzer's comment here) to immediately quilify a module as fake when detected.
    Of course this doesn't mean it's genuine when doesn't have the bit inverted, but the sketch could also dump register settings to be able to detect a pattern.
    Moshe LivneM
    Moshe LivneM
    Moshe Livne
    @Yveaux wonderful! Even if fake, ones with correct ack bit will probably work better so its a step in the right direction
    • YveauxY Yveaux
      An overview of the module I have lying around (origin is unclear, as I don't really keep track of where they come from)
      The chip close-ups were taken using a microscope, so they have far higher resolution then shown in the table (right-click & show image to view at native resolution) .
      Datecode YYWWLL Module top Module bottom Closeup Fake/Genuine
      0830AE 2015-07-27 18.59.21.jpg 2015-07-27 18.59.32.jpg 20150727_0005.jpg Genuine? Datecode 0830 indicates production wk30 2008. nRF24L01+ was launched in 2008
      1242AF 2015-07-27 18.53.12.jpg 2015-07-27 18.53.28.jpg 20150727_0006.jpg Known counterfeit, according to this
      1331AF 2015-07-27 18.56.26.jpg 2015-07-27 18.56.34.jpg 20150727_0008.jpg Known counterfeit, according to this
      1408AF 2015-07-27 18.54.33.jpg 2015-07-27 18.54.41.jpg 20150727_0002.jpg Probably fake (identical to left one bottom of the page
      NeverDieN
      NeverDieN
      FWIW, the 0830AE date code is only a little earlier (4 weeks?) than the 0834AF datecode on the chip above in Hek's post where Hek alleges the module is genuine.
      • YveauxY Yveaux
        @hek said:
        What microscope are you using?
        This one. It's sold under various names/brands (e.g. Oitez e-scope).
        I really needed it to hand-solder those QFN's ;-)
        NeverDieN
        NeverDieN
        How hard would it be to desolder a bogus NRF chip and then solder a known good NRF24L01+ (purchased either directly from Nordic, if Nordic does that, or else from a trusted distributor like Digikey) in its place? Perhaps in this way the modules can be given a second life of sorts.
        • NeverDieN
          NeverDieN
          #44
          @Yveaux: Those are wonderful photos! Thanks so much for posting them. :smile: Did you use the microscope for the module shots also, or just the NRF chip closeups?
          Since you have a nice module collection that spans different NRF chips and also different module types, have you noticed whether any of your modules stand out head-and-shoulders above the others as having clearly better performance?
          • DwaltD
            DwaltD
            Dwalt
            wrote on last edited by Dwalt
            #45
            Lol, I just checked all of my radios from Alice1101983 and they are all dated 1242AF - FAKES! I have 20 from two orders of 10 radios each placed about six months apart (10/14 & 4/15) and they all have the same production date. They do work but I have occasional and random node hangup. This is an ongoing problem which I have been unable to troubleshoot. @hek, we might want to change the vendor in the MySensors store.
            • NeverDieN
              NeverDieN
              #46
              Here's a module that is itself surface mountable. It seems like roughly half the footprint of typical modules.
              Anyone have suggestions on how best to cheaply hook it up to an arduino? Not sure, but the pin pitch might be 1.27mm. I do have arduino prototyping shields, and there do seem to be 7 pin areas meant for soldering on something with surface mount (see SOIC area in upper left below):
              Unfortunately, there are only 7 pads on the SOIC that I can solder it to, and the ground pin is on the end, with the IRQ next to it.
              Not ideal! Should I try soldering a wire to the ground pin but solder the rest of the pins to the SOIC pads on the prototyping board? Seems like that may be the cleanest way to do it.
              That might be fine if using an Uno, but what about if using a pro mini? How best to connect it then? Anyone here already doing it?
              As a ghetto method I could also run jumper pins through each through-hole and solder into place, and then run each wire to the proper pin on the pro mini and solder into place, but... not very elegant. Are there better ways I'm not aware of?
              • NeverDieN
                NeverDieN
                Anyone know by what method Nordic prints the lettering on the chips? In looking at Yveaux's CSI-like photos, from chip-to-chip all of the letters have some amount of black mixed in, but on some they seem to be gaps left by air bubbles (so you're seeing through paint gaps to the black background) from the lettering being sprayed on, and on others the black seems like black dust or or something that was sprinkled on top after the lettering was applied. So, if you look closely through a microscope, some differences do seem to emerge. Under magnification, the lettering on the 1331AF is visibly sloppy, almost as if printed by a professional cake decorator from your local bakery.
                Anyone know what some of the other lettering is supposed to mean? e.g. M, AF, EV, CH, A, 0, CL, AE, DQ, FJ, or FY? On Hek's genuine chip, it seems blank after the NRF, whereas that's not true for any of the other chips.
                YveauxY 1 Reply Last reply
                • SparkmanS
                  SparkmanS
                  Sparkman
                  My "regular" modules were bought from gc_supermarket and the NRF chips all have the following printing. There is no circle in the center of the +.
                  NRF  T
                  24L01+
                  1420JB
                  My LNA/PA modules were bought from alice11011983 and the NRF chips have the following printing. There is a circle in the center of the + on the first set, but not the second set.
                  NRF  M
                  24L01+
                  1431FC
                  NRF  O
                  24L01+
                  1417GP
                  I'll try to grab some pics this weekend.
                  Cheers
                  Al
                  NeverDieN 1 Reply Last reply
                  • NeverDieN
                    NeverDieN
                    #49
                    Update: I provided Itead with my contact information, and they will try to arrange for a Nordic FAE to contact me.
                    As there's no telling how long the above might take to resolve, I decided to roll the dice again and ordered three of these modules:
                    I hope to receive them by later in the week. I'm hopeful, but only slightly optimistic. If there's interest, I'll post closeups after I receive and test them.
                    I also ordered more blob modules, but from a different source than the two I already have, so who knows what I'll actually receive. If it turns out blob modules from different sources are all about the same, I might standardize on that and simply move on. The two that I have work well enough that I wouldn't mind doing that, though it may put me on a fork from the rest of you. My only reluctance is that we'd all be more productive if we can find some way to leverage a common platform, so that remains my preference (and hope) for the long-term.
                    • NeverDieN NeverDie
                      YveauxY
                      YveauxY
                      Only the chips were shot using my microscope. The field of view is simply too small to shoot the whole module.
                      Only > Since you have a nice module collection that spans different NRF chips and also different module types, have you noticed whether any of your modules stand out head-and-shoulders above the others as having clearly better performance?
                      No, but I had troubles mixing different modules in the past (even the NO_ACKs were involved iirr), so I'm very interested to know which ones are genuine.
                      • YveauxY Yveaux
                        YveauxY
                        YveauxY
                        Yes, it's in the data sheet. The date code is in YYWWLL which stands for year & week of production, an LL indicates wafer lot. The top right code indicates the production location (first letter) followed by optional letter indicating engineering sample.
                        Nordic is fabless so only they know what the location letters mean.
                        The text is normally written using a laser scriber, so no ink is involved.
                        Thinking of it, differences in font/thickness etc. can be caused by different laser scribers at different production facilities (or even within one facility) so I'm starting to doubt if it will help us in distinguishing fakes from genuine.
                        • YveauxY Yveaux
                          NeverDieN
                          NeverDieN
                          Thanks for pointing that out. Looking at the version 1.0 spec sheet (available at http://www.nordicsemi.com/eng/Products/2.4GHz-RF/nRF24L01P), I see it covered in section 13.1 and 13.2.
                          Curiously, according to the spec sheet, the chips should be marked "nRF", not "NRF".
                            YveauxY
                            YveauxY
                            Maybe they hoped the copycats would also copy this error, but unfortunately they didn't :facepunch:
                            • SparkmanS Sparkman
                              NRF  T
                              24L01+
                              1420JB
                              NRF  M
                              24L01+
                              1431FC
                              NRF  O
                              24L01+
                              1417GP
                              Cheers
                              Al
                              NeverDieN
                              NeverDieN
                              NRF  T
                              24L01+
                              1420JB
                              NRF  M
                              24L01+
                              1431FC
                              NRF  O
                              24L01+
                              1417GP
                              Cheers
                              Al
                              Hi Al,
                              Funny that you happen to mention gc_supermarket, because just yesterday I was noticing that they had good pricing on blob modules. These visually resemble the two blob modules I have and which seem to perform quite well at 1mbps air datarate. Intriguingly, the listing title says "Power enhanced version Compatible NRF24L01" and in the description it says:
                              "This module is design to solve the problem of small power in NRF24L01 module, its distance is far away than NRF24L01
                              Please download the data in below link
                              http://www.ai-thinker.com/forum.php?mod=viewthread&tid=411&extra=page%3D1 "
                              It would be easy to dismiss this as gibberish or as a failed attempt at chinglish, except for the fact that my two blob modules do, in fact, seem to have much better range than any of the "regular" NRF24L01+ modules I've tried so far. So, whether deserved or not, that does seem to give gc_supermarket more credability in my eyes than a lot of other re-sellers. Also, whether by luck or intent, they referred to it as "NRF24L01", not "NRF24L01+", which is also closer to reality, as it doesn't support 250kbps. So, in my book they get some credibility points for that also.
                              Have your transactions to date with gc_supermarket gone well?
                              SparkmanS 1 Reply Last reply
                                NRF  T
                                24L01+
                                1420JB
                                NRF  M
                                24L01+
                                1431FC
                                NRF  O
                                24L01+
                                1417GP
                                Cheers
                                Al
                                Hi Al,
                                SparkmanS
                                SparkmanS
                                Sparkman
                                Overall yes. First shipment from them got lost, but they replaced the shipment right away without any argument and it showed up ok. The modules seem to be a good quality with nice soldering and the flux cleaned up properly. I haven't done any packet loss testing with them, but have had good range with them (@250kbps).
                                Cheers
                                Al
                                • NeverDieN
                                  NeverDieN
                                  #56
                                  Here's a link which lists chips similar to the NRF24L01+ (there are many more than I had supposed), and it also highlights some of their differences: http://sigrok.org/wiki/Protocol_decoder:Nrf24l01
                                  Especially useful is the mirror of the datasheets.
                                  I have a hunch that a simple way to differentiate among the various chips might be to measure the amount of current consumed in various modes (e.g. standby, powerdown, etc), because those numbers are also given in the datasheets. Anyone tried that?
                                  • NeverDieN
                                    NeverDieN
                                    #57
                                    I just placed an order on Ali Express for four NRF24L01+ modules that look similar to the one Hek says is genuine: http://www.aliexpress.com/item/Free-shipping-Original-Genuine-NRF24L01-Wireless-Module-2-4G-wireless-communication-module-2-54mm-Interface-2/1781618813.html I mainly picked this seller because he will be sending by ePacket for only 4 cents extra, and that should mean much faster delivery (5 to 15 days). Also, the seller has decent feedback and is promising that the chips are "original" and "genuine." So, with shipping, the modules will be costing me an average of $2.82 each. I hope they're worth not just the money, but also the wait.
                                    I would have preferred to first receive and then test the modules I've already ordered to see if they are genuine, but given the shipping time from Asia, I'm doing parallel orders in the hope of getting at least one shipment of genuine NRF24l01+ modules up and working fairly soon. Doing the orders serially would have run the risk of the procurement process taking too long.
                                    • F
                                      F
                                      Fabien
                                      @NeverDie : Can you please post the sketch you use to test your NRFs modules. I just recieve 10 today from Itead. Same packaging that the ones you recieve. I just want to compare result in same conditions.
                                      • OitzuO
                                        OitzuO
                                        Oitzu
                                        wrote on last edited by Oitzu
                                        #59
                                        I ordered some surface-mounted by accident.
                                        The reading say:
                                        NRF M
                                        24L01+
                                        1436AH
                                        They seem to work fine, but if somebody has an packet-loss testing sketch i would test it.
                                        • F Fabien
                                          NeverDieN
                                          NeverDieN
                                          #60
                                          OK, sure. It started out as RF toy code, and then I just evolved it. It contains a lot of commented out code that I haven't bothered to delete. If that gets in the way of your understanding, just delete the code that's commented out. Aside from that, it's straightforward.
                                          Here's the main transmitter code. After compiling and uploading, you should open a serial window on your computer to read the statistics it prints out:
                                           nRF24Sender Demo for RFToy
                                           This demo shows how to use RFToy to make a
                                           wireless temperature sensor. This is the
                                           sender module which transmits the current
                                           temperature value to a receiver module. The
                                           demo uses the Mirf library.
                                           This demo uses a 100K resistor and 100K
                                           thermistor to form a simple temperature
                                           sensor. Pin A1 is used to read the value.
                                           The connection is:
                                           VCC->100K->A1->thermistor->GND
                                           Written by Jonathan Goldin @ Rayshobby LLC
                                           Nov 2014
                                           For details, visit http://rayshobby.net/rftoy
                                          #include <Mirf.h>
                                          #include <nRF24L01.h>
                                          #include <MirfHardwareSpiDriver.h>
                                          #include <U8glib.h>
                                          U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NONE);	// I2C / TWI
                                          void setup(){
                                            Serial.begin(115200);
                                            Serial.println("Starting...");
                                             Set ce and csn pins
                                            Mirf.cePin = 17;
                                            Mirf.csnPin = 16;
                                            Mirf.spi = &MirfHardwareSpi;
                                            Mirf.init();
                                             * Configure reciving address.
                                            Mirf.setRADDR((byte *)"clie1");
                                             * Set the payload length to sizeof(unsigned long) the
                                             * return type of millis().
                                             * NB: payload on client and server must be the same.
                                            //Mirf.payload = sizeof(long);
                                             * Write channel and payload config then power up reciver.
                                             * To change channel:
                                             * Mirf.channel = 10;
                                             * NB: Make sure channel is legal in your area.
                                              // we use channel 90 as it is outside of WLAN bands
                                            // or channels used by wireless surveillance cameras
                                            //Mirf.channel = 90;
                                            Mirf.config();
                                            //This register value is not remembered between power cycles.
                                            //It defaults to 0x0F.
                                            //It should be initialized each time if different than 0x0F.
                                            Mirf.configRegister(RF_SETUP,0x07); //0x0F is 2mbps, max Tx power
        //0x07 is 1mbps, max Tx power
        //0x2F is 250kbps, max Tx power.
                                            Serial.println("OTA datarate set to  1Mbps.  Transmit Power set to Maximum.");
                                            // Read and print RF_SETUP
                                           byte rf_setup = 0;
                                           Mirf.readRegister( RF_SETUP, &rf_setup, sizeof(rf_setup) );
                                           Serial.print( "rf_setup = " );
                                           Serial.println( rf_setup, BIN );
                                            // OLED
                                            u8g.firstPage();
                                            do{
                                              uint8_t h;
                                              u8g.setFont(u8g_font_10x20);
                                              u8g.setFontRefHeightText();
                                              u8g.setFontPosTop();
                                              h = u8g.getFontAscent()-u8g.getFontDescent();
                                              u8g.drawStr(29,(u8g.getHeight()-h)/2,"Tx Sender");
                                            while(u8g.nextPage());
                                            Mirf.setTADDR((byte *)"serv1");
                                            Serial.write("Sending...\r\n");
                                            delay(200);
                                          } // End of *Setup*
                                          long temp;
                                            int temp1;
                                            int temp2;
                                            long timeTxSent;
                                            long timeRxReceived;
                                            long roundTrip;
                                            byte age1=52;
                                            byte age2=11;
                                            long txCounter=0;
                                            long matchCount=0;
                                            long differentCount=0;
                                            long lostCount=0;
                                            long cumulativeRoundTrip=0;
                                            long averageRoundTrip=0;
                                            boolean packetLost=false;
                                            float packetErrorRate=0;  //no errors yet, and maybe there never will be.
                                            float lostPacketRate=0;  //no packets lost yet.
                                            const int statusFrequency=500;  //How many iterations of main loop before printing status info.
                                            long minRoundTrip=9999; //value will be driven down when program runs
                                            long maxRoundTrip=0;  //value will be driven up when program runs
                                          void loop(){
                                            txCounter++;
                                            packetLost = false;  //It can't be lost, because it hasn't even been sent yet.
                                            temp = txCounter;  //getTemp(resistance);
                                            temp1=temp;
                                            timeTxSent=micros();
                                            Mirf.send((byte *)&temp);
                                            while(Mirf.isSending()){
                                            Serial.write("temp=");
                                            Serial.print(temp,DEC);
                                            Serial.write("\r\n");
                                            Serial.write("temp1=");
                                            Serial.print(temp1,DEC);
                                            Serial.write("Finished sending.\r\n");
                                            //delay(10);
                                            unsigned long time = millis();
                                            while ((!packetLost) && (!Mirf.dataReady())){
                                              //Serial.println("Waiting");
                                              if ( ( millis() - time ) > 8 ) {
                                                //Serial.println("Timeout on response from Rx Echo Reflector!");
                                                lostCount++;
                                                packetLost=true;
                                            if (!packetLost) {
                                            Mirf.getData((byte *) &temp);
                                            timeRxReceived=micros();
                                            temp2 = temp;
                                            roundTrip =  timeRxReceived - timeTxSent;
                                            if (roundTrip < minRoundTrip) {
                                              minRoundTrip=roundTrip;
                                            if (roundTrip > maxRoundTrip) {
                                              maxRoundTrip = roundTrip;
                                            if(temp1 == temp2){
                                              matchCount++;
                                              cumulativeRoundTrip += roundTrip;
                                              averageRoundTrip = cumulativeRoundTrip/(txCounter-lostCount-differentCount);
                                            } else {
                                              differentCount++;
                                              Serial.println("***DIFFERENT**");
                                                Serial.println(temp1, BIN);
                                                Serial.write("temp2=");
                                                Serial.println(temp2, BIN);
                                            if ((txCounter%statusFrequency)==0) {
                                              if(temp1 == temp2){
                                                Serial.print("Match");
                                              else {
                                              Serial.write(",");
                                            lostPacketRate = 100*((float)(lostCount))/((float)txCounter);
                                              Serial.print(txCounter);
                                              Serial.write(",lost=");
                                              Serial.print(lostPacketRate);
                                              Serial.write("%,T=");
                                              //Serial.write(".  ");
                                              Serial.write(",T1=");
                                              Serial.write(",T2=");
                                              Serial.print(temp2,DEC);
                                              Serial.write("%,RT=");
                                              Serial.print(roundTrip,DEC);
                                              Serial.write(",minRT=");
                                              Serial.print(minRoundTrip);
                                              Serial.write(",maxRT=");
                                              Serial.print(maxRoundTrip);
                                              Serial.write(",aRT=");
                                              Serial.print(averageRoundTrip,DEC);
                                              Serial.print(",#lost=");
                                              Serial.print(lostCount);
                                              //Serial.write(",mat=");
                                              //Serial.print(matchCount);
                                              Serial.write(",diff=");
                                              Serial.print(differentCount);
                                              delay(100); //give time for it to print out
                                              //txCounter = 0;  //restart gathering statistics
                                            delay(1000);  // keep the 'sending' message displayed on OLED for 1 sec
                                            u8g.firstPage();
                                            do{
                                            } while(u8g.nextPage());
                                            delay(2000);  // wait for 2 seconds till next transmission
                                          }  //End of main loop.
                                          Here's the code for the receiver node. It doesn't need to be plugged into a computer:
                                           nRF24Receiver Demo for RFToy
                                           receiver module which displays the received
                                           temperature value to OLED. The demo uses
                                           the Mirf library.
                                           Nov 2014
                                          #include <Mirf.h>
                                          #include "U8glib.h"
                                          void setup(){
                                            Serial.println("Echo Receiver.  Listening");
                                            Mirf.cePin = 17;  //???
                                            Mirf.csnPin = 16;  //???
                                             * Set the SPI Driver.
                                             * Setup pins / SPI.
                                            Mirf.init();
                                            Mirf.setRADDR((byte *)"serv1");
                                            Mirf.config();
                                           byte rf_setup = 0;
                                            u8g.firstPage();
                                            do{
                                              uint8_t h;
                                              u8g.drawStr(19,(u8g.getHeight()-h)/2,"Echo Rx");
                                          }  //End of *Setup* procedure
                                          void loop(){
                                             * A buffer to store the data.
                                            byte data[Mirf.payload];
                                             * If a packet has been recived.
                                             * isSending also restores listening mode when it
                                             * transitions from true to false.
                                            if(!Mirf.isSending() && Mirf.dataReady()){
                                              //Serial.print("Got packet: ");
                                               * Get load the packet into the buffer.
                                              Mirf.getData(data);
                                              // Set the send address.
                                              Mirf.setTADDR((byte *)"clie1");
                                               * Send the data back to the client.
                                              Mirf.send(data);
                                               * Wait untill sending has finished
                                               * NB: isSending returns the chip to receving after returning true.
                                              //Serial.println("Reply sent.");
                                          As background, here's a link to the RFToy:
                                          http://rayshobby.net/rftoy/
                                          Links to the RFToy library, as well as the hardware design, can be found there. It's all open source.
                                          This shows the pin assignments: https://github.com/rayshobby/rftoy-hw/blob/master/RFToy.png
                                          You'll need a pinout diagram to match-up those internal pins to the physical pins of whatever Arduino you're using. For instance, for an Uno, here's a pinout diagram which maps internal pins to physical pins:
                                          http://marcusjenkins.com/wp-content/uploads/2014/06/ARDUINO_V2.png
                                          That way you'll know how to properly wire-up your NRF24L01+ so that it works properly with the library code.
                                          So, I did that just now and tested it on the UNO, and so for the UNO the simplified wiring directions are:
                                          NRF24L01+Pin --- --> Uno Female Header Pin
                                          GND (1) ----------------------------> GND
                                          VCC (2) -----------------------------> 3.3V
                                          CE (3) ------------------------------> A3
                                          CSN (4) -------------------------------> A2
                                          SCK (5) --------------------------------> D13
                                          MOSI (6) --------------------------------> D11
                                          MISO (7) --------------------------------> D12
                                          IRQ(8) ---------------------------------> n/a
                                          The RFToy has an OLED screen that gets written to. You can remove that code if you wish, but leaving it in does no harm, even if you don't have an OLED screen on your arduino. I modified the code so that it's only written to during the setup loop, so regardless it shouldn't interfere with any of the measurements taken in the main loop..
                                          Hope that helps!
                                          parachutesjP 1 Reply Last reply
