  3. Understanding the message
7 Posts 3 Posters 2.9k Views 2 Watching
  • D
    D
    diggs
    I have had a read through the general API info and I think I generally understand the message formats, but not sure why my system would always be sending the following string/payload and what it exactly means (think it is from the temp/humidity sensor reading.
    0;0;3;0;9;read: 20-20-0;0;3;0;9;read: 20-20-0
    s=1,c=1,t=0,pt=7,l=5,sg=0:5.0
    The other message is OK which is from the straight temp sensor. That is easy to understand.
    2;0;1;0;0;15.7
    • ch3b7C
      ch3b7C
      ch3b7
      see this post
      D 1 Reply Last reply
      • D
        D
        diggs
        This post is deleted!
        • ch3b7C ch3b7
          see this post
          D
          D
          diggs
          @ch3b7 Thanks for that.
          When reading through the API info, the 0,0,3,0,9 message relates to an internal type message, which I get. However I don't understanding why I seem to get it continually occurring on my serial port when I monitor it (every few minutes). However when I am running MYSController, the only internal message that comes up is when the gate way reboots?
          Wondering why I would see the difference.
          Serial Output
          upload-42ac8319-1db4-4f96-a104-1358e26c81ba
          MYSController Output with only two internal messages
          upload-014b4222-b613-4436-8067-a19fa8755182
          tekkaT 1 Reply Last reply
          • ch3b7C
            ch3b7C
            ch3b7
            @diggs to hide this 0,0,3,0,9 you need disable "#define DEBUG" replace with "//#define DEBUG" in libraries\MySensors\MyConfig.h and then upload sketch again
            • D diggs
              Serial Output
              tekkaT
              tekkaT
              tekka
              @diggs the internal/debug (=I_LOG) messages are filtered from the main tab and displayed in the MySensors Debug tab.
              • D
                D
                diggs
                hi guys
                thanks all for the responses. Tis all clear now and makes sense
