  3. WITH_LEDS_BLINKING - for gateways only?
5 Posts 4 Posters 2.2k Views 1 Watching
  • stevebusS
    stevebusS
    stevebus
    Hi all,
    For some of my sensors that are fully powered (as opposed to battery powered ones), I'd like to get quick and dirty visual confirmation that they are sending and receiving data. I'm trying to use the WITH_LEDS_BLINKING functionality. But the behavior I'm seeing that transmit never comes on, and receive seems to come on at unrelated and random times. It occurs to me that functionality may be intended for gateways only and tied to some gateway specific functionality. Is that the case? I figured I'd ask before I go digging around in the code to see why they aren't working for me...
    thanks,
    --Steve
    Vera Edge/UI7; mysensors; Arduino's and RPIs; data posted to Azure for an IoT 'dashboard' of my house
    Opinions expressed here are my own and do not necessarily reflect Microsoft's feelings on a given topic :-)
      Hmm..strange, it should work. A Gateway or Sensor should work the same way when it comes to radio transmits/reads.. Feel free to dig.
      • stevebusS
        stevebusS
        stevebus
        Ok, will do... my experience is that TX never blinked at all, and RX seemed to come on for about 20-30 seconds out of every minute. but I'll try to troubleshoot some more when I have time.
        • ServerovS
          ServerovS
          Serverov
          Hi all!
          In my case the LEDs do not blink on sensor nodes when I use a gw.sleep(xxx) function in the sketch. Still don't know why its happening.
          (MySensors v1.5)
          • H
            H
            HarryDutch
            MySensors 1.5.1
            Controller: Domoticz
            I'm using a simpel test sensor with the "blinking led's" to find "dead zones" in my house. The "blinking led's" are a big help for this and works flawlessly all the time.
            #define CHILD_ID_BUTTON 0        //pushbutton attached to interrupt 0 (= pin 2).
            #define CHILD_ID_LED 1           //LED that is switch on/off by the controller (Domoticz).
            MyMessage msg(CHILD_ID_LED, V_LIGHT);
            MyMessage msg2(CHILD_ID_BUTTON, V_STATUS);
            byte firstTime = 1;     //make sure that the mcu is going to sleep for the first time (no loop)
            gw.begin(incomingMessage);
            gw.sendSketchInfo("Test sensor","1.0");
            gw.present(CHILD_ID_LED, S_LIGHT);
            gw.present(CHILD_ID_BUTTON, S_BINARY);
            pinMode(2, INPUT_PULLUP);        //interrupt = 0;
            pinMode(7, OUTPUT);              //LED is attached to pin 7
            digitalWrite(7, LOW);            //make sure that the LED is off
              if(firstTime == 0) {
                gw.process();
                gw.send(msg2.set(1)); // send to controller a message that the button has been pushed. The controller then swithes the LED on (incomingMessage)
                gw.wait(2000);
                if(digitalRead(7) == HIGH) digitalWrite(7, LOW); // switch the LED off after 2 seconds
                gw.send(msg.set(0)); // let the controller know that the mcu has switched off the LED
                gw.wait(2000);
              firstTime = 0;
              gw.sleep(0,FALLING); // go to sleep and wait for the next button push
                if (message.getInt() == 1) digitalWrite(7, HIGH);
