  3. ESP8266 WiFi gateway port for MySensors
328 Posts 56 Posters 398.0k Views 39 Watching
  • P Pseudomizer
    Thanks a lot. This version provides much more details but at this stage of my learning progress I am not able to understand all those registers where I have to rely on your help guys. I assume that my password is not being exposed here.
    ESP8266 MySensors Gateway
    Connecting to ZEUS
    scandone
    f 0, scandone
    .add 0
    aid 1
    pm open phy_2,type:2 0 0
    cnt
    connected with ZEUS, channel 6
    dhcp client start...
    ......ip:192.168.1.222,mask:255.255.255.0,gw:192.168.1.1
    .Connected!
    IP: 192.168.1.222
    write_register(0x04,0x5F)
    write_register(0x06,0x23)
    write_register(0x06,0x03)
    write_register(0x00,0x0E)
    write_register(0x07,0x70)
    write_register(0x05,0x4C)
    STATUS 0x0E RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
    RX_ADDR_P0-1 0x0E0E0E0E0E 0707070707
    RX_ADDR_P2-5 0xFF C4 C5 C6
    TX_ADDR 0x0E0E0E0E0E
    RX_PW_P0-6 0x00 00 20 00 00 00
    EN_AA 0x3B
    EN_RXADDR 0x07
    RF_CH 0x4C
    RF_SETUP 0x03
    CONFIG 0x0E
    DYNPD/FEATURE 0x3F 06
    Data Rate 1MBPS
    Model nRF24L01+
    CRC Length 16 bits
    PA Power PA_LOW
    write_register(0x01,0x3F)
    write_register(0x01,0x3B)
    write_register(0x1D,0x06)
    FEATURE=0x06
    write_register(0x1C,0x3F)
    ets Jan 8 2013,rst cause:4, boot mode:(3,7)
    wdt reset
    load 0x4010f000, len 1264, room 16
    tail 0
    chksum 0x42
    csum 0x42
    ~ld
    Connecting to ZEUS
    scandone
    f 0, scandone
    .add 0
    aid 1
    cnt
    .Connected!
    IP: 192.168.1.222
    EN_AA 0x3B
    EN_RXADDR 0x07
    RF_CH 0x4C
    RF_SETUP 0x03
    CONFIG 0x0E
    Data Rate 1MBPS
    Model nRF24L01+
    CRC Length 16 bits
    PA Power PA_LOW
    FEATURE=0x06
    wdt reset
    tail 0
    chksum 0x42
    csum 0x42
    ~ld
    YveauxY
    YveauxY
    @Pseudomizer just had a quick look at your results. Radio config (and this communication) seem to be OK, but it restarts due to watchdog timeout.
    Hopefully tonight I can have a better look.
      miguelingles
      when I put the development package I can not compile anything (all gives me error). I tried it with a clean install and nothing.
      I think the problem is the IRQ pin DIØØ , if the ESP cpu does not recognize this interruption when the RF module receives data is unable to apply for the request .
      YveauxY 1 Reply Last reply
      • M miguelingles
        YveauxY
        YveauxY
        The irq pin from the nrf24 stays unconnected, like the build instructions clearly state!
          miguelingles
          but RF69 need irq.
          • M miguelingles
            but RF69 need irq.
            YveauxY
            YveauxY
            @miguelingles didn't know you were talking about rf69... Sorry but I cannot keep track of what everyone is using.
            • P Pseudomizer
              The only changes to the sketch are the SSID, the pass and the debug line
              Serial.setDebugOutput(true);
              as instructed. No other changes were made.
              Here the the debug output....you will see multiple resets in a row based on the internal watchdog timer.
              Connecting to MYWIFI
              scandone
              f 0, scandone
              .add 0
              aid 1
              cnt
              connected with MYWIFI, channel 6
              .Connected!
              IP: 192.168.1.222
              ets Jan 8 2013,rst cause:4, boot mode:(3,6)
              wdt reset
              tail 0
              chksum 0x42
              csum 0x42
              ~ld
              scandone
              f 0, scandone
              .add 0
              aid 1
              cnt
              .......ip:192.168.1.222,mask:255.255.255.0,gw:192.168.1.1
              .Connected!
              IP: 192.168.1.222
              wdt reset
              tail 0
              chksum 0x42
              csum 0x42
              ~ld
              scandone
              f 0, scandone
              .add 0
              aid 1
              cnt
              .Connected!
              IP: 192.168.1.222
              YveauxY
              YveauxY
              #126
              For everyone wondering what serial output during startup of the ESP8266-NRF24 gateway should look like (all captures taken using link development branch from Oct 6, 2015 (hek just merged gateway-refactoring this morning, so output might have slightly changed)) .
              WiFi startup comes first after reset, followed by MySensors (nRF24) startup:
              • WiFi startup (not using Serial.setDebugOutput(true) )
              Connecting to YOUR_SSID
              ...........Connected!
              IP: 192.168.1.101
              • WiFi startup (using Serial.setDebugOutput(true) )
              scandone
              f 0, ....scandone
              .add 0
              aid 10
              cnt
              connected with YOUR_SSID, channel 1
              .....ip:192.168.1.101,mask:255.255.255.0,gw:192.168.1.1
              .Connected!
              IP: 192.168.1.101
              • MySensors startup (not using DEBUG and MY_DEBUG_VERBOSE)
              • MySensors startup (using DEBUG and MY_DEBUG_VERBOSE)
              write_register(0x06,0x27)
              write_register(0x06,0x07)
              write_register(0x00,0x0C)
              RX_ADDR_P0-1	0x0E0E0E0E0E 0303030303
              RX_ADDR_P2-5	0xC3 C4 C5 C6
              RX_PW_P0-6	0x00 00 00 00 00 00
              EN_AA		0x3F
              EN_RXADDR	0x03
              RF_CH		0x4C
              RF_SETUP	0x07
              CONFIG		0x0E
              DYNPD/FEATURE	0x00 00
              Data Rate	1MBPS
              Model		nRF24L01+
              CRC Length	16 bits
              PA Power	PA_MAX
              FEATURE=0x06
              write_register(0x1C,0x03)
              FEATURE=0x06
              write_register(0x13,0x20)
              write_register(0x02,0x07)
              write_register(0x11,0x20)
              write_register(0x12,0x20)
              write_register(0x00,0x0F)
              write_register(0x02,0x06)
              • P Pseudomizer
                Connecting to ZEUS
                scandone
                f 0, scandone
                .add 0
                aid 1
                cnt
                .Connected!
                IP: 192.168.1.222
                EN_AA 0x3B
                EN_RXADDR 0x07
                RF_CH 0x4C
                RF_SETUP 0x03
                CONFIG 0x0E
                Data Rate 1MBPS
                Model nRF24L01+
                CRC Length 16 bits
                PA Power PA_LOW
                FEATURE=0x06
                wdt reset
                tail 0
                chksum 0x42
                csum 0x42
                ~ld
                Connecting to ZEUS
                scandone
                f 0, scandone
                .add 0
                aid 1
                cnt
                .Connected!
                IP: 192.168.1.222
                EN_AA 0x3B
                EN_RXADDR 0x07
                RF_CH 0x4C
                RF_SETUP 0x03
                CONFIG 0x0E
                Data Rate 1MBPS
                Model nRF24L01+
                CRC Length 16 bits
                PA Power PA_LOW
                FEATURE=0x06
                wdt reset
                tail 0
                chksum 0x42
                csum 0x42
                ~ld
                YveauxY
                YveauxY
                @Pseudomizer Had a better look at your crashdump.
                Your ESP seems to crash with a watchdog timeout when MySensors is setting the datarate (or shortly after that) after nRF24 has been initialized.
                Default datarate is RF24_250KBPS.
                Some questions, trying to rule things out:
                • Do you use this default datarate?
                • Could it be that you have an nRF24L01+ clone, which in reality is a nRF24L01 (clone)?
                • Did you ever try and succeed to connect these radios to a regular Arduino?
                • Are all radio's from the same batch/order?
                • P
                  P
                  Pseudomizer
                  I tried multiple different data rates when I created the ethernet gateway from mysensors. It didn't work at all in terms of connecting the sensors to the gateway while the gateway was visible in Vera until I made them all the same data rate. If I recall correctly I got them working with both at 250kpbs or 1Mbps.
                  Since I tried to build the wifi gateway I haven't checked the data rates. I am going to check this next.
                  In regards to your other questions:
                  I purchased 4 radios from Amazon:
                  http://www.amazon.com/nRF24L01-Wireless-Transceiver-Arduino-Compatible/dp/B00E594ZX0/ref=cm_cr_pr_product_top?ie=UTF8
                  Yes, those radios work totally fine with the ethernet gateway from mysensors and I had two sensors attached. My goal is to have a wireless gateway so I can place it anywhere in the house and your great work would enable me to do so. ;-)
                  • P
                    P
                    Pseudomizer
                    Thinking about the data rate... at the moment I don't have any other sensors powered on at all which means I am just installing the wifi gateway. There should be no mismatch in the data rates unless I would have at least one sensor with a different data rate causing the issue. The Wifi gateway should boot up successfully without any client sensor.
                    Is my thinking correct?
                      miguelingles
                      @Yveaux said:
                      y but I
                      it,s works !!!!! you have to do is remove the DIO0 while Bots and put it quickly . If not removed DIO0 not start.
                      • P
                        P
                        Pseudomizer
                        I have done EXTENSIVE testing and I got it working now but I don't understand why.
                        It seems like my MyConfig.h is broken which is the one which I copied over from your development package. I used one of my MyConfig.h files and the module boot was successfull and it did not crash anymore. It is stable and fully integrated into Vera with sensors now.
                        I also tested the different data rates. I tested 250KBPS and 1MBPS and both work fine as long as I configure the gateway and the sensor clients with the same data rate. If I use different data rates between client and gateway, the gateway does NOT crash but the sensor clients simply don't connect.
                        Now I have a working MyConfig.h and a broken MyConfig.h. Here is the WORKING MyConfig.h file.
                        #ifndef MyConfig_h
                        #define MyConfig_h
                        #include <stdint.h>
                        // Enable debug flag for debug prints. This will add a lot to the size of the final sketch but good
                        // to see what is actually is happening when developing
                        //#define DEBUG
                        //#define MY_DEBUG_VERBOSE
                        // Disable this line, If you are using TX(1), RX(0) as normal I/O pin
                        #define ENABLED_SERIAL
                        // Serial output baud rate (for debug prints and serial gateway)
                        #define BAUD_RATE 115200
                        *  Over the air firmware updates
                        // The following define enables the safe over-the-air firmware update feature
                        // which requires external flash and the DualOptiBoot bootloader.
                        // Note: You can still have OTA FW updates without external flash but it
                        // requires the MYSBootloader and disabled MY_OTA_FIRMWARE_FEATURE
                        //#define MY_OTA_FIRMWARE_FEATURE
                        // Slave select pin for external flash
                        #define MY_OTA_FLASH_SS 8
                        // Flash jdecid
                        #define MY_OTA_FLASH_JDECID 0x1F65
                        *  Information LEDs blinking
                        // This feature enables LEDs blinking on message receive, transmit
                        // or if some error occured. This was commonly used only in gateways,
                        // but now can be used in any sensor node. Also the LEDs can now be
                        // disabled in the gateway.
                        // #define WITH_LEDS_BLINKING
                        // The following setting allows you to inverse the blinking feature WITH_LEDS_BLINKING
                        // When WITH_LEDS_BLINKING_INVERSE is enabled LEDSs are normally turned on and switches
                        // off when blinking
                        //#define WITH_LEDS_BLINKING_INVERSE
                        // default LEDs blinking period in milliseconds
                        #define DEFAULT_LED_BLINK_PERIOD 300
                        // The RX LED default pin
                        #define DEFAULT_RX_LED_PIN 6
                        // The TX LED default pin
                        #define DEFAULT_TX_LED_PIN 5
                        // The Error LED default pin
                        #define DEFAULT_ERR_LED_PIN 4
                        *  Message Signing Settings
                        // Disable to completly disable signing functionality in library
                        //#define MY_SIGNING_FEATURE
                        // Define a suitable timeout for a signature verification session
                        // Consider the turnaround from a nonce being generated to a signed message being received
                        // which might vary, especially in networks with many hops. 5s ought to be enough for anyone.
                        #define MY_VERIFICATION_TIMEOUT_MS 5000
                        // Enable to turn on whitelisting
                        // When enabled, a signing node will salt the signature with it's unique signature and nodeId.
                        // The verifying node will look up the sender in a local table of trusted nodes and
                        // do the corresponding salting in order to verify the signature.
                        // For this reason, if whitelisting is enabled on one of the nodes in a sign-verify pair, both
                        // nodes have to implement whitelisting for this to work.
                        // Note that a node can still transmit a non-salted message (i.e. have whitelisting disabled)
                        // to a node that has whitelisting enabled (assuming the receiver does not have a matching entry
                        // for the sender in it's whitelist)
                        //#define MY_SECURE_NODE_WHITELISTING
                        // MySigningAtsha204 default setting
                        #define MY_ATSHA204_PIN 17 // A3 - pin where ATSHA204 is attached
                        // MySigningAtsha204Soft default settings
                        #define MY_RANDOMSEED_PIN 7 // A7 - Pin used for random generation (do not connect anything to this)
                        // Key to use for HMAC calculation in MySigningAtsha204Soft (32 bytes)
                        #define MY_HMAC_KEY 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
                        *  NRF24L01 Driver Defaults
                        #define RF24_CE_PIN		   9
                        #define RF24_CS_PIN		   10
                        #define RF24_PA_LEVEL 	   RF24_PA_MAX
                        #define RF24_PA_LEVEL_GW   RF24_PA_LOW
                        // RF channel for the sensor net, 0-127
                        #define RF24_CHANNEL	   76
                        //RF24_250KBPS for 250kbs, RF24_1MBPS for 1Mbps, or RF24_2MBPS for 2Mbps
                        //#define RF24_DATARATE 	   RF24_1MBPS
                        #define RF24_DATARATE 	   RF24_250KBPS
                        // This is also act as base value for sensor nodeId addresses. Change this (or channel) if you have more than one sensor network.
                        #define RF24_BASE_RADIO_ID ((uint64_t)0xA8A8E1FC00LL)
                        // Enable SOFTSPI for NRF24L01 when using the W5100 Ethernet module
                        //#define SOFTSPI
                        #ifdef SOFTSPI
                        	// Define the soft SPI pins used for NRF radio
                        	const uint8_t SOFT_SPI_MISO_PIN = 16;
                            const uint8_t SOFT_SPI_MOSI_PIN = 15;
                            const uint8_t SOFT_SPI_SCK_PIN = 14;
                        *  RFM69 Driver Defaults
                        // Default network id. Use the same for all nodes that will talk to each other
                        #define RFM69_NETWORKID     100
                        // Default frequency to use. This must match the hardware version of the RFM69 radio (uncomment one):
                        // #define RFM69_FREQUENCY   RF69_433MHZ
                        #define RFM69_FREQUENCY   RF69_868MHZ
                        //#define FREQUENCY     RF69_915MHZ
                        // Enable this for encryption of packets
                        //#define RFM69_ENABLE_ENCRYPTION
                        #define RFM69_ENCRYPTKEY    "sampleEncryptKey" //exactly the same 16 characters/bytes on all nodes!
                        And here is the NON WORKING MyConfig.h file.
                        #ifndef MyConfig_h
                        #define MyConfig_h
                        #include <stdint.h>
                        #define DEBUG
                        // Enable MY_DEBUG_VERBOSE flag for verbose debug prints. Requires DEBUG to be enabled.
                        // This will add even more to the size of the final sketch!
                        // Flash jdecid
                        //#define SOFTSPI
                        #ifdef SOFTSPI
                        I don't understand why the second one makes the module reboot constantly. However, I am happy now that it is working but I wanted to share my experience and maybe it can help others to troubleshoot this and understand why this was happening as I am sure I will not be the only one having that issue in the future.
                        I do appreciate all the help so far and I wouldn't have been able to solve it without your help Yveaux. THANK YOU!!!
                          You cannot mix MyConfig.h between branches.
                          In the development brach all MySensors related defines has the prefix "MY_".
                          • Frank HerrmannF
                            Frank HerrmannF
                            Frank Herrmann
                            Hi, if it possible to show a sketch with an ESP8266 WIFI => MQTT gateway? I figure out, that the received sensor data will automatic publish to my MQTT Server running on my Raspi. Then i can install this pice of wonderfull work in every room from my house :)
                              I created a simple ESP-MQTT sketch a while ago. I've only done some simple tests using it. Feedback appreciated.
                              https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/GatewayESP8266MQTTClient/GatewayESP8266MQTTClient.ino
                              Frank HerrmannF FotoFieberF V 3 Replies Last reply
                                Frank HerrmannF
                                Frank HerrmannF
                                Frank Herrmann
                                wrote on last edited by Frank Herrmann
                                #135
                                @hek Very nice! the code are magic :) Very nice solution, i'll test this next days.
                                #include <ESP8266WiFi.h>
                                void presentation() {
                                  // Send locally attech sensors data here
                                  FotoFieberF
                                  FotoFieberF
                                  FotoFieber
                                  Testing the above sket from the development branch with a new sensbender micro I get:
                                  mygateway/255/255/3/0/3 (null) on MQTT
                                  This is an id request. I answer this request with
                                  mosquitto_pub -h ds -t "mygateway/255/255/3/0/4" -m 8
                                  which should set the ID 8 on the sensbender micro in my undestanding. I can see the message in the serial terminal on the ESP-8266 but the message doesn't arrive at the sensbender micro.
                                  Is my message to set the id correct?
                                    Yes, the response message looks ok. But I must confess that I haven't verified the MQTT gateway much yet. Probably something I've missed (=bug).
                                    Do you have the possibility to to see where the message ends up or being thrown away (debug-print-debugging is awesome, yes I know...) in the MQTT gateway?
                                    Or wait a few days until I've had time to look at it.
                                    FotoFieberF 1 Reply Last reply
                                      FotoFieberF
                                      FotoFieberF
                                      FotoFieber
                                      There seems to be a bug in incomingMQTT:
                                      replace
                                      for (str = strtok_r(topic, "/", &p); str && i < 5;
                                      with
                                      for (str = strtok_r(topic, "/", &p); str && i <= 5;
                                      or it will never send a message.
                                      There seems to be another problem:
                                      0;0;3;0;9;send: 0-0-0-255 s=255,c=3,t=4,pt=0,l=1,sg=0,st=fail:8
                                      Why is the payload in st=fail?
                                      The messages sent to MQTT seem to make a merry go round and come back.... :)
                                        The payload (8) seems correct. Gateway just never received any ack from node... which is fine for broadcast messages (to node 255) such as this.
                                        Ok, like you suspected earlier? So we need to subscribe to something else than we publish to then...
                                          FotoFieberF
                                          FotoFieberF
                                          FotoFieber
                                          @hek
                                          Loaded the ethernet ESP-8266 gateway and entered with telnet:
                                          255;255;3;0;4;8
                                          It is working as it should. Now I have assigned the id 8.
                                          Tried to solve the merry go round but it didn't help. Now I let the stage to the pros.. :)
