  3. Domoticz
  4. Duplicate Sensors
Duplicate Sensors
5 Posts 3 Posters 2.5k Views 2 Watching
  • D
    D
    diggs
    Not sure if this is a Domoticz or MySensors question, but I seem to get a lot of duplicate sensors in Domoticz. Anyone seen this before and have an idea what it is about or how to stop it. ID's are the same
    upload-c5d83f54-91b8-40ad-9437-736f34b78127
    • AWIA
      AWIA
      AWI
      Domoticz is combining humidity and temperature sensors when both are in the same node. You can just delete the 'not updated' one. The combination rather arbitrary / confusing when you have multiple temperature humidity sensors in one node..
      D 1 Reply Last reply
      • AWIA AWI
        D
        D
        diggs
        @AWI Thanks for the reply. When I first setup the sensors I am sure i deleted those extra ones, but they seem to have come back again for some reason. Is there a way to permanently delete them?
        Will Domoticz always combine the temp and humidity if they are from the one DT22 sensor? Would be good to report and graph them separately
        • F
          F
          fleinze
          I think you could prevent them from coming back when you disable "Accept new Hardware Devices" in the settings-section.
          I habe a similar issue with a power-meter sensor. From time to time a new device appears which is never updated.
          • D
            D
            diggs
            Ok, Thanks. Will give that a try
