  3. ESP8266 WiFi gateway port for MySensors
328 Posts 56 Posters 398.0k Views 39 Watching
  • F
    F
    Fabien
    Do you think we can use this board with MySensors (with NRF24 or RFM69) ?
    https://github.com/hallard/NodeMCU-Gateway
      Mike Cayouette
      If I want to use the GatewayESP8266MQTTClient sketch located in the development branch do I also need to use the mysensors libraries in that branch?
      Thank you,
      Mike
      hekH 1 Reply Last reply
      • M Mike Cayouette
        Thank you,
        Mike
        @Mike-Cayouette
        Yes
          I created a simple ESP-MQTT sketch a while ago. I've only done some simple tests using it. Feedback appreciated.
          https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/GatewayESP8266MQTTClient/GatewayESP8266MQTTClient.ino
          V
          V
          vickey
          wrote on last edited by vickey
          #144
          @hek Thanks for the code. I have few questions in my mind. Firstly do I just have to upload this ESP8266MQTTClient.ino sketch on esp8266 12-E model? or does it needs anything to add in the sketch except SSID and password? I want to use ESP-8266-E and NRF24L01+ as gateway for openhab. If it is possible then, do I have to adopt the same procedure for configuring openhab as ethernet gateway? Secondly, Can I make two gateways using this sketch, is this possible? As I want to add sensors which are 500 meters away at my farmhouse.
          • J
            J
            joshmosh
            This is a bit off topic, but hopefully not too off ;-)
            What about a port of the MySensors library /API to ESP8266 ? Instead of two "boards" (Arduino nano plus nRF24L01+) only one would be required. For simple sensors an ESP-01 would be sufficient - about the size of a nRF24, but with much more muscle than an Arduino. Of course, running off a battery probably would not work because of the high power consumption of the ESP.
            Or am I asking for something which is already possible ?
            Josh
            • V vickey
              Yes
              Entering SSID/PW should be enough.
              I'm not an expert on openhab.. so I'll let someone else answer this one. But the ESP variant behaves exactly like the W5100 version.
              If openhab supports multiple gateways, sure. But you might wanna run sensor networks on different frequencies or changing MY_RF24_BASE_RADIO_ID.
              @joshmosh
              Yes, the code runs directly on the ESP8266.
              • J
                J
                joshmosh
                @hek
                that's good news, thank you ! Now the most expensive part will be the power supply ;-)
                Cheers
                Josh
                • V
                  V
                  vickey
                  #148
                  @hek I have installed GatewayESP8266MQTTClient sketch on my ESP-8266 12E.
                  Here is sketch I am using
                  #include <EEPROM.h>
                  #define MY_BAUD_RATE 9600
                  // Set this nodes topic prefix
                  #define MY_MQTT_TOPIC_PREFIX "mygateway"
                  // Set MQTT client id
                  //#define MY_MQTT_USER "admin"
                  //#define MY_MQTT_PASSWORD "MyPassword"
                  // Set WIFI SSID and password
                  #define MY_ESP8266_SSID "Ahmed"
                  #define MY_ESP8266_PASSWORD "MyPassword"
                  #define MY_IP_ADDRESS 192,168,0,31
                  #define MY_IP_GATEWAY_ADDRESS 192,168,0,1
                  // MQTT broker ip address.
                  #define MY_CONTROLLER_IP_ADDRESS 192, 168, 0, 30
                  #define MY_PORT 1883
                  // Flash leds on rx/tx/err
                  #define MY_LEDS_BLINKING_FEATURE
                  // Set blinking period
                  // Enable inclusion mode
                  #include <ESP8266WiFi.h>
                  void presentation() {
                    // Send locally attech sensors data here
                  Here is the debug
                  0;0;3;0;9;Starting...
                  scandone
                  f 0, ....scandone
                  state: 0 -> 2 (b0)
                  .state: 2 -> 3 (0)
                  state: 3 -> 5 (10)
                  add 0
                  aid 1
                  cnt
                  connected with Ahmed, channel 1
                  ip:192.168.0.31,mask:255.255.255.0,gw:192.168.0.1
                  .IP: 192.168.0.31
                  0;0;3;0;9;Attempting MQTT connection...
                  And it keeps attempinng for MQTT connection.
                  I have installed Domoticz on my RPi and added a hardware Mysensors Gateway with LAN interface with remote address i.e. 192.168.0.31 in my case and port 1883. Here is Domoticz log
                  2015-10-17 12:50:26.675  Hardware Monitor: Fetching data (System sensors)
                  2015-10-17 12:50:31.590  Error: MySensors: Error: Connection refused
                  2015-10-17 12:50:31.590  Error: TCP: Error: Connection refused
                  I don't have mosquitto installed in my Rpi.
                  May someone suggest me any solution.
                  • J
                    J
                    joshmosh
                    @hek
                    Good morning. I had wired up my nodemcu a nRF24L01+, loaded the gateway sketch and bingo ! Zero problems, works like charm. Thanks a lot !!!
                    I am using Domoticz as controller, with a serial USB gateway to connect my various sensors. In the serial console of the ESP8266 gateway I see that the messages of my sensors show up, but since I have not yet announced the gateway to Domoticz, there seems to be no interference. If I connect the ESP8266 gateway to a controller (in my case Domoticz), I guess that it will be required that the nodes need to choose the respective gateway (by using the parentNodeId) with which they like to communicate ? Currently, I am using parentNodeId = AUTO in all my nodes.
                    I will do some testing to get an idea of the reach of my WiFi compared to the reach of my serial USB gateway (I have a nRF24L01+ with external antanna and booster in my gateway, so I am able to "see" a portable node even outside my house and 50 m away.
                    Again, thank you for this very useful extension of MySensors. I think I have not yet an estimate of the full potential of it
                    Cheers
                    Josh
                    YveauxY 1 Reply Last reply
                    • G
                      G
                      gloob
                      I also tried to build a WiFi gateway today.
                      I get the following serial output when starting the gateway:
                      ESP8266 MySensors Gateway
                      Connecting to *************
                      ...Connected!
                      IP: 192.168.1.218
                      Does this mean that everything is correct and I can integrate it into my FHEM solution?
                      Currently I'm working with a serial gatway. Do I have to modify something in my sensors when I switch to the new gateway?
                      • G gloob
                        ...Connected!
                        IP: 192.168.1.218
                        YveauxY
                        YveauxY
                        Looking good! Congrats!
                        I have no experience using FHEM, but you should be able to use the WiFi gateway just like the regular ethernet gateway (as seen from FHEM).
                        So look around on this forum for any posts regarding usage of FHEM & ethernet gateway and you should be good.
                        • J joshmosh
                          @hek
                          Cheers
                          Josh
                          YveauxY
                          YveauxY
                          @joshmosh You cannot have multiple gateways in a single MySensors network. The node-ID of the gateway is always hardcoded to 0.
                          If you want to run multiple networks, each should have a unique RF24_CHANNEL & RF24_BASE_RADIO_ID combination. For best results make sure to have a separate RF24_CHANNEL for each network, and don't use directly adjacent channels.
                          J 1 Reply Last reply
                          • FotoFieberF
                            FotoFieberF
                            FotoFieber
                            Playing with AES signing and encryption I enabled verbose debug.
                            #define MY_DEBUG_VERBOSE
                            The sketch crashes with this setting but seems to work fine without verbose debug.
                            Is this a problem of my setup or a problem in the code?
                            The log pf the serial terminal:
                            write_register(0x04,0x5F)
                            write_register(0x06,0x27)
                            write_register(0x06,0x07)
                            write_register(0x00,0x0C)
                            write_register(0x07,0x70)
                            write_register(0x05,0x4C)
                            write_register(0x00,0x0E)
                            STATUS		0x0E RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
                            RX_ADDR_P0-1	0x0E0E0E0E0E 0303030303
                            RX_ADDR_P2-5	0xC3 C4 C5 C6
                            TX_ADDR		0x0E0E0E0E0E
                            RX_PW_P0-6	0x00 00 00 00 00 00
                            EN_AA		0x3F
                            EN_RXADDR	0x03
                            RF_CH		0x4C
                            RF_SETUP	0x07
                            CONFIG		0x0E
                            DYNPD/FEATURE	0x00 00
                            Data Rate	1MBPS
                            Model		nRF24L01+
                            CRC Length	16 bits
                            PA Power	PA_MAX
                            write_register(0x01,0x3F)
                            write_register(0x01,0x3B)
                            write_register(0x1D,0x06)
                            FEATURE=0x06
                            write_register(0x1C,0x03)
                            write_regis
                            • FotoFieberF FotoFieber
                              EN_AA		0x3F
                              EN_RXADDR	0x03
                              RF_CH		0x4C
                              RF_SETUP	0x07
                              CONFIG		0x0E
                              Data Rate	1MBPS
                              Model		nRF24L01+
                              CRC Length	16 bits
                              PA Power	PA_MAX
                              FEATURE=0x06
                              write_regis
                              YveauxY
                              YveauxY
                              I'll opt for the first, but lets see:
                              • What ESP hardware are you using?
                              • Which Arduino/ESP8266 port/MySensors version are you using?
                              • Did you define both DEBUG and MY_DEBUG_VERBOSE?
                              • What did you do to 'Play with AES signing and encryption' ?
                              • AES stuff is untested for ESP8266, however, you don't seen to get that far as it crashes during startup.
                              • My startup log (see here ) shows what it shoes during startup with DEBUG and MY_DEBUG_VERBOSE enabled.
                              FotoFieberF 1 Reply Last reply
                              • YveauxY Yveaux
                                FotoFieberF
                                FotoFieberF
                                FotoFieber
                                @Yveaux
                                • ESP12E
                                • Development Version
                                • Defined both DEBUG AND VERBOSE
                                • Playing with AES:
                                #define MY_RF24_CHANNEL  13
                                #define MY_RF24_BASE_RADIO_ID ((uint64_t)0xF8A813FC09CL)
                                #define MY_RF24_ENABLE_ENCRYPTION
                                #define MY_RF24_ENCRYPTKEY  secret....
                                #define MY_SIGNING_SOFT // Software signing enabled
                                #define MY_SIGNING_SOFT_SERIAL secret....
                                // Key to use for HMAC calculation in soft signing (32 bytes)
                                #define MY_SIGNING_SOFT_HMAC_KEY secret
                                It seems to work perfect without the verbose debug.
                                I will test now without AES. My gut tells me, I should look inside the AES stuff.
                                • YveauxY Yveaux
                                  J
                                  J
                                  joshmosh
                                  @Yveaux
                                  Thank you for this piece of information - I was not aware of this fact.
                                  My idea was to reduce cost and parts count for sensors by using ESPs instead of nRF plus Arduino. Since I have Domoticz as controller, there is pehaps no need for an additional gateway, because Domoticz can handle TCP-attached sensors. Of course this would require to use WiFi instead of nRF24 as underlying transport for MySensors. My interpretation of some of hek's contributions is that he is working on it for realisation in version 1.6.
                                    @Yveaux
                                    • ESP12E
                                    • Playing with AES:
                                    FotoFieberF
                                    FotoFieberF
                                    FotoFieber
                                    @Yveaux
                                    Downloaded the development branch again and used the sketch included as example. The sketch is hanging too. My gut was wrong, AES is not the problem.
                                    • V
                                      V
                                      vickey
                                      Hi.
                                      I am having an issue with my ESP8266 gateway. I have tried all versions of mysensors including developmental versions, but my esp8266 does not show any serial debug, nor it gets connected to my router. I also enabled debug in configuration file. When I install AT firmware, it replies to AT command, it also works with nodemcu firmware, but it does not respond with Arduino firmware. May someone help me?
                                      • AndurilA
                                        AndurilA
                                        Anduril
                                        wrote on last edited by Anduril
                                        #159
                                        Finally I got my NodeMCU and tried the WiFi gateway too. But I get the following messages (with Serial.setDebugOutput(true);):
                                        Connecting to WLAN
                                        scandone
                                        f 0, ....scandone
                                        .add 0
                                        aid 1
                                        pm open phy_2,type:2 0 0
                                        cnt
                                        ..................rm 0
                                        pm close 7 0 0/9299504
                                        ..reconnect
                                        f -240, ....scandone
                                        no WLAN found, reconnect after 1s
                                        .reconnect
                                        f 0, ....scandone
                                        .add 0
                                        aid 1
                                        cnt
                                        pm close 7 0 0/8288631
                                        ..reconnect
                                        .reconnect
                                        f 0, ....scandone
                                        .add 0
                                        aid 1
                                        cnt
                                        pm close 7 0 0/8124923
                                        ..reconnect
                                        Additionally I tried to use
                                          IPAddress ip(192, 168, 38, 18);  /* Set to whatever IP address you'd like the gateway to have */
                                          WiFi.config(ip);
                                        to avoid DHCP, but that gives error during compiling:
                                        no matching function for call to 'ESP8266WiFiClass::config(IPAddress&)'
                                        Any hints how to solve?
                                        Edit:
                                        to find the problem I tested to connect the ESP to the wifi-hotspot of my smartphone... worked. Is it maybe a problem if the password contain special characters which behave strange during compiling?
                                        • YveauxY
                                          YveauxY
                                          #160
                                          That's a clear indication the ESP cannot connect to your WiFi accesspoint.
                                          Is the SSID matching your accesspoint ('WLAN')?
                                          Is the encryption supported by the ESP (see e.g. https://nurdspace.nl/ESP8266#Features -- not sure if it is accurate)
                                          Weird characters in the password could be problematic (and of course the password is case-sensitive).
                                          Changing between DHCP/Fixed IP won't make a difference here, as the ESP doesn't even connect. IP configuration starts once connected.
                                          AndurilA 1 Reply Last reply
