  3. ESP8266 WiFi gateway port for MySensors
328 Posts 56 Posters 398.0k Views 39 Watching
  • D
    D
    D_dude
    update,
    the error changed to "rst cause:4, boot mode:(3,6)" once i added a capacitor.
    • D D_dude
      Hi @Yveaux
      could you please assist in the error.
      ESP8266 MySensors Gateway
      Connecting to HoUsEoFcLoWnS
      scandone
      f 0, scandone
      .add 0
      aid 5
      pm open phy_2,type:2 0 0
      cnt
      connected with HoUsEoFcLoWnS, channel 11
      dhcp client start...
      .ip:192.168.0.23,mask:255.255.255.0,gw:192.168.0.1
      .Connected!
      IP: 192.168.0.23
       ets Jan  8 2013,rst cause:4, boot mode:(3,7)
      wdt reset
      load 0x4010f000, len 1264, room 16
      tail 0
      chksum 0x42
      csum 0x42
      ~ld
      The gateway just keeps looping and connecting.
      I'm using a NodeMCU with a NRF ( both from ebay),
      Using the Regular library, and default sketch with SSID/pass updated.
      i tried checking the error "rst cause:4, boot mode:(3,7)" but wasn't able to find something.
      I even tried to power it using a USB cellphone charger, but i was unable to telnet so that rules out the power issue
      Thanks in advance
      YveauxY
      YveauxY
      @D_dude said:
      These ESP's seem to walk in mysterious ways...
      A lot of people have them, running without any issues (including myself and hek) and some people can't seem to get them to run stable.
      On the net, a lot of stability/reset issues are are claimed to have a relation to power supply.
      There are a lot of assumptions in this sentence ;-)
      What current rating is the cellphone charger? I'd advise one with at least 1amps, and a stable output.
      Not being able to telnet to the gateway can have more issues then just the ESP crashing...
      D 1 Reply Last reply
      • YveauxY Yveaux
        D
        D
        D_dude
        wrote on last edited by D_dude
        #183
        @Yveaux
        Thank you for the response.
        As for the cell phone charger, I'm using a tablet charger Specifically original HP stream 7 charger, and it is able to provide more that 1amp. I Will try to use other charger/power supply to see if that helps.
        PS: I reloaded the gateway sketch and the error went back to boot mode (3,7) even with cap present.
        YveauxY 1 Reply Last reply
        • D D_dude
          @Yveaux
          YveauxY
          YveauxY
          @D_dude I searched the net for a description of reset causes and boot modes but failed to find one.
          I have no clue of what they mean.
          • YveauxY Yveaux
            D
            D
            D_dude
            @Yveaux
            thank you for your assistance. I will try adding some debug in the code on the weekend to see what exactly is not running and possibly causing crash.
              I got a suggestion here to erase the flash before flashing. Haven't tried it yet, but it might help you @D_dude
              D 2 Replies Last reply
                D
                D
                D_dude
                @mfalkvidd
                Thank you, i will try this and post results.
                  D
                  D
                  D_dude
                  @mfalkvidd
                  tried erasing the flash using the method suggested but doesn't seem to be working for me. same result.
                  Thanks for the tip though.
                    Too bad. Thanks for posting your results.
                    • L
                      L
                      luisgcu
                      here is my ESP8266 wifi gateway installed in wifi repeater box, taking the advantage that its has a 5 volts power supply.
                      • L luisgcu
                        YveauxY
                        YveauxY
                        @luisgcu Nice housing!
                        Thanks for the pics!
                        • sowardS
                          sowardS
                          soward
                          I'd been using the ESP gateway for several weeks, but recently was having trouble adding a new sensor I am developing.
                          Since the copy of dev I built it with was now out of date, I went ahead and updated... still wasn't working right so while I had the serial link to it I checked and noticed it was crashing and cycling. It would work for hours, until I fired up my new node, then crash about immediately. A few dozen debug(PSTR())'s later, I found a cause.
                          In core/MySensorsCore.cpp the result of _msg.getConfig() is dereferenced in a comparison, and it's possible it could return NULL ( like when it's a new node ). I put a check around that and it's not crashing anymore. Which is more than what I can say for my new sensor node....
                          I have not tested this change with an AVR.
                          I submitted PR 264.
                            Great work @soward !
                            • D
                              D
                              D_dude
                              on some basic debugging, seems like my sketch is crashing in setupGateway.
                              infact even adding a print statement, it only prints first 3 chars.
                              My question is setupGateway takes output as an arg, which in turn is a function, should there be some parameters for this function?
                              also "Serial.print(serialBuffer);" does not print anything i added prints above and before and they don't show up either.
                                va_end (args);
                                Serial.print("A1");
                                Serial.print("A2");
                              any suggestions?
                              • D D_dude
                                  va_end (args);
                                  Serial.print("A1");
                                  Serial.print("A2");
                                any suggestions?
                                YveauxY
                                YveauxY
                                #195
                                @D_dude flush the serial output after each print.
                                The ESP will output the serial data in the background while your programm continues and then it crashes.
                                YhtY D 2 Replies Last reply
                                • YveauxY Yveaux
                                  YhtY
                                  YhtY
                                  Yht
                                  I'm getting all the time this:
                                  Connecting to layla
                                  ......Connected!
                                  IP: 192.168.0.102
                                  Then it got stuck so I do reset and getting this in loop:
                                  Connecting to layla
                                  ..Connected!
                                  IP: 192.168.0.102
                                  0;0;3;0;9;radio init fail
                                  Soft WDT reset
                                  ctx: cont
                                  sp: 3ffefe70 end: 3fff00a0 offset: 01b0
                                  stack>>>
                                  3fff0020: 00000000 00000000 3ffeed74 40203665
                                  3fff0030: 0000007f 3ffef074 40205ba0 3ffef080
                                  3fff0040: 40202114 00000001 00000000 40205c10
                                  3fff0050: 6600a8c0 00ffffff 0100a8c0 3ffef074
                                  3fff0060: 3ffe84ac 3ffeee8c 3ffeefb0 4020256b
                                  3fff0070: 3ffe86b8 6600a8c0 00000000 00000000
                                  3fff0080: 3fffdc20 00000000 3ffef06d 40205bde
                                  3fff0090: 00000000 00000000 3ffef080 40100114
                                  <<<stack<<<
                                  ets Jan 8 2013,rst cause:2, boot mode:(3,6)
                                  tail 0
                                  chksum 0x42
                                  csum 0x42
                                  ~ld
                                  • YhtY Yht
                                    Connecting to layla
                                    ......Connected!
                                    IP: 192.168.0.102
                                    Connecting to layla
                                    ..Connected!
                                    IP: 192.168.0.102
                                    Soft WDT reset
                                    ctx: cont
                                    stack>>>
                                    <<<stack<<<
                                    tail 0
                                    chksum 0x42
                                    csum 0x42
                                    ~ld
                                    YveauxY
                                    YveauxY
                                    #197
                                    @Yht 0;0;3;0;9;radio init fail
                                    Means there's something wrong with your nRF communication. The WDT reset following this is normal.
                                    • C
                                      C
                                      ciprian
                                      i have been using wifi gateway with Domoticz controller without any problems until recentely. After the last update to beta version of the controller, the gateway crashes when the controller request gateway version:
                                      Gateway startup complete.
                                      Client 0: 0;0;3;0;2;
                                      Exception (28):
                                      epc1=0x4000bf80 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
                                      ctx: cont
                                      sp: 3ffebf60 end: 3ffec1f0 offset: 01a0
                                      I have tested with telnet client with the same request and it was ok. Then I saw that the request from controller was terminated with only <LF> and not with <CR><LF> and this is why it crashed. I have added the following to the sketch:
                                      •    if (inChar == '\n')
                                            if (inputString[i].string[inputString[i].idx-1] != '\r') { // if the last char is not CR then add it
                                            inputString[i].string[inputString[i].idx++]='\r';
                                            // a command was issued by the client
                                            // we will now try to send it to the actuator
                                      and now it seems to work.
                                      Is this the right way to go?
                                        @ciprian
                                        Are you talking abut this line of code?
                                        https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/core/MyGatewayTransportEthernet.cpp#L194
                                        C 1 Reply Last reply
                                          @ciprian
                                          C
                                          C
                                          ciprian
                                          @hek My code is from GatewayESP8266.ino example in Mysensors 1.5, line 234.
