  3. My Slim 2AA Battery Node
498 Posts 71 Posters 584.5k Views 69 Watching
  • K
    K
    Komaandy
    @m26872
    Hi there,
    im still into troubleshooting, and what i did last was create a "mock up temperatursensor slim node " with this sketch
    , so its really only the node and batteries. But it still freezes :(
    Hardware i use is :
    -Atmega328p 1Mhz bootloader. // Burnt the bootloader with one Arduino UNO as master and another Arduino UNO on which I replaced the Atmega328p as slave // Arduino as ISP // with the latest Arduino IDE (1.8.2)
    • after burning the bootloader on the bare ATMEGA´s i assemble them on the node and transfer the sketch via FTDI232
    Furthermore i use
    -generic Capacitors and restistors ( specs from your BOM)
    • Kuman nRF24L01 batches ( bought like 30 in a bulk once, but other "nonslimnodes" are working)
      -fresh batteries
    Any help is very aprreciated :) :)
    * MockMySensors
    * This skecth is intended to crate fake sensors which register and respond to the controller
    * Barduino 2015, GizMoCuz 2015
    #define MY_NODE_ID 123
    #define RADIO_ERROR_LED_PIN 4  // Error led pin
    #define RADIO_RX_LED_PIN    6  // Receive led pin
    #define RADIO_TX_LED_PIN    13  // the PCB, on board LED
    // Wait times
    #define LONG_WAIT 500
    #define SHORT_WAIT 50
    #define SKETCH_NAME "MockMySensors "
    #define SKETCH_VERSION "v0.5"
    // Define Sensors ids
    /*      S_DOOR, S_MOTION, S_SMOKE, S_LIGHT, S_DIMMER, S_COVER, S_TEMP, S_HUM, S_BARO, S_WIND,
       S_RAIN, S_UV, S_WEIGHT, S_POWER, S_HEATER, S_DISTANCE, S_LIGHT_LEVEL, S_ARDUINO_NODE,
       S_ARDUINO_REPEATER_NODE, S_LOCK, S_IR, S_WATER, S_AIR_QUALITY, S_CUSTOM, S_DUST,
       S_SCENE_CONTROLLER
    ////#define ID_S_ARDUINO_NODE            //auto defined in initialization
    ////#define ID_S_ARDUINO_REPEATER_NODE   //auto defined in initialization
    // Some of these ID's have not been updated for v1.5.  Uncommenting too many of them
    // will make the sketch too large for a pro mini's memory so it's probably best to try
    // one at a time.
    //#define ID_S_ARMED             0  // dummy to controll armed stated for several sensors
    //#define ID_S_DOOR              1
    //#define ID_S_MOTION            2
    //#define ID_S_SMOKE             3
    //#define ID_S_LIGHT             4
    //#define ID_S_DIMMER            5
    //#define ID_S_COVER             6
    #define ID_S_TEMP              7
    //#define ID_S_HUM               8
    //#define ID_S_BARO              9
    //#define ID_S_WIND              10
    //#define ID_S_RAIN              11
    //#define ID_S_UV                12
    //#define ID_S_WEIGHT            13
    //#define ID_S_POWER             14
    //#define ID_S_HEATER            15
    //#define ID_S_DISTANCE          16
    //#define ID_S_LIGHT_LEVEL       17
    //#define ID_S_LOCK              18
    //#define ID_S_IR                19
    //#define ID_S_WATER             20
    //#define ID_S_AIR_QUALITY       21
    //#define ID_S_DUST              22
    //#define ID_S_SCENE_CONTROLLER  23
    //// Lib 1.5 sensors
    //#define ID_S_RGB_LIGHT         24
    //#define ID_S_RGBW_LIGHT        25
    //#define ID_S_COLOR_SENSOR      26
    //#define ID_S_HVAC              27
    //#define ID_S_MULTIMETER        28
    //#define ID_S_SPRINKLER         29
    //#define ID_S_WATER_LEAK        30
    //#define ID_S_SOUND             31
    //#define ID_S_VIBRATION         32
    //#define ID_S_MOISTURE          33
    //#define ID_S_CUSTOM            99
    // Global Vars
    unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
    bool metric = true;
    long randNumber;
    //Instanciate Messages objects
    #ifdef ID_S_ARMED
    bool isArmed;
    #ifdef ID_S_DOOR // V_TRIPPED, V_ARMED
    MyMessage msg_S_DOOR_T(ID_S_DOOR,V_TRIPPED);
    MyMessage msg_S_DOOR_A(ID_S_DOOR,V_ARMED);
    #ifdef ID_S_MOTION // V_TRIPPED, V_ARMED
    MyMessage msg_S_MOTION_A(ID_S_MOTION,V_ARMED);
    MyMessage msg_S_MOTION_T(ID_S_MOTION,V_TRIPPED);
    #ifdef ID_S_SMOKE  // V_TRIPPED, V_ARMED
    MyMessage msg_S_SMOKE_T(ID_S_SMOKE,V_TRIPPED);
    MyMessage msg_S_SMOKE_A(ID_S_SMOKE,V_ARMED);
    #ifdef ID_S_LIGHT
    MyMessage msg_S_LIGHT(ID_S_LIGHT,V_LIGHT);
    bool isLightOn=0;
    #ifdef ID_S_DIMMER
    MyMessage msg_S_DIMMER(ID_S_DIMMER,V_DIMMER);
    int dimmerVal=100;
    #ifdef ID_S_COVER
    MyMessage msg_S_COVER_U(ID_S_COVER,V_UP);
    MyMessage msg_S_COVER_D(ID_S_COVER,V_DOWN);
    MyMessage msg_S_COVER_S(ID_S_COVER,V_STOP);
    MyMessage msg_S_COVER_V(ID_S_COVER,V_VAR1);
    int coverState=0; //0=Stop; 1=up; -1=down
    #ifdef ID_S_TEMP
    MyMessage msg_S_TEMP(ID_S_TEMP,V_TEMP);
    #ifdef ID_S_HUM
    MyMessage msg_S_HUM(ID_S_HUM,V_HUM);
    #ifdef ID_S_BARO
    MyMessage msg_S_BARO_P(ID_S_BARO,V_PRESSURE);
    MyMessage msg_S_BARO_F(ID_S_BARO,V_FORECAST);
    #ifdef ID_S_WIND
    MyMessage msg_S_WIND_S(ID_S_WIND,V_WIND);
    MyMessage msg_S_WIND_G(ID_S_WIND,V_GUST);
    MyMessage msg_S_WIND_D(ID_S_WIND,V_DIRECTION);
    #ifdef ID_S_RAIN
    MyMessage msg_S_RAIN_A(ID_S_RAIN,V_RAIN);
    MyMessage msg_S_RAIN_R(ID_S_RAIN,V_RAINRATE);
    #ifdef ID_S_UV
    MyMessage msg_S_UV(ID_S_UV,V_UV);
    #ifdef ID_S_WEIGHT
    MyMessage msg_S_WEIGHT(ID_S_WEIGHT,V_WEIGHT);
    #ifdef ID_S_POWER
    MyMessage msg_S_POWER_W(ID_S_POWER,V_WATT);
    MyMessage msg_S_POWER_K(ID_S_POWER,V_KWH);
    #ifdef ID_S_HEATER
    //////// REVIEW IMPLEMENTATION ////////////
    MyMessage msg_S_HEATER_SET_POINT(ID_S_HEATER,
                                    V_HVAC_SETPOINT_HEAT);  // HVAC/Heater setpoint (Integer between 0-100). S_HEATER, S_HVAC
    MyMessage msg_S_HEATER_FLOW_STATE(ID_S_HEATER,
                                     V_HVAC_FLOW_STATE);     // Mode of header. One of "Off", "HeatOn", "CoolOn", or "AutoChangeOver" // S_HVAC, S_HEATER
    //MyMessage msg_S_HEATER_STATUS(ID_S_HEATER,V_STATUS);
    //MyMessage msg_S_HEATER_TEMP(ID_S_HEATER,V_TEMP);
    float heater_setpoint=21.5;
    String heater_flow_state="Off";
    //  float heater_temp=23.5;
    //  bool heater_status=false;
    // V_TEMP                // Temperature
    // V_STATUS              // Binary status. 0=off 1=on
    // V_HVAC_FLOW_STATE     // Mode of header. One of "Off", "HeatOn", "CoolOn", or "AutoChangeOver"
    // V_HVAC_SPEED          // HVAC/Heater fan speed ("Min", "Normal", "Max", "Auto")
    // V_HVAC_SETPOINT_HEAT  // HVAC/Heater setpoint
    #ifdef ID_S_DISTANCE
    MyMessage msg_S_DISTANCE(ID_S_DISTANCE,V_DISTANCE);
    #ifdef ID_S_LIGHT_LEVEL
    MyMessage msg_S_LIGHT_LEVEL(ID_S_LIGHT_LEVEL,V_LIGHT_LEVEL);
    #ifdef ID_S_LOCK
    MyMessage msg_S_LOCK(ID_S_LOCK,V_LOCK_STATUS);
    bool isLocked = 0;
    #ifdef ID_S_IR
    MyMessage msg_S_IR_S(ID_S_IR,V_IR_SEND);
    MyMessage msg_S_IR_R(ID_S_IR,V_IR_RECEIVE);
    long irVal = 0;
    #ifdef ID_S_WATER
    MyMessage msg_S_WATER_F(ID_S_WATER,V_FLOW);
    MyMessage msg_S_WATER_V(ID_S_WATER,V_VOLUME);
    #ifdef ID_S_AIR_QUALITY
    MyMessage msg_S_AIR_QUALITY(ID_S_AIR_QUALITY,V_LEVEL);
    #ifdef ID_S_DUST
    MyMessage msg_S_DUST(ID_S_DUST,V_LEVEL);
    #ifdef ID_S_SCENE_CONTROLLER
    MyMessage msg_S_SCENE_CONTROLLER_ON(ID_S_SCENE_CONTROLLER,V_SCENE_ON);
    MyMessage msg_S_SCENE_CONTROLLER_OF(ID_S_SCENE_CONTROLLER,V_SCENE_OFF);
    // not sure if scene controller sends int or chars
    // betting on ints as Touch Display Scen by Hek // compiler warnings
    char *scenes[] = {
       (char *)"Good Morning",
       (char *)"Clean Up!",
       (char *)"All Lights Off",
       (char *)"Music On/Off"
    int sceneVal=0;
    int sceneValPrevious=0;
    #ifdef ID_S_RGB_LIGHT
    MyMessage msg_S_RGB_LIGHT_V_RGB(ID_S_RGB_LIGHT,V_RGB);
    MyMessage msg_S_RGB_LIGHT_V_WATT(ID_S_RGB_LIGHT,V_WATT);
    String rgbState="000000";
    //RGB light V_RGB, V_WATT
    //RGB value transmitted as ASCII hex string (I.e "ff0000" for red)
    #ifdef ID_S_RGBW_LIGHT
    MyMessage msg_S_RGBW_LIGHT_V_RGBW(ID_S_RGBW_LIGHT,V_RGBW);
    MyMessage msg_S_RGBW_LIGHT_V_WATT(ID_S_RGBW_LIGHT,V_WATT);
    String rgbwState="00000000";
    //RGBW light (with separate white component)	V_RGBW, V_WATT
    //RGBW value transmitted as ASCII hex string (I.e "ff0000ff" for red + full white)	S_RGBW_LIGHT
    #ifdef ID_S_COLOR_SENSOR
    MyMessage msg_S_COLOR_SENSOR_V_RGB(ID_S_COLOR_SENSOR,V_RGB);
    //Color sensor	V_RGB
    //RGB value transmitted as ASCII hex string (I.e "ff0000" for red)	S_RGB_LIGHT, S_COLOR_SENSOR
    #ifdef ID_S_HVAC
    MyMessage msg_S_HVAC_V_HVAC_SETPOINT_HEAT(ID_S_HVAC,V_HVAC_SETPOINT_HEAT);
    MyMessage msg_S_HVAC_V_HVAC_SETPOINT_COOL(ID_S_HVAC,V_HVAC_SETPOINT_COOL);
    MyMessage msg_S_HVAC_V_HVAC_FLOW_STATET(ID_S_HVAC,V_HVAC_FLOW_STATE);
    MyMessage msg_S_HVAC_V_HVAC_FLOW_MODE(ID_S_HVAC,V_HVAC_FLOW_MODE);
    MyMessage msg_S_HVAC_V_HVAC_SPEED(ID_S_HVAC,V_HVAC_SPEED);
    float hvac_SetPointHeat = 16.5;
    float hvac_SetPointCool = 25.5;
    String hvac_FlowState   = "AutoChangeOver";
    String hvac_FlowMode    = "Auto";
    String hvac_Speed       = "Normal";
    //Thermostat/HVAC device
    //V_HVAC_SETPOINT_HEAT,  // HVAC/Heater setpoint
    //V_HVAC_SETPOINT_COOL,  // HVAC cold setpoint
    //V_HVAC_FLOW_STATE,     // Mode of header. One of "Off", "HeatOn", "CoolOn", or "AutoChangeOver"
    //V_HVAC_FLOW_MODE,      // Flow mode for HVAC ("Auto", "ContinuousOn", "PeriodicOn")
    //V_HVAC_SPEED           // HVAC/Heater fan speed ("Min", "Normal", "Max", "Auto")
    // NOT IMPLEMENTED YET
    //V_TEMP                 // Temperature
    //V_STATUS               // Binary status. 0=off 1=on
    #ifdef ID_S_MULTIMETER
    MyMessage msg_S_MULTIMETER_V_IMPEDANCE(ID_S_MULTIMETER,V_IMPEDANCE);
    MyMessage msg_S_MULTIMETER_V_VOLTAGE(ID_S_MULTIMETER,V_VOLTAGE);
    MyMessage msg_S_MULTIMETER_V_CURRENT(ID_S_MULTIMETER,V_CURRENT);
    // Multimeter device	V_VOLTAGE, V_CURRENT, V_IMPEDANCE
    // V_IMPEDANCE	14	Impedance value
    // V_VOLTAGE	38	Voltage level
    // V_CURRENT	39	Current level
    #ifdef ID_S_SPRINKLER
    // S_SPRINKLER	31	Sprinkler device	V_STATUS (turn on/off), V_TRIPPED (if fire detecting device)
    // V_STATUS	2	Binary status. 0=off 1=on
    // V_ARMED	15	Armed status of a security sensor. 1=Armed, 0=Bypassed
    // V_TRIPPED	16	Tripped status of a security sensor. 1=Tripped, 0=Untripped
    #ifdef ID_S_WATER_LEAK
    #ifdef ID_S_SOUND
    #ifdef ID_S_VIBRATION
    #ifdef ID_S_MOISTURE
    MyMessage msg_S_MOISTURE(ID_S_MOISTURE,V_LEVEL);
    #ifdef ID_S_CUSTOM
    MyMessage msg_S_CUSTOM_1(ID_S_CUSTOM,V_VAR1);
    MyMessage msg_S_CUSTOM_2(ID_S_CUSTOM,V_VAR2);
    MyMessage msg_S_CUSTOM_3(ID_S_CUSTOM,V_VAR3);
    MyMessage msg_S_CUSTOM_4(ID_S_CUSTOM,V_VAR4);
    MyMessage msg_S_CUSTOM_5(ID_S_CUSTOM,V_VAR5);
       // Random SEED
       randomSeed(analogRead(0));
       wait(LONG_WAIT);
       Serial.println("GW Started");
       Serial.print("Send Sketch Info: ");
       Serial.print(SKETCH_NAME);
       Serial.println(SKETCH_VERSION);
       wait(LONG_WAIT);
       // Get controller configuration
       Serial.print("Get Config: ");
       Serial.println(metric ? "Metric":"Imperial");
       wait(LONG_WAIT);
       // Init Armed
    #ifdef ID_S_ARMED
       isArmed = true;
       Serial.println("Presenting Nodes");
       Serial.println("________________");
    #ifdef ID_S_DOOR
       Serial.println("  S_DOOR");
       present(ID_S_DOOR,S_DOOR,"Outside Door");
       wait(SHORT_WAIT);
    #ifdef ID_S_MOTION
       Serial.println("  S_MOTION");
       present(ID_S_MOTION,S_MOTION,"Outside Motion");
       wait(SHORT_WAIT);
    #ifdef ID_S_SMOKE
       Serial.println("  S_SMOKE");
       present(ID_S_SMOKE,S_SMOKE,"Kitchen Smoke");
       wait(SHORT_WAIT);
    #ifdef ID_S_LIGHT
       Serial.println("  S_LIGHT");
       present(ID_S_LIGHT,S_LIGHT,"Hall Light");
       wait(SHORT_WAIT);
    #ifdef ID_S_DIMMER
       Serial.println("  S_DIMMER");
       present(ID_S_DIMMER,S_DIMMER,"Living room dimmer");
       wait(SHORT_WAIT);
    #ifdef ID_S_COVER
       Serial.println("  S_COVER");
       present(ID_S_COVER,S_COVER,"Window cover");
       wait(SHORT_WAIT);
    #ifdef ID_S_TEMP
       Serial.println("  S_TEMP");
       present(ID_S_TEMP,S_TEMP,"House Temperarue");
       wait(SHORT_WAIT);
    #ifdef ID_S_HUM
       Serial.println("  S_HUM");
       present(ID_S_HUM,S_HUM,"Current Humidity");
       wait(SHORT_WAIT);
    #ifdef ID_S_BARO
       Serial.println("  S_BARO");
       present(ID_S_BARO,S_BARO," Air pressure");
       wait(SHORT_WAIT);
    #ifdef ID_S_WIND
       Serial.println("  S_WIND");
       present(ID_S_WIND,S_WIND,"Wind Station");
       wait(SHORT_WAIT);
    #ifdef ID_S_RAIN
       Serial.println("  S_RAIN");
       present(ID_S_RAIN,S_RAIN,"Rain Station");
       wait(SHORT_WAIT);
    #ifdef ID_S_UV
       Serial.println("  S_UV");
       present(ID_S_UV,S_UV,"Ultra Violet");
       wait(SHORT_WAIT);
    #ifdef ID_S_WEIGHT
       Serial.println("  S_WEIGHT");
       present(ID_S_WEIGHT,S_WEIGHT,"Outdoor Scale");
       wait(SHORT_WAIT);
    #ifdef ID_S_POWER
       Serial.println("  S_POWER");
       present(ID_S_POWER,S_POWER,"Power Metric");
       wait(SHORT_WAIT);
    #ifdef ID_S_HEATER
       Serial.println("  S_HEATER");
       present(ID_S_HEATER,S_HEATER,"Garage Heater");
       wait(SHORT_WAIT);
       Serial.println("  S_DISTANCE");
       present(ID_S_DISTANCE,S_DISTANCE,"Distance Measure");
       wait(SHORT_WAIT);
       Serial.println("  S_LIGHT_LEVEL");
       present(ID_S_LIGHT_LEVEL,S_LIGHT_LEVEL,"Outside Light Level");
       wait(SHORT_WAIT);
    #ifdef ID_S_LOCK
       Serial.println("  S_LOCK");
       present(ID_S_LOCK,S_LOCK,"Front Door Lock");
       wait(SHORT_WAIT);
    #ifdef ID_S_IR
       Serial.println("  S_IR");
       present(ID_S_IR,S_IR,"Univeral Command");
       wait(SHORT_WAIT);
    #ifdef ID_S_WATER
       Serial.println("  S_WATER");
       present(ID_S_WATER,S_WATER,"Water Level");
       wait(SHORT_WAIT);
       Serial.println("  S_AIR_QUALITY");
       present(ID_S_AIR_QUALITY,S_AIR_QUALITY,"Air Station");
       wait(SHORT_WAIT);
    #ifdef ID_S_DUST
       Serial.println("  S_DUST");
       present(ID_S_DUST,S_DUST,"Dust Level");
       wait(SHORT_WAIT);
       Serial.println("  S_SCENE_CONTROLLER");
       present(ID_S_SCENE_CONTROLLER,S_SCENE_CONTROLLER,"Scene Controller");
       wait(SHORT_WAIT);
       Serial.println("  RGB_LIGHT");
       present(ID_S_RGB_LIGHT,S_RGB_LIGHT,"Mood Light");
       wait(SHORT_WAIT);
       Serial.println("  RGBW_LIGHT");
       present(ID_S_RGBW_LIGHT,S_RGBW_LIGHT,"Mood Light 2");
       wait(SHORT_WAIT);
       Serial.println("  COLOR_SENSOR");
       present(ID_S_COLOR_SENSOR,S_COLOR_SENSOR,"Hall Painting");
       wait(SHORT_WAIT);
    #ifdef ID_S_HVAC
       Serial.println("  HVAC");
       present(ID_S_HVAC,S_HVAC,"HVAC");
       wait(SHORT_WAIT);
       Serial.println("  MULTIMETER");
       present(ID_S_MULTIMETER,S_MULTIMETER,"Electric Staion");
       wait(SHORT_WAIT);
    #ifdef ID_S_SOUND
       Serial.println("  S_MOISTURE");
       present(ID_S_MOISTURE,S_MOISTURE,"Basement Sensor");
       wait(SHORT_WAIT);
    #ifdef ID_S_CUSTOM
       Serial.println("  S_CUSTOM");
       present(ID_S_CUSTOM,S_CUSTOM,"Other Stuff");
       wait(SHORT_WAIT);
       Serial.println("");
       Serial.println("");
       Serial.println("");
       Serial.println("#########################");
       randNumber=random(0,101);
       Serial.print("RandomNumber:");
       Serial.println(randNumber);
       // Send fake battery level
       Serial.println("Send Battery Level");
       sendBatteryLevel(randNumber);
       wait(LONG_WAIT);
       // Request time
       Serial.println("Request Time");
       requestTime();
       wait(LONG_WAIT);
       //Read Sensors
    #ifdef ID_S_DOOR
       door();
    #ifdef ID_S_MOTION
       motion();
    #ifdef ID_S_SMOKE
       smoke();
    #ifdef ID_S_LIGHT
       light();
    #ifdef ID_S_DIMMER
       dimmer();
    #ifdef ID_S_COVER
       cover();
    #ifdef ID_S_TEMP
       temp();
    #ifdef ID_S_HUM
       hum();
    #ifdef ID_S_BARO
       baro();
    #ifdef ID_S_WIND
       wind();
    #ifdef ID_S_RAIN
       rain();
    #ifdef ID_S_UV
       uv();
    #ifdef ID_S_WEIGHT
       weight();
    #ifdef ID_S_POWER
       power();
    #ifdef ID_S_HEATER
       heater();
       distance();
       light_level();
    #ifdef ID_S_LOCK
       lock();
    #ifdef ID_S_IR
       ir();
    #ifdef ID_S_WATER
       water();
       air();
    #ifdef ID_S_DUST
       dust();
       scene();
       rgbLight();
       rgbwLight();
       color();
    #ifdef ID_S_HVAC
       hvac();
       multimeter();
    #ifdef ID_S_SOUND
       moisture();
    #ifdef ID_S_CUSTOM
       custom();
       wait(SHORT_WAIT);
       wait(SLEEP_TIME); //sleep a bit
    // This is called when a new time value was received
    void receiveTime(unsigned long controllerTime)
       Serial.print("Time value received: ");
       Serial.println(controllerTime);
    //void door(){}
    #ifdef ID_S_DOOR
    void door()
       Serial.print("Door is: " );
       if (randNumber <= 50) {
       	Serial.println("Open");
       	send(msg_S_DOOR_T.set((int16_t)1));
       } else {
       	Serial.println("Closed");
       	send(msg_S_DOOR_T.set((int16_t)0));
    #ifdef ID_S_ARMED
       Serial.print("System is: " );
       Serial.println((isArmed ? "Armed":"Disarmed"));
       send(msg_S_DOOR_A.set(isArmed));
    #ifdef ID_S_MOTION
    void motion()
       Serial.print("Motion is: " );
       	Serial.println("Active");
       	send(msg_S_MOTION_T.set(1));
       } else {
       	Serial.println("Quiet");
       	send(msg_S_MOTION_T.set(0));
    #ifdef ID_S_ARMED
       send(msg_S_MOTION_A.set(isArmed));
    #ifdef ID_S_SMOKE
    void smoke()
       Serial.print("Smoke is: " );
       	send(msg_S_SMOKE_T.set(1));
       } else {
       	send(msg_S_SMOKE_T.set(0));
    #ifdef ID_S_ARMED
       send(msg_S_SMOKE_A.set(isArmed));
    #ifdef ID_S_LIGHT
    void light()
       Serial.print("Light is: " );
       Serial.println((isLightOn ? "On":"Off"));
       send(msg_S_LIGHT.set(isLightOn));
    #ifdef ID_S_DIMMER
    void dimmer()
       Serial.print("Dimmer is set to: " );
       Serial.println(dimmerVal);
       send(msg_S_DIMMER.set(dimmerVal));
    #ifdef ID_S_COVER
    void cover()
       Serial.print("Cover is : " );
       if (coverState == 1) {
       	Serial.println("Opening");
       	send(msg_S_COVER_U.set(1));
       } else if (coverState == -1) {
       	Serial.println("Closing");
       	send(msg_S_COVER_D.set(0));
       } else {
       	Serial.println("Idle");
       	send(msg_S_COVER_S.set(-1));
       send(msg_S_COVER_V.set(coverState));
    #ifdef ID_S_TEMP
    void temp()
       Serial.print("Temperature is: " );
       Serial.println(map(randNumber,1,100,0,45));
       send(msg_S_TEMP.set(map(randNumber,1,100,0,45)));
    #ifdef ID_S_HUM
    void hum()
       Serial.print("Humitidty is: " );
       send(msg_S_HUM.set(randNumber));
    #ifdef ID_S_BARO
    void baro()
       const char *weather[] = {"stable","sunny","cloudy","unstable","thunderstorm","unknown"};
       long pressure = map(randNumber,1,100,870,1086);// hPa?
       int forecast = map(randNumber,1,100,0,5);
       Serial.print("Atmosferic Pressure is: " );
       Serial.println(pressure);
       send(msg_S_BARO_P.set(pressure));
       Serial.print("Weather forecast: " );
       Serial.println(weather[forecast]);
       send(msg_S_BARO_F.set(weather[forecast]));
    #ifdef ID_S_WIND
    void wind()
       Serial.print("Wind Speed is: " );
       send(msg_S_WIND_S.set(randNumber));
       Serial.print("Wind Gust is: " );
       Serial.println(randNumber+10);
       send(msg_S_WIND_G.set(randNumber+10));
       Serial.print("Wind Direction is: " );
       Serial.println(map(randNumber,1,100,0,360));
       send(msg_S_WIND_D.set(map(randNumber,1,100,0,360)));
    #ifdef ID_S_RAIN
    void rain()
       Serial.print("Rain ammount  is: " );
       send(msg_S_RAIN_A.set(randNumber));
       Serial.print("Rain rate  is: " );
       Serial.println(randNumber/60);
       send(msg_S_RAIN_R.set(randNumber/60,1));
    #ifdef ID_S_UV
    void uv()
       Serial.print("Ultra Violet level is: " );
       Serial.println(map(randNumber,1,100,0,15));
       send(msg_S_UV.set(map(randNumber,1,100,0,15)));
    #ifdef ID_S_WEIGHT
    void weight()
       Serial.print("Weight is: " );
       Serial.println(map(randNumber,1,100,0,150));
       send(msg_S_WEIGHT.set(map(randNumber,1,100,0,150)));
    #ifdef ID_S_POWER
    void power()
       Serial.print("Watt is: " );
       send(msg_S_POWER_W.set(map(randNumber,1,100,0,150)));
       Serial.print("KWH is: " );
       send(msg_S_POWER_K.set(map(randNumber,1,100,0,150)));
    #ifdef ID_S_HEATER
    void heater()
       //  float heater_setpoint=21.5;
       //  String heatState="Off";
       Serial.print("Heater flow state is: " );
       Serial.println(heater_flow_state);
       send(msg_S_HEATER_FLOW_STATE.set(heater_flow_state.c_str()));
       //  Serial.print("Heater on/off is: " );
       //  Serial.println((heater_status==true)?"On":"Off");
       //  send(msg_S_HEATER_STATUS.set(heater_status));
       //  Serial.print("Heater Temperature is: " );
       //  Serial.println(heater_temp,1);
       //  send(msg_S_HEATER_TEMP.set(heater_temp,1));
       Serial.print("Heater Setpoint: " );
       Serial.println(heater_setpoint,1);
       send(msg_S_HEATER_SET_POINT.set(heater_setpoint,1));
    void distance()
       Serial.print("Distance is: " );
       send(msg_S_DISTANCE.set(map(randNumber,1,100,0,150)));
    void light_level()
       send(msg_S_LIGHT_LEVEL.set(map(randNumber,1,100,0,150)));
    #ifdef ID_S_LOCK
    void lock()
       Serial.print("Lock is: " );
       Serial.println((isLocked ? "Locked":"Unlocked"));
       send(msg_S_LOCK.set(isLocked));
    #ifdef ID_S_IR
    void ir()
       Serial.print("Infrared is: " );
       Serial.println(irVal);
       send(msg_S_IR_S.set(irVal));
       send(msg_S_IR_R.set(irVal));
    #ifdef ID_S_WATER
    void water()
       Serial.print("Water flow is: " );
       send(msg_S_WATER_F.set(map(randNumber,1,100,0,150)));
       Serial.print("Water volume is: " );
       send(msg_S_WATER_V.set(map(randNumber,1,100,0,150)));
    void air()
       Serial.print("Air Quality is: " );
       send(msg_S_AIR_QUALITY.set(randNumber));
    #ifdef ID_S_DUST
    void dust()
       Serial.print("Dust level is: " );
       send(msg_S_DUST.set(randNumber));
    void scene()
       Serial.print("Scene is: " );
       Serial.println(scenes[sceneVal]);
       if(sceneValPrevious != sceneVal) {
       	send(msg_S_SCENE_CONTROLLER_OF.set(sceneValPrevious));
       	send(msg_S_SCENE_CONTROLLER_ON.set(sceneVal));
       	sceneValPrevious=sceneVal;
    void rgbLight()
       Serial.print("RGB Light state is: " );
       Serial.println(rgbState);
       send(msg_S_RGB_LIGHT_V_RGB.set(rgbState.c_str()));
       Serial.print("RGB Light Watt is: " );
       send(msg_S_RGB_LIGHT_V_WATT.set(map(randNumber,1,100,0,150)));
    void rgbwLight()
       Serial.print("RGBW Light state is: " );
       Serial.println(rgbwState);
       send(msg_S_RGBW_LIGHT_V_RGBW.set(rgbwState.c_str()));
       Serial.print("RGBW Light Watt is: " );
       send(msg_S_RGBW_LIGHT_V_WATT.set(map(randNumber,1,100,0,150)));
    void color()
       String colorState;
       String red   = String(random(0,256),HEX);
       String green = String(random(0,256),HEX);
       String blue  = String(random(0,256),HEX);
       colorState=String(red + green + blue);
       Serial.print("Color state is: " );
       Serial.println(colorState);
       send(msg_S_COLOR_SENSOR_V_RGB.set(colorState.c_str()));
    #ifdef ID_S_HVAC
    void hvac()
       //  float hvac_SetPointHeat = 16.5;
       //  float hvac_SetPointCool = 25.5;
       //  String hvac_FlowState   = "AutoChangeOver";
       //  String hvac_FlowMode    = "Auto";
       //  String hvac_Speed       = "Normal";
       Serial.print("HVAC Set Point Heat is: " );
       Serial.println(hvac_SetPointHeat);
       send(msg_S_HVAC_V_HVAC_SETPOINT_HEAT.set(hvac_SetPointHeat,1));
       Serial.print("HVAC Set Point Cool is: " );
       Serial.println(hvac_SetPointCool);
       send(msg_S_HVAC_V_HVAC_SETPOINT_COOL.set(hvac_SetPointCool,1));
       Serial.print("HVAC Flow State is: " );
       Serial.println(hvac_FlowState);
       send(msg_S_HVAC_V_HVAC_FLOW_STATET.set(hvac_FlowState.c_str()));
       Serial.print("HVAC Flow Mode is: " );
       Serial.println(hvac_FlowMode);
       send(msg_S_HVAC_V_HVAC_FLOW_MODE.set(hvac_FlowMode.c_str()));
       Serial.print("HVAC Speed is: " );
       Serial.println(hvac_Speed);
       send(msg_S_HVAC_V_HVAC_SPEED.set(hvac_Speed.c_str()));
    void multimeter()
       int impedance=map(randNumber,1,100,0,15000);
       int volt=map(randNumber,1,100,0,380);
       int amps=map(randNumber,1,100,0,16);
       Serial.print("Impedance is: " );
       Serial.println(impedance);
       send(msg_S_MULTIMETER_V_IMPEDANCE.set(impedance));
       Serial.print("Voltage is: " );
       Serial.println(volt);
       send(msg_S_MULTIMETER_V_VOLTAGE.set(volt));
       Serial.print("Current is: " );
       Serial.println(amps);
       send(msg_S_MULTIMETER_V_CURRENT.set(amps));
    #ifdef ID_S_SOUND
    void moisture()
       Serial.print("Moisture level is: " );
       send(msg_S_MOISTURE.set(randNumber));
    #ifdef ID_S_CUSTOM
    void custom()
       Serial.print("Custom value is: " );
       send(msg_S_CUSTOM_1.set(randNumber));
       send(msg_S_CUSTOM_2.set(randNumber));
       send(msg_S_CUSTOM_3.set(randNumber));
       send(msg_S_CUSTOM_4.set(randNumber));
       send(msg_S_CUSTOM_5.set(randNumber));
       switch (message.type) {
    #ifdef ID_S_ARMED
       case V_ARMED:
       	isArmed = message.getBool();
       	Serial.print("Incoming change for ID_S_ARMED:");
       	Serial.print(message.sensor);
       	Serial.println((isArmed ? "Armed":"Disarmed" ));
    #ifdef ID_S_DOOR
       	door();//temp ack for door
    #ifdef ID_S_MOTION
       	motion();//temp ack
    #ifdef ID_S_SMOKE
       	smoke();//temp ack
       	break;
       case V_STATUS: // V_LIGHT:
    #ifdef ID_S_LIGHT
       	if(message.sensor==ID_S_LIGHT) {
       		isLightOn =  message.getBool();
       		Serial.print("Incoming change for ID_S_LIGHT:");
       		light(); // temp ack
       	//    #ifdef ID_S_HEATER
       	//        if(message.sensor == ID_S_HEATER){
       	//          heater_status = message.getBool();
       	//          Serial.print("Incoming change for ID_S_HEATER:");
       	//          Serial.print(message.sensor);
       	//          Serial.print(", New status: ");
       	//          Serial.println(heater_status);
       	//          heater();//temp ack
       	//    #endif
       	break;
    #ifdef ID_S_DIMMER
       case V_DIMMER:
       	if ((message.getInt()<0)||(message.getInt()>100)) {
       		Serial.println( "V_DIMMER data invalid (should be 0..100)" );
       		break;
       	dimmerVal= message.getInt();
       	Serial.print("Incoming change for ID_S_DIMMER:");
       	Serial.println(message.getInt());
       	dimmer();// temp ack
       	break;
    #ifdef ID_S_COVER
       case V_UP:
       	coverState=1;
       	Serial.print("Incoming change for ID_S_COVER:");
       	Serial.println("V_UP");
       	cover(); // temp ack
       	break;
       case V_DOWN:
       	coverState=-1;
       	Serial.println("V_DOWN");
       	cover(); //temp ack
       	break;
       case V_STOP:
       	coverState=0;
       	Serial.println("V_STOP");
       	cover(); //temp ack
       	break;
       case V_HVAC_SETPOINT_HEAT:
    #ifdef ID_S_HEATER
       	if(message.sensor == ID_S_HEATER) {
       		heater_setpoint=message.getFloat();
       		Serial.print("Incoming set point for ID_S_HEATER:");
       		heater();//temp ack
    #ifdef ID_S_HVAC
       	if(message.sensor == ID_S_HVAC) {
       		hvac_SetPointHeat=message.getFloat();
       		Serial.print("Incoming set point for ID_S_HVAC:");
       		Serial.println(hvac_SetPointHeat,1);
       		hvac();//temp ack
       	break;
       case V_HVAC_FLOW_STATE:
    #ifdef ID_S_HEATER
       		heater_flow_state=message.getString();
       		Serial.print("Incoming flow state change for ID_S_HEATER:");
       		heater();//temp ack
    #ifdef ID_S_HVAC
       		hvac_FlowState=message.getString();
       		hvac();//temp ack
       	break;
    #ifdef ID_S_LOCK
       case V_LOCK_STATUS:
       	isLocked =  message.getBool();
       	Serial.print("Incoming change for ID_S_LOCK:");
       	Serial.println(message.getBool()?"Locked":"Unlocked");
       	lock(); //temp ack
       	break;
    #ifdef ID_S_IR
       case V_IR_SEND:
       	irVal = message.getLong();
       	Serial.print("Incoming change for ID_S_IR:");
       	ir(); // temp ack
       	break;
       case V_IR_RECEIVE:
       	ir(); // temp ack
       	break;
       case V_SCENE_ON:
       	sceneVal = message.getInt();
       	Serial.print("Incoming change for ID_S_SCENE_CONTROLLER:");
       	Serial.print(scenes[sceneVal]);
       	Serial.println(" On");
       	scene();// temp ack
       	break;
       case V_SCENE_OFF:
       	Serial.println(" Off");
       	scene();// temp ack
       	break;
       case V_RGB:
       	rgbState=message.getString();
       	Serial.print("Incoming flow state change for ID_S_RGB_LIGHT:");
       	rgbLight(); // temp ack
       	break;
       case V_RGBW:
       	rgbwState=message.getString();
       	Serial.print("Incoming flow state change for ID_S_RGBW_LIGHT:");
       	rgbwLight();
       	break;
    #ifdef ID_S_HVAC
       //  hvac_SetPointHeat
       //  hvac_SetPointCool
       //  hvac_FlowState
       //  hvac_FlowMode
       //  hvac_Speed
       case V_HVAC_SETPOINT_COOL:
       	hvac_SetPointCool=message.getFloat();
       	Serial.println(hvac_SetPointCool,1);
       	hvac();//temp ack
       	break;
       case V_HVAC_FLOW_MODE:
       	hvac_Speed=message.getString();
       	hvac();//temp ack
       	break;
       case V_HVAC_SPEED:
       	hvac_FlowMode=message.getString();
       	hvac();//temp ack
       	break;
       default:
       	Serial.print("Unknown/UnImplemented message type: ");
       	Serial.println(message.type);
    m26872M 1 Reply Last reply
      can you try to add the watchdog timers and see what happens? Try using a different bootloader? Different power source or using a small booster or an additional AA battery and a LDO. I am just throwing ideas and see what you can do with the stuff you may have at home.
      • K
        K
        Komaandy
        @gohan said in My Slim 2AA Battery Node:
        LDO
        @gohan
        Hi, i added a WDT now into the MotionSensorSketch.
        Well at least i guess i did. I just read about it , never used it before. Does the 1Mhz Optiboot boatloaders support this ?
        Unfortunalty I didnt recieve my 3,3V boosters yet and i dont have LDO´s around.
        Concerning the bootloaders. Do you have a suggestion which one to use ? As I read that sticking to 1Mhz is important when using only 2AA batteries because of instability when voltage goes belowe certian values.
        Obviously i could use more batteries, but then i cant supply the nRF2401 from the board right ?
        // Enable debug prints
        #define MY_NODE_ID 40
        #include <avr/wdt.h>
        // Initialize motion message
        	wdt_enable(WDTO_2S);
        	sendSketchInfo("Motion Sensor", "AndyWasHere");
        	present(CHILD_ID, S_MOTION);
        	// Read digital motion value
        	bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
        	Serial.println(tripped);
        	send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
        	sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
         wdt_reset();
          Actually you would have to put wdt_enable(WDTO_8S); right after Loop() and wdt_disable(); before calling the sleep (this is what I copied from another sketch). The wdt_reset you cold use in the middle of the loop in case you have a function that could take long time to execute and it may trigger the WD timer so you can reset the timer (you can play with the length of the timer according to your needs)
          K 1 Reply Last reply
            K
            K
            Komaandy
            @gohan
            maybe like this ?
            wdt_disable();
              that's what I found. You could also use wdt_enable(WDTO_2S) I think. I haven't done any test yet on this.
              • K Komaandy
                @m26872
                Hi there,
                Hardware i use is :
                Furthermore i use
                  -fresh batteries
                * MockMySensors
                // Wait times
                   S_SCENE_CONTROLLER
                // one at a time.
                #define ID_S_TEMP              7
                // Global Vars
                bool metric = true;
                long randNumber;
                #ifdef ID_S_ARMED
                bool isArmed;
                #ifdef ID_S_LIGHT
                bool isLightOn=0;
                #ifdef ID_S_DIMMER
                int dimmerVal=100;
                #ifdef ID_S_COVER
                #ifdef ID_S_TEMP
                #ifdef ID_S_HUM
                #ifdef ID_S_BARO
                #ifdef ID_S_WIND
                #ifdef ID_S_RAIN
                #ifdef ID_S_UV
                #ifdef ID_S_WEIGHT
                #ifdef ID_S_POWER
                #ifdef ID_S_HEATER
                #ifdef ID_S_LOCK
                bool isLocked = 0;
                #ifdef ID_S_IR
                long irVal = 0;
                #ifdef ID_S_WATER
                #ifdef ID_S_DUST
                char *scenes[] = {
                int sceneVal=0;
                #ifdef ID_S_HVAC
                #ifdef ID_S_SOUND
                #ifdef ID_S_CUSTOM
                   // Random SEED
                   wait(LONG_WAIT);
                   wait(LONG_WAIT);
                   wait(LONG_WAIT);
                   // Init Armed
                #ifdef ID_S_ARMED
                   isArmed = true;
                #ifdef ID_S_DOOR
                   wait(SHORT_WAIT);
                #ifdef ID_S_MOTION
                   wait(SHORT_WAIT);
                #ifdef ID_S_SMOKE
                   wait(SHORT_WAIT);
                #ifdef ID_S_LIGHT
                   wait(SHORT_WAIT);
                #ifdef ID_S_DIMMER
                   wait(SHORT_WAIT);
                #ifdef ID_S_COVER
                   wait(SHORT_WAIT);
                #ifdef ID_S_TEMP
                   wait(SHORT_WAIT);
                #ifdef ID_S_HUM
                   wait(SHORT_WAIT);
                #ifdef ID_S_BARO
                   wait(SHORT_WAIT);
                #ifdef ID_S_WIND
                   wait(SHORT_WAIT);
                #ifdef ID_S_RAIN
                   wait(SHORT_WAIT);
                #ifdef ID_S_UV
                   wait(SHORT_WAIT);
                #ifdef ID_S_WEIGHT
                   wait(SHORT_WAIT);
                #ifdef ID_S_POWER
                   wait(SHORT_WAIT);
                #ifdef ID_S_HEATER
                   wait(SHORT_WAIT);
                   wait(SHORT_WAIT);
                   wait(SHORT_WAIT);
                #ifdef ID_S_LOCK
                   wait(SHORT_WAIT);
                #ifdef ID_S_IR
                   wait(SHORT_WAIT);
                #ifdef ID_S_WATER
                   wait(SHORT_WAIT);
                   wait(SHORT_WAIT);
                #ifdef ID_S_DUST
                   wait(SHORT_WAIT);
                   wait(SHORT_WAIT);
                   wait(SHORT_WAIT);
                   wait(SHORT_WAIT);
                   wait(SHORT_WAIT);
                #ifdef ID_S_HVAC
                   wait(SHORT_WAIT);
                   wait(SHORT_WAIT);
                #ifdef ID_S_SOUND
                   wait(SHORT_WAIT);
                #ifdef ID_S_CUSTOM
                   wait(SHORT_WAIT);
                   Serial.println("");
                   Serial.println("");
                   Serial.println("");
                   wait(LONG_WAIT);
                   // Request time
                   requestTime();
                   wait(LONG_WAIT);
                   //Read Sensors
                #ifdef ID_S_DOOR
                   door();
                #ifdef ID_S_MOTION
                   motion();
                #ifdef ID_S_SMOKE
                   smoke();
                #ifdef ID_S_LIGHT
                   light();
                #ifdef ID_S_DIMMER
                   dimmer();
                #ifdef ID_S_COVER
                   cover();
                #ifdef ID_S_TEMP
                   temp();
                #ifdef ID_S_HUM
                   hum();
                #ifdef ID_S_BARO
                   baro();
                #ifdef ID_S_WIND
                   wind();
                #ifdef ID_S_RAIN
                   rain();
                #ifdef ID_S_UV
                   uv();
                #ifdef ID_S_WEIGHT
                   weight();
                #ifdef ID_S_POWER
                   power();
                #ifdef ID_S_HEATER
                   heater();
                   distance();
                   light_level();
                #ifdef ID_S_LOCK
                   lock();
                #ifdef ID_S_IR
                   ir();
                #ifdef ID_S_WATER
                   water();
                   air();
                #ifdef ID_S_DUST
                   dust();
                   scene();
                   rgbLight();
                   rgbwLight();
                   color();
                #ifdef ID_S_HVAC
                   hvac();
                   multimeter();
                #ifdef ID_S_SOUND
                   moisture();
                #ifdef ID_S_CUSTOM
                   custom();
                   wait(SHORT_WAIT);
                //void door(){}
                #ifdef ID_S_DOOR
                void door()
                   } else {
                #ifdef ID_S_ARMED
                #ifdef ID_S_MOTION
                void motion()
                   } else {
                #ifdef ID_S_ARMED
                #ifdef ID_S_SMOKE
                void smoke()
                   } else {
                #ifdef ID_S_ARMED
                #ifdef ID_S_LIGHT
                void light()
                #ifdef ID_S_DIMMER
                void dimmer()
                #ifdef ID_S_COVER
                void cover()
                   } else {
                #ifdef ID_S_TEMP
                void temp()
                #ifdef ID_S_HUM
                void hum()
                #ifdef ID_S_BARO
                void baro()
                #ifdef ID_S_WIND
                void wind()
                #ifdef ID_S_RAIN
                void rain()
                #ifdef ID_S_UV
                void uv()
                #ifdef ID_S_WEIGHT
                void weight()
                #ifdef ID_S_POWER
                void power()
                #ifdef ID_S_HEATER
                void heater()
                void distance()
                void light_level()
                #ifdef ID_S_LOCK
                void lock()
                #ifdef ID_S_IR
                void ir()
                #ifdef ID_S_WATER
                void water()
                void air()
                #ifdef ID_S_DUST
                void dust()
                void scene()
                void rgbLight()
                void rgbwLight()
                void color()
                   String colorState;
                #ifdef ID_S_HVAC
                void hvac()
                void multimeter()
                #ifdef ID_S_SOUND
                void moisture()
                #ifdef ID_S_CUSTOM
                void custom()
                #ifdef ID_S_ARMED
                   case V_ARMED:
                #ifdef ID_S_DOOR
                #ifdef ID_S_MOTION
                   	motion();//temp ack
                #ifdef ID_S_SMOKE
                   	smoke();//temp ack
                   	break;
                #ifdef ID_S_LIGHT
                   	//    #endif
                   	break;
                #ifdef ID_S_DIMMER
                   case V_DIMMER:
                   		break;
                   	break;
                #ifdef ID_S_COVER
                   case V_UP:
                   	coverState=1;
                   	break;
                   case V_DOWN:
                   	coverState=-1;
                   	cover(); //temp ack
                   	break;
                   case V_STOP:
                   	coverState=0;
                   	cover(); //temp ack
                   	break;
                #ifdef ID_S_HEATER
                   		heater();//temp ack
                #ifdef ID_S_HVAC
                   		hvac();//temp ack
                   	break;
                #ifdef ID_S_HEATER
                   		heater();//temp ack
                #ifdef ID_S_HVAC
                   		hvac();//temp ack
                   	break;
                #ifdef ID_S_LOCK
                   case V_LOCK_STATUS:
                   	lock(); //temp ack
                   	break;
                #ifdef ID_S_IR
                   case V_IR_SEND:
                   	ir(); // temp ack
                   	break;
                   case V_IR_RECEIVE:
                   	ir(); // temp ack
                   	break;
                   case V_SCENE_ON:
                   	scene();// temp ack
                   	break;
                   case V_SCENE_OFF:
                   	scene();// temp ack
                   	break;
                   case V_RGB:
                   	break;
                   case V_RGBW:
                   	rgbwLight();
                   	break;
                #ifdef ID_S_HVAC
                   //  hvac_FlowState
                   //  hvac_FlowMode
                   //  hvac_Speed
                   	hvac();//temp ack
                   	break;
                   	hvac();//temp ack
                   	break;
                   case V_HVAC_SPEED:
                   	hvac();//temp ack
                   	break;
                   default:
                m26872M
                m26872M
                m26872
                @Komaandy Try to remove all your Serial.print.
                • JonAndersenJ
                  JonAndersenJ
                  JonAndersen
                  wrote on last edited by JonAndersen
                  #428
                  1. Has anyone used NRF24L01+ + PA + LNA on these modules ?
                  2. Any reason why it shouldnt work out of the box ( does AA batteries give enough power to drive them on LOW settings? )
                  3. What type of battery monitoring is recommended on these ones? The resistance or the library way?
                  I just got 90 PCBs, beautiful, fast shipping ( i think under 2 weeks to Norway ) and looks well made.
                  I'll drop one in each beehive I have ( 7 ) and see how long they last
                  • K
                    K
                    Komaandy
                    So, it seems i made some progress.
                    After changing to the @GertSanders bootloader ( https://www.openhardware.io/view/33/Various-bootloader-files-based-on-Optiboot-62) all the PIR nodes seem to be stable.
                    Wish me luck :)
                    • K Komaandy
                      Wish me luck :)
                      m26872M
                      m26872M
                      m26872
                      #430
                      @Komaandy Yes, using 8MHz instead of 1MHz is perhaps a good idea. Stable enough at room temperature, well proven and will e.g. solve a "Serial.print()" interrupt loop issue. Just remember that you'll lose ~25uA if you'll leave BOD enabled.
                      Nca78N 1 Reply Last reply
                      • m26872M m26872
                        Nca78N
                        Nca78N
                        @m26872 said in My Slim 2AA Battery Node:
                        No, on ATMega328 MySensors disables BOD before going to sleep.
                        So extra consumption from BOD will only exist when node is active and in that case it's negligible.
                        • Nca78N Nca78
                          m26872M
                          m26872M
                          m26872
                          @Nca78 Ok. Thanks. Since ever, or only from 2.x ?
                          • m26872M m26872
                            Nca78N
                            Nca78N
                            @m26872 no idea I started MySensors with 2.x :P
                            • K
                              K
                              Komaandy
                              Update : Day 3 and still all PIR nodes are working ;)
                              I´m using the given sketch here.
                              • K
                                K
                                Komaandy
                                wrote on last edited by Komaandy
                                #435
                                Still up and running stable.
                                8Mhz Bootloader did the trick for me :)
                                • K Komaandy
                                  m26872M
                                  m26872M
                                  m26872
                                  @Komaandy Nice! Thumbs up for 8MHz (and your "dark-style Fhem" - same as I use) :+1:
                                  • K
                                    K
                                    Komaandy
                                    @m26872
                                    thanks again for this great idea and that you developed these fine boards !
                                    And by the way...
                                    As you are using fhem as well...
                                    How do you manage to reset the tripped "1" in Fhem ?
                                    I just added a delay and a gw.send"0" to your sketch :), but using fhem would be more sophisticated actually ...
                                    • K Komaandy
                                      @m26872
                                      And by the way...
                                      m26872M
                                      m26872M
                                      m26872
                                      @Komaandy said in My Slim 2AA Battery Node:
                                      I don't. I just use the last trip time as it's state and then notify (e.g. light or push message) on trip. I think it should be very simple to make a notify with a timer "at" to reset it after a while, if you wish.
                                      • siodS
                                        siodS
                                        siod
                                        just want to mention that I am using successfully the same Bootloader @Komaandy is using for about 2 weeks now. So it seems like my problems with freezing nodes are depending on a bad or too slow bootloader...
                                        still learning...
                                        • B
                                          B
                                          buxtronix
                                          All of the ducting near me is a bit too slim to fit sensors based on this, so I decided to design and print a case instead.
                                          Does the trick nicely, and I also chose to use proper AA battery clips to retain a good connection, as the cable-tie battery assembly wasn't holding well for me!
                                          On the Thingiverse page I have a link to the original OnShape doc.
                                          https://www.thingiverse.com/thing:2418194
                                          Thoughts, suggestions, etc will be much appreciated!
