  3. Open Source Home Automation (Raspberry)
automationopen sourceraspberrycontroller
111 Posts 30 Posters 186.2k Views 15 Watching
    @John-Sirach
    Yes, that is correct. There are both device- and variable types. You can report multiple variables on one device.
    When to use a specific variable type for a device is really a silent agreement between sensor and controller. Today you could actually report a temperature variable to a humidity device. It would not make any sense, but noting prohibits this. A good example where multiple variables is reported for one device is POWER-device where you usually report both KWH and WATT.
    If we can find a more general way of handling this in the future (and not over complex from the sensors point of view) it would be good. We had an discussion going about this but the thread disappeared in an crash.
    - I might split this into a new topic -
    JohnJ
    JohnJ
    John
    @hek Having multiple kind variables posted to a single device is no problem, it's more about the datatype handling because of possible automatic graph creations. It would be nice of there was a table somewhere telling what kind of data a variable is for the internal mappings used. But this would an other topic.
    • daulagariD
      daulagariD
      daulagari
      Yes, agree, and it would be even nicer if that table was in a machine readable format so that again not everybody has to reinvent the wheel.
      • JohnJ John
        marceltrapmanM
        marceltrapmanM
        marceltrapman
        wrote on last edited by marceltrapman
        #63
        You can start the yourself topic and publish the table :)
        It is in the Vera files on Github...
        Fulltime Servoy Developer
        JohnJ 1 Reply Last reply
        • marceltrapmanM marceltrapman
          JohnJ
          JohnJ
          John
          @marceltrapman The internal mappings was meant for my project ;). When i take a look at the github code they all seem to be handled as strings? I meant in the case of a variable to be intepreted as a string,boolean,int,float,etc..
          • daulagariD
            daulagariD
            daulagari
            I checked out the Vera repository and do not really see a table, what comes most close are the tDeviceTypes and the tVarTypes definitions in L_Arduino.lua.
            Any better definition/source?
            • daulagariD daulagari
              marceltrapmanM
              marceltrapmanM
              marceltrapman
              @daulagari said:
              I do not really see a table...
              OK, now I understand :)
              What I was trying to say is that many rely on @hek to do this work but we can contribute ourselves as well.
              In case you think a table is what helps you to do the job it might be a good exercise to assemble that table yourself.
              Apologies for not being more clear on that.
                The table is also represented here.
                http://www.mysensors.org/build/sensor_api#the-serial-protocol
                (an updated table will be created for 1.4 once we decide to make it official)
                If your using the serial protocol to communicate with the sensor network everything coming to the controller is represented as a string. Some values might might have decimals where applicable like temperature. But this is really up to the sensor to decide.
                Boolean values is represented by 1/0.
                Some sensor values is represented with percentage 0-100 (e.g. DIMMER, LIGHT_LEVEL, BATTERY_LEVEL).
                Yet is some values (or modes) is represented by a string (like for HEATER). But is uncommon and mostly a legacy from Vera.
                  JohnJ
                  JohnJ
                  John
                  Ok, this is making things more clear, i will let the datatype the be decided by the user creating a device.
                  Thnx.
                  • S
                    sensorsusr
                    @bjornhallberg
                    I'm currently using OpenHAB with a couple Arduino sensor nodes. It works great. It does everything you've put in your required list and then some: rules engine, slick android app and browser interface, email / push notifications, data collection and charts. The only missing piece is the GUI for scene creation, but it's in the works. Also, great active community.
                    Here's some videos and tutorial of what I've got working:
                    http://goo.gl/je6LzU
                    I was in the same boat as you. All these "Home Automation" platforms take a lot of digging into to find out where their shortcomings are, what they're capable of. Although I did not do an exhaustive survey of everything out there, I did look at a few on your list, and ended up with OpenHAB.
                    • Z
                      Z
                      Zeph
                      wrote on last edited by Zeph
                      #70
                      See thread http://forum.mysensors.org/topic/248/generalizing-mysensors for some very related thoughts about making MySensors more easily and cleanly adaptable to different controllers, cloud storage, MQTT, radio networks, etc.
                      (For once, I had the self discipline to start another thread rather than embed that discussion in this related one, yay!)
                      • bjornhallbergB
                        bjornhallbergB
                        bjornhallberg
                        wrote on last edited by bjornhallberg
                        #71
                        Here are some benchmarks that also happen to include certain ARM platforms, like the Cubieboard, Raspberry as well as x86 Atom and NUC solutions. It also has the N40L Microserver that I run as a storage server (but am reluctant to run 24/7).
                        https://s1.hoffart.de/7zip-bench/
                        http://www.7-cpu.com/
                        Perhaps not entirely applicable to JAVA or node.js or whatever but nevertheless a good guide.
                        I bought my N40L for about €100 a while back (has since been deprecated by the N54L, don't know if it's still around?). Still stands up as pretty much the cheapest x86 board you can get, especially if you get the 4GB model and consider the performance which is better than a lot of fusion and atom platforms. Not super energy efficient though, even with the picoPSU mod and Dell powerbrick, and a bunch of 4TB drives obviously makes it even less so.
                        If this whole Raspberry thing doesn't work out I'd definitely look into Intel's NUC line-up. The newer i5 Haswell model (D54250WYK) can allegedly run as lean as 3.7-4.6W idle. I figure they might get pretty cheap once the next generation comes out.
                        • JohnJ
                          JohnJ
                          John
                          I have put some support for mysensors in the software i'm using/creating. It is in early stage and there is some manual labor needed.
                          Still need to add:
                          • Automatic node addresses
                          • Automatic create node devices based on node presentations
                          • And other stuff that can be added, etc...
                          A penny for your thoughts:
                          http://pidome.wordpress.com/2014/08/10/added-partly-mysensors-org-wireless-devices-support-api-1-4-beta/
                          • JohnJ John
                            Still need to add:
                            bjornhallbergB
                            bjornhallbergB
                            bjornhallberg
                            @John I did a quick install on my RPi to see how it would work out. I must say I'm impressed. Server web interface was up and running in under 40 seconds or so (openhab = 4 minutes). Very snappy and the interface seems like a good basis for a powerful controller. Shows real promise! Renewed faith in Java ;-)
                            • JohnJ
                              JohnJ
                              John
                              @bjornhallberg
                              Disable the ssl in config/system.default.properties or copy and paste the below line in config.properties (default has precedence)
                              server.enablessl = false
                              And it will be even faster, it then disables the certificate generation(at least 5 seconds), ssl websocket, http and raw socket instances (couple seconds per instance type).
                              I'm glad you got it up and running quite quickly if i understood correct because the downloads are still in alpha state (snapshots). I wish i already had some example sensors in the DB so it could by tried out without having to create XML definition files yourself.
                              • B
                                B
                                Bandra
                                @John
                                Your project looks great! I'm looking around for an home automation controller and was tossing between domoticz, openhab and FHEM.
                                My criteria are:
                                • MySensors support (whether directly or through a gateway)
                                • Z-Wave support
                                • Visual floor plan
                                • Runnable on a Pi
                                May have to add yours to the mix to trial.
                                How difficult would it be to compile openzwave and integrate it by some mechanism to PiDome, do you think?
                                • B Bandra
                                  @John
                                  My criteria are:
                                  • Z-Wave support
                                  • Visual floor plan
                                  • Runnable on a Pi
                                  JohnJ
                                  JohnJ
                                  John
                                  @Bandra
                                  • MySensors support: Almost completely done with todo's as including AUTO addressing and datatype assignments.
                                  • Visual Floor plan: Available in the server and desktop client.
                                  • Runnable on a Pi: This is the primary target.
                                  • Z-Wave support: On our todo list: https://bitbucket.org/pidome/pidome-server/issue/70/add-zwave-support
                                  OpenZWave is the best candidate to use but has not yet been completely looked into yet because the internal pidome device, web interface, and package management bindings api is not completely finished yet and grows with supporting protocols etc.. It is possible it takes between two and three months before it is included by default if i follow my roadmap.
                                  MQTT is planned to be implemented after MySensors and other stuff, so if there is an MQTT interface for OpenZWave it should be possible somewhere in the end of September/begin October.
                                    @Damme TTS caught my eye the first time around, but I sort of dismissed it because it was node.js, immature, unheard of, and seemed reluctant to show much of its web gui. Seemed more like a concept and a bunch of techno babble. Also, support for a bunch of expensive commercial stuff that I'll never buy (Tesla cars anyone?). And, no smartphone apps (yet). I guess they're the sort of hipsters that like to run things in their smartphone browsers. But I can see the potential here. The web ui seems pretty snappy from their vimeo demo, and like you say, they have basically served up a functioning example of how to interface with an Arduino.
                                    They sort of shut me up about user interfaces also. Their web ui is so different it seems to be from the future ;-)
                                    http://vimeo.com/88873020#t=240
                                    Z
                                    Z
                                    Zeph
                                    #77
                                    The spiel on The Thing System about having "magic" in place of user visible control raises my caution flags. It remind me of the frustrations that Microsoft's software sometimes generates - when what you want it to do matches what they expected you to want, it automagically just does it behind the scenes and you say "wow, cool" -- but when you step off the paved path and want to do something different, the branbles can become very complex and difficult if not impossible.
                                    So if your water leak detector activates, the system should "just know" what the most appropriate actions are - without the user needing to specify or configure or any of that difficult stuff. But in many decades of dancing with computers, the software has never (in any complex system) done exactly what I want. I don't trust that there is one size that fits all when it comes to "automagically" doing what I want, that adapts to all varieties of systems and all preferences. I need the option (1) to clearly know what actions will be triggered by some event by default, and (2) to be able to override or customize that action.
                                    The Ignite video "the Trouble with Things" linked from their site does not inspire confidence. They show a wireless keyboard television control and a three button remote control and suggest that the latter is much to be preferred. Yeah, I love using up/down/left/right screen keyboards for finding youtube videos, it's so much more intuitive than typing.
                                    When I worked on dedicated word processor systems many years ago, we used to talk about the need for a DWIM button on the keyboard (Do What I Mean). But at least we knew that we were joking. I'm not sure TTS knows when they are blowing smoke in thinking they can design some kind of hidden smarts that magically and accurately does what the user means.
                                    I am much more interested in user interfaces where the effort has been making complex things clear to understand and easy to control, than those that think they know what I need better than I do and want me not to worry my pretty little head about what they are going to do or how on my behalf.
                                    (And I do get that their target market is not people who are willing to solder together and program their own wireless sensor network. They want to attract people who want home automation to be as easy as using a microwave oven or driving a go-kart. But I've seen misguided and arrogant implementations of DWIM frustrate and confuse non-technical users many, many times as well).
                                    That said, they may come up with something worthwhile in some niches. But my warning flags are up.
                                    • Z Zeph
                                      bjornhallbergB
                                      bjornhallbergB
                                      bjornhallberg
                                      @Zeph Yeah, it almost seems like a trend these last couple of years. I agree completely with what you say. I don't know how or why this came about, perhaps we are all experiencing the consequences of the Iphone boom and all that it ushered in. Windows 8, Windows Phone and even Android seem to be creeping towards this goal. A desire to reach out to tech illiterate people (and ultimately profit from them).
                                      I just realized it's hard not to sound like a complete elitist though when talking about these things. Haha.
                                      "Magic" wouldn't be so bad if it just didn't strip away user control and choice, dumbing things down, but it always seems to be the case. Like it is some ideological tenet. I can't shake the feeling that more often than not (in the case of Microsoft for instance) there are murkier reasons for doing what they do. Just like with the rise of "the cloud". takes off tinfoil hat
                                        A Former User
                                        A little late to the thread here, but as I'm constantly looking at open source automation software, thought I'd chip in.
                                        My first forays into HA were with an RFXTRX and domotiga - it's a great system with plenty of interfaces. The downside for me was that it needs (maybe doesn't any more) a linux host to run the UI - I use a windows PC and the extra step of having to run a Linux VM to make any changes got in the way.... that said the vast number of options gave me a lot of ideas about what and how I want to automate things.
                                        I spent around 18 months running AgoControl - I was impressed with this from the outset, and persevered for sometime with it's quirky interface (web gui isn't intuitive for building scenes and doesn't resize for tablet/mobiles). The deal breaker recently for me was one of reliability - I found the RPi needed to be rebooted every 4-5 days due to a memory leak issue with the AMPQ engine, a daily cron reboot of the RPi seemed to improve things, but then for some reason certain events wouldn't reload. I think (not sure) there were some issues with the openzwave wrapper which caused a few issues and slowness with the response times. The second issue I had was that the majority of the plugins are written in perl, which seemed to dramatically slow down the system when more than a couple were running.
                                        I haven't given up on it - I still have an RPi set aside for AgoControl, and will look into it again when I have more time.
                                        It was time to investigate issues which led me to purchase a veralite a couple of months ago, and while not in itself not quirky (multiple lua restarts needed to pick up changes etc), it has been faultlessly reliable in that two months.
                                        I have looked at OpenHAB, it's vast number of interfaces (bindings?) and mature looking interface being the appeal. Unfortunately, despite being technically minded, I'm not a hardcore developer - and having looked at the documentation for OpenHAB, it looks hellishly complicated just to set up, let alone build scenes and so on for.
                                        I've also played around with NodeRed and a few jeenodes and am considering/planning to use nodered and the mqtt gateway for mysensors to re-use some of the code I built to send sensor data to emoncms.org.
                                        Cheers
                                        James
                                        • A
                                          A
                                          andriej
                                          Domoticz crew is looking for someone to implement (in C++) the MySensors api/gateway…
                                          Here's the ticket if anyone is interested.
