  3. Temperature Sensor problem
15 Posts 7 Posters 8.1k Views 2 Watching
  • V
    V
    vampircik
    http://www.mysensors.org/build/temp
    http://ru.aliexpress.com/item/orignial-sensor-Temperature-and-humidity-sensor-module-Fapplication-DHT-11-DHT11-PCB/1206875250.html
    Library can not Correctly?
      wrote on last edited by hek
      Looks like garbage... try switching usb cable to your board.
      Nice to see the site in russian BTW :)
      • V
        V
        vampircik
        You need to change the cable? I am also pleased to work with you.
        tbowmoT 1 Reply Last reply
        • V vampircik
          tbowmoT
          tbowmoT
          tbowmo
          @vampircik
          Have you set the correct board type in arduino? Could look like the baudrate doesn't match..
          • BulldogLowellB
            BulldogLowellB
            BulldogLowell
            wrote on last edited by BulldogLowell
            @vampircik
            it could also be as simple as the sketch in the library does not by default enable serial communication, nor does that sketch output any Serial data!!
            try inserting the lines I added below and make sure that your baudrate on your serial Monitor is the same (115200bps)
              Serial.begin(115200);  //<<<<<<<<<<<<<<<<<<<<<  Add This Line
              // Startup OneWire
              sensors.begin();
              gw.begin();
              gw.sendSketchInfo("Temperature Sensor", "1.0");
                 gw.present(i, S_TEMP);
              Serial.println("Yeah!! now it works!!");
            @Admin
            Entire library sketch:
            // Example sketch showing how to send in OneWire temperature readings
            #include <OneWire.h>
            OneWire oneWire(ONE_WIRE_BUS);
            int numSensors=0;
            boolean metric = true;
            MyMessage msg(0,V_TEMP);
              // Startup OneWire
              sensors.begin();
              gw.begin();
              gw.process();
                if (lastTemperature[i] != temperature && temperature != -127.00) {
              gw.sleep(SLEEP_TIME);
            • HeinzH
              HeinzH
              Heinz
              Yep I agree, looks like wrong baudrate.
              • V
                V
                vampircik
                Arduino: 1.6.3 (Windows 8), Плата"Arduino Pro or Pro Mini, ATmega328 (3.3V, 8 MHz)"
                Изменена опция сборки, пересобираем все
                sketch_jul26d.ino:2:3: error: invalid preprocessing directive #\
                sketch_jul26d.ino:3:3: error: invalid preprocessing directive #\
                sketch_jul26d.ino:4:3: error: invalid preprocessing directive #\
                sketch_jul26d.ino:5:3: error: invalid preprocessing directive #\
                sketch_jul26d.ino:7:3: error: invalid preprocessing directive #\
                sketch_jul26d.ino:8:4: error: invalid preprocessing directive #\
                sketch_jul26d.ino:9:1: error: stray '' in program
                sketch_jul26d.ino:10:1: error: stray '' in program
                sketch_jul26d.ino:11:1: error: stray '' in program
                sketch_jul26d.ino:13:1: error: stray '' in program
                sketch_jul26d.ino:15:1: error: stray '' in program
                sketch_jul26d.ino:16:1: error: stray '' in program
                sketch_jul26d.ino:20:1: error: stray '' in program
                sketch_jul26d.ino:35:3: error: stray '' in program
                sketch_jul26d.ino:36:6: error: stray '' in program
                sketch_jul26d.ino:41:1: error: stray '' in program
                sketch_jul26d.ino:50:3: error: stray '' in program
                sketch_jul26d.ino:53:5: error: stray '' in program
                sketch_jul26d.ino:56:5: error: stray '' in program
                sketch_jul26d.ino:59:7: error: stray '' in program
                sketch_jul26d.ino:60:7: error: stray '' in program
                sketch_jul26d.ino:9:2: error: 'u0437' does not name a type
                sketch_jul26d.ino:10:1: error: 'Wire' does not name a type
                sketch_jul26d.ino:11:1: error: 'DallasTemperature' does not name a type
                sketch_jul26d.ino:12:1: error: 'MySensor' does not name a type
                sketch_jul26d.ino:13:2: error: 'u043f' does not name a type
                sketch_jul26d.ino:14:2: error: 'INT' does not name a type
                sketch_jul26d.ino:15:2: error: 'u043b' does not name a type
                sketch_jul26d.ino:16:2: error: 'u043b' does not name a type
                sketch_jul26d.ino:18:1: error: 'MyMessage' does not name a type
                sketch_jul26d.ino:20:2: error: 'u043d' does not name a type
                sketch_jul26d.ino:41:2: error: 'u043d' does not name a type
                Ошибка компиляции.
                Это сообщение будет содержать больше информации чем
                "Отображать вывод во время компиляции"
                включено в Файл > Настройки
                • V
                  V
                  vampircik
                  • V
                    V
                    vampircik
                    int numSensors=0;
                    // Startup OneWire
                    sensors.begin();
                    gw.begin();
                    gw.process();
                    • BulldogLowellB
                      BulldogLowellB
                      BulldogLowell
                      "Check wires" error when you don't have the NRF radio connected properly.
                      • V
                        V
                        vampircik
                        I connected properly checked.
                        • sundberg84S
                          I have seen "check wires" a 100 times and every time it is because I missed in the wiring.
                          Double and tripple check wiring in both arduino and radio side.
                          If its correct, try another radio, change wires or even try another arduino.
                          Good luck.
                            And make sure you haven't enabled SOFTSPI earlier and forgot to change it back.
                            • V
                              V
                              vinzouille
                              I had the check wires problem and this topic was helpful thanks a lot :)
                              Now I don't have this error message anymore but I don't have any message at all, so my question is am I supposed to have any message while running my temperature sensor on serial monitor ?
                              • V
                                V
                                vinzouille
                                I found the solution this was my NRF that didn't work
