  3. Nubie help please
Nubie help please
3 Posts 2 Posters 1.3k Views 1 Watching
  • E
    E
    esawyja
    Hi all,
    When can I find an explanation of the values below please? The 106-106 I take is the nodeid, but what about the -0? , s=1 or s=2, Temperature and Humidity, but what are the c=1, t=0,pt and l-5 values?
    2015-09-25T13:19:37.7152470+02:00 DEBUG MySensors Read: 106-106-0 s=1,c=1,t=0,pt=7,l=5:26.2
    2015-09-25T13:19:37.7228050+02:00 INFO MySensors N106S1 Sensor.Temperature 26.2 -
    2015-09-25T13:19:37.7363030+02:00 DEBUG MySensors Read: 106-106-0 s=2,c=1,t=1,pt=2,l=2:40
    2015-09-25T13:19:37.7410300+02:00 INFO MySensors N106S2 Sensor.Humidity 40
    Thanks!!
    • F
      F
      fleinze
      this message translates to:
      106-106-0: sender of message - last node (when relaying) - destination (0 is gateway)
      s=1: sensor child-id is 1
      c=1: message type presentation
      t=0: subtype temperature
      pt=7: payload-type float
      l=5: length of payload: 5 byte (4 byte float, 1 byte precision)
      other message:
      t=1: subtype humidity
      see also:
      http://www.mysensors.org/download/serial_api_15
      hope this helps
      • E
        E
        esawyja
        Thanks so much, it does help a lot!!
